9 Replies Latest reply on Jun 10, 2014 5:16 AM by s_ashok
    Help need for Package creation in same path
    siva k Level 1
      Hello everyone,
      I have script for package the file. It’s working good but I need package on the same path instead of on Destktop with file name.
      Like if artwork file xyz.idd in D:\ Projects\Today\
      I need same location (D:\ Projects\Today\) with folder name as file name (xyz)
      Can some one modify the code I have tried to modify but it’s not working.
      var to = new File("~/Desktop/package_folder/");
      var flag = Folder(to).create();
      var copyingFonts = true;
      var copyingLinkedGraphics = true;
      var copyingProfiles = true;
      var updatingGraphics = true;
      var includingHiddenLayers = true;
      var ignorePreflightErrors = true;
      var creatingReport = true;
      var versionComments = "comment";
      var forceSave = true;
      if ( flag === true){
          app.activeDocument.packageForPrint (
                to,
                copyingFonts,
                copyingLinkedGraphics,
                copyingProfiles,
                updatingGraphics,
                includingHiddenLayers,
                ignorePreflightErrors,
                creatingReport,
                versionComments,
                forceSave
      Thanks in Advance
      Regards,
      Siva
        • 1. Re: Help need for Package creation in same path
          Mi_D Level 3
          hi
          ADD this line and try
          var myDocument = app.activeDocument;
          var myFolder =myDocument.filePath;
          var to = new File(myFolder + "/" + "package_folder/");
          Mi_D
          • 2. Re: Help need for Package creation in same path
            siva k Level 1
            Hi
            I have tried your code it’s saying error can please post the whole code here, I am
            Not familiar with code
            regards,
            Siva
            • 3. Re: Help need for Package creation in same path
              Mi_D Level 3
                        to,
                        copyingFonts,
                        copyingProfiles,
                        updatingGraphics,
                        creatingReport,
                        versionComments,
                        forceSave
              Mi_D
              • 4. Re: Help need for Package creation in same path
                siva k Level 1
                Hello Mi_D,
                Thanks for your help script are working well. But I am requesting a small change in that. It’s creating every time folder name with “package_folder” instead of InDesign file name. I need package folder name with folder name. This modification will helps for optimization to my daily tasks.
                Ex: My InDesign file name is “Mi_D” the package folder name also “Mi_D” instead of “package_folder
                Thanks in Advance,
                Best regards,
                Siva
                • 5. Re: Help need for Package creation in same path
                  Mi_D Level 3
                  var myDocName = myDocument.name;
                  temp=myDocName.replace(/\.indd/g,"");
                  var myFileNme=temp.toString();
                  var to = new File(myFolder + "/" + myFileNme + "/");
                            to,
                            copyingFonts,
                            copyingProfiles,
                            updatingGraphics,
                            creatingReport,
                            versionComments,
                            forceSave
                  Mi_D
                  • 6. Re: Help need for Package creation in same path
                    siva k Level 1
                    Hello Mi_D,
                    Now your script working well exactly what I want many many many thanks for your help.
                    Best regards,
                    Siva
                    • 7. Re: Help need for Package creation in same path
                      s_ashok Level 1
                      Hi all,
                      In the same script i need to remove link folder and move all the links to the root folder.
                      Example:
                      Can some one help on these i have tried to modify i can't able to remove the link folder and move the links to the root folder.
                      var copyingFonts = false;
                      var creatingReport = false;
                                to,
                                copyingFonts,
                                copyingProfiles,
                                updatingGraphics,
                                creatingReport,
                                versionComments,
                                forceSave
                      • 8. Re: Help need for Package creation in same path
                        Mi_D Level 3
                        try below code
                                  to,
                                  copyingFonts,
                                  copyingProfiles,
                                  updatingGraphics,
                                  creatingReport,
                                  versionComments,
                                  forceSave
                        var moveLink=new Folder(to+"/"+"Links");
                        var myFiles = moveLink.getFiles( "*.*" );
                              for ( i = myFiles.length-1; i >= 0 ; i-- )
                                  var myResult = myFiles[i].copy(to+"/"+myFiles[i].name);
                                 (myFiles[i]).remove()
                        moveLink.remove();
                        Mi_D
                        • 9. Re: Help need for Package creation in same path
                          s_ashok Level 1
                          Your script is working fine
                          Thanks Mi_D for your fast help. Thanks a million.
                          Thank you!!!
