0 Replies Latest reply on Jan 10, 2011 7:06 PM by Digitalfixx
    HELP: Catalyst crashes constantly
    Digitalfixx
      I've been using Catalyst on a project but it constantly crashes on me. I don't think its my computer because someone tried to open it on another machine and it wouldn't even open.
      I have reinstalled the entire CS5 suite and all of the programs work fine except Catalyst.
      I don't know how to read an error log. Can someone please take a look and tell me what is going on?
      I can email the file in question to anyone willing to take a look.
      Thanks in advance.
      Process:         Adobe Flash Catalyst CS5 [219]
      Path:            /Applications/Adobe Flash Catalyst CS5/Adobe Flash Catalyst CS5.app/Contents/MacOS/Adobe Flash Catalyst CS5
      Identifier:      com.adobe.thermo
      Version:         1.0.0.273393 (1.0.0.273393)
      Code Type:       X86 (Native)
      Parent Process:  launchd [77]
      Interval Since Last Report:          2142056 sec
      Crashes Since Last Report:           6
      Per-App Interval Since Last Report:  342640 sec
      Per-App Crashes Since Last Report:   42
      Date/Time:       2011-01-10 20:07:20.175 -0500
      OS Version:      Mac OS X 10.5.8 (9L31a)
      Report Version:  6
      Anonymous UUID:  81B418C8-DE41-4C7E-B44A-0493A48FA33C
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000000000d4
      Crashed Thread:  0
      Application Specific Information:
      Java information:
      Version: Java HotSpot(TM) Client VM (1.5.0_26-156 mixed mode)
      Virtual Machine version: Java HotSpot(TM) Client VM (1.5.0_26-156) for macosx-x86, built on Oct 18 2010 11:25:10 by root with gcc 4.0.1 (Apple Inc. build 5465)
      Exception type: Bus Error (0xa) at pc=0x51d7018e
      Current thread (0x14301540):  JavaThread "main" [_thread_in_native, id=-1600907488]
      Stack: [0xbf800000,0xc0000000)
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      J  org.eclipse.swt.internal.carbon.OS.CFRunLoopRunInMode(IDZ)I
      J  org.eclipse.swt.widgets.Display.sleep()Z
      J  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptio nHandler;Lorg/eclipse/swt/widgets/Display;)V
      v  ~OSRAdapter
      j  org.eclipse.ui.internal.Workbench.runUI()I+393
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+23
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.thermo.application.ThermoApplication.start(Lorg/eclipse/equinox/app/IApplicatio nContext;)Ljava/lang/Object;+250
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      v  ~StubRoutines::call_stub
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      Java Threads: ( => current thread )
        0x1439f780 JavaThread "Code Model Worker" [_thread_blocked, id=1807666688]
        0x1439f120 JavaThread "Code Model Worker" [_thread_blocked, id=1510159360]
        0x143916e0 JavaThread "Thread-17" [_thread_in_native, id=1513761280]
        0x14342d50 JavaThread "Worker-2" [_thread_blocked, id=14327808]
        0x1433f510 JavaThread "AWT-Shutdown" [_thread_blocked, id=16428544]
        0x1433b1e0 JavaThread "Thread-7" [_thread_blocked, id=14368768]
        0x1432c7b0 JavaThread "Worker-1" [_thread_blocked, id=13891072]
        0x1432c380 JavaThread "Thread-1" [_thread_in_native, id=13863936]
        0x14312dd0 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=9047552]
        0x14312a90 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=8922112]
        0x14309060 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8653312]
        0x143085b0 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8649728]
        0x143080a0 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8643072]
        0x143077d0 JavaThread "Finalizer" daemon [_thread_blocked, id=8639488]
        0x143073f0 JavaThread "Reference Handler" daemon [_thread_blocked, id=8633344]
      =>0x14301540 JavaThread "main" [_thread_in_native, id=-1600907488]
      Other Threads:
        0x14306b00 VMThread [id=8629760]
        0x14309c40 WatcherThread [id=8656896]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 36288K, used 19238K [0x18a20000, 0x1b180000, 0x1b180000)
        eden space 32256K,  58% used [0x18a20000, 0x19c71fa0, 0x1a9a0000)
        from space 4032K,  11% used [0x1a9a0000, 0x1aa178a8, 0x1ad90000)
        to   space 4032K,   0% used [0x1ad90000, 0x1ad90000, 0x1b180000)
      tenured generation   total 483968K, used 71205K [0x1b180000, 0x38a20000, 0x38a20000)
         the space 483968K,  14% used [0x1b180000, 0x1f709708, 0x1f709800, 0x38a20000)
      compacting perm gen  total 65536K, used 37171K [0x38a20000, 0x3ca20000, 0x48a20000)
         the space 65536K,  56% used [0x38a20000, 0x3ae6cc70, 0x3ae6ce00, 0x3ca20000)
      No shared spaces configured.
