36 Replies Latest reply on Jun 5, 2013 9:39 AM by DashDogear
    Extension Manager CS5 does'nt work
    mamzellleju
      I installed CS5 on my new mac and I tried to open Extension Manager but it doesn't work. I have a open icon in my taskbar but  I see nothing.
      When I tried to close the program, it did a error message :"Extension Manager a quitté de manière imprévue".
      Someone have a issue ? I need it for AIR 2.5 ..
        • 1. Re: Extension Manager CS5 does'nt work
          Carl Sun Level 4
          Do you login as administrator? Does your account have write privilege to “/Users/<YourUserName>/Library/Application Support/Adobe/Extension Manager CS5”?
          If the answer is yes, you can create a file named “ExManLog.YES” (The content of file doesn't matter, only the file name need be accurate, please uncheck "Hide extension" option in info window to make sure this file name really ends with .YES.) in "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS", then startup Extension Manager. you will get two log files in “/Users/<YourUserName>/Library/Application Support/Adobe/Extension Manager CS5”. Could you please upload these log files as attachment so others can give you some help? Thanks.
          • 2. Re: Extension Manager CS5 does'nt work
            Carl Sun Level 4
            You can also switch to other space to know whether Extension Manager window is displayed in other space if you enabled spaces in System Preferences. If Extension Manager window is not located in current space, Clicking icon on dock will not switch to that space.
            • 3. Re: Extension Manager CS5 does'nt work
              GAH212
              Like you, my Exten Mgr does not work, but I go all the way to a Problem Report after a 'quit unexpectedly'. I've tried it in a new 'test user' and it DOES run in that environment, while at the same bringing up a number of notices, which mean little to me, about other CS5 applications with which I'm having problems.
              Fully 50% of this expensive Design Premium upgrade will not run properly, after all these years with the full range of CS offering, and long before with PageMaker, Distiller, and the rest.
              Very frustrating and makes me feel so dumb.
              • 4. Re: Extension Manager CS5 does'nt work
                sduttonusa
                I have the exact same problem on my MacBook Pro / CS 5.  After updating all my CS5 apps, I opened Dreamweaver and was given the message about the Extension Manager opening . . . but it never really got up and running.  It started and then froze.  When I quit, I was given the message that it crashed.  I logged out and logged in to other users on my laptop and all was fine.  The extension manager loads everything.  It just doesn't work for me, the administrator.  So it appears there is a permissions issue with a folder / file / preference.  Any suggestions?
                • 5. Re: Extension Manager CS5 does'nt work
                  M H2ag
                  I have the same problem.
                  Did you solve it?
                  Thanks!
                  • 6. Re: Extension Manager CS5 does'nt work
                    GAH212 Level 1
                    Nope, no solutions so far. I live without it.
                    Greg Heuer, CSI
                    http://www.linkedin.com/in/gheuer
                    When you think of the long and gloomy history of man, you will find more hideous crimes have been committed in the name of obedience than have ever been committed in the name of rebellion.
                      - C. P. Snow
                    • 7. Re: Extension Manager CS5 does'nt work
                      Carl Sun Level 4
                      I think it should be a permission issue. To help troubleshooting, please save the following commands as a script file, and run it from terminal, e.g. "bin/sh <YourFileName>". A plain text file named "output.txt" will be generated in your home directory. Please upload output.txt so we can get more information about your system.
                      In addition, there are some locale-dependent directories in these commands. If your locale is not American English (en_US), please replace "en_US" with your locale.
                      cd ~
                      ls -ld "./Library/Application Support/Adobe" > output.txt
                      ls -ld "./Library/Application Support/Adobe/Bridge CS5" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Bridge CS5/Configuration" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Bridge CS5/Configuration/Extensions" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Extension Manager CS5" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Extension Manager CS5/Configuration" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Extension Manager CS5/Configuration/Extensions" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Extensions" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5/Configuration" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Adobe InDesign CS5/Configuration/Extensions" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Flash CS5" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US/Configuration" >> output.txt
                      ls -ld "./Library/Application Support/Adobe/Flash CS5/en_US/Configuration/Extensions" >> output.txt
                      ls -ld "/Applications/Adobe Illustrator CS5" >> output.txt
                      ls -ld "/Applications/Adobe Illustrator CS5/Configuration" >> output.txt
                      ls -ld "/Applications/Adobe Illustrator CS5/Configuration/Extensions" >> output.txt
                      ls -ld "/Applications/Adobe Photoshop CS5" >> output.txt
                      ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5" >> output.txt
                      ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US" >> output.txt
                      ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration" >> output.txt
                      ls -ld "/Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/Extensions" >> output.txt
                      ls -ld "/Library/Application Support/Adobe" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Extension Manager CS5" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Extension Manager CS5/Illustrator CS5" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/InDesign" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/EmStorePath" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/en_US" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/InDesign/Version 7.0/en_US/Extensions" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Extension Manager" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Extension Manager CS5/FlashCS5" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Fireworks CS5" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Fireworks CS5/EmStorePath" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Fireworks CS5/Extensions" >> output.txt
                      ls -ld "/Library/Application Support/Adobe/Fireworks CS5/PreInstall" >> output.txt
                      • 8. Re: Extension Manager CS5 does'nt work
                        Bodester22 Level 1
                        I am having the same issue.  The user is an admin.  Brand new install of OS & CS5 Design Premium.  Do not have this issue on any of the 250 machines that this build is out there on.  Extension Manager starts and no window comes up.  No, spaces is not on.  Log in as another user.  Extension Manager starts.  Go into Library/Application Support/Adobe....there isn't an Extension Manager folder.
                        Thoughts?
                        • 9. Re: Extension Manager CS5 does'nt work
                          Carl Sun Level 4
                          Have you tried to run Extension Manager using sudo command? That the user is admin doesn't means that every application you start up will be run with administrative privilege. If with sudo command you can launch Extension Manager successfully, subsequent launch will not need sudo. If it still doesn't work, could you please generate log files and upload them as attachment according to the first reply in this thread?
                          • 10. Re: Extension Manager CS5 does'nt work
                            sduttonusa Level 1
                            Can you please explain how to use the sudo command to fix this problem.
                            Thanks.
                            • 11. Re: Extension Manager CS5 does'nt work
                              Carl Sun Level 4
                              1. Open Terminal window.
                              2. Input the following command and press enter.
                              sudo "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS/Adobe Extension Manager CS5"
                              3. When requested, input your root password.
                              • 12. Re: Extension Manager CS5 does'nt work
                                macKARMA_online Level 1
                                Carl..if you were here, I'd kiss you!!
                                After spending last hour searching for a solution, yours worked!  I did have to adjust for CS5.5 ...that's where I was having the issue, but after I changed that and pasted into terminal, I FINALLY got extension manager working.
