• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Does anyone know why....
Explorer ,
Jul 05, 2007 Jul 05, 2007
You can't put write query cells (<cfset temp = QuerySetCell) inside of <cfif> tags? Whenever I try it the code won't run. It just skips that portion completely.
Thanks in advance,
Anthony
TOPICS
Advanced techniques
Views
471
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
> Thanks in advance,
> Anthony
Can you show some code? I can not say I have ever tried this exact
concept. But I can't see why it would be a problem.
Votes
Translate
Translate
Report
Report
LEGEND ,
never had a problem with having querysetcell inside a cfif/cfelse block.
make sure:
a) your cfif condition validates to true so the code inside (the
querysetcell code) is executed
b) you are not forgetting the queryaddrow() part before querysetcell()
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Votes
Translate
Translate
Report
Report
LEGEND ,
quote:
Thanks in advance,
Anthony
When stuff like that happens to me, it is pretty much always because the condition of the cfif tag is not met.
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 06, 2007 Jul 06, 2007
The coditions of the cfif are being met. Other code within the tag is being executed. I actually populated an array inside in of same cfif tag.
Yes, I did the queryaddrow. The code works just fine outside of the cfif tag.
There is no fancy code. Just querysetcells inside of a cfif tag. The query is created outside of the cfif tag. This is not the first time I have encountered it. I wasn't looking for a solution. More of looking to see if anyone else has experienced this. Perhaps this is a bug/limitation in cold fusion.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
When I run this code (sisi is an oracle db),
<cfquery name="x" datasource="sisi">
select 'a' as aaa from dual
</cfquery>
<cfdump var="#x#">
<cfif true>
<cfset temp = QuerySetCell(x, "aaa", "b")>
</cfif>
<cfdump var="#x#">
I see a on the first dump and b on the second. What happens when you try it, or something similar if you don't use oracle?
Votes
Translate
Translate
Report
Report
Resources
Documentation
