1 Reply Latest reply: Jan 26, 2011 8:25 AM by Randy Edmunds RSS
    Having problems with calendar placement in a div tag
    leesc46 Community Member
      Is there something I need to do when placing my calendar in a div tag?  When viewed in a browser, it does not appear to be in the same location that I've placed it, and, it is a different size and shape.  I've tried changing the calendar container using css but I'm not having any luck.
        • 1. Re: Having problems with calendar placement in a div tag
          Randy Edmunds Employee Hosts
          FYI, this forum is for creating extensions --  not using them, so you'll probably get a better response on the DW general forum.
          With that said, it's hard to know exactly where the IP (insertion pointer) is in Design View, so try using Split View so you can see where the IP is in the code pane before you insert something or make an edit.
          HTH,
          Randy
