0 Replies Latest reply on Jan 11, 2011 12:01 PM by Afterman
    Embedded swfs max number
    Afterman
      Is there a maximum number of swf assets I can embed in an fla using this syntax:
      [Embed(source ="../swfs/swf1.swf", symbol = "symb" )]
      var SWF1:Class;
      var swf1:MovieClip = new SWF1();
      swf1
      .gotoAndStop(1);
      [Embed(source ="../swfs/swf2.swf", symbol = "symb" )]
      var SWF2:Class;
      var swf2:MovieClip = new SWF2();
      swf2
      .gotoAndStop(1);
      [Embed(source ="../swfs/swf3.swf", symbol = "symb" )]
      var SWF3:Class;
      var swf3:MovieClip = new SWF3();
      swf3
      .gotoAndStop(1);
      I'm doing this in flash cs5 with a bout 20 or 30 swf files and at one point it compiles but some or all movieclips are shrunk down to one blank frame.
      I check using this:
      var allPages:Array = [swf1,swf2,swf3...];
      var t:int = 0;
      for each(var clip:MovieClip in allPages) {
      var f:int = clip.totalFrames;
          t
      +=f;
          trace
      (f);
      trace
      (t);
      trace
      (this.totalFrames);
      Sometimes this code above does not even get executed and the compiled swf does not respond at all.
      Each swf contains anywhere between 500 and 3500 frames. Sometimes I embed the same swf multiple times to grab different symbols in it.I have had no luck determining the root of the cause:
      -number of embedded swfs?
      -size of the embedded swfs?
      -number fo frames in an embedded swf?
      -total number of frames in the main swf?
      Can anyone help?
