5 Replies Latest reply on Dec 18, 2013 1:54 AM by fiona Lee
    Extending HTTPService breaks <mx:request> style variables
    slaingod Level 1
      This is probably something simple I am doing wrong, or lack of understanding, but I have seen the question asked and not answered elsewhere on the interwebs.
      I want to extend HTTPService to add a globally set static rootURL for when the SWF is hosted on a CDN:
      package com.something.shared.util
          import mx.rpc.http.mxml.HTTPService;
          public class StaticRootHTTPService extends HTTPService
              public static var staticRootURL:String;
              public function StaticRootHTTPService(rootURL:String=null, destination:String=null)
                  if((rootURL == null || rootURL == '') && staticRootURL != null && staticRootURL != '') {
                      rootURL = staticRootURL;
                  super(rootURL, destination);
      However when I do this, I can't seem to figure out what to do to get mxml style request definition working again:
          <util:StaticRootHTTPService id="models_edit"
              url="/{models}/{editingItem.id}.xml"
              useProxy="false" method="POST"
              fault="FlexGlobals.topLevelApplication.faultHandler(event);"
              result="saveHandler(event)" showBusyCursor="true"
              <util:request>
      //********* THESE BREAK ************
      // Could not resolve <_method> to a component implementation.
                  <_method>PUT</_method>
      // Could not resolve <company> to a component implementation.
                  <company>{model_name.text}</company>
      // Could not resolve <allowed_streams> to a component implementation.
                  <allowed_streams>{streams.value}</allowed_streams>
              </util:request>
          </util:StaticRootHTTPService>
      Any quick solution? Thanks.
        • 1. Re: Extending HTTPService breaks <mx:request> style variables
          saisri2k2 Level 4
          try this
          <components:request>
          <fx:XML>
          <contentType>
          e4x
          </contentType>
          </fx:XML>
          </components:request>
          each of the request type ahs to bee xml document, so, you have to enclose the name value pair in fx:Xml . hopefully it has to work.
          • 2. Re: Extending HTTPService breaks <mx:request> style variables
            slaingod Level 1
            It is not clear what you are trying to say. This is a Flex 4.1 SDK project using the Flex 3.5 compatibility mode. The 'fx' namespace is not something this project uses currently.
            My question is:
            When I use HTTPService directly,
                    <mx:request>
                    </mx:request>
            works as expected, but when I subclass HTTPService,
                    <util:request>
                    </util:request>
            does NOT work correctly.
            How can I get this to work as it does with HTTPService, when I have extended that class?
            Thanks.
            • 3. Re: Extending HTTPService breaks <mx:request> style variables
              Flex harUI Adobe Employee
              Try using -keep-generated-actionscript MXMLC option when just using
              HTTPService to see what it generates.  You may just need to specify an
              <mx:Object> wrapper or <mx:XML> wrapper around those params.
              • 4. Re: Extending HTTPService breaks <mx:request> style variables
                slaingod Level 1
                Ok, so I think I finally figured out the workaround, tho it requires a lot of hand editing lol.
                Both:
                        <util:request>
                            <mx:Object company="{testBinding}" _method="PUT"/>
                        </util:request>
                Or:
                        <util:request xmlns="">
                            <mx:Object>
                                <mx:company>{testBinding}</mx:company>
                                <mx:_method>PUT</mx:_method>
                            </mx:Object>
                        </util:request>
                Works.
                Thanks for the guidance.
                • 5. Re: Extending HTTPService breaks <mx:request> style variables
                  fiona Lee
                  I have the same question.
                  But I tried the second method and it doesn't work.
                  <base:request xmlns="">
                      <fx:Object>
                       <page>
                        {nowPage}
                       </page>
                      </fx:Object>
                     </base:request>
                  It doesn't works.
                      <fx:Object page="{nowPage}"/>
                     </base:request>
                  It works.
