3 Replies Latest reply on Jan 10, 2011 3:23 PM by kglad
    Developing a simple score counter
    Def Jeff
      Working on a simple score counter for my young son -- the idea is to simply add or subtract 1 digit to reveal the score. The variables only need to be 0-9 in each column. Can someone advise on how to make this work correctly?
      The animation was developed using a root.xxxx +1 or -1. It does the trick but as you can see, it keeps going into the double digits in each column.
      Any help is much appreciated and my 7 YO will be thrilled. He personally does not care about the code glitch -- but his perfectionist Dad does
      Thanks for any help that can be given.
      SWF: http://www.mymedel.com/flash/yugioh_score.swf
      FLA: http://www.mymedel.com/flash/score_final.fla
      Jeff
        • 1. Re: Developing a simple score counter
          check each column's counter to see when it exceeds 9 or is less than 0.   when either of those occur update the current column and the column to the left or right as needed.
          • 2. Re: Developing a simple score counter
            Def Jeff Level 1
            Thanks so much for the quick reply. Unfortunately, my knowledge of AS is very limited. I found a sample code and tailored it for this use, but unable to modify it according to your suggestions. Where do I add the variable for these buttons?
            For each [ + ] button:
            on (release) {
                _root.thou = _root.thou + 1;
            with "thou", being "hun", "ten", and "one" respective to each column.
            For each { - } button:
            on (release) {
                 _root.thou = _root.thou i 1;
            in a separate frame on the timeline:
            thou = 8; hun = 0; ten = 0; one = 0;
            thou2 = 8; hun2 = 0; ten2 = 0; one2 = 0
            to make the number start at 8000 for each score
            How do I keep the numbers to stay in the range from 0-9?
            It is easier to just shift the numbers to the right score instead of making this add up as there are different points awarded. Thanks for all of your help.
            • 3. Re: Developing a simple score counter
              you would use something like:
              // thou plus
              on (release) {
                  _root.hundreds = _root.hundreds + 1;
              if(_root.hundreds==10){
              _root.hundreds=0;
              _root.thousands++;
              // thou minus
              on (release) {
                   _root.hundreds = _root.hundreds - 1;
              if(_root.hundreds==-1){
              _root.hundreds=0;
              _root.tens++;
