3 Replies Latest reply on Jan 13, 2011 10:25 AM by abhinav1singhal
    Unable to set Labelfield for child element  in List
    abhinav1singhal
      Hi All,
      Below is code I am trying to execute
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" verticalGap="0" xmlns:local="*" height="500" creationComplete="init()" >
      <mx:Script>
      <![CDATA[
      private var arr:Array = [{ firstName: "Alex", children:{lastName: "Abc"}}]
      private function init():void{
      list.dataProvider=arr;
      </mx:Script>
      <mx:List variableRowHeight="true"
      wordWrap="
      true" id="list"
      labelField="
      chidren.lastName" />
      </mx:Application>
      I basically want to access the children.lastName on my List. Please let me know how exactly can I do it.
        • 1. Re: Unable to set Labelfield for child element  in List
          saisri2k2 Level 4
          try using labelfunction
          • 2. Re: Unable to set Labelfield for child element  in List
            Gregory Lafrance Level 6
            labelFunction is the best way to do this. The attached code also shows how to do it with an itemRenderer, though that would not be as efficient.
            <mx:Application
              layout="horizontal"
              <mx:Script>
                <![CDATA[
                    list1.dataProvider=arr;
                    list2.dataProvider=arr;
                  private function createLabels(item:Object):String{
                    return item.children.lastName;
              </mx:Script>
                wordWrap="true" id="list1">
                <mx:itemRenderer>
                  <mx:Component>
                    <mx:Label text="{data.children.lastName}"/>
                  </mx:Component>
                </mx:itemRenderer>
              </mx:List>
                wordWrap="true" id="list2"
                labelFunction="createLabels"/>
            </mx:Application>
            If this post answers your question or helps, please mark it as such. Thanks!
            http://www.stardustsystems.com
            Adobe Flex Development and Support Services
            • 3. Re: Unable to set Labelfield for child element  in List
              abhinav1singhal Level 1
              Thank you. I was basically truing to get the label informaiton in my Itemrederer. So this should work out.
