5 Replies Latest reply on Jan 11, 2011 11:17 AM by Harm Millaard
    will this build run Ppro CS5 well?
    johnmanchester
      guys, hope you can help me with this, im looking at buying a new PC mostly to edit HD in CS5, does this build look like it could handle this task well?
      cheers
      Processor
      DescriptionIntel Core i5 2400 - With Integrated Graphics
      Architecture FeaturesIntegrated Intel Graphics
      Cache8MB
      Clockspeed3.1GHz
      ManufacturerIntel
      Memory
      Description2 x 2GB DDR3 1333Mhz
      Speed1333Mhz
      Harddrive
      Description1TB 3.5" 7200rpm SATA Hard Drive
      InterfaceSATA
      Case
      DescriptionNovatech ATX Gaming Case
      ColourBlack & Silver
      Dimensions200(w) x 440(d) x 430(h)mm
      Drive Bays 3 1/2"6
      Drive Bays 5 1/4"4
      Optical Drives
      Description22x DVD Writer
      InterfaceSATA
      Power Supply
      DescriptionNovatech PowerStation Gaming 400W Silent ATX2 Modular Power Supply
      Wattage / Rating400W
      Motherboard
      DescriptionIntel H67 Chipset Motherboard
      Form FactoruATX form factor (9.6" x 8.8")
      CPU SupportSupports LGA 1155 for Intel Sandybridge processors
      ChipsetIntel H67 Chipset
      AudioSupports 5.1 channel HD Audio
      IO1 x PS/2 keyboard port
      1 x VGA port
      1 x DVI port
      1 x Audio jack supports 3 jacks
      1 x RJ45 LAN port
      6 x USB 2.0 ports
      LANGigabit LAN
      Socket Type1155
      USBSupports up to 12 USB 2.0 ports (Rear panel x6, pin header x3 support 6 ports)
      RAIDSupports SATA RAID 0, 1, 0+1, 5
      SATA Ports6 ( 2 x 6.0Gb/s / 4 x 3.0Gb/s)
      PCI2 PCIe x1 slots
      PCI-EX2 PCIe2.0 x16 slots(1x16,1x4)
      Memory Slots4
      Max Memory Capacity16GB
