9 Replies Latest reply on Jan 15, 2011 10:19 PM by kglad
    How to make a simple login in AS2
    Harley Frank
      I am trying to make a login that allows the user to create an account and be able to access it at anytime. Like if I was going to go on to facebook I can login. Something like that except I want it in my swift and not like a php or whatever you call it now.
        • 1. Re: How to make a simple login in AS2
          you can't create anything secure without something outside the swf.
          • 2. Re: How to make a simple login in AS2
            Harley Frank Level 1
            really? not even if it is like a cookie? just like a login that is the swf and not linked to anything else.
            • 3. Re: How to make a simple login in AS2
              really.  all a cookie can do is to check if users are using the same login/password that they initially created.   that's actually a memory test for users and not a security item.
              without external files, the best you can do is to have the same login/password for everyone and that can be made semi-secure by using a hash algorithm.   you would have to communicate the login/password to your selected users outside of flash (eg, via email).
              • 4. Re: How to make a simple login in AS2
                ok if i wanted to make one globallly how would i go about doing so?
                • 5. Re: How to make a simple login in AS2
                  using the secure hash algorithm function is a bit of overkill for you app but it's so easy to use and fast there's no downside:
                  function SHA256(s){
                       var chrsz   = 8;
                       var hexcase = 0;
                       function safe_add (x, y) {
                            var lsw = (x & 0xFFFF) + (y & 0xFFFF);
                            var msw = (x >> 16) + (y >> 16) + (lsw >> 16);
                            return (msw << 16) | (lsw & 0xFFFF);
                       function S (X, n) { return ( X >>> n ) | (X << (32 - n)); }
                       function R (X, n) { return ( X >>> n ); }
                       function Ch(x, y, z) { return ((x & y) ^ ((~x) & z)); }
                       function Maj(x, y, z) { return ((x & y) ^ (x & z) ^ (y & z)); }
                       function Sigma0256(x) { return (S(x, 2) ^ S(x, 13) ^ S(x, 22)); }
                       function Sigma1256(x) { return (S(x, 6) ^ S(x, 11) ^ S(x, 25)); }
                       function Gamma0256(x) { return (S(x, 7) ^ S(x, 18) ^ R(x, 3)); }
                       function Gamma1256(x) { return (S(x, 17) ^ S(x, 19) ^ R(x, 10)); }
                       function core_sha256 (m, l) {
                            var K = new Array(0x428A2F98, 0x71374491, 0xB5C0FBCF, 0xE9B5DBA5, 0x3956C25B, 0x59F111F1, 0x923F82A4, 0xAB1C5ED5, 0xD807AA98, 0x12835B01, 0x243185BE, 0x550C7DC3, 0x72BE5D74, 0x80DEB1FE, 0x9BDC06A7, 0xC19BF174, 0xE49B69C1, 0xEFBE4786, 0xFC19DC6, 0x240CA1CC, 0x2DE92C6F, 0x4A7484AA, 0x5CB0A9DC, 0x76F988DA, 0x983E5152, 0xA831C66D, 0xB00327C8, 0xBF597FC7, 0xC6E00BF3, 0xD5A79147, 0x6CA6351, 0x14292967, 0x27B70A85, 0x2E1B2138, 0x4D2C6DFC, 0x53380D13, 0x650A7354, 0x766A0ABB, 0x81C2C92E, 0x92722C85, 0xA2BFE8A1, 0xA81A664B, 0xC24B8B70, 0xC76C51A3, 0xD192E819, 0xD6990624, 0xF40E3585, 0x106AA070, 0x19A4C116, 0x1E376C08, 0x2748774C, 0x34B0BCB5, 0x391C0CB3, 0x4ED8AA4A, 0x5B9CCA4F, 0x682E6FF3, 0x748F82EE, 0x78A5636F, 0x84C87814, 0x8CC70208, 0x90BEFFFA, 0xA4506CEB, 0xBEF9A3F7, 0xC67178F2);
                            var HASH = new Array(0x6A09E667, 0xBB67AE85, 0x3C6EF372, 0xA54FF53A, 0x510E527F, 0x9B05688C, 0x1F83D9AB, 0x5BE0CD19);
                            var W = new Array(64);
                            var a, b, c, d, e, f, g, h, i, j;
                            var T1, T2;
                            m[l >> 5] |= 0x80 << (24 - l % 32);
                            m[((l + 64 >> 9) << 4) + 15] = l;
                            for ( var i = 0; i<m.length; i+=16 ) {
                                 a = HASH[0];
                                 b = HASH[1];
                                 c = HASH[2];
                                 d = HASH[3];
                                 e = HASH[4];
                                 f = HASH[5];
                                 g = HASH[6];
                                 h = HASH[7];