                                Thanks!!!!
                                • 13. Re: Extension Manager CS5 does'nt work
                                  billhdz Level 1
                                  Hi Carl,
                                  This works, but the moment I quit Terminal and try to run it as usual ( as a app ), it stops working again.
                                  What do you think can be causing this problem?
                                  • 14. Re: Extension Manager CS5 does'nt work
                                    Carl Sun Level 4
                                    Please verify whether you have write privilege for the following folders. (If you have not installed some products, you can ignore corresponding folders). If not, grant youself write privilege. If some of these folders don’t exist yet, you can create them manually and grant write privilege.
                                    /Library/Application Support/Adobe/InDesign/Version 7.0/<Locale>/Extensions
                                    /Library/Application Support/Adobe/ Premiere Pro CS5/Configuration/Extensions
                                    /Library/Application Support/Adobe/Extension Manager CS5/ Premiere Pro CS5
                                    /Users/<UserName>/Library/Application Support/Adobe/Flash CS5/<Locale>/Configuration/Extensions
                                    /Users/<UserName>/Library/Application Support/Adobe/ Adobe Contribute CS5/<Locale>/Configuration/Extensions
                                    /Users/<UserName>/Library/Application Support/Adobe/Adobe InDesign CS5/Configuration/Extensions
                                    /Users/<UserName>/Library/Application Support/Adobe/Bridge CS5/Configuration/Extensions
                                    /Users/<UserName>/Library/Application Support/Adobe/Dreamweaver CS5/<Locale>/Configuration/Extensions
                                    /Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS5/Configuration/Extensions
                                    /Users/Shared/Library/Application Support/Adobe/Dreamweaver CS5/<Locale>/Configuration/Extensions
                                    Orange directories are created by CS installer, green directories are created by ExMan during the first launch, blue directories are created by ExMan when necessary.
                                    • 15. Re: Extension Manager CS5 does'nt work
                                      Carl Sun Level 4
                                      Sorry, the reply loses the font color after post. But it has no much impact.
                                      • 16. Re: Extension Manager CS5 does'nt work
                                        kalantan Level 1
                                        I tried all of the above as well. No change. EM launches and immediately crashes.
                                        • 17. Re: Extension Manager CS5 does'nt work
                                          Carl Sun Level 4
                                          Have you install Flash FireBug? It conflicts with Extension Manager. Is the window of Extension Manager visible or nothing is displayed when crash?
                                          1. Please move all files under "/Users/<UserName>/Library/Preferences/Macromedia/Flash Player/#Security/FlashPlayerTrust" and "/Library/Application Support/Macromedia/FlashPlayerTrust" to somewhere else, then start up Extension Manager.
                                          2. If it doesn't help, move all above files back. please generate log files to help troubleshooting.
                                          • 18. Re: Extension Manager CS5 does'nt work
                                            StrongBeaver Level 3
                                            I installed Adobe Extension Manager 5.5 all the while I use Adobe Photoshop 5.02. I'm trying to install a Adobe Extension but it gives me an error, it wouldn't be related to the fact I installed Extension Manager 5.5 and not 5.02, if so where do find Extension Manager 5.02 ?
                                            • 19. Re: Extension Manager CS5 does'nt work
                                              Carl Sun Level 4
                                              Extension Manager CS5 should be used with Photoshop 5.02. You can download Extension Manager CS5 from http://www.adobe.com/exchange/em_download/em50_download.html. If you use Mac OS X 10.7 (Lion), after installing Extension Manager CS5, you will be notified to update to 5.0.2. You can also install 5.0.2 patch manually (click http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager _5_0_2_mul_AdobeUpdate.dmg to download). This patch solved the issue that the signature of third party extensions cannot be validated.
                                              • 20. Re: Extension Manager CS5 does'nt work
                                                What do I do with the update which is a DMG file ? I read it's an iso file on one site,I read on another site you need a special program ?
                                                • 21. Re: Extension Manager CS5 does'nt work
                                                  Carl Sun Level 4
                                                  Are you using Windows or Mac OS X? The dmg file is only needed on Mac OS X 10.7. If you do use Mac OS X 10.7, you can double click the DMG file to mount it, then double click the installer in new window.
                                                  • 22. Re: Extension Manager CS5 does'nt work
                                                    I'm using Windows.  Is there an update for Windows ?
                                                    • 23. Re: Extension Manager CS5 does'nt work
                                                      Carl Sun Level 4
                                                      There is no update for Windows. That issue only exists on Mac.
                                                      • 24. Re: Extension Manager CS5 does'nt work
                                                        Jlev911
                                                        I have this issue on Windows 7. It appears to be the same as posted above.
                                                        I have installed Extension manager CS5 from the adobe site. but the app will not open. I see it on the windows bar but cannot video the actual screen. See attached video.
                                                        Video here
                                                        http://acoustified.com/ExtensionManagerNotWorkingWindows7/ExtensionManagerNotWorkingWindow s7.mp4
                                                        Please help. J
                                                        • 25. Re: Extension Manager CS5 does'nt work
                                                          Xiaoyi Tong Adobe Employee
                                                          Hi Jlev911,
                                                          I am not sure what the root cause is for your problem, but you can try the steps below. Hope they can work.
                                                          1. Delete extension manager gui preference file in X:\Users\<username>\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\exman_uiPreferences.xml, and restart extension manager.
                                                          2. From your video I know you have 4 products installed. Have you ever launched extension manager successfully?Did this problem happen after you installed one product? If this problem showed up after you installed a product, try to rename its XManConfig.xml to other file name and restart extension manager.
                                                          3. If "X:\Users\<username>\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust" exists, move it to somewhere else and restart extenson manager.
                                                          4. From your video I saw FireFox was opened. Try to close it and restart extenson manager. If it does not help, disable its plugins and restart extension manager again( some plugins conflict with extension manager ).
                                                          5. Do you have enough permission to launch extension manager? Try to launch it with administrator and make sure you have write access to extension manager folders( I don't have extension manger cs5 installed, but they might locate in your home directory and pubic directory )?
                                                          6. If all of them still can not help you, generate extenson manger log files, attach them to the forum and we can check what happened( create ExManLog.YES in the same folder of extension manager exe file ).
                                                          • 26. Re: Extension Manager CS5 does'nt work
                                                            johnpalacio
                                                            Hello.  My extension manager will not start either.  I have deleted and reinstalled. I have tried to start using the sudo command.  Nothing seems to work.  Please advise (error log attached).  Thank you.
