3 Replies Latest reply on Jan 12, 2011 3:04 PM by kglad
    using script to add a button effect? possible?
    RedLine_24_12
      Hi @ all
      i have a question:
      is it possible to ad a "button effect" (different state for "normal" and "hover") to an existing button without having to do it graphically but only with a script?
      i ask this because i have a flash-gallery with hundrets of thumbinails in converted to buttons that recall a javascript to open the full image (lightbox) and it would be nice to add each button a nice "hover" effect (maybe they should look dark and become normal brightness when hovered) but i don't want to edit each single button ..
      maybe some AS that define such an effect that i have only to copy into each object??
      thanks a lot for the help, it's appreciated
        • 1. Re: using script to add a button effect? possible?
          you can't do what you want but you might be able to fake some effects.  as2 or as3?
          • 2. Re: using script to add a button effect? possible?
            RedLine_24_12 Level 1
            as2
            it's not really a matter of wich effect .. just want to have the gallery a bit more animating ..
            the best would be a brightness effect (button up: dark  ||  button hover and pressed: normal)
            • 3. Re: using script to add a button effect? possible?
              create something to overlay your button that gives you the rollover effect you want.  maybe a white rectangle with 50% alpha.  experiment.
              convert that to a movieclip and assign a linkage id (eg, over_mc).  you can then use:
              // 1.  you already have a button rollout you want to use:
              Button.prototype.attachMovie=MovieClip.prototype.attachMovie;
              b.onRollOver=function(){
                  mc = b.attachMovie("overID","over_mc",1,{_width:b._width,_height:b._height});
                  mc.onRollOut=b.onRollOut;
                  delete b.onRollOut;
              b.onRollOut=function(){
                  b.over_mc.removeMovieClip();  // <- add this to your existing rollout
              // 2.  you have no rollouts:
                  mc.onRollOut=function(){
                      this.removeMovieClip();
