6 Replies Latest reply on Jan 13, 2011 5:28 AM by Dee McDee
    Need help with making the camera move with the mouse (FPS style)
    ollie111 Level 1
      First of all, I'm very new to Director.
      I'm doing a small project which is a game with a first person view and the player can click on objects to pick them up. That's the plan anyway.
      I have made a box to act as a character and made the arrow keys move it. Then I've positioned the camera 10 pixels(?) ahead of the character and made the camera a child of the character.
      I've also made the camera move with the mouse (with help from an old thread I found on here), but it's far from perfect. Here is the code for all of it:
      property pScene, pBox, pPlane, pCharacter, pCamera, xAn, yAn, pMouse
      on beginSprite me
        -- world variable
        pScene = member("3dworld")
        -- reset the world when done
        pScene.resetWorld()
        -- variable for the mouse location
        pMouse = the mouseLoc
        -- x and y angle variables
        xAn = 0
        yAn = 0
        -- run the create functions
        createBox(me)
        createPlane(me)
        createCharacter(me)
        createCamera(me)
      end
      on mouseDown
      end
      on exitFrame me
        -- character movement
        -- 125 = down arrow. Move forward
        if keyPressed(125) then pCharacter.translate(0,0,4.5)
        -- 126 = up arrow. Move backward
        if keyPressed(126) then pCharacter.translate(0,0,-4.5)
        -- 123 = left arrow. Move left
        if keyPressed(123) then pCharacter.translate(-1.5,0,0)
        -- 124 = right arrow. Move right
        if keyPressed(124) then pCharacter.translate(1.5,0,0)
        -- camera mouse movement
        dMouse = (pMouse - the mouseLoc) / 100.0
        dx = dMouse.locV*10 -- sensitivity
        dy = dMouse.locH*10 -- sensitivity
        xAn = xAn + dx
        yAn = yAn + dy
        if (xAn > 80) then
          xAn = 80
        end if
        if (xAn < -80) then
          xAn = -80
        end if
        yAnRad = yAn*pi/180.0
        xAnRad = xAn*pi/180.0
        lookAt = pCamera.transform.position+vector(50*sin(-yAnRad),50*tan(xAnRad),-50*cos(-yAnRad))
        pCamera.pointAt(lookAt)
      end if
      end
      on createBox me
        -- create a box resource
        boxResource = pScene.newModelResource("BoxResource",#box)
        boxResource.width = 10
        boxResource.height = 10
        boxResource.length = 10
        -- create new model
        pBox = pScene.newModel("Box",boxResource)
        -- assign a texture to all 6 faces
        --pScene.newtexture("box texture",#fromCastMember,member("texture-blue"))
        --pScene.newshader("box shader", #standard)
        --pScene.shader("box shader").texture = pScene.texture("box texture")
        --repeat with i = 1 to pBox.shaderList.count
        --pBox.shaderList[i] = pScene.shader("box shader")
        --end repeat
        -- position box
        pBox.translate(0,-35,0)
      end
      on createPlane me
        -- create a plane resource
        planeResource = pScene.newModelResource("PlaneResource",#plane)
        planeResource.length = 1000
        planeResource.width = 1000
        -- create new model
        pPlane = pScene.newModel("Plane",planeResource)
        -- position plane
        pPlane.translate(0,-40,0)
        -- rotate plane so it is parallel to ground
        pPlane.rotate(90,0,0)
      end
      on createCharacter me
        boxResource = pScene.newModelResource("Character",#box)
        -- create new model
        pCharacter = pScene.newModel("Character",boxResource)
        --end repeat
        -- position character
        pCharacter.translate(0,-15,205)
      end
      on createCamera me
        -- camera variable
        pCamera = member(1, 1).camera("DefaultView")
        -- camera properties
        pCamera.fieldOfView = 73.7389
        pCamera.projectionAngle = 73.7389
        pCamera.yon = 3.40282346638529e38
        pCamera.hither = 1.0000
        pCamera.rect = rect(0,0, 800,600)
        -- position camera
        --pCamera.transform.position = vector( 0.0000, -20.0000, 500.0000 )
        -- move to 10 infront of the character
        pCamera.transform.position = pCharacter.transform.position + vector(0,0,-10)
        -- lock camera relative to box
        pCharacter.addChild(pCamera)
      end
      Hopefully it is simple enough / commented enough to understand. Feel free to try it yourself.
      My immediate problem is this: When I move the mouse to the right, for example, the camera turns right, until a certain point where it starts going back to the left, even though I'm moving the mouse to the right.
      Any ideas what is causing that? The part of the code most relevant is the "camera mouse movement" between the on exitFrame part.