                                                            Process:     Adobe Extension Manager CS5.5 [1774]
                                                            Path:        /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
                                                            Identifier:  com.adobe.ExtensionManager
                                                            Version:     "5.5.2.20" (5.5.20)
                                                            Code Type:   X86 (Native)
                                                            Parent Process:  launchd [135]
                                                            User ID:     501
                                                            Date/Time:   2013-02-26 07:50:06.041 -0500
                                                            OS Version:  Mac OS X 10.8.2 (12C60)
                                                            Report Version:  10
                                                            Interval Since Last Report:      687747 sec
                                                            Crashes Since Last Report:       17
                                                            Per-App Interval Since Last Report:  13 sec
                                                            Per-App Crashes Since Last Report:   3
                                                            Anonymous UUID:                  6E42F100-0B0C-CBA5-E28E-70FC1D9E5CB8
                                                            Crashed Thread:  11
                                                            Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                                                            Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
                                                            VM Regions Near 0:
                                                            --> __PAGEZERO         0000000000000000-0000000000001000 [4K] ---/--- SM=NUL  /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
                                                            __TEXT             0000000000001000-0000000000210000 [ 2108K] r-x/rwx SM=COW  /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
                                                            Thread 0:: Dispatch queue: com.apple.main-thread
                                                            0   com.apple.CoreGraphics    0x912dcd38 sseCGSBlendXXXX8888Transpose + 520
                                                            1   com.apple.CoreGraphics    0x9118ae84 CGSBlendABGR8888toRGBA8888 + 949
                                                            2   com.apple.CoreGraphics    0x911635e1 argb32_image + 2504
                                                            3   libRIP.A.dylib            0x936fed08 ripd_Mark + 291
                                                            4   libRIP.A.dylib            0x936feba3 ripl_BltImage + 1585
                                                            5   libRIP.A.dylib            0x936fe30f ripc_RenderImage + 259
                                                            6   libRIP.A.dylib            0x936fbeca ripc_DrawImage + 1078
                                                            7   com.apple.CoreGraphics    0x9115f435 CGContextDrawImage + 427
                                                            8   com.apple.HIToolbox       0x9402c37a HIViewDrawCGImage + 220
                                                            9   AdobeOwl                  0x0049df95 OWLOSXApplicationContainerCreate + 94901
                                                            10  AdobeOwl                  0x0049fb2a OWLOSXApplicationContainerCreate + 101962
                                                            11  AdobeOwl                  0x0039887c OWLThemeChangeInterpolator + 84760
                                                            12  AdobeOwl                  0x00398d5b OWLThemeChangeInterpolator + 86007
                                                            13  AdobeOwl                  0x004a04ac OWLOSXApplicationContainerCreate + 104396
                                                            14  AdobeOwl                  0x003842b1 OWLThemeChangeInterpolator + 1357
                                                            15  com.apple.HIToolbox       0x94109b6b _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
                                                            16  com.apple.HIToolbox       0x93f91594 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
                                                            17  com.apple.HIToolbox       0x93f90980 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
                                                            18  com.apple.HIToolbox       0x93f907ca SendEventToEventTargetWithOptions + 94
                                                            19  com.apple.HIToolbox       0x93faad17 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 491
                                                            20  com.apple.HIToolbox       0x940379d5 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 759
                                                            21  com.apple.HIToolbox       0x94037d5c HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1662
                                                            22  com.apple.HIToolbox       0x94037d5c HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1662
                                                            23  com.apple.HIToolbox       0x94036df0 HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 802
                                                            24  com.apple.HIToolbox       0x94036a82 HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 82
                                                            25  com.apple.HIToolbox       0x94036a29 HIView::Render(unsigned long, CGContext*) + 45
                                                            26  com.apple.HIToolbox       0x93fb3460 FlushWindowObject(WindowData*, void**, unsigned char) + 812
                                                            27  com.apple.HIToolbox       0x93fbbfb1 FlushAllBuffers(__CFRunLoopObserver*, unsigned long, void*) + 245
                                                            28  com.apple.CoreFoundation  0x9326adfe __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30
                                                            29  com.apple.CoreFoundation  0x9326ad3d __CFRunLoopDoObservers + 381
                                                            30  com.apple.CoreFoundation  0x93244623 CFRunLoopRunSpecific + 355
                                                            31  com.apple.CoreFoundation  0x932444ab CFRunLoopRunInMode + 123
                                                            32  com.apple.HIToolbox       0x93fb515a RunCurrentEventLoopInMode + 242
                                                            33  com.apple.HIToolbox       0x93fb4ec9 ReceiveNextEventCommon + 374
                                                            34  com.apple.HIToolbox       0x9411a35d _AcquireNextEvent + 68
                                                            35  com.apple.HIToolbox       0x9410911a RunApplicationEventLoop + 225
                                                            36  com.adobe.ExtensionManager0x00005e88 main + 4416
                                                            37  com.adobe.ExtensionManager0x0000232a start + 54
                                                            Thread 1:
                                                            0   libsystem_kernel.dylib    0x978100ee __workq_kernreturn + 10
                                                            1   libsystem_c.dylib         0x9572604c _pthread_workq_return + 45
                                                            2   libsystem_c.dylib         0x95725e19 _pthread_wqthread + 448
                                                            3   libsystem_c.dylib         0x9570dcca start_wqthread + 30
                                                            Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                                                            0   libsystem_kernel.dylib    0x978109ae kevent + 10
                                                            1   libdispatch.dylib         0x996c4c71 _dispatch_mgr_invoke + 993
                                                            2   libdispatch.dylib         0x996c47a9 _dispatch_mgr_thread + 53
                                                            Thread 3:
                                                            Thread 4:
                                                            0   libsystem_kernel.dylib    0x9780d8e6 mach_wait_until + 10
                                                            1   libsystem_c.dylib         0x957b4c1c nanosleep + 375
                                                            2   com.adobe.ExtensionManager0x0015182f ScObjects::Thread::sleep(unsigned int) + 143
                                                            3   com.adobe.ExtensionManager0x0015188f ScObjects::Thread::wait(unsigned int) + 23
                                                            4   com.adobe.ExtensionManager0x0014845a ScObjects::BridgeTalkThread::run() + 332
                                                            5   com.adobe.ExtensionManager0x00151d99 ScObjects::Thread::go(void*) + 315
