2 Replies Latest reply on Jan 12, 2011 9:01 AM by saisri2k2
    Create XML file
    capitainequebec Level 1
      I am using AIR and FileStream class to save file locally but I don"t know how to create XML file using AS. I think I should use something like this:
      var xmlPoincon:XML = new XML();
      But I don't know how to create the node of the XML and then the values.
      Regards,
      Daniel Cantin
        • 1. Re: Create XML file
          Gregory Lafrance Level 6
          Here is a simple code snippet:
          private function createXML(): void{
              var xm:XML = <Relyon></Relyon>;
              var nodeName:String = "EMPLOYEENAME";
              var nodeValue:String = "KUMAR";
              var xmlList:XMLList = XMLList("<"+nodeName+">"+nodeValue+"</"+nodeName+">");
              xm.appendChild(xmlList);
              Alert.show(xm);
          Most important here is the appendChild() method, that allows you to add a node you have constructed.
          http://flexonblog.wordpress.com/2008/02/04/generate-xml-data-dynamically-in-flex/
          If this post answers your question or helps, please mark it as such. Thanks!
          http://www.stardustsystems.com
          Adobe Flex Development and Support Services
          • 2. Re: Create XML file
            saisri2k2 Level 4
            programmatically you can do the following
                           protected function application1_creationCompleteHandler(event:FlexEvent):void
                                var root:XML = <root></root>;
                                xmlPoincon.appendChild(root);
                                var firstElement:XML = <subElement>{"value"}</subElement>;
                                root.appendChild(firstElement);
                                xmlPoincon = root;
                                trace(xmlPoincon.toString());
            it will give
            <root>
              <subElement>value</subElement>
            </root>
            else you can give
            var xmlPoincon:XML = <root>
            </root>;
            the above will work as well.