                                 for ( var j = 0; j<64; j++) {
                                      if (j < 16) W[j] = m[j + i];
                                      else W[j] = safe_add(safe_add(safe_add(Gamma1256(W[j - 2]), W[j - 7]), Gamma0256(W[j - 15])), W[j - 16]);
                                      T1 = safe_add(safe_add(safe_add(safe_add(h, Sigma1256(e)), Ch(e, f, g)), K[j]), W[j]);
                                      T2 = safe_add(Sigma0256(a), Maj(a, b, c));
                                      h = g;
                                      g = f;
                                      f = e;
                                      e = safe_add(d, T1);
                                      d = c;
                                      c = b;
                                      b = a;
                                      a = safe_add(T1, T2);
                                 HASH[0] = safe_add(a, HASH[0]);
                                 HASH[1] = safe_add(b, HASH[1]);
                                 HASH[2] = safe_add(c, HASH[2]);
                                 HASH[3] = safe_add(d, HASH[3]);
                                 HASH[4] = safe_add(e, HASH[4]);
                                 HASH[5] = safe_add(f, HASH[5]);
                                 HASH[6] = safe_add(g, HASH[6]);
                                 HASH[7] = safe_add(h, HASH[7]);
                            return HASH;
                       function str2binb (str) {
                            var bin = Array();
                            var mask = (1 << chrsz) - 1;
                            for(var i = 0; i < str.length * chrsz; i += chrsz) {
                                 bin[i>>5] |= (str.charCodeAt(i / chrsz) & mask) << (24 - i%32);
                            return bin;
                       function Utf8Encode(string) {
                            var utftext = "";
                            for (var n = 0; n < string.length; n++) {
                                 var c = string.charCodeAt(n);
                                 if (c < 128) {
                                      utftext += String.fromCharCode(c);
                                 else if((c > 127) && (c < 2048)) {
                                      utftext += String.fromCharCode((c >> 6) | 192);
                                      utftext += String.fromCharCode((c & 63) | 128);
                                 else {
                                      utftext += String.fromCharCode((c >> 12) | 224);
                                      utftext += String.fromCharCode(((c >> 6) & 63) | 128);
                            return utftext;
                       function binb2hex (binarray) {
                            var hex_tab = hexcase ? "0123456789ABCDEF" : "0123456789abcdef";
                            var str = "";
                            for(var i = 0; i < binarray.length * 4; i++) {
                                 str += hex_tab.charAt((binarray[i>>2] >> ((3 - i%4)*8+4)) & 0xF) +
                                 hex_tab.charAt((binarray[i>>2] >> ((3 - i%4)*8  )) & 0xF);
                            return str;
                       s = Utf8Encode(s);
                       return binb2hex(core_sha256(str2binb(s), s.length * chrsz));
                  • 6. Re: How to make a simple login in AS2
                    Hi again,
                    This time I want to create an Actionscript 2 fla file for a login script deal thingy. I want it to be server side where a file is on the server and that holds login information and that can be updated i.e. new accounts, and accessed. I also want to be able to save other information to that file on the server, such as when they log out their stuff is saved (variables). How can I do that?
                    -Harley
                    • 7. Re: How to make a simple login in AS2
                      you should use a database.  does your server support a database?
                      • 8. Re: How to make a simple login in AS2
                        its a linksis web server so I am assuming so.... I put something similar to a database in there before and it worked.
                        • 9. Re: How to make a simple login in AS2
                          then use server-side scripting (eg, php) to communicate with your flash (using loadvars) and to communicate with your database.