                                                            6   libsystem_c.dylib         0x95723557 _pthread_start + 344
                                                            7   libsystem_c.dylib         0x9570dcee thread_start + 34
                                                            Thread 5:
                                                            0   libsystem_kernel.dylib    0x9780d7d2 mach_msg_trap + 10
                                                            1   libsystem_kernel.dylib    0x9780ccb0 mach_msg + 68
                                                            2   com.adobe.adobeswfl       0x062d518f ExternalPlayer_Initialize + 465535
                                                            3   libsystem_c.dylib         0x95723557 _pthread_start + 344
                                                            4   libsystem_c.dylib         0x9570dcee thread_start + 34
                                                            Thread 6:
                                                            0   libsystem_kernel.dylib    0x9780f8e2 __psynch_cvwait + 10
                                                            1   libsystem_c.dylib         0x95728289 _pthread_cond_wait + 938
                                                            2   libsystem_c.dylib         0x957b5afc pthread_cond_wait + 48
                                                            3   com.adobe.adobeswfl       0x06282f54 ExternalPlayer_Initialize + 129092
                                                            4   com.adobe.adobeswfl       0x0605334a 0x6044000 + 62282
                                                            5   com.adobe.adobeswfl       0x06282ce7 ExternalPlayer_Initialize + 128471
                                                            6   com.adobe.adobeswfl       0x06282d3f ExternalPlayer_Initialize + 128559
                                                            7   libsystem_c.dylib         0x95723557 _pthread_start + 344
                                                            8   libsystem_c.dylib         0x9570dcee thread_start + 34
                                                            Thread 7:
                                                            Thread 8:
                                                            Thread 9:
                                                            Thread 10:
                                                            Thread 11 Crashed:
                                                            0   com.apple.CoreFoundation  0x93229d1e CFURLCreateStringWithFileSystemPath + 206
                                                            1   com.apple.CoreFoundation  0x93229c25 CFURLCopyFileSystemPath + 53
                                                            2   com.adobe.ExtensionManager0x000d08e5 CMemoryMappedFile::CMemoryMappedFile(FSRef const&, bool) + 97
                                                            3   com.adobe.ExtensionManager0x000d0d2a CMacFileBuffer::CMacFileBuffer(FSRef const&, HFSUniStr255 const&, bool, bool) + 192
                                                            4   com.adobe.ExtensionManager0x000adbc1 CFile::Open(wchar_t const*, unsigned int, bool) + 411
                                                            5   com.adobe.ExtensionManager0x0011dd70 CMacrPluginConfigFile::load(CString const&) + 196
                                                            6   com.adobe.ExtensionManager0x00019062 CMacrExtensionManager::updatePluginFile(CMacrExtension const*, CMacrProduct const*, CMacrExtensionPaths const&, bool) + 126
                                                            7   com.adobe.ExtensionManager0x000298b7 CMacrExtensionManager::migrateFiles(CString const&, CMacrPath const&, CMacrPath const&, CMacrPath const&, CMacrPath const&, CMacrProduct const*, int) + 7253
                                                            8   com.adobe.ExtensionManager0x00029fe3 CMacrExtensionManager::migrateExtensionFromExtensionFile(CString const&, CString const&, CString const&, CMacrProduct const*) + 1377
                                                            9   com.adobe.ExtensionManager0x0002a45c CMacrExtensionManager::migrateExtensionsFromProductPreferredFolder(CMacrProduct const*) + 574
                                                            10  com.adobe.ExtensionManager0x0002a91d CMacrExtensionManager::migrateExtensionsFromProductsPreferredFolders() + 163
                                                            11  com.adobe.ExtensionManager0x00119b53 MigratePreferredExtensionCommand::execute() + 19
                                                            12  com.adobe.ExtensionManager0x000dd150 CommandExecutor_Impl::run() + 144
                                                            13  com.adobe.ExtensionManager0x000dd16b CommandExecutor_Impl::runHelper(void*) + 17
                                                            14  libsystem_c.dylib         0x95723557 _pthread_start + 344
                                                            15  libsystem_c.dylib         0x9570dcee thread_start + 34
                                                            Thread 11 crashed with X86 Thread State (32-bit):
                                                              eax: 0x00000000  ebx: 0x93229c61  ecx: 0x00000000  edx: 0x00000000
                                                              edi: 0x00000000  esi: 0xac448840  ebp: 0xb05b0798  esp: 0xb05aef20
                                                               ss: 0x00000023  efl: 0x00010246  eip: 0x93229d1e   cs: 0x0000001b
                                                               ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
                                                              cr2: 0x00000000
                                                            Logical CPU: 2
                                                            Binary Images:
                                                            0x1000 -   0x20ffeb +com.adobe.ExtensionManager ("5.5.2.20" - 5.5.20) <E83C03FC-E291-08C5-9492-CB67B8FC2F19> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/MacOS/Adobe Extension Manager CS5.5
                                                              0x367000 -   0x36afe7 +libwchar.dylib (1) <DE7B4F71-F31A-46F7-B70D-A8A157B5EB6B> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/libwchar.dylib
                                                              0x36e000 -   0x568fef +AdobeOwl (1) <466BD72B-E2A5-447A-9384-B6DC9AD3AE0C> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                                              0x5e3000 -   0xae1fc3 +AdobeOwlCanvas (1) <45219076-15E0-4A0D-9BC0-2FFED8EA7E46> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
                                                              0xc2a000 -   0xc9afeb +com.adobe.adobe_caps (adobe_caps 3.5.18.0 - 3.5.18.0) <A54D73C5-EBCF-75F1-9BB0-ADBB36042DEC> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/a/adobe_caps
                                                              0xca8000 -   0xcacffc +com.adobe.AdobeCrashReporter (3.0 - 5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                                              0xcb2000 -   0xce7fef +com.adobe.pip (5.5.0.1272) <4AD1ED99-8BB9-B49E-16E5-B7E7A97AAA99> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
                                                              0xcf2000 -   0xd48ffb +com.adobe.headlights.LogSessionFramework (2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                                              0xd8c000 -   0xdc8ff7  com.apple.vmutils (4.2.1 - 108) <6918860D-B24F-356C-9374-025BFFEA66A3> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                                                              0xde2000 -   0xe8dfff  libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
                                                            0x18c3000 -  0x18d0ff3  com.apple.Librarian (1.1 - 1) <88A55A5E-40FF-3234-8394-2317120B79AB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                                                            0x1f00000 -  0x1f70feb +com.adobe.adobe_caps (adobe_caps 3.5.18.0 - 3.5.18.0) <A54D73C5-EBCF-75F1-9BB0-ADBB36042DEC> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                                                            0x1ff6000 -  0x1ff8ff3  com.apple.LiveType.component (2.1.4 - 2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
                                                            0x3403000 -  0x3405ff7  Motion (729) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
                                                            0x3445000 -  0x3446ffd  com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                                            0x3798000 -  0x37deffb  com.apple.motion.component (1.0 - 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
                                                            0x6044000 -  0x6847fe2 +com.adobe.adobeswfl (1.0.7) <53D59B93-133D-41B4-AE25-83532E5C0F6C> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Resources/AdobeSWFL.bundle/Contents/MacO S/AdobeSWFL
                                                            0x7b18000 -  0x7b26fff  libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                                            0x7b2d000 -  0x7b91fe2  com.apple.LiveType.framework (2.1.4 - 2.1.4) <C9D29156-2471-2A9D-3657-EF06204229C6> /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
                                                            0x7bb1000 -  0x7c4eff8  com.apple.procore.framework (4.0.2 - 757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
