1 Reply Latest reply on Jan 13, 2011 8:10 AM by snunicycler
    dynamic text wont show up in movie - as2
    snunicycler Level 3
      basically i have dynamic text fields that i have been trying to parse to an xml file. when i test the movie it does not work, all the fields are blank. but the info DOES show up in the output tab, so i know that it is making the connection.... it just doesnt show up in the movie. weird.
      here is my actionscript:
      var xml:XML=new XML();
      xml.ignoreWhite=true;
      xml.onLoad=parseXML;
      xml.load("popup.xml");
      function parseXML(){
      trace(this);
          if (success)
              var diagramNode=this.firstChild;
              var infoNode=diagramNode.childNodes[0];
              var nameNode=infoNode.childNodes[1];
              var ssnumberNode=infoNode.childNodes[2];
              var descriptionNode=infoNode.childNodes[3];
              var stockNode=infoNode.childNodes[4];
              var priceNode=infoNode.childNodes[5];
              var typeNode=infoNode.childNodes[6];
              var qtyNode=infoNode.childNodes[7];
          else {
              content="oops, this stuff is confusing";
      and here is my xml:
      <diagram>
          <config>
          </config>
          <info>
              <name>
                  Pedal Set With Toe Cage and Straps
              </name>
              <ssnumber>
                  P01LEM14139
              </ssnumber>
              <description>
                  Pedal set comes complete with both left and right pedals, toe cages and straps. Pedals have 9/16” shaft diameter where pedal threads into the crank arm.
              </description>
              <stock>
                  Item is in stock
              </stock>
              <price>
                  $15.95
              </price>
              <type>
                  EA
              </type>
              <qty>
                  1
              </qty>
          </items>
      </diagram>
      thanks, -mitchell
        • 1. Re: dynamic text wont show up in movie - as2
          snunicycler Level 3
          ok, i must have been doing it wrong. i ended up following a different tutorial and i rewrote it this way and it works great now!
          function processXMLData(success)
              if (success)
                  var rootNode=this.firstChild;
                  var nameNode=findNode(rootNode, "name");
                  name=getValue(nameNode);
                  var ssnumberNode=findNode(rootNode, "ssnumber");
                  ssnumber=getValue(ssnumberNode);
                  var descriptionNode=findNode(rootNode, "description");
                  description=getValue(descriptionNode);
                  var stockNode=findNode(rootNode, "stock");
                  stock=getValue(stockNode);
                  var priceNode=findNode(rootNode, "price");
                  price=getValue(priceNode);
                  var typeNode=findNode(rootNode, "type");
                  type=getValue(typeNode);
                  var qtyNode=findNode(rootNode, "qty");
                  qty=getValue(qtyNode);
              else
                  content="oops, this is hard";
          function getValue(node)
            if (node && node.firstChild)
                return node.firstChild.nodeValue;
            return "";
          function findNode(node, nodeName)
              if (node.nodeName==nodeName)
                  return node;
              for (var i=0; node.childNodes && i<node.childNodes.length; i++)
                  var foundNode=findNode(node.childNodes[i], nodeName);
                  if (foundNode!=null)
                      return foundNode;
              return null;
          var xmlData=new XML();
          xmlData.ignoreWhite=true;
          xmlData.onLoad=processXMLData;
          xmlData.load("popup.xml");
          stop();
