5 Replies Latest reply on Jan 10, 2011 9:10 AM by jfb00
    Convert Date stored in MYSQL to date flex can use
    djh88ukwb Level 1
      Hello All.
      I am trying to finish a simple log in script for a program i am working on.
      Its using amfphp to check a mysql database to ensure that the username and password that the user enters is in the database and flagged to allow them to log in,
      I have all this working fine.
      However the database also has a table named "Date" that contains a date in the format os DD/MM/YYYY  this date is generated by flex in a process earlier.   The field type for this date field is a varChar.
      My flex application also has a variable that contains the current Date. In the same format.
              <mx:DateFormatter id="DateDisplay"  formatString="DD/MM/YYYY"/>
                [Bindable] private var today:Date = new Date();
      and i have a label that displays it using the code below.
      DateDisplay.format(today)
      Now what i want to do is when the user clicks the log in button, in the result of the function that is run, i want to convert the date stored in the mysql table to a date variable so that i can compare it witht he actual date.   So that the user can not log in once the date has expired.
      The result function is as follows
      protected function qrycandidateLogin(event:ResultEvent):void
                      if(event.result.length > 0 && event.result[0].Taken =='Yes') {
                          Alert.show(LoginError,"Error");
                      else if (event.result.length > 0 )
                          viewstack1.selectedChild=welcome;
                          userArray = event.result as ArrayCollection;
                      else
                          Alert.show("Please consult an account admin.", "Login failed");
      So i need to add the code to the first "Else IF" statement.  to ensure that the date hasnt expired.
      If anyone can help that would be great !
      Dave