                                                            0xf326000 -  0xf338ffd  libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                                            0xf93b000 -  0xfd2dfff +WebKit.dylib (1.0.7) <6FB30C58-17FE-4A4B-971E-CDE89FB7DD1B> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Resources/WebKit.dylib
                                                            0x111a5000 - 0x11263ff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                                                            0x8fea3000 - 0x8fed5e57  dyld (210.2.3) <23DBDBB1-1D21-342C-AC2A-0E55F27E6A1F> /usr/lib/dyld
                                                            0x90007000 - 0x9000bffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
                                                            0x9000c000 - 0x900bbff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                                            0x900bc000 - 0x900bcfff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
                                                            0x900c9000 - 0x900d0fff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
                                                            0x900d1000 - 0x90115fff  libGLU.dylib (8.6.1) <06BAFDCA-800C-35E3-B1A3-F05E105B86AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                                            0x90116000 - 0x90164ff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <7BA6C58B-0357-356F-BB69-17ACB5E35988> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                                            0x90165000 - 0x901c9fff  com.apple.datadetectorscore (4.0 - 269.1) <3EFFB8D8-CD46-3BB2-9B9F-2F757B9EC998> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                                            0x901ca000 - 0x901ccfff  libCVMSPluginSupport.dylib (8.6.1) <8A174BD9-992E-351D-8F9A-DF6991723ABE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                                            0x901cd000 - 0x90265fff  com.apple.CoreServices.OSServices (557.4 - 557.4) <C724AB29-A596-3E1E-9FF1-A4E509AD843A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                                            0x90266000 - 0x90266fff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                                            0x90267000 - 0x902c2fff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                                                            0x902c3000 - 0x90327ff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
                                                            0x906a1000 - 0x906e6ff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                                                            0x906e7000 - 0x906f1fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                                            0x906f2000 - 0x90727fff  libTrueTypeScaler.dylib (84.5) <2598F930-5E6B-37D7-B1E6-18181A972C6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                                                            0x90959000 - 0x90986ffb  com.apple.CoreServicesInternal (154.2 - 154.2) <DCCF604B-1DB8-3F09-8122-545E2E7F466D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                                            0x90987000 - 0x909d6ff6  libTIFF.dylib (845) <989A2EB9-3A49-3157-8E9C-B16E6005BC64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                                            0x909d7000 - 0x909d9fff  com.apple.securityhi (4.0 - 55002) <79E3B880-3AB7-3BF3-9CDF-117A45599545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                                            0x909da000 - 0x909defff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                                            0x909df000 - 0x90c5bff7  com.apple.QuickTime (7.7.1 - 2599.13) <FE609160-E1EF-341D-9B6A-205D3E03A4D2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                                                            0x90c5c000 - 0x90cd8ffb  libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
                                                            0x90dce000 - 0x90e28fff  com.apple.Symbolication (1.3 - 93) <A839CFC2-F870-3652-B353-15A55D88F88D> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                                            0x90f8b000 - 0x91103ff5  com.apple.QuartzCore (1.8 - 304.0) <D9E018B8-6E5F-3FFA-A1B2-2B1BC1E03CA2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                            0x91104000 - 0x91546fff  com.apple.CoreGraphics (1.600.0 - 324.6) <66556166-F9A7-3EEC-A562-46061C7A79E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                                            0x91547000 - 0x915affe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                                            0x9171b000 - 0x9171cfff  libdnsinfo.dylib (453.18) <41C7B8E2-2A81-31DE-BD8B-F0C29E169D4F> /usr/lib/system/libdnsinfo.dylib
                                                            0x9171d000 - 0x9177afff  com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                                            0x917f5000 - 0x9188ffff  com.apple.CoreSymbolication (3.0 - 87) <1A13CC83-4635-3AC6-9A86-E8DCE99562B5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                                            0x91890000 - 0x918c6ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                                            0x918c7000 - 0x91929fff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
                                                            0x921a7000 - 0x9222cff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                                            0x9222d000 - 0x9233a057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
                                                            0x9233b000 - 0x92349fff  com.apple.opengl (1.8.6 - 1.8.6) <1AD1AE7B-B57B-35B5-B571-32A34F0DA737> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                                            0x9234d000 - 0x92509ffd  libicucore.A.dylib (491.11.1) <B19E450A-BAF1-3967-9C95-7F77DC0B4639> /usr/lib/libicucore.A.dylib
                                                            0x9250c000 - 0x92529fff  libxpc.dylib (140.41) <1BFE3149-C242-3A77-9729-B00DEDC8CCF2> /usr/lib/system/libxpc.dylib
                                                            0x9252d000 - 0x9253dff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                                            0x9256f000 - 0x92812ffb  com.apple.CoreImage (8.2.2 - 1.0.1) <85BFFB09-D765-3F5F-AF65-FB136DDCAEF3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                                            0x9281a000 - 0x92821fff  libsystem_dnssd.dylib (379.32.1) <6A505284-2382-3F27-B96F-15FFDACF004E> /usr/lib/system/libsystem_dnssd.dylib
                                                            0x9282e000 - 0x9285aff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
                                                            0x928a5000 - 0x928a5fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                                            0x928a6000 - 0x928aefff  com.apple.CommerceCore (1.0 - 26) <AF0D1990-8CBF-3AB4-99DF-8B7AE14FB0D5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                                            0x928af000 - 0x92bccff3  com.apple.Foundation (6.8 - 945.11) <03B242AC-519C-3683-AA52-E73536B3D55F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                                            0x92bd3000 - 0x92bd5ffb  libRadiance.dylib (845) <3F87840F-217D-3074-A29D-919BAAED2F4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                                            0x92bd6000 - 0x92c2dff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                                                            0x930e9000 - 0x930ecff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
                                                            0x930ed000 - 0x930edfff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                                            0x930ee000 - 0x930f7ffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                                                            0x930f8000 - 0x93127ff7  com.apple.securityinterface (6.0 - 55024.4) <7C5E28DC-F8BE-3238-883F-E1646A2AF895> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                                            0x93128000 - 0x93147ff3  com.apple.Ubiquity (1.2 - 243.10) <D2C9F356-1681-31D2-B292-5227E2DDEB0B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                                                            0x93190000 - 0x9320cff3  com.apple.Metadata (10.7.0 - 707.3) <6B6A6216-23D0-34CE-8099-BEE9BA42501E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                                            0x9320d000 - 0x933f5ff3  com.apple.CoreFoundation (6.8 - 744.12) <E939CEA0-493C-3233-9983-5070981BB350> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                            0x933f6000 - 0x933f9ffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
                                                            0x933fa000 - 0x934f2ff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
                                                            0x934f5000 - 0x934fdfff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
