4 Replies Latest reply on Jan 17, 2011 3:15 AM by Kasyan Servetsky
    Get icc-profile from a image
    slusteg
      Is ist possible to get the ICC-profile of a image
      I try this with  a Adobe RGB 1998 with embeded profile:
      alert(app.activeDocument.selection[0].graphics[0] .profile);
      alert(app.activeDocument.selection[0].graphics[0] .space);
      But it only return  "Emdeded" for .profile and "RGB" for .space. But i want it to return adobe rgb 1998
      Is it possible?
        • 1. Re: Get icc-profile from a image
          Kasyan Servetsky Level 5
          As far as I know, you can't get profile of an image directly in InDesign, but you can get it via metadata:
          var link = app.selection[0].graphics[0].itemLink;
          var linkXmp = link.linkXmp;
          var profile = linkXmp.getProperty("http://ns.adobe.com/photoshop/1.0/", "ICCProfile");
          alert(profile);
          However not all images contain the nesessary metadata, especially some old files.
          You can check this by choosing Link File Info (in Links Panel menu) and going to Advanced section.
          • 2. Re: Get icc-profile from a image
            slusteg Level 1
            Thank you, that's exactly what i wanted!
            • 3. Re: Get icc-profile from a image
              slusteg Level 1
              Why can't i read  the profile variable from PSD-documents file don't contain xmp profile variable when i look under link file info. But when i look link information i can read profile: adobe rgb
              Read from XMP script also don't work.
              But when i open i photoshop i can read it
              Bug?
              • 4. Re: Get icc-profile from a image
                I can't think nothing better than temporarily open the link in Photoshop and get its embedded profile from there:
                #target indesign
                #targetengine "session"
                if (!BridgeTalk.isRunning("photoshop")) {
                     alert("Photoshop is not running.");
                else {
                     CreateBridgeTalkMessage(link.filePath);
                function CreateBridgeTalkMessage(filePath) {
                     var bt = new BridgeTalk();
                     bt.target = "photoshop";
                     var script = GetProfile.toString() + "\r";
                     script += "GetProfile(\""  + filePath + "\");";
                     bt.body = script;
                     // $.writeln(script);
                     bt.onResult = function(resObj) {
                          var result = resObj.body;
                          DisplayProfile(result);
                     bt.send(100);
                function GetProfile(filePath) {
                     try {
                          app.displayDialogs = DialogModes.NO;
                          var psDoc = app.open(new File(filePath));
                          var prof = app.activeDocument.colorProfileName;
                          psDoc.close(SaveOptions.DONOTSAVECHANGES);
                          app.displayDialogs = DialogModes.ALL;
                          return prof;
                     catch(err) {
                function DisplayProfile(result) {
                     alert( "Color profile is \"" + ((result == "undefined") ? "Not embedded" : result) + "\"");
