28 Replies Latest reply on Jan 16, 2011 8:47 AM by bazlid50
    PRE 9 Preview screen
    bazlid50 Level 1
      Hi
      Can't seem to get preview screen to work properly.  I have clips on the Timeline/Sceneline but when I click on them and press 'play' nothing happens.  I seem to be locked into 'motion tracking' mode - how do I solve the problem?
      Many thanks
      Barry
        • 1. Re: PRE 9 Preview screen
          the_wine_snob Level 9
          With Clips in the Timeline, you do not need to click on the Clip, but just hit the Spacebar to play. Does that get you what you want?
          When you click on a Clip, you have selected that Clip, and it's the Timeline, that you want.
          • 2. Re: PRE 9 Preview screen
            Also, is there a red line above your clips on the timeline? This is an indication that you are not using the proper project settings for that type of video and
            the program is too overloaded to soft render it.
            What type of camcorder did your video come from, and which project settings did you select when you started your Premiere Elements project?
            • 3. Re: PRE 9 Preview screen
              bazlid50 Level 1
              Hunt,
              The space bar sets the red line moving but  there isn’t a picture in the preview window.  All the preview window has in it is ‘to add menu drag template here’
              Cheers
              Barry
              Sent: Saturday, January 08, 2011 11:56 PM
              To: Barry Graham
              Subject: PRE 9 Preview screen
              • 4. Re: PRE 9 Preview screen
                bazlid50 Level 1
                Yes there’s a red line above the clips.  Video came from a Panasonic ‘point and shoot’ camera and is a .MOV file.
                Where do I select project settings?
                Sent: Sunday, January 09, 2011 12:03 AM
                To: Barry Graham
                • 5. Re: PRE 9 Preview screen
                  Can you be more specific about the camera that shot these?
                  Is it a video camcorder or a camera that shoots video?
                  Video from still cameras can have its own unique challenges.
                  Also make sure you have the latest version of Quicktime from Apple.
                  • 6. Re: PRE 9 Preview screen
                    bazlid50 Level 1
                    Hi Steve,
                    It’s a compact stills camera that shoots video, although I have the same problem with all the movie clips I am using and some of them have been shot on a new Panasonic Camcorder that uses SD cards.  I’m not convinced it’s solely a problem with the capture format, more likely that I have to alter a setting in PRE9.
                    Cheers
                    Barry
                    Sent: Sunday, January 09, 2011 12:41 AM
                    To: Barry Graham
                    • 7. Re: PRE 9 Preview screen
                      I'm sorry, but if you can't tell me the model number of the camera or camcorder (Is it a secret?) I can't help you.
                      After all, there are dozens of cameras that also shoot video.
                      But nearly all of them (at least of the non-DSLR variety) shoot video that can't be edited as is in Premiere Elements. Have you looked into converting this video to a more traditional format, like a DV-AVI, per the FAQs to the right of this forum?
                      http://forums.adobe.com/thread/415317?tstart=0
                      • 8. Re: PRE 9 Preview screen
                        bazlid50 Level 1
                        Steve,
                        Of course it’s not a secret it’s a Panasonic DMC-TZ5.  The point I made in my previous post was that it’s not only these files that won’t display in the preview window.  As I said,  I have a Panasonic camcorder too and files shot on that also don’t display – neither do MPEGs.
                        Cheers
                        Barry
                        Sent: Sunday, January 09, 2011 12:57 PM
                        To: Barry Graham
                        • 9. Re: PRE 9 Preview screen
                          Yes, that's a non-DSLR still camera, so it's likely using an MJPEG codec to save its video rather than a standard video codec.
                          Your best solution is to convert the video to an editable format (like DV-AVI) using one of the programs I linked you to above.
                          Bill Hunt also has a solution that sometimes works. It involves installing some additional codecs on your computer. He may chime in with that suggestion if you want to give it a go.
                          • 10. Re: PRE 9 Preview screen
                            If it is MJPEG, then this ARTICLE might be able to help.
                            Good luck, and hope that helps,
                            • 11. Re: PRE 9 Preview screen
                              bazlid50 Level 1
                              Hi Steve,
                              I know it’s a non-DSLR camera as I have a DSLR too –  The Panasonic is just something I sometimes pocket for convenience.
                              I still think there’s more to this than you think as I have video files in various formats and none of them display in the preview window.
                              Thanks for your continued interest and help
                              Cheers
                              Barry
                              Sent: Sunday, January 09, 2011 8:35 PM
                              To: Barry Graham
                              • 12. Re: PRE 9 Preview screen
                                bazlid50 Level 1
                                Hi Bill,
                                I’ve just replied to Steve and explained that I have videos in various formats and so I think it’s more likely to be something I’m doing (or not doing) rather than the file format.
                                Cheers
                                Barry
                                Sent: Sunday, January 09, 2011 9:04 PM
                                To: Barry Graham
                                If it is MJPEG, then this http://forums.adobe.com/thread/730396?tstart=0 might be able to help.
                                • 13. Re: PRE 9 Preview screen
                                  If no formats/CODEC's are displaying, the first thing that I look at is the graphics driver. Refresh my memory, but have you updated that from the mfgr's. Web site?
                                  • 14. Re: PRE 9 Preview screen
                                    bazlid50 Level 1
                                    I have a brand new Dell XPS laptop with Nvidia graphics card
                                    Sent: Sunday, January 09, 2011 9:18 PM
                                    To: Barry Graham
                                    • 15. Re: PRE 9 Preview screen
                                      I have a brand new Dell XPS laptop with Nvidia graphics card.