                                                            0x93501000 - 0x93576ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <95206704-F9C9-33C4-AF25-FE9890E160B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                                            0x935a6000 - 0x935b0fff  libCSync.A.dylib (324.6) <D2E8AC70-C6D1-3C40-8A82-E50422EDCFBF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                                            0x935c0000 - 0x935ccff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
                                                            0x9366a000 - 0x9366dff9  libCGXType.A.dylib (324.6) <3004616B-51F6-3B9D-8B85-DCCA3DF9BC10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                                            0x936ee000 - 0x93717ff7  libRIP.A.dylib (324.6) <7976E6A2-A489-33F5-A727-7634DDE3B761> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                                            0x93aac000 - 0x93aacfff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                                            0x93aed000 - 0x93af4ffe  com.apple.agl (3.2.1 - AGL-3.2.1) <D0A9B878-7F1F-3210-B6AF-91D2DBEFF21B> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                                            0x93af5000 - 0x93eadffa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                                            0x93eae000 - 0x93ebcff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
                                                            0x93ebd000 - 0x93ebdfff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                                            0x93ebe000 - 0x93ee3ffb  com.apple.framework.familycontrols (4.1 - 410) <5A8504E7-D95D-3101-8E20-38EADE8DEAE1> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                                            0x93f3e000 - 0x93f5cff3  com.apple.openscripting (1.3.6 - 148.2) <55738D66-CC15-3F43-9265-00C3322D39C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                                            0x93f5d000 - 0x94340ff3  com.apple.HIToolbox (2.0 - 625) <5A312E41-9940-363E-B891-90C4672E6850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                                            0x94341000 - 0x9435afff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                                            0x9435b000 - 0x9442ffff  com.apple.backup.framework (1.4.1 - 1.4.1) <55F2A679-9B21-3F43-A580-4C2ECF6A5FC5> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                                            0x94430000 - 0x94431fff  libsystem_sandbox.dylib (220) <4E42390B-25EC-3530-AF01-337E430C16EB> /usr/lib/system/libsystem_sandbox.dylib
                                                            0x94432000 - 0x9457fffb  com.apple.CFNetwork (596.2.3 - 596.2.3) <1221EF86-659B-3136-AB57-0CC6B130CDA2> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                                            0x94581000 - 0x945a5fff  libJPEG.dylib (845) <547FA9A5-0BBB-3E39-BACA-F3E2DAE57DB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                                            0x94644000 - 0x9485bfff  com.apple.CoreData (106.1 - 407.7) <17FD06D6-AD7C-345A-8FA4-1F0FBFF4DAE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                                            0x94975000 - 0x95531ffb  com.apple.AppKit (6.8 - 1187.34) <06EDB1D1-3B8A-3699-8E3A-D8F50A27AB7C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                                            0x95532000 - 0x955e6fff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                            0x955e7000 - 0x955e8fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
                                                            0x9570d000 - 0x957cafeb  libsystem_c.dylib (825.25) <B1F6916A-F558-38B5-A18C-D9733625FDC9> /usr/lib/system/libsystem_c.dylib
                                                            0x957d1000 - 0x9580cfe7  libGLImage.dylib (8.6.1) <A3442557-18D5-332E-8859-423D5A20EBBE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                                            0x95939000 - 0x959a1ff7  com.apple.framework.IOKit (2.0 - 755.18.10) <9A80E97E-544F-3A45-916D-6DB7ED217E33> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                                            0x959a2000 - 0x959f0ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                                            0x959f1000 - 0x95a91ff7  com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                                            0x95a92000 - 0x95abbfff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
                                                            0x95abc000 - 0x95ad9fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
                                                            0x95ada000 - 0x95be7ff3  com.apple.ImageIO.framework (3.2.0 - 845) <BF959BCB-C30A-3680-B7C2-91B327B2B63B> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                                            0x95d38000 - 0x95d5afff  libc++abi.dylib (24.4) <06479DA4-BC23-34B6-BAFC-A885814261D0> /usr/lib/libc++abi.dylib
                                                            0x95fe8000 - 0x95ffbff9  com.apple.MultitouchSupport.framework (235.28 - 235.28) <5C8CFA21-D4FC-32E8-B199-0F7155E6ED9A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                                            0x9603b000 - 0x96042ffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
                                                            0x96043000 - 0x960edfff  com.apple.LaunchServices (539.7 - 539.7) <AF33EBD3-BC0B-30B5-B7DA-5CCCF12D7EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                                            0x96e27000 - 0x96e28ffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
                                                            0x96e55000 - 0x96ea1fff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
                                                            0x96ee3000 - 0x96f75ffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                                            0x96f76000 - 0x96f78fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
                                                            0x96f79000 - 0x96f7cfff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                                            0x96f82000 - 0x96f8effe  libkxld.dylib (2050.18.24) <48A75AF6-9D5A-3552-948E-30A1682D3664> /usr/lib/system/libkxld.dylib
                                                            0x96f90000 - 0x96f90fff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                                            0x9761e000 - 0x97698ff3  com.apple.securityfoundation (6.0 - 55115.4) <8A3DA1FE-1985-3ECB-945A-6B1E853B4BDC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                                            0x97699000 - 0x977f1ffb  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <9205DFC2-8DAE-354E-AD87-46E229B5F2F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                                            0x977f2000 - 0x977fafff  com.apple.DiskArbitration (2.5.1 - 2.5.1) <25A7232F-9B6A-3746-A3A8-12479D086B1E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                                            0x977fb000 - 0x97815ffc  libsystem_kernel.dylib (2050.18.24) <C17D49D0-7961-3B67-B443-C788C6E5AA76> /usr/lib/system/libsystem_kernel.dylib
                                                            0x97816000 - 0x978d4ff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                                            0x978d5000 - 0x97a10ff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                                            0x97a69000 - 0x97b5affc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
                                                            0x97b5b000 - 0x97b64ff9  com.apple.CommonAuth (3.0 - 2.0) <A1A6CC3D-AA88-3519-A305-9B5D76C5D63B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                                            0x97b65000 - 0x97b66fff  libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
                                                            0x97b67000 - 0x97b87ffd  com.apple.ChunkingLibrary (2.0 - 133.2) <FE5F0F1E-B15D-3F76-8655-DC2FE19BF56E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                                            0x97c99000 - 0x97ca0ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                                            0x97ca3000 - 0x97cc7fff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                                            0x97ddc000 - 0x97de6ffe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                                            0x97de7000 - 0x97df3ff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                                            0x97df4000 - 0x97e09fff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                                            0x97e0a000 - 0x97e3dff3  com.apple.GSS (3.0 - 2.0) <B1D719C1-B000-3BE3-B747-329D608585DD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                                            0x97e3e000 - 0x97e3efff  com.apple.Carbon (154 - 155) <C0A26E7B-28F1-3C7E-879E-A3CF3ED5111C> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                                            0x980d9000 - 0x980ddff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