      Virtual Machine arguments:
      JVM args: -Xdock:icon=../Resources/fc_app.icns -Xdock:name=Flash Catalyst -XstartOnFirstThread -Xms512m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Dorg.eclipse.swt.internal.carbon.smallFonts -Dorg.eclipse.swt.internal.carbon.noFocusRing
      Java command: <unknown>
      launcher type: generic
      Thread 0 Crashed:
      0   com.adobe.adobeswfl               0x51d7018e APXGetHostAPI + 3277566
      1   com.adobe.adobeswfl               0x51aa2911 APXGetHostAPI + 338561
      2   com.adobe.adobeswfl               0x51aa625c APXGetHostAPI + 353228
      3   com.adobe.adobeswfl               0x51e57b27 APXGetHostAPI + 4226199
      4   com.adobe.adobeswfl               0x51d865b6 APXGetHostAPI + 3368742
      5   com.adobe.adobeswfl               0x51e6be92 APXGetHostAPI + 4308994
      6   com.adobe.adobeswfl               0x51e6c3a4 APXGetHostAPI + 4310292
      7   com.adobe.adobeswfl               0x51ebb448 SWFLPlayer_Initialize + 8568
      8   com.apple.CoreFoundation          0x930503c5 CFRunLoopRunSpecific + 3141
      9   com.apple.CoreFoundation          0x93050aa8 CFRunLoopRunInMode + 88
      10  libswt-pi-carbon-3449.jnilib      0x4f8f053d Java_org_eclipse_swt_internal_carbon_OS_CFRunLoopRunInMode + 61
      11  ???                               0x1703be5f 0 + 386121311
      12  ???                               0x170d89f0 0 + 386763248
      13  ???                               0x170d1f18 0 + 386735896
      14  ???                               0x16a8e980 0 + 380168576
      15  ???                               0x16a159d3 0 + 379673043
      16  ???                               0x16a15a7f 0 + 379673215
      17  ???                               0x16a15a7f 0 + 379673215
      18  ???                               0x16a15cd9 0 + 379673817
      19  ???                               0x16a159d3 0 + 379673043
      20  ???                               0x16a15a7f 0 + 379673215
      21  ???                               0x16a15a7f 0 + 379673215
      22  ???                               0x16a15db0 0 + 379674032
      23  ???                               0x16a15db0 0 + 379674032
      24  ???                               0x16a15aaa 0 + 379673258
      25  ???                               0x16a15aaa 0 + 379673258
      26  ???                               0x16a15aaa 0 + 379673258
      27  ???                               0x16a13227 0 + 379662887
      28  libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      29  libjvm.dylib                      0x13eeb436 0x13e73000 + 492598
      30  libjvm.dylib                      0x13efd911 0x13e73000 + 567569
      31  libjvm.dylib                      0x13f288cf 0x13e73000 + 743631
      32  libjvm.dylib                      0x140bfdab JVM_InvokeMethod + 411
      33  ???                               0x16a1b9b1 0 + 379697585
      34  ???                               0x16a15aaa 0 + 379673258
      35  ???                               0x16a15aaa 0 + 379673258
      36  ???                               0x16a15db0 0 + 379674032
      37  ???                               0x16a15aaa 0 + 379673258
      38  ???                               0x16a159d3 0 + 379673043
      39  ???                               0x16a159d3 0 + 379673043
      40  ???                               0x16a13227 0 + 379662887
      41  libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      42  libjvm.dylib                      0x13eeb436 0x13e73000 + 492598
      43  libjvm.dylib                      0x13ef6d8c 0x13e73000 + 540044
      44  libjvm.dylib                      0x14078a2a JNI_CreateJavaVM_Impl + 102186
      45  eclipse_1117.so                   0x00018473 startJavaJNI + 1725
      46  eclipse_1117.so                   0x00016e81 startJavaVM + 382
      47  eclipse_1117.so                   0x00015ef0 run + 4742
      48  com.adobe.thermo                  0x0000218e original_main + 1782
      49  com.adobe.thermo                  0x0000287a main + 1517
      50  com.adobe.thermo                  0x000018e2 start + 54
      Thread 1:
      0   libSystem.B.dylib                 0x97c05266 mach_msg_trap + 10
      1   libSystem.B.dylib                 0x97c0ca5c mach_msg + 72
      2   libSystem.B.dylib                 0x97c7a12f mach_msg_server + 491
      3   libjvm.dylib                      0x13e7fde5 0x13e73000 + 52709
      4   libjvm.dylib                      0x13e7fc25 0x13e73000 + 52261
      5   libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      6   libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 2:
      2   libjvm.dylib                      0x13eea083 0x13e73000 + 487555
      3   libjvm.dylib                      0x13ee9f1c 0x13e73000 + 487196
      4   libjvm.dylib                      0x13eea70d 0x13e73000 + 489229
      5   libjvm.dylib                      0x13eea297 0x13e73000 + 488087
      6   libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      7   libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 3:
      2   libjvm.dylib                      0x13eea13a 0x13e73000 + 487738
      3   libjvm.dylib                      0x13ef5d0a 0x13e73000 + 535818
      4   libjvm.dylib                      0x13ef5305 0x13e73000 + 533253
      5   libjvm.dylib                      0x140a8761 JVM_MonitorWait + 465
      6   ???                               0x16b44859 0 + 380913753
      7   ???                               0x16ac24cc 0 + 380380364
      8   ???                               0x16a87dc0 0 + 380140992
      10  ???                               0x16a13227 0 + 379662887
      11  libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      12  libjvm.dylib                      0x13ef4fe3 0x13e73000 + 532451
      13  libjvm.dylib                      0x13ef4ed5 0x13e73000 + 532181
      14  libjvm.dylib                      0x13ef4e15 0x13e73000 + 531989
      15  libjvm.dylib                      0x13ef4d38 0x13e73000 + 531768
      16  libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      17  libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 4:
      7   ???                               0x16b24b44 0 + 380783428
