1 Reply Latest reply on Jul 4, 2007 10:20 PM by wgb14
    Display a series of pictures on the stage based on the value of a variable
    wgb14
      Hi all,
      Here is another interesting problem! Well, I have an interactive retention test that loads questions from an xml file based on the value of a scenario variable (e.g., if scenario = Architecture then load Q_set 1, if scenario = History then load something else). Now, I would like to extent this and display a series of pictures on my stage that will be valid only in the current scenario. Here is my code so far. I was thinking to load some image list on the start of the movie (e.g., Architecture_list, History_list) and then call them based on the value of the scenario variable, but i would also like to hear what you have to say. Any ideas?
        • 1. Re: Display a series of pictures on the stage based on the value of a variable
          wgb14 Level 1
          The answer is a series of handlers: One called at the beginning of the movie to fill in the lists from the proper folders (based on the value of the gimage variable) and the others called on next and previous. Here they are in case yu need them:
          global gFileList,gImagePath,gimages
          on buildList
          gFileList = []
          -- defining path to images:
          gImagePath = "@images/"&gimages&"/"
          repeat with i = 1 to the maxinteger
          thisFile = getNthFileNameInFolder(gImagePath, i)
          if thisFile = EMPTY then exit repeat
          if thisFile = the movie then next repeat
          fileTypes = [".bmp", ".pct", ".jpg", ".gif"]
          howManyTypes = count(fileTypes)
          repeat with thisType = 1 to howManyTypes
          extension = getAt(fileTypes, thisType)
          if thisFile contains extension then
          gFileList.append(thisFile)
          end if
          end repeat
          end repeat
          member("display").filename = gImagePath & gFileList[1] -- put the first picture of the folder to the proper place
          member("display").picture = member ("display").picture
          end buildList
          global gFileList, gFileIndex,gImagePath
          on nextFile
          gFileIndex = gFileIndex + 1
          if gFileIndex > count(gFileList) then
          whichFile = gFileList[1] --set the image holder = to the last image loaded
          gFileIndex = 1 -- set the index to the last loaded question
          member("display").filename = gImagePath & whichFile
          updateStage
          -- go to the audio questions
          _movie.go(31)
          else
          whichFile = gFileList.getAt(gFileIndex)
          updateStage
          end if
          end
          global gFileList,gFileIndex,gImagePath
          on backFile
          gFileIndex = gFileIndex - 1
          if gFileIndex = 1 then
          updateStage
          sprite(17).enabled = FALSE -- deactivate back button
          -- gFileIndex = count(gFileList)
          end if
          if gFileIndex > 1 then
          updateStage
          end if
          end
