0 Replies Latest reply on Jan 9, 2011 5:43 PM by Michael Ezra
    Mamiya ZD camera maker tags
    Michael Ezra Level 1
      Mamiya digital photo stuidio allows to see the following information extracted from MEF raw file:
      File Name                     : MMFC0998.MEF
      File Size                     : 34.88MB
      Format                        : Mamiya Raw Image
      Pixels                        : 5328x4000
      Shooting Date                 : 2008:08:08 12:46:25
      Edit Date                     : 2008:08:08 11:46:30
      Maker Name                    : Mamiya-OP Co.,Ltd.
      Model Name                    : MAMIYA ZD
      Exposure Time                 : 1/2000sec
      F-Stop Number                 : F6.3
      Exposure Program              : Aperture Priority
      ISO                           : 50
      Exif Version                  : ------
      Image Creation Date           : 2008:08:08 12:46:25
      Digital Data Creation Date    : 2008:08:08 12:46:25
      Shutter Speed                 : 1/2048sec
      Aperture Setting              : F6.3
      Exposure Compensation Setting : +0.3EV
      Light Metering Method         : Averaged Metering
      Flash                         : Flash Off
      Lens Focal Length             : 80.0mm
      Color Space Info.             : sRGB
      Effective Image Width         : ------
      Effective Image Height        : ------
      Focus Width Resolution        : ------
      Focus Height Resolution       : ------
      Focus Resolution Units        : ------
      Exposure Mode                 : Auto Exposure
      White Balance                 : Auto
      Exposure Mode                 : Aperture Priority
      Release Mode                  : Single Release
      Focus Mode                    : Single AF
      Bracketing                    : Off
      Mirror Up                     : Off
      ISO Sensitivity               : 50
      Compression Rate              : ------
      Quality                       : Set Individually
      Filter                        : IR Cut
      Rotation                      : Off
      Power Source                  : Battery
      Noise Reduction               : Disable
      WB Fine Adjustment            : 0
      Color Setting                 : Normal
      Tone Setting                  : Normal
      Sharpness                     : Off
      Index                         : 00000000000
      Serial Number                 : FF1049
      Camera Firmware               : 1.00
      Firmware                      : 1.03
      when MEF is converted to DNG (using version 6.3), camera maker's notes cannot be located in the exif of the DNG file.
      E.g. Serial Number, Camera Firmware, etc.
      Could you please point me where to find this in the DNG file, or, if this does not get saved, could such an enhancement be made?
      Thank you,
      Michael