      8   ???                               0x16b2490c 0 + 380782860
      9   ???                               0x16a87dc0 0 + 380140992
      10  ???                               0x16a15aaa 0 + 379673258
      11  ???                               0x16a13227 0 + 379662887
      12  libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      13  libjvm.dylib                      0x13ef4fe3 0x13e73000 + 532451
      14  libjvm.dylib                      0x13ef4ed5 0x13e73000 + 532181
      15  libjvm.dylib                      0x13ef4e15 0x13e73000 + 531989
      16  libjvm.dylib                      0x13ef4d38 0x13e73000 + 531768
      17  libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      18  libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 5:
      0   libSystem.B.dylib                 0x97c052a2 semaphore_wait_trap + 10
      1   libjvm.dylib                      0x13f01ade 0x13e73000 + 584414
      2   libjvm.dylib                      0x13f01685 0x13e73000 + 583301
      3   libjvm.dylib                      0x13ef4d38 0x13e73000 + 531768
      4   libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      5   libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 6:
      3   libjvm.dylib                      0x13ee9dd9 0x13e73000 + 486873
      4   libjvm.dylib                      0x13f028fb 0x13e73000 + 588027
      5   libjvm.dylib                      0x13f020e8 0x13e73000 + 585960
      Thread 7:
      4   libjvm.dylib                      0x13f02c50 0x13e73000 + 588880
      Thread 8:
      3   libjvm.dylib                      0x13f570df 0x13e73000 + 934111
      4   libjvm.dylib                      0x13f56c2a 0x13e73000 + 932906
      Thread 9:
      Thread 10:
      6   ???                               0x16a1b9b1 0 + 379697585
      7   ???                               0x16a159d3 0 + 379673043
      9   ???                               0x16a15aaa 0 + 379673258
      Thread 11:
      0   libSystem.B.dylib                 0x97c0c44e __semwait_signal + 10
      1   libBridgeTalk.jnilib              0x4fe23d8b ScObjects::Thread::sleep(unsigned int) + 59
      2   libBridgeTalk.jnilib              0x4fe1df33 ScObjects::BridgeTalkThread::run() + 163
      3   libBridgeTalk.jnilib              0x4fe23e98 ScObjects::Thread::go(void*) + 168
      4   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      5   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 12:
      1   libBridgeTalk.jnilib              0x4fe059fb mysleep(unsigned long) + 59
      2   libBridgeTalk.jnilib              0x4fe063ac Java_com_adobe_flexide_nativelibs_BridgeTalk_WaitForMessages + 124
      4   ???                               0x16a159d3 0 + 379673043
      5   ???                               0x16a13227 0 + 379662887
      6   libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      7   libjvm.dylib                      0x13ef4fe3 0x13e73000 + 532451
      8   libjvm.dylib                      0x13ef4ed5 0x13e73000 + 532181
      9   libjvm.dylib                      0x13ef4e15 0x13e73000 + 531989
      10  libjvm.dylib                      0x13ef4d38 0x13e73000 + 531768
      11  libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      12  libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 13:
      8   ???                               0x16b5edfc 0 + 381021692
      Thread 14:
      0   libSystem.B.dylib                 0x97c052ae semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib                 0x97c372c6 _pthread_cond_wait + 1267
      2   libSystem.B.dylib                 0x97c7c539 pthread_cond_wait + 48
      3   com.adobe.amt.services            0x50125126 AMTConditionLock::LockWhenCondition(int) + 46
      4   com.adobe.amt.services            0x5011ddb0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
      5   com.adobe.amt.services            0x5012518c AMTThread::Worker(void*) + 24
      6   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      7   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 15:
      3   libjvm.dylib                      0x13f56f39 0x13e73000 + 933689
      4   libjvm.dylib                      0x140b7c21 JVM_Sleep + 481
      5   ???                               0x16a1b9b1 0 + 379697585
      6   ???                               0x16a159d3 0 + 379673043
      7   ???                               0x16a15cd9 0 + 379673817
      8   ???                               0x16a13227 0 + 379662887
      9   libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      10  libjvm.dylib                      0x13ef4fe3 0x13e73000 + 532451
      11  libjvm.dylib                      0x13ef4ed5 0x13e73000 + 532181
      12  libjvm.dylib                      0x13ef4e15 0x13e73000 + 531989
      13  libjvm.dylib                      0x13ef4d38 0x13e73000 + 531768
      14  libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      15  libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 16:
      3   com.adobe.adobeswfl               0x51cc2d5f APXGetHostAPI + 2567887
      4   com.adobe.adobeswfl               0x51a641ef APXGetHostAPI + 82783
      5   com.adobe.adobeswfl               0x51cc2e4c APXGetHostAPI + 2568124
      6   com.adobe.adobeswfl               0x51cc2eb7 APXGetHostAPI + 2568231
      7   com.adobe.adobeswfl               0x51cc2f9b APXGetHostAPI + 2568459
      8   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      9   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 17:
      Thread 18:
      Thread 19:
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      Thread 24:
      2   com.apple.CoreFoundation          0x9304fe7e CFRunLoopRunSpecific + 1790
      3   com.apple.CoreFoundation          0x93050aa8 CFRunLoopRunInMode + 88
      4   com.apple.audio.CoreAudio         0x931775f8 HALRunLoop::OwnThread(void*) + 160
      5   com.apple.audio.CoreAudio         0x93177480 CAPThread::Entry(CAPThread*) + 96
      Thread 25:
      0   libSystem.B.dylib                 0x97c052c6 semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib                 0x97c372af _pthread_cond_wait + 1244
      2   libSystem.B.dylib                 0x97c38b33 pthread_cond_timedwait_relative_np + 47
