2 Replies Latest reply on Jan 21, 2011 2:56 AM by CMogilko
    An internal error has occurred! + Runtime error! Program C…
      I have Vista 64 SP2 all patches and Acrobat CS4 installed.Reader 9.4 was running without more then the normal troble with Adobe software. After installing Adobe Reade X it won't even start.
      The only  thing Reader X is doing is showing: An internal error has occurred!
      And: Runtime error! Program C… The program has requested the Runtime  to terminate in an unusual way. Please contact the application’s support  team for more information.
      I have enough of Adobes Beta Software released to me as a customer.  Never seen anything worse then your products. Flash as THE security hole  closely followed by Adobe reader. Okay that hole is closed now an  forever as I never will install anything from Adobe on my PC again. The  **** with downloading by Adobe DLM in firefox and such crap not to  mention.
      Welcome Foxit Reader!
        • 1. Re: An internal error has occurred! + Runtime error! Program C…
          this Error can occur if you make use of JUNCTION in your filesystem. Sometimes those JUNCTIONS are made by your Operating System (e.g. windows anytime-upgrade and than changeing system language). But perhaps you manually changed program and data storage locations by using JUNCTION ( e.g. mklink or any other tool ).
          ONE SOLUTION which works for me was to install Adobe Reader manually by downloading the appropriate version at ftp://ftp.adobe.com/pub/adobe/reader/win . The startup with the desktop shortcut will not work.
          1. You should create a new Folder (e.g. TEST ) in the HOMEDRIVE ( normally C: ) root location which is not a JUNCTION .
          2. Open a command line ( press WinodwsKey+R than type "%COMSPEC%" without quotes and press OK Button)
          3. Use now the set command to change environment varibles temporarily Change APPDATA and USERPROFILE by typing
               SET APPDATA=C:\TEST
               SET USERPROFILE=C:\TEST
          4. Now start Adobe Reader from this command line by typing
               "C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32.exe"
          Adobe Reader will open.
          5. You should go straight to Menu: Edit->Preferences->General
          Disable or deselect the "Enable Protected Mode at startup" at the bottom. Click OK. and exit Adobe Reader.
          6. Adobe settings are now written to C:\TEST
          copy all from C:\TEST to your original USERPROFILE dir
          Now you can use the desktop shortcut of Adobe Reader and it will also open pdf directly in your browser.
          • 2. Re: An internal error has occurred! + Runtime error! Program C…
            I have the same problem, but this solution doesn't work. In 5, Preferences doesn't appear, Reader freezes and I need to kill process. I have win7-64 and ssd drive, because of that my userprofile stored at hdd and c:\users is a link.
