2 Replies Latest reply on Jan 12, 2011 7:27 AM by skeptic098rt0q387
    Error 1402
    skeptic098rt0q387
      OK,  so i downloaded reader x to upgradeo from 7.
      Dowloads fine but won't finish he install.
      Error 1402: cound not open key:
      Hkey_local_machine\software\microsoft\windows\currrent\verson\Run\OptionalComponents\MSFS
      I've gone though removing all previous versions,  disabled firewall  etc.. (I'm using ESET), changed permision to full with regedit and still no luck.
      The registry changes are sticking.
      I'm about ready to use this CPU  for target practice....
      Any ideas?
        • 1. Re: Error 1402
          Himanshu01
          If you are getting the permission issue for below perticular key and your changes are not working.
          Hkey_local_machine\software\microsoft\windows\CurrrentVersion\Run\OptionalComponents\MSFS
          Instead of giving the permission to MSFS key, give the permission to parant folder that is  "OptionalComponents".
          On the permission part, you need to make Administrator as Owner.
          Before applying any changes take a back-up of Registry and after that apply the changes.
          Refer the Document to change the permission >>>      http://kb2.adobe.com/cps/329/329137.html
          Hope this will resolve the issue.
          • 2. Re: Error 1402
            skeptic098rt0q387 Level 1
            Nope,  didn't help.
            I had to delete and then recreate MSFS and then it installed.
            I'm not happy about loosing a day to get this fixed...
            I shouldn't have to do registry editing for a simple version upgrade.