      3   com.adobe.adobeswfl               0x51cc2d27 APXGetHostAPI + 2567831
      4   com.adobe.adobeswfl               0x51e380d8 APXGetHostAPI + 4096584
      Thread 26:
      4   com.adobe.adobeswfl               0x51cdd6de APXGetHostAPI + 2676814
      Thread 27:
      1   libSystem.B.dylib                 0x97c36dcd pthread_cond_wait$UNIX2003 + 73
      2   ...ple.CoreServices.CarbonCore    0x96845de3 TSWaitOnCondition + 126
      3   ...ple.CoreServices.CarbonCore    0x96824c36 TSWaitOnConditionTimedRelative + 202
      4   ...ple.CoreServices.CarbonCore    0x96845a60 MPWaitOnQueue + 208
      5   AdobeACE                          0x548a26f1 0x54868000 + 239345
      6   AdobeACE                          0x548a20ed 0x54868000 + 237805
      7   ...ple.CoreServices.CarbonCore    0x96843fbb PrivateMPEntryPoint + 56
      Thread 28:
      Thread 29:
      Thread 30:
      Thread 31:
      Thread 32:
      Thread 33:
      Thread 34:
      7   ???                               0x1703dbb4 0 + 386128820
      8   ???                               0x16a8e980 0 + 380168576
      9   ???                               0x16a15cd9 0 + 379673817
      Thread 35:
      4   com.apple.CFNetwork               0x97dcc18c CFURLCacheWorkerThread(void*) + 388
      5   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      6   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 36:
      4   com.apple.Foundation              0x97178520 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 320
      5   com.apple.Foundation              0x97114dfd -[NSThread main] + 45
      6   com.apple.Foundation              0x971149a4 __NSThread__main__ + 308
      7   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      8   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 37:
      0   libSystem.B.dylib                 0x97c546fa select$DARWIN_EXTSN + 10
      1   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      2   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 38:
      Thread 39:
      2   libGLProgrammability.dylib        0x91650b32 glvmDoWork + 162
      3   libSystem.B.dylib                 0x97c36155 _pthread_start + 321
      4   libSystem.B.dylib                 0x97c36012 thread_start + 34
      Thread 40:
      Thread 41:
      Thread 42:
      2   com.apple.ColorSync               0x946b33f8 pthreadSemaphoreWait(t_pthreadSemaphore*) + 42
      3   com.apple.ColorSync               0x946c5d4e CMMConvTask(void*) + 54
      Thread 43:
      Thread 44:
      Thread 45:
      Thread 46:
      Thread 47:
      Thread 48:
      Thread 49:
      0   libSystem.B.dylib                 0x97c359c6 kevent + 10
      1   ???                               0x16a1b9b1 0 + 379697585
      2   ???                               0x16a15a7f 0 + 379673215
      3   ???                               0x16a15a7f 0 + 379673215
      4   ???                               0x16a15a7f 0 + 379673215
      5   ???                               0x16a15a7f 0 + 379673215
      Thread 50:
      3   libjvm.dylib                      0x1412d8f7 JVM_RaiseSignal + 438439
      4   libjvm.dylib                      0x141887b7 JVM_RaiseSignal + 810855
      9   ???                               0x16a15db0 0 + 379674032
      11  ???                               0x16a15cd9 0 + 379673817
      12  ???                               0x16a13227 0 + 379662887
      13  libjvm.dylib                      0x13eeb71a 0x13e73000 + 493338
      14  libjvm.dylib                      0x13ef4fe3 0x13e73000 + 532451
      15  libjvm.dylib                      0x13ef4ed5 0x13e73000 + 532181
      16  libjvm.dylib                      0x13ef4e15 0x13e73000 + 531989
      17  libjvm.dylib                      0x13ef4d38 0x13e73000 + 531768
      18  libjvm.dylib                      0x14136f11 JVM_RaiseSignal + 476865
      19  libSystem.B.dylib                 0x97c81200 _pthread_body + 27
      Thread 51:
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000000  ebx: 0x51d6f156  ecx: 0x6556f838  edx: 0x6557109c
        edi: 0x65571040  esi: 0x00000000  ebp: 0xbfffd688  esp: 0xbfffd5e0
         ss: 0x0000001f  efl: 0x00010282  eip: 0x51d7018e   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x000000d4
      Binary Images:
          0x1000 -     0x3fff +com.adobe.thermo 1.0.0.273393 (1.0.0.273393) <46de9f3a6dc7b864b60adcf332bab5a4> /Applications/Adobe Flash Catalyst CS5/Adobe Flash Catalyst CS5.app/Contents/MacOS/Adobe Flash Catalyst CS5
         0x13000 -    0x1bffe +eclipse_1117.so ??? (???) <5f5fe7eae629f1166e09eb5430af7f6e> /Applications/Adobe Flash Catalyst CS5/plugins/org.eclipse.equinox.launcher.carbon.macosx_1.0.100.v20080509-1800/eclipse_111 7.so
         0xa5000 -    0xa6ff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
         0xb4000 -    0xb4fff +SPBasic ??? (???) <5d1760d8c910c6410bc9cf74a1a5190d> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/SPBasic.framework/Versio ns/A/SPBasic
         0xcf000 -    0xd7ffe  com.apple.JavaVM 12.7.0 (12.7.0) <d9cf554378c7cafa431ea651c476fb80> /System/Library/Frameworks/JavaVM.framework/JavaVM
         0xf1000 -    0xf8fe0  libverify.dylib ??? (???) <285ad3d0df893e1c981708f6246f1c7e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libverify.dylib
        0x79b000 -   0x7a2fff  JavaNativeFoundation ??? (???) <a769fd73cb622057a89b69d44730df81> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
        0x7ad000 -   0x7c7fef  libjava.jnilib ??? (???) <183f7ad1fcd2c930739d92c22956d6a1> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjava.jnilib
        0x7d7000 -   0x7e2ffb  libzip.jnilib ??? (???) <cf7880a3066b501a32be8731da97a50d> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libzip.jnilib
      0x13e73000 - 0x141c5fe3  libjvm.dylib ??? (???) <e9c4219856dd32836bbfdbf6e0cf385e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/bundle/Libraries/libjvm.d ylib
      0x4a929000 - 0x4a92cff7 +libEmbeddedPlayerJNILib.jnilib ??? (???) <8af3001eef311a6ec94249bf66e876f1> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.embeddedplayer_1.0.0.273393/os/macosx/x86/libEmbeddedPlayer JNILib.jnilib
