2 Replies Latest reply on Jan 13, 2011 7:57 AM by _spoboyle
    Get select data value from Combobox
    JoGlez Level 1
      Hi all,
          I am having a major issue while trying to obtain the selected items value through the change event in a combobox.  below is my code.. I really do need help as soon as possible...Thanks in advanced
      public var test:ArrayCollection = new ArrayCollection([
                  { Id:"one", Amount:2000 },
                  { Id:"two", Amount:1000 },
                  { Id:"three", Amount:200 } ]);
      protected function regionCB_changeHandler(event:ListEvent):void
                        Alert.show(//tried so many things here to acces the items amount field.. nothing is working
      <s:ComboBox change="regionCB_changeHandler(event)" dataProvider="{test}" labelField="Id" id="regionCB" visible="false" />
        • 1. Re: Get select data value from Combobox
          Zolotoj Level 3
          Did you try selectedItem.Amount?
          • 2. Re: Get select data value from Combobox
            _spoboyle Level 4
            <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                   xmlns:mx="library://ns.adobe.com/flex/mx">
                <fx:Script>
                    <![CDATA[
                        import mx.collections.ArrayCollection;
                        import mx.controls.Alert;
                        import spark.events.IndexChangeEvent;
                        [Bindable]
                        protected function regionCB_changeHandler(event:IndexChangeEvent):void
                            var combo:ComboBox = event.target as ComboBox;
                            var obj:Object = combo.selectedItem;
                            Alert.show(obj.Id +": " + obj.Amount);
                </fx:Script>
                <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
                <s:ComboBox change="regionCB_changeHandler(event)" dataProvider="{test}" labelField="Id" id="regionCB" visible="true" />
            </s:WindowedApplication>
            sorry some of "'s in the Alert.show have been removed by the syntax highlighting should be