                                      If you have not updated your video card's driver, it is probably 6 mos. out of date. This would be the same with Dell, HP, Gateway, or any non-custom-built computer.
                                      Go to the nVidia Web site, plug in your card's model number, and your OS, and check.
                                      • 16. Re: PRE 9 Preview screen
                                        nealeh Level 5
                                        Another user had the identical problem. As Bill has already suggested, updating the graphics driver (and QuickTime while you are at it) should fix that for you. Don't forget to reboot after they are installed. Also check that you have the 9.0.1 update.
                                        Cheers,
                                        Neale
                                        • 17. Re: PRE 9 Preview screen
                                          bazlid50 Level 1
                                          Hi Neale,
                                          I’m pretty sure it’s not my graphics card etc. as this is the current situation:
                                          I can display any video clip in the monitor window but the only way I can get it to move is by dragging the red marker/line over the timeline.  If I just press the ‘play’ button nothing happens.
                                          I’m sure I’ve overlooked a setting somewhere.
                                          Many thanks
                                          Barry
                                          Sent: Monday, January 10, 2011 11:16 AM
                                          To: Barry Graham
                                          • 18. Re: PRE 9 Preview screen
                                            I am not ready to rule out the video display driver yet. What you report is a common issue with an obsolete video driver.
                                            What version (date/time) do you have installed?
                                            Also if you would restate your nVidia card model and your OS, that would be appreciated.
                                            Thanks, and good luck,
                                            • 19. Re: PRE 9 Preview screen
                                              bazlid50 Level 1
                                              Hi Hunt,
                                              Display driver
                                              INTEL(R) HD Graphics
                                              Version: 8.15.10.2182
                                              Date: 19th July 2010
                                              Informed that no update is available and it’s working properly
                                              Video Card
                                              NVIDIA GeForce GT 420M
                                              Version: 8.17.12.5939
                                              Date: 12th August 2010
                                              I am using Windows 7 Home Premium
                                              Regards
                                              Barry
                                              Sent: Monday, January 10, 2011 8:03 PM
                                              To: Barry Graham
                                              • 20. Re: PRE 9 Preview screen
                                                The nVidia site shows one released on 10/25/2010 for the 460 and Win7-32.
                                                • 21. Re: PRE 9 Preview screen
                                                  bazlid50 Level 1
                                                  Hi Hunt,
                                                  mine is a 420
                                                  Regards
                                                  Barry
                                                  Sent: Monday, January 10, 2011 9:03 PM
                                                  To: Barry Graham
                                                  The http://www.nvidia.com/object/notebook-win7-winvista-260.99-whql-driver.html shows one released on 10/25/2010 for the 460 and Win7-32.
                                                  • 22. Re: PRE 9 Preview screen
                                                    Yes, it was the 420M that I showed the driver for. There is also a notation that for Dell Inspirions, one should go to the Dell site. There are several links from the nVidia site/page to Dell, so you may very well have the latest one. Usually, Dell is pretty good at getting the nVidia drivers and then tweaking them, if necessary, and posting those.
                                                    Another consideration with failed playback is the source footage, and the Project Preset chosen. Last, if something like AVCHD, then the CPU's power becomes a concern.
                                                    • 23. Re: PRE 9 Preview screen
                                                      jeffgedgaud Level 1
                                                      Bazlid50 seems to be using a laptop,any identifier like M with a video card designates it a mobile for laptop. What is the specs of the laptop. If you are unsure how to get these right click the My Computer Icon and click on properties at the bottom of the menu. Pertinent information will be listed in the System box i.e. Processor, Installed RAM and Operating System.
                                                      • 24. Re: PRE 9 Preview screen
                                                        bazlid50 Level 1
                                                        see screen shot which gives the info you asked for
                                                        Sent: Monday, January 10, 2011 11:32 PM
                                                        To: Barry Graham
                                                        • 25. Re: PRE 9 Preview screen
                                                          bazlid50 Level 1
                                                          seems screen shot didn't show so here is the info:
                                                          DEll XPS L501X
                                                          Processor: Intel (R) Core 9TM) i5 CPU M460 @ 2.53GHz
                                                          Memory: 4.00GB (3.74 usable)
                                                          System Type: 64-bit Operating System
                                                          Is this the info you are after?
                                                          Cheers
                                                          Barry
                                                          • 26. Re: PRE 9 Preview screen
                                                            Yes, and the driver that I directed them to was for the nVidia 420 Mobile card, and for laptops.
                                                            Now knowing that the OS is Win7-64, here is the link to nVidia's latest driver for the 420M: http://www.nvidia.com/object/notebook-win7-winvista-64bit-260.99-whql-driver.html
                                                            • 27. Re: PRE 9 Preview screen
                                                              The above was a ms-type on my part. I now see why you questioned. The link was to the 420. The title of the nVidia page was in front of me, and says that it is for the Verde Lapotp 260. The six must have stuck in my feeble mind. Sorry about that - my bad!
                                                              • 28. Re: PRE 9 Preview screen
        bazlid50 Level 1
        Sorted at last!!!
        Many thanks for all your assistance.  Got on to Dell and, as some of you
        suspected, my NVidia graphics card needed updating.
        Another question.  I have been editing some MPEG footage shot on a
        Panasonic Camcorder and recorded on SD Card.  Whilst previewing the
        quality looks a bit poor.  Is this just the preview quality and do you
        think it will be fine when it's burned to DVD?
        Thanks again guys - much appreciated
        Barry