      0x4a932000 - 0x4a932fff +liblocalfile_1_0_0.jnilib ??? (???) /Users/NewUser/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/94/1/.cp/os/macosx/liblocalfile_1_0_0.jni lib
      0x4acb3000 - 0x4acb6ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <ffddab7a220f7344f12b010ca0c41dab> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.embeddedplayer_1.0.0.273393/os/macosx/owl/adbeape.framework /Versions/A/adbeape
      0x4b31b000 - 0x4b326ffb  libnet.jnilib ??? (???) <6cec9b22cc117b105476cbcb7151096a> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnet.jnilib
      0x4b32d000 - 0x4b330ffc  libnio.jnilib ??? (???) <bd3ff475f5d7d3f46ad142a62697b85d> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnio.jnilib
      0x4f8e5000 - 0x4f8e7ff7 +libswt-carbon-3449.jnilib ??? (???) <696a09df02b06fb7680ab307a11c3846> /Users/NewUser/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/206/1/.cp/libswt-carbon-3449.jnilib
      0x4f8ec000 - 0x4f922ff7 +libswt-pi-carbon-3449.jnilib ??? (???) <a0f09b13f884f8aa46a8ebf0a4de941f> /Users/NewUser/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/206/1/.cp/libswt-pi-carbon-3449.jnilib
      0x4fe04000 - 0x4fe43ffb +libBridgeTalk.jnilib ??? (???) <14711af1e7c3a69a42793f802d34705f> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libBridgeTalk.jnilib
      0x4fe65000 - 0x4fed5feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115bedc72f9c42d374196e83ec2> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/adobe_caps.framework/ado be_caps
      0x4ff05000 - 0x4ff07fff +libAMT_JNILib.jnilib ??? (???) <048b3f3c85c5483ab3f5a6cfc6a1d236> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/x86/libAMT_JNILib.jnilib
      0x4ff0d000 - 0x4ff73ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <dd47101191201bc2f1b5d6ff09d0859f> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/amtlib.framework/Vers ions/A/amtlib
      0x4ffc0000 - 0x4ffc3ff7 +libswt-cocoa-carbon-3449.jnilib ??? (???) <5bb65e1528405c78f72ee1fa1b27948a> /Users/NewUser/Library/Application Support/Adobe/Flash Catalyst/configuration/org.eclipse.osgi/bundles/206/1/.cp/libswt-cocoa-carbon-3449.jnilib
      0x50100000 - 0x50167fea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <ee468e2ca6bde2ee7abe69168b143b44> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/amtservices.framework /Versions/A/amtservices
      0x5022c000 - 0x5022ffff  com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <51c811377017028f8904ad779e6a1344> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x50236000 - 0x502a6feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115bedc72f9c42d374196e83ec2> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/adobe_caps.framework/ Versions/A/adobe_caps
      0x502b4000 - 0x502bcfff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195b5c2c67d841232c74fcab79d304> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/asneu.framework/Versi ons/A/asneu
      0x502ef000 - 0x50328ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <c64ccbdcb8e945e853e78577cfe9f2f0> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.amt_1.0.0.273393/os/macosx/Frameworks/UpdaterNotifications. framework/Versions/A/UpdaterNotifications
      0x50393000 - 0x503a5fff +com.adobe.pip ??? (5.0.0.2021) <5251926bc2c0282cb3a994a9fef0fcb8> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePIP.framework/Adobe PIP
      0x50443000 - 0x5045fff7  GLRendererFloat ??? (???) <7badea5e2b8167c0e6391623bb46140a> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
      0x519e7000 - 0x51a10feb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <e0f7666b921dc4d663b3e8b445d26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x51a20000 - 0x52839fc3 +com.adobe.adobeswfl ??? (2.0.0.7489) <c954ca649b28a7fae391c1c6524f1639> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
      0x52bf9000 - 0x52bfffff  com.apple.audio.AppleHDAHALPlugIn 1.7.1 (1.7.1a2) <a0a4389b5ac52ab84397d2b25c9d3b9c> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x52c16000 - 0x52c1bfff +libHeadlights.jnilib ??? (???) <b05a37be02232032623c831b48fc6125> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libHeadlights.jnilib
      0x52c20000 - 0x52c21fe1  com.apple.textencoding.unicode 2.2 (2.2) <542f2b8930d6bdf16c318ffea541acab> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x531c6000 - 0x531d4feb  libSimplifiedChineseConverter.dylib ??? (???) <68f130a585c3f580d166ef7cbbf47e69> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x53e5d000 - 0x53e6ffff  libTraditionalChineseConverter.dylib ??? (???) <6108541a452ff07d2f67db4a488b9d22> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x542d3000 - 0x542eefff +AdobeBIB ??? (???) <dc9bc9b6f46d6ebb54194b332d4a8265> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeBIB.framework/Versi ons/A/AdobeBIB
      0x542f8000 - 0x542f8fff  libcmm.jnilib ??? (???) <c463dc1c492138894f1f16f923259145> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libcmm.jnilib
      0x54642000 - 0x546c3fe7 +libNativeImporter.jnilib ??? (???) <3799f3a195e8b41b928e791c6b698dd0> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libNativeImporter.jni lib
      0x5474d000 - 0x5478efe3 +MFILoaderLibrary_v3.dylib ??? (???) <980979c657f253fb1787f9a136a240af> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/MFILoaderLibrary_v3.dyli b
      0x547b8000 - 0x54849ff7 +libicucnv.dylib.36.0 ??? (???) <581475ccc0391b4249ba71811d8b4e15> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUConverter.framework/V ersions/3.6/libicucnv.dylib.36.0
      0x54868000 - 0x5497cfff +AdobeACE ??? (???) <dd291a17ecf4fe205837ac1f5bc76940> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeACE.framework/Versi ons/A/AdobeACE
      0x5499f000 - 0x54ec5fff +AdobeAGM ??? (???) <2c7e89435433e75ee1d98c701d249504> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeAGM.framework/Versi ons/A/AdobeAGM
      0x55006000 - 0x55042fff +AdobeARE ??? (???) <5e9ab1c83d4224125277c519f28ed120> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeARE.framework/Versi ons/A/AdobeARE
      0x5504b000 - 0x5506cff7 +AdobeBIBUtils ??? (???) <87abd1c314da0d8a80c51d03dc7a20e8> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeBIBUtils.framework/ Versions/A/AdobeBIBUtils