                                                            0x98114000 - 0x9821fff7  libJP2.dylib (845) <D409C913-6FA4-3D60-BFE0-B9FC6A02FEE0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                                            0x98220000 - 0x98251fff  com.apple.DictionaryServices (1.2 - 184.4) <0D5BE86F-F40A-3E39-8569-19FCA5EDF9D3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                                            0x98252000 - 0x982b8fff  com.apple.print.framework.PrintCore (8.1 - 387.1) <F8CF762B-B707-3021-958F-BB8D33DB3576> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                                            0x982b9000 - 0x982baffd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                                            0x982bb000 - 0x982c8ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                                                            0x982c9000 - 0x982cdffc  libGIF.dylib (845) <714E9F0D-D7A3-3F58-B46E-FCBE0F144B23> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                                            0x982ce000 - 0x982dcff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
                                                            0x982dd000 - 0x9831cff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                                                            0x98327000 - 0x985e7fff  com.apple.security (7.0 - 55179.1) <CB470E48-621B-34D9-9E78-8B773358CB6B> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                                            0x985e8000 - 0x9860dff7  com.apple.CoreVideo (1.8 - 99.3) <5B872AC0-E82D-3475-A3F9-FD95F380560D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                            0x9860e000 - 0x98653ff5  com.apple.opencl (2.1.20 - 2.1.20) <41C4AE6E-67B6-33E2-A9B6-BF6F01580B16> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                                            0x986ab000 - 0x9871affb  com.apple.Heimdal (3.0 - 2.0) <1ABF438B-30E6-3165-968C-E2EA1A9DF1FD> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                                            0x9871b000 - 0x988a4ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                                            0x988a5000 - 0x9893cff7  com.apple.ink.framework (10.8.2 - 150) <D90FF7BC-6B90-39F1-AC52-670269947C58> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                                            0x9893d000 - 0x98940ffd  libCoreVMClient.dylib (24.4) <C54E8FD0-61EC-3DC8-8631-54288AC66AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                                            0x98941000 - 0x98941ffd  libOpenScriptingUtil.dylib (148.2) <907E25B1-4F50-3461-B8D5-733C687EB534> /usr/lib/libOpenScriptingUtil.dylib
                                                            0x9895a000 - 0x98d77fff  FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                                                            0x98d78000 - 0x98d78fff  libSystem.B.dylib (169.3) <F479E729-89C7-3B4C-9731-678EB673A861> /usr/lib/libSystem.B.dylib
                                                            0x98d79000 - 0x98d95ff7  libPng.dylib (845) <14C43094-C670-3575-BF9B-3A967E05EAC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                                            0x98d96000 - 0x98da1fff  libcommonCrypto.dylib (60026) <A6C6EDB8-7E69-3827-81F3-9A74D0935461> /usr/lib/system/libcommonCrypto.dylib
                                                            0x98da2000 - 0x98dfbfff  com.apple.AE (645.3 - 645.3) <6745659F-006D-3F25-94D6-DF944E9A01FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                                            0x98dfc000 - 0x98e08ffa  com.apple.CrashReporterSupport (10.8.2 - 415) <BAE9900A-51E7-3AD4-A7FB-7E6CCFFB2F21> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                                            0x98e09000 - 0x98e13fff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
                                                            0x98e14000 - 0x98e29fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                                            0x98e2a000 - 0x98e30fff  libGFXShared.dylib (8.6.1) <E32A7266-FCDD-352C-9C2A-8939265974AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                                            0x98e75000 - 0x98e87fff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
                                                            0x98eb3000 - 0x98eb4fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
                                                            0x98eb5000 - 0x98f9eff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
                                                            0x98f9f000 - 0x98fadfff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
                                                            0x98fae000 - 0x992b3ff7  com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <4571EDDC-704A-3FB1-B9A6-59870AA6165F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                                            0x992b4000 - 0x992bafff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                                            0x995a7000 - 0x995a8fff  libremovefile.dylib (23.1) <98622D14-DAAB-3AD8-A5D9-C322BF572A98> /usr/lib/system/libremovefile.dylib
                                                            0x995a9000 - 0x995bffff  com.apple.CFOpenDirectory (10.8 - 151.10) <3640B988-F915-3E0D-897C-CB04C95BA601> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                                            0x995c0000 - 0x996beff7  libFontParser.dylib (84.5) <B3006327-7B2D-3966-A56A-BD85F1D71641> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                                            0x996bf000 - 0x996bffff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
                                                            0x996c0000 - 0x996d2ff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
                                                            0x996d3000 - 0x996d6ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                                            0x996d7000 - 0x997f3ff7  com.apple.desktopservices (1.7.2 - 1.7.2) <8E74D101-8398-34F1-A463-B4950680A597> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                                            0x997fe000 - 0x99802fff  com.apple.IOSurface (86.0.3 - 86.0.3) <E3A4DB0A-1C1A-31E3-A550-5C0E1C874509> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                                            0x99803000 - 0x99820ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
                                                            0x99821000 - 0x99838fff  com.apple.GenerationalStorage (1.1 - 132.2) <93694E0D-35D3-3633-976E-F354CBD92F54> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                                            0x99895000 - 0x998d7ff7  libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
                                                            0x998d8000 - 0x9991affb  com.apple.RemoteViewServices (2.0 - 80.5) <60E04F2F-AFD8-3B1F-BF07-8A3A7EABB8E9> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                                            0x99982000 - 0x9998ffff  libGL.dylib (8.6.1) <C7A3917A-C444-33CC-8599-BB9CD8C12BC4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                                            0x99990000 - 0x999d1ff7  libcups.2.dylib (327) <F46F8703-FEAE-3442-87CB-45C8BF98BEE5> /usr/lib/libcups.2.dylib
                                                            0x9a377000 - 0x9a37bfff  com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                                            0x9a3bf000 - 0x9a3ecffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
                                                            0x9a3ed000 - 0x9a444ff3  com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                                            0x9a69e000 - 0x9a69effd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <4C13DEA2-1EB0-3D06-901A-DB93184C06F0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                                            0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Extension Manager CS5.5/Adobe Extension Manager CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                                            0xba900000 - 0xba91cffd  libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                                            0xbab00000 - 0xbab21ffc  libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                                            External Modification Summary:
                                                              Calls made by other processes targeting this process:
                                                            task_for_pid: 2
                                                            thread_create: 0
                                                            thread_set_state: 0
                                                              Calls made by this process:
                                                            task_for_pid: 0
                                                            thread_create: 0
                                                            thread_set_state: 0
                                                              Calls made by all processes on this machine:
                                                            task_for_pid: 4869
                                                            thread_create: 0
                                                            thread_set_state: 0
                                                            VM Region Summary:
                                                            ReadOnly portion of Libraries: Total=147.0M resident=112.1M(76%) swapped_out_or_unallocated=34.9M(24%)
                                                            Writable regions: Total=138.1M written=28.7M(21%) resident=35.2M(25%) swapped_out=0K(0%) unallocated=102.9M(75%)
                                                            REGION TYPE                  VIRTUAL
