4 Replies Latest reply on Jul 12, 2011 9:46 AM by lirask8
    Spark List disable Scrolling
    ne_polle Level 1
      Hi
      I'm using a List and I disabled the scrollpolicy und allowed the hole drag/drop stuff.
      The visible rows are smaller than the existing ones.
      Problem when I try to drag/drop an list-item I could scroll through the hole content of the list.
      I want to disble the scrolling effect.
      How could I do this???
      thanks for any advive and regards
        • 1. Re: Spark List disable Scrolling
          Gregory Lafrance Level 6
          Perhaps set the dropEnabled property to false?
          If this post answers your question or helps, please mark it as such. Thanks!
          http://www.stardustsystems.com
          Adobe Flex Development and Support Services
          • 2. Re: Spark List disable Scrolling
            ne_polle Level 1
            hmm thats the point.
            I want to see a small view of the hole list and I also want to have the drag/drop/drag-move possibilities.
            I did a little bit workaround as I tried this with the mx:List component. I reseted the vertical scroll position to zero when the ScrollEvent.SCROLL was catched.
            the s:List component doesn't interact with the ScrollEvent.
            Any other advice???
            • 3. Re: Spark List disable Scrolling
              Shongrunden Adobe Employee
              I'm not sure if this is the best way of doing this, but what about detecting scroll position changes and preventing changes:
              <s:Application
                  xmlns:fx="http://ns.adobe.com/mxml/2009"
                  creationComplete="init()">
                  <fx:Script>
                      <![CDATA[
                          import mx.events.PropertyChangeEvent;
                          import mx.managers.DragManager;
                          private var storedVSP:Number = 0;
                          private function init():void {
                              list2.dataGroup.addEventListener(PropertyChangeEvent.PROPERTY_CHANGE, handle);
                          private function handle(e:PropertyChangeEvent):void {
                              if (DragManager.isDragging && e.property == "verticalScrollPosition"){
                                  trace('verticalSrollPosition trying to go to', e.newValue, 'changing to', storedVSP);
                                  e.target.verticalScrollPosition = storedVSP;
                          private function storeCurrentScrollPosition():void {
                              storedVSP = list2.dataGroup.verticalScrollPosition;
                  </fx:Script>
                  <s:layout>
                      <s:HorizontalLayout />
                  </s:layout>
                  <s:List id="list1" height="100" dragEnabled="true" mouseDown="storeCurrentScrollPosition()">
                      <s:dataProvider>
                          <s:ArrayList>
                              <fx:Array>
                                  [0,1,2,3,4,5,6,7,8,9]
                              </fx:Array>
                          </s:ArrayList>
                      </s:dataProvider>
                  </s:List>
                  <s:List id="list2" height="100" dropEnabled="true">
                      <s:dataProvider>
                          <s:ArrayList>
                              <fx:Array>
                              </fx:Array>
                          </s:ArrayList>
                      </s:dataProvider>
                  </s:List>
              </s:Application>
              • 4. Re: Spark List disable Scrolling
                lirask8
                You can try: MyList.scroller.enabled = false;