      0x55078000 - 0x5536aff7 +AdobeCoolType ??? (???) <432b8366503ce6554dafe26df7371e87> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeCoolType.framework/ Versions/A/AdobeCoolType
      0x553f2000 - 0x557caff7 +AdobeMPS ??? (???) <136148674d80eb74fa7f6136492478ba> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeMPS.framework/Versi ons/A/AdobeMPS
      0x558f9000 - 0x55f2dfeb +AdobePDFL ??? (???) <49d6d58a1ebb424a4cb08f9691e0991d> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePDFL.framework/Vers ions/A/AdobePDFL
      0x56059000 - 0x560b1ff7 +AdobeXMP ??? (???) <73329999c364245165744d0277057d19> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeXMP.framework/Versi ons/A/AdobeXMP
      0x560c0000 - 0x56191fe7 +AdobeJP2K ??? (???) <2abf10a7540a06c821fa186263931df9> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeJP2K.framework/Vers ions/A/AdobeJP2K
      0x561b3000 - 0x561d9ff6 +AdobeAXE8SharedExpat ??? (???) <2c79b4a179af41dc9ef153a4a98d396d> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeAXE8SharedExpat.fra mework/Versions/A/AdobeAXE8SharedExpat
      0x561ea000 - 0x563d0ff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <af8043538b137180f2c8832361eb2d5a> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobeLinguistic.framewor k/Versions/3/AdobeLinguistic
      0x5645e000 - 0x5652bff3 +libicui18n.dylib.36.0 ??? (???) <08f152197f35574e77251acaa1b18a00> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUInternationalization. framework/Versions/3.6/libicui18n.dylib.36.0
      0x565d9000 - 0x5731cfff +com.adobe.psl AdobePSL 12.0.0.7471 (12.0.0.7471) <50e013b2d1bae032344044b603e0d6c2> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePSL.framework/Versi ons/A/AdobePSL
      0x5765b000 - 0x5800bfff +libicudata.dylib.36.0 ??? (???) <02108dea3dd214bedaebbe522b619c1d> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUData.framework/Versio ns/3.6/libicudata.dylib.36.0
      0x5800e000 - 0x580e8fef +libicuuc.dylib.36.0 ??? (???) <5ee7200940b37fb73a49576aede0d400> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/ICUUnicode.framework/Ver sions/3.6/libicuuc.dylib.36.0
      0x58128000 - 0x5820bfef +AdobePDFPort ??? (???) <e70aa3dad99b6646cb46dbd16c0a8c2d> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/AdobePDFPort.framework/V ersions/A/AdobePDFPort
      0x58240000 - 0x58378fe7 +WRServices ??? (???) <9e3a36ad71f1b9c7ac3f30a7e63c8b57> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/WRServices.framework/Ver sions/A/WRServices
      0x585c9000 - 0x5861cfe7 +libCoolTypeJNI.jnilib ??? (???) <52d924d3e422bb0214cdd7481cb21e15> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/os/macosx/x86/libCoolTypeJNI.jnilib
      0x5867d000 - 0x5881afff  libawt.jnilib ??? (???) <a549adf48539b8c6d85cfe82d4c8c2eb> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libawt.jnilib
      0x588ba000 - 0x58902ff3  libsuncmm.jnilib ??? (???) <6dbda6ca9bc5f0868b15ecb475ceb60b> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libsuncmm.jnilib
      0x5894c000 - 0x5896efe7  libjpeg.jnilib ??? (???) <6f905cb2ee2bec9f8e7d099e85f9e434> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjpeg.jnilib
      0x59ea6000 - 0x59ef9ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4f2bff0301d2a07de5e27f88d4c2dec4> /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.flexide.nativelibs_1.0.0.273393/Frameworks/LogSession.framework/Ver sions/A/LogSession
      0x5a9c0000 - 0x5acb9ff3  com.apple.RawCamera.bundle 2.3.0 (505) <1c7cea30ffe2b4de98ced6518df1e54b> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x5bbd9000 - 0x5bd5efe3  GLEngine ??? (???) <052e02d9a452a45d014ffbd2a84a4e7c> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x5bd8c000 - 0x5c06aff1  com.apple.ATIRadeonX2000GLDriver 1.5.48 (5.4.8) <0858896931bc8cdd84f736ed21e23738> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
      0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
      0x90003000 - 0x906a3fef  com.apple.CoreGraphics 1.409.7 (???) <7b65edcce394f39b6a1954d5e30bc34c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x906a4000 - 0x90ab4fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x90cea000 - 0x90d00fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x90d46000 - 0x90d4afff  libGIF.dylib ??? (???) <36f7b0255a81d97c7b360c3b11b4e462> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x90d4b000 - 0x90d4dfff  com.apple.securityhi 3.0 (30817) <31baaf7ea27b41480604ffc910fe827f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x90d83000 - 0x90dceff7  com.apple.CoreMediaIOServices 130.0 (935) <e7c6d794bbec49f9d1ee8261c3f9ff0e> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x90dcf000 - 0x90eb0ff7  libxml2.2.dylib ??? (???) <b3bc0b280c36aa17ac477b4da56cd038> /usr/lib/libxml2.2.dylib
      0x90eb1000 - 0x90eb1ff8  com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x90eb2000 - 0x90f62fff  edu.mit.Kerberos 6.0.14 (6.0.14) <673f107cdae80c084774a27bc7bc46c1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x90f63000 - 0x90f6afe9  libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
      0x90f6b000 - 0x9105fff4  libiconv.2.dylib ??? (???) <c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
      0x91143000 - 0x911f5ffb  libcrypto.0.9.7.dylib ??? (???) <d02f7e5b8a68813bb7a77f5edb34ff9d> /usr/lib/libcrypto.0.9.7.dylib
      0x911f6000 - 0x911f6ffe  com.apple.quartzframework 1.5 (1.5) <4b8f505e32e4f2d67967a276401f9aaf> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x911f7000 - 0x913b3ff3  com.apple.QuartzComposer 2.1 (106.13) <dc04566811ab9c5316d1a622f42da8ba> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x913b4000 - 0x91447fff  com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x91448000 - 0x9150fff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x91510000 - 0x915a3ff3  com.apple.ApplicationServices.ATS 3.8 (???) <e61b0945da6ab368348a927f7428ad67> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x915a4000 - 0x91621fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x91622000 - 0x91628fff  com.apple.print.framework.Print 218.0.3 (220.2) <8c541d587e4068a5fe5a5ce8ee208516> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x91629000 - 0x91afafbe  libGLProgrammability.dylib ??? (???) <d5cb4e7997a873cd77523689e6749acd> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x91afb000 - 0x91b35ffe  com.apple.securityfoundation 3.0.2 (36131) <dd2a4d1a4f50b82923d7cfc5df10455d> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x91b36000 - 0x91b5ffff  libcups.2.dylib ??? (???) <2b0ab6b9fa1957ee940835d0cfd42894> /usr/lib/libcups.2.dylib
