6 Replies Latest reply on Nov 30, 2011 10:14 AM by Flex harUI
    How to set s:BorderContainer backgroundImage from URL
    RafaelMCunha
      I've read many examples on web showing how to set a background image on s:BorderContainer using @Embed("image.xxx"), however, how can I load a background image from an URL ?
      Example:
      <s:BorderContainer
          id="bc"
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          width="150"
          height="150"
          cornerRadius="25"
          borderColor="#1E84E8"
          borderWeight="5"
          backgroundImage="http://mydomain/myimage.jpg"
      </s:BorderContainer>
      Thanks.
      []'s.
        • 1. Re: How to set s:BorderContainer backgroundImage from URL
          _spoboyle Level 4
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                      creationComplete="init()">
               <fx:Script>
                    <![CDATA[
                         import spark.primitives.BitmapImage;
                         public function init():void
                              var loader:Loader = new Loader();
                              loader.contentLoaderInfo.addEventListener(Event.COMPLETE, onLoad);
                              var request:URLRequest = new URLRequest("http://www.loscavio.com/downloads/blog/images/Fx.png");
                              loader.load(request);
                         private function onLoad(e:Event):void
                              trace("image loaded");
                              var info:LoaderInfo = e.target as LoaderInfo;
                              var loader:Loader = info.loader;
                              var bitmap:BitmapImage = new BitmapImage();
                              bitmap.source = loader;
                              bitmap.width = container.width;
                              bitmap.height = container.height;
                              container.addElement(bitmap);
               </fx:Script>
               <s:BorderContainer
                    id="container"
                    width="150"
                    height="150"
                    cornerRadius="25"
                    borderWeight="5">
          </s:WindowedApplication>
          There may be a better way of doing it and its certainly possible to tidy up the code I've written but this shows the basic premise of how you could go about it.
          Although to get it to work as the background image you ar probably going to have to use this technique in a custom skin
          you could also try lokoing at http://polygeek.com/2452_flex_extending-spark-bitmapimage
          • 2. Re: How to set s:BorderContainer backgroundImage from URL
            RafaelMCunha Level 1
            Thanks.
            However I am not using AIR. It is just a web app using Flex 4. So, I do not have s:WindowedApplication.
            • 3. Re: How to set s:BorderContainer backgroundImage from URL
              _spoboyle Level 4
              ok here is a version for web and note I have set the background image properly rather than just adding an image to the displalist
                  <fx:Script>
                      <![CDATA[
                              var request:URLRequest = new URLRequest('http://www.loscavio.com/downloads/blog/images/Fx.png');
                              container.setStyle('backgroundImage', loader.content);
                  </fx:Script>
                  <s:BorderContainer
                      id="container"
                      width="150"
                      height="150"
                      cornerRadius="25"
                      borderWeight="5">
              </s:Application>
              • 4. Re: How to set s:BorderContainer backgroundImage from URL
                Correct answer. Thank you.
                []'s.
                • 5. Re: How to set s:BorderContainer backgroundImage from URL
                  adqsdfqsdf
                  This doesn't seem to work any more? All I get is a white background.
                  • 6. Re: How to set s:BorderContainer backgroundImage from URL
                    Flex harUI Adobe Employee
                    BackgroundImage doesn’t support loading external images.