                                                            ATS (font support)             33.1M
                                                            CG backing stores              3232K
                                                            CG shared images               1216K
                                                            CoreServices                   2352K
                                                            MALLOC                         48.6M
                                                            MALLOC guard page                48K
                                                            Memory tag=240                    4K
                                                            Memory tag=242                   12K
                                                            Memory tag=249                  192K
                                                            Memory tag=35                  7080K
                                                            Stack                          69.6M
                                                            VM_ALLOCATE                   116.5M
                                                            __DATA                         9792K
                                                            __DATA/__OBJC                   256K
                                                            __IMAGE                         528K
                                                            __IMPORT                        100K
                                                            __LINKEDIT                     34.4M
                                                            __OBJC                         1704K
                                                            __OBJC/__DATA                   248K
                                                            __PAGEZERO                        4K
                                                            __TEXT                        112.6M
                                                            __UNICODE                       544K
                                                            mapped file                   121.5M
                                                            shared memory                   308K
                                                            TOTAL                         563.1M
                                                            Model: iMac12,1, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.5 GHz, 8 GB, SMC 1.71f22
                                                            Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
                                                            Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
                                                            Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
                                                            AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.70.23-P2P
                                                            Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
                                                            Network Service: Wi-Fi, AirPort, en1
                                                            Serial ATA Device: WDC WD5000AAKS-402AA0, 500.11 GB
                                                            Serial ATA Device: OPTIARC DVD RW AD-5690H
                                                            USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
                                                            USB Device: eUSB ORCA Quad Reader, 0x04e6  (Shuttle Technology), 0x0325, 0xfd130000 / 5
                                                            USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 4
                                                            USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
                                                            USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 3
                                                            USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
                                                            USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa120000 / 5
                                                            USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfa123000 / 10
                                                            USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa122000 / 9
                                                            USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
                                                            USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7
                                                            FireWire Device: OEM ATA Device 00, G-TECH, 800mbit_speed
                                                            • 27. Re: Extension Manager CS5 does'nt work
                                                              Carl Sun Level 4
                                                              You have to apply Extension Manager 5.5.3 update. Apple made some API changes in Lion which causes Extension Manager CS5/5.5 crash. We released Extension Manager 5.0.3 and 5.5.3 update last April to solve this issue. You can apply this update via Adobe Application Manager or download and install http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager _5_5_3_mul_AdobeUpdate.dmg (which can be found at http://www.adobe.com/downloads/updates/).
                                                              • 28. Re: Extension Manager CS5 does'nt work
        DashDogear
        on OS 10.8.3 with CS5 I have tried everything in here and still not working.  Extension Manager opens, but with no window.  I really need Extension Manager for my work.  What now!!!
        • 29. Re: Extension Manager CS5 does'nt work
        Carl Sun Level 4
        You said you have tried everything. If you have installed 5.0.3 update, deleted files in "/Users/<UserName>/Library/Preferences/Macromedia/Flash Player/#Security/FlashPlayerTrust" and "/Library/Application Support/Macromedia/FlashPlayerTrust", deleted "/Users/<UserName>/Library/Preferences/Adobe/Extension Manager CS5/exman_uiPreferences.xml", launched Extension Manager with sudo command, please generate log files and send them to exman.beijing@gmail.com.
        • 30. Re: Extension Manager CS5 does'nt work
        DashDogear Level 1
        I am sorry if I appear ignorant, but I have no /Library/ file under my /Users/<user name>.  Only under /Users/Shared/ which does not have a Preference file.  The only other Library file I have is straight under the Macintosh HD.  I can not find a file called FlashPlayerTrust or exman_uiPreferences.xml.  Launching via sudo cammand still gives me no window in Extension Manager.  How do I generate a log file to send you?
        • 31. Re: Extension Manager CS5 does'nt work
        Carl Sun Level 4
        The folder ""/Users/<UserName>/Library/" is hidden since Mac OS X 10.7. You have two ways to go to this folder in Finder.
        1. Click menu "Go"->"Go to Folder...", input "/Users/<UserName>/Library/" (exclude quotation mark) then click "Go".
        2. Press "option" key down, click menu "Go" then click "Library" in the dropdown menu.
        To generate log files, please refer to http://forums.adobe.com/message/4275082#4275082. You have to replace all "6" in the instruction with "5".
        • 32. Re: Extension Manager CS5 does'nt work
        DashDogear Level 1
        I deleted all the files and still no Extension Manager.  The link you gave to generate a log file is awfully vague for a novice like me.  How does one create a ExManLog.Yes file? Should it be created in the Extension Manager CS5 folder in /Applications/?
        • 33. Re: Extension Manager CS5 does'nt work
        Carl Sun Level 4
        1. Open Finder.
        2. Navigate to "Applications/Utilities".
        3. Double click "Terminal.app" to launch it.
        4. In the Terminal window, input the following command (including double quotation mark) then press "return" key.
        cd "/Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/MacOS"
        5. Input the following command then press "return" key.
        sudo touch ExManLog.YES
        6. When being prompted, input the password of administrator user then press "return" key. A file named "ExManLog.YES" should have been created in this folder.
        7. Launch Extension Manager.
        8. Wait a while then quit Extension Manager.
        9. Send log files (ExtensionManager.log, log0.log, ...) in "/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS5/" to exman.beijing@gmail.com .
        • 34. Re: Extension Manager CS5 does'nt work
        DashDogear Level 1
        Thank you.  I have sent the files from
        rickhaz@yahoo.com
        • 35. Re: Extension Manager CS5 does'nt work
        Carl Sun Level 4
        The logs are really strange. I suspect the update was not complete so the swf file didn't match with main executable file. Currently you can delete the EM CS5 installation folder ("/Applications/Adobe Extension Manager CS5/") directly, then download and install EM CS5 GM build (http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager 5All.dmg) and EM 5.0.3 patch (http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager _5_0_3_mul_AdobeUpdate.dmg) in turn.
        • 36. Re: Extension Manager CS5 does'nt work
        DashDogear Level 1
        Thank you!  It seemes to be fine now.