      0x91c20000 - 0x91c2effd  libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
      0x91c2f000 - 0x91c3bffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x91c54000 - 0x91c93fef  libTIFF.dylib ??? (???) <a5991d757f0c17a9bb8b1bcb14ab9ec0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x91c94000 - 0x9278efff  com.apple.WebCore 5533.19 (5533.19.4) <9b91bb00c553ec746fdbe51abca306af> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
      0x927de000 - 0x92fdcfef  com.apple.AppKit 6.5.9 (949.54) <4df5d2e2271175452103f789b4f4d8a8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x92fdd000 - 0x93110fe7  com.apple.CoreFoundation 6.5.7 (476.19) <a332c8f45529ee26d2e9c36d0c723bad> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x9313b000 - 0x93159fff  libresolv.9.dylib ??? (???) <0e26b308654f33fc94a0c010a50751f9> /usr/lib/libresolv.9.dylib
      0x9315a000 - 0x931d7feb  com.apple.audio.CoreAudio 3.1.2 (3.1.2) <782a08c44be4698597f4bbd79cac21c6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x931d8000 - 0x932c0ff3  com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x932c1000 - 0x93409ff7  com.apple.ImageIO.framework 2.0.7 (2.0.7) <acf821a3c418fdc86ef02b654366f5f6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x9340a000 - 0x93463ff7  libGLU.dylib ??? (???) <64d010e31d7596bd8f9edc6e027d1d0c> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x93464000 - 0x934a2fff  libGLImage.dylib ??? (???) <2e570958595e0c9c3a289158223b39ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x934a3000 - 0x937ceff6  com.apple.QuickTime 7.6.9 (1680.9) <024f122335016a54f8e59ddb4c79901d> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x937cf000 - 0x937deffe  com.apple.DSObjCWrappers.Framework 1.3 (1.3) <a2f7a163a74c134f6f17d497423436fe> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x93804000 - 0x93891ff7  com.apple.framework.IOKit 1.5.2 (???) <7a3cc24f78f93931731203854ae0d891> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x93892000 - 0x938a7ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x938a8000 - 0x938adfff  com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x938ae000 - 0x93aa6fff  com.apple.JavaScriptCore 5533.19 (5533.19.1) <a099821bc9203b1bba37aee855280e28> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x93aa7000 - 0x93e63ff4  com.apple.VideoToolbox 0.484.2 (484.2) <46c37a5fead4e4f58501f15a641ff476> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x93e64000 - 0x93ea4fef  com.apple.CoreMedia 0.484.2 (484.2) <81221976abdc19f30723c81c5669bbc9> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x93edd000 - 0x93ef8ff3  libPng.dylib ??? (???) <c0791798fb92acc136c250a373449359> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x93ef9000 - 0x940caff3  com.apple.security 5.0.6 (37592) <0b25e1e4cc34431630f01edb3fdf54d1> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x940cb000 - 0x940cbffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x940cc000 - 0x940ebffa  libJPEG.dylib ??? (???) <d23f3f3b9d168bf32f89449f83fa07f7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x940ec000 - 0x941a7fe3  com.apple.CoreServices.OSServices 228.1 (228.1) <76fdc146b4d9937f9c5cbaa1512e0023> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x941a8000 - 0x941d3fe7  libauto.dylib ??? (???) <4f3e58cb81da07a1662c1f647ce30225> /usr/lib/libauto.dylib
      0x941d4000 - 0x941f2ff3  com.apple.DirectoryService.Framework 3.5.7 (3.5.7) <b4cd561d2481c4162ecf0acdf8cb062c> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x941f3000 - 0x9427dff7  com.apple.DesktopServices 1.4.9 (1.4.9) <f5e51a76d315798371b3dd35a4d46d6c> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x9427e000 - 0x94282fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
      0x94283000 - 0x94283ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x94284000 - 0x94642fea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x94673000 - 0x9467aff7  libCGATS.A.dylib ??? (???) <29154398dbefc2a1a97715e5af1e3552> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGATS.A.dylib
      0x94680000 - 0x9474bfef  com.apple.ColorSync 4.5.3 (4.5.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x9474c000 - 0x94756feb  com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x94757000 - 0x94798fe7  libRIP.A.dylib ??? (???) <378694b494a02de1b0c812da572579d2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x94799000 - 0x948a0ff7  com.apple.WebKit 5533.19 (5533.19.4) <9299024ba5d2d796781e6d7312fae16a> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x948be000 - 0x94bc6fe7  com.apple.HIToolbox 1.5.6 (???) <eece3cb8aa0a4e6843fcc1500aca61c5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x94bc7000 - 0x94f64fef  com.apple.QuartzCore 1.5.8 (1.5.8) <18113e06d296230d63a63b58baf35f55> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x94f65000 - 0x94f66ffc  libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
      0x94f67000 - 0x94f67ff8  com.apple.Cocoa 6.5 (???) <e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x94f68000 - 0x94fb6fe3  com.apple.AppleVAFramework 4.1.17 (4.1.17) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x94fb7000 - 0x94fc2fe7  libCSync.A.dylib ??? (???) <06652e36188190ec04d294f49c68f28a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x95ec7000 - 0x95ed7ffc  com.apple.LangAnalysis 1.6.5 (1.6.5) <d057feb38163121ffd871c564c692804> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x95f4c000 - 0x9602cfff  libobjc.A.dylib ??? (???) <3ca288b625a47bbcfe378158e4dc328f> /usr/lib/libobjc.A.dylib
      0x9602d000 - 0x9602dffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x9613b000 - 0x9613bffa  com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x9613c000 - 0x96145fff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <73cf6b3c5ddf94d7ce9ae2c81c1b558c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x96146000 - 0x961a0ff7  com.apple.CoreText 2.0.5 (???) <5483518a613464d043455ac661a9dcbe> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x961a1000 - 0x961aefe7  com.apple.opengl 1.5.10 (1.5.10) <e7d1198d869f45f09251f9697cbdd192> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x961af000 - 0x9620cffb  libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
