3 Replies Latest reply on Jan 13, 2011 6:33 AM by mlabriola
    Question about the Before/After/Test metadata tags
      i think that i have read all of the appropriate sections on the wiki but i am a little unclear on how/when i need to add extra info to the Before/After/Test metadata tags.
      thus far, i have not done any unit tests that require a component to be added to the display list.  i was reading the section on how to do that and i see that all of the above mentioned tags have extra info:
      [Before( async, ui )], [After( async, ui )] and [Test( async, ui )]
      what do those do and when/why do i need to use them?
      additionally, i am trying to run this simple example derived from what's on the wiki and it always times out.
      package HM.FO.User {
      import mx.controls.Button;
      import mx.events.FlexEvent;
      import org.flexunit.Assert;
      import org.flexunit.async.Async;
      import org.fluint.uiImpersonation.UIImpersonator;
      public class UserWindowPresenterTest {
      //protected var window:UserWindow;
      protected var button:Button;
      [Before( async, ui )] public function setUp():void {
      //this.window = new UserWindow();
      this.button = new Button();
      //Async.proceedOnEvent( this, this.window, FlexEvent.CREATION_COMPLETE, 20000 );
      Async.proceedOnEvent( this, this.button, FlexEvent.CREATION_COMPLETE, 20000 );
      //UIImpersonator.addChild( this.window );
      UIImpersonator.addChild( this.button );
      [Before( async, ui )] public function tearDown():void {
      //UIImpersonator.removeChild( this.window );
      //this.window = null;
      UIImpersonator.removeChild( this.button );
      this.button = null;
      [Test( async, ui )] public function on_user_saved_clears_password_fields():void {
      // this.window.pass_txt.text = "foo";
      // this.window.pass_confirm_text.text = "bar";
      // var presenter:UserWindowPresenter = this.window.presenter as UserWindowPresenter;
      // presenter.on_user_saved( null );
      // Assert.assertNull( this.window.pass_txt.text );
      // Assert.assertNull( this.window.pass_confirm_text.text );
      Assert.assertTrue( true );
