• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
cffile author,comments and other attributes
Participant ,
Jul 09, 2007 Jul 09, 2007
I would like to upload the author name, comments and other data with the cffile action=upload. Anyone already solved this or has a way of doing this?
TOPICS
Advanced techniques
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Jul 11, 2007 Jul 11, 2007
Something like this:
<form action="next.cfm" method="post" enctype="multipart/form-data">
Author: <input type="Text" name="author"><br>
File: <input type="File" name="aFileName"><br>
<input type="Submit" value="ok">
</form>
Then on your processing page, you'll have access to all the form fields (including the file name that you can upload with cffile.
Votes
Translate
Translate
Report
Report
Participant ,
Jul 12, 2007 Jul 12, 2007
thank you so much for taking the time to help me out.
I am willing to know how to attach an author name in a cffile attribute.
Namely: when I use cffile in a cffunction such as:
<cffile action="upload" filefield="filedata" destination= "#destination#" nameconflict="makeunique" accept="application/octet-stream"/>
how can I hope to find a way of attaching attributes such as author and other attributes to the file being uploaded?
Votes
Translate
Translate
Report
Report
New Here ,
AFAIK you can not attach those attributes directly to a file.
Normal practice is to have a database table which has the data inserted for each file uploaded.
Votes
Translate
Translate
Report
Report
Participant ,
Jul 20, 2007 Jul 20, 2007
John
When I query the file object I have
Attributes
DateLastModified
Size
Type
Mode
Name
However you know that every file has a list of references in its properties in which you can see the
author name
commentary
and some more attribtutes attached.
How do I access these attributes is the question.
Since we can access them through a windows file explorer we should have these somewhere?
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 21, 2007 Jul 21, 2007
With which code?
Votes
Translate
Translate
Report
Report
Guide ,
I suspect they're using cfdirectory based on the list of attributes (DateLastModified, size, type, mode, name ...)
Votes
Translate
Translate
Report
Report
Guide ,
Not with CFFILE. Those are windows o/s extended file properties. Afaik, you'd need some sort of activeX control to access those properties.
Votes
Translate
Translate
Report
Report
Participant ,
Hi guys
cf_dev2 is correct. I use:
<cfdirectory directory="#presentdirectory#" name="subdirectoryQuery" sort="Name ASC" filter="*" recurse = "no">
Here I look at the type="file" only and have the attributes mentionned above.
How do you gentlemen think I can get the other attributes? I am far from a windows man and activex and stuff is chinese to me.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 22, 2007 Jul 22, 2007
Goingflex,
Neither cfdirectory nor cffile will be of any use here. One way to go is Apache POI - HPSF - Java API. I hope the following example works for you, too.
P.S.:
To download the Apache POI application, go to Apache POI mirror closest to you ( http://www.apache.org/dyn/closer.cgi/poi/release ). Open the bin directory and download the appropriate file for your operating system. For example, I am on Windows, so I downloaded poi-bin-3.0.1-FINAL-20070705.zip.
Extract the file and copy the directory poi-3.0.1-FINAL to {CF_INSTALL}/lib/thirdpartytools. For the usual Coldfusion installation of MX7 on Windows, {CF_INSTALL} is C:/CFusionMX7.
Restart Coldfusion.
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Hi BKBK
thanks for the time spent responding. I appreciate it very much.
I will take a look at it and try it out.
Regards and thanks to all who tried to help.
Votes
Translate
Translate
Report
Report
Resources
Documentation