      0x9620d000 - 0x96247fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x96295000 - 0x963ceff7  libicucore.A.dylib ??? (???) <f2819243b278259b9a622ea111ea5fd6> /usr/lib/libicucore.A.dylib
      0x963cf000 - 0x96507fe7  com.apple.imageKit 1.0.2 (1.0) <00d03cf7f26e1b6023efdc4bd15dd52e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x96689000 - 0x96689ffe  com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <a2b462be6c51187eddf7d097ef0e0a04> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x9668a000 - 0x96711ff7  libsqlite3.0.dylib ??? (???) <aaaf72c093e13f34b96e2688b95bdb4a> /usr/lib/libsqlite3.0.dylib
      0x96712000 - 0x96736fff  libxslt.1.dylib ??? (???) <adfe90a3d564d824d5ae0fa6df8d6c3f> /usr/lib/libxslt.1.dylib
      0x9679e000 - 0x967faff7  com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x967fb000 - 0x96ad5ff3  com.apple.CoreServices.CarbonCore 786.16 (786.16) <60b518e4ad02b91826240199a6311286> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x96ad6000 - 0x96af3ff7  com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x96af4000 - 0x96af4ffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x96afb000 - 0x96b2afe3  com.apple.AE 402.3 (402.3) <dba512e47f68eea1dd0ab35f596edb34> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x96b2b000 - 0x96bd2feb  com.apple.QD 3.11.57 (???) <35f058678972d42b88ebdf652df79956> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x96bd3000 - 0x96c4dff8  com.apple.print.framework.PrintCore 5.5.4 (245.6) <9ae833544b8249984c07544dbe6a97fa> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x96c51000 - 0x96c82ffb  com.apple.quartzfilters 1.5.0 (1.5.0) <22581f8fe9dd2cb261f97a897407ec3e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x96c83000 - 0x96c8bfff  com.apple.DiskArbitration 2.2.1 (2.2.1) <ba64dd6ada417b5e7be736957f380bca> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x96c8c000 - 0x96ca8ff3  com.apple.CoreVideo 1.6.1 (48.6) <186cb311c17ea8714e918273c86d3c13> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x96ca9000 - 0x96cb0ffe  libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
      0x96cb1000 - 0x96e35fef  com.apple.MediaToolbox 0.484.2 (484.2) <32bf3254fafd942cf8f2c813960217fd> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x96e36000 - 0x96e5eff7  com.apple.shortcut 1.0.1 (1.0) <37e4b08cfaf9edb08b8682a06c4ec844> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x96e71000 - 0x96ec2ff7  com.apple.HIServices 1.7.1 (???) <ba7fd0ede540a0da08db027f87efbd60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x96fb7000 - 0x97109ff3  com.apple.audio.toolbox.AudioToolbox 1.5.3 (1.5.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x9710a000 - 0x97386fe7  com.apple.Foundation 6.5.9 (677.26) <c68b3cff7864959becfc7fd1a384f925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x97387000 - 0x97414ff7  com.apple.LaunchServices 292 (292) <a41286c7c1eb20ffd5cc796f791070f0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x9741b000 - 0x97464fef  com.apple.Metadata 10.5.8 (398.26) <e4d268ea45379200f03cdc7c8bedae6f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x97465000 - 0x975affeb  com.apple.QTKit 7.6.9 (1680.9) <fe987e6adf235d5754399dcdae6e5a8e> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x975e3000 - 0x97625fef  com.apple.NavigationServices 3.5.2 (163) <7f4f1766414a511bf5bc68920ac85a88> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x97626000 - 0x97626ffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
      0x97627000 - 0x97699fff  com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x9769a000 - 0x976aafff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <9a71429c74ed6ca43eb35e1f78471b2e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x976ab000 - 0x976b0fff  com.apple.DisplayServicesFW 2.0.2 (2.0.2) <cb9b98b43ae385a0f374baabe2b71764> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x976b1000 - 0x976defeb  libvDSP.dylib ??? (???) <f39d424bd56a0e75d5c7a2280a25cd76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x976df000 - 0x976e1ff5  libRadiance.dylib ??? (???) <276f13ab6429e05b093a8dda251e3b53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x976e2000 - 0x97761ff5  com.apple.SearchKit 1.2.2 (1.2.2) <3b5f3ab6a363a4d8a2bbbf74213ab0e5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x97b3c000 - 0x97b54fff  com.apple.openscripting 1.2.8 (???) <a888b18c8527f71629702ed8dce9c877> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x97b55000 - 0x97b55fff  com.apple.Carbon 136 (136) <27d42531a2cbeb05a7f4d05a28281bd7> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x97b74000 - 0x97b77fff  com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x97b78000 - 0x97b7ffff  com.apple.agl 3.0.9 (AGL-3.0.9) <5a57ce58f8adb7825e1adb9f7cdea151> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x97b80000 - 0x97bcbfe1  com.apple.securityinterface 3.0.4 (37213) <16de57ab3e3f85f3b753f116e2fa7847> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
      0x97bcc000 - 0x97c03fff  com.apple.SystemConfiguration 1.9.2 (1.9.2) <41d5aeffefc6d19d471f51ae0b15024f> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x97c04000 - 0x97d6bff3  libSystem.B.dylib ??? (???) <c8f52e158bf540cc000146ca8a705958> /usr/lib/libSystem.B.dylib
      0x97d6c000 - 0x97dbbfff  com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
      0x97dbc000 - 0x97dc8ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x97dc9000 - 0x97e70fec  com.apple.CFNetwork 438.16 (438.16) <dbf00ca36a09edfae60ec44f9d7a9ef9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0xba900000 - 0xba916fff  libJapaneseConverter.dylib ??? (???) <b9aea83b1cd97f3230999ebfcbf63e7c> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe2  libKoreanConverter.dylib ??? (???) <bc0bb2eed0f4558f07bbaa812d79371b> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
      0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
