2 Replies Latest reply on Jan 13, 2011 2:41 PM by _durin_
    Audition Keeps crashing over and over
    grimflea
      Hi there.
      I'm having an enormous struggle with Audition for Mac. I just got the Beta recently and quite liked it initially, but now it's got me shouting curses.
      It was my mistake to rely on it for a project, seeing as it's a beta, but I was busy doing editing for a small commercial in Premiere Pro, and was really disappointed with how audio is handled between Premiere Pro and Soundbooth, so I decided to try the Audition beta since I can open .omf files and work on audio for the entire project all at once instead of the very annoying back-and-forth with Soundbooth. (Why Soundbooth doesn't support a better workflow for posting audio for video is totally beyond me seeing as it's supposed to be aimed at pros that work with Premiere Pro, After Effects and whatever else).
      Anyway, so I got down to cleaning up some audio and got to a place where I had 4 track filters on one track, with only 5 or 6 tracks in the project, less than a minute and a half in total time. Not much to handle you'd imagine. But before I knew it, it started crashing over and over and over. Every time I opened it it I tried to move the play line or move a clip and then it would crash. Somehow I managed to delete a clip, juggle a few things around and I wanted to make a cut on another clip and off it went again, crash crash crash. Tried redownloading it. Tried saving projects as new ones. No change.
      I'm pulling my hair out since I need to deliver this project shortly and I've done so much work already that I can't possibly imagine having to start over in something like soundbooth.
      A second problem I find is that often it takes many seconds for an effect to take place when you play the audio file. You can add something, let it play and only about 6-10 seconds later hear the difference kick in. Not sure if this is due to the fact that it's not a massive install but rather just a standalone application at the moment.
      Thirdly, sometimes clips won't play at all. The play line runs over the wav files, but nothing comes out. When you start it, you hear a split second of audio, which disappears and then there's nothing else. No tracks muted, nothing changed, it just seems temperamental in doing this from time to time.
      Anyway, here's my crash report from the last time I tried to make a cut.
      I had no other audio programs running at the time, only Premiere Pro, Word and Safari running at the time of this crash.
      Thanks for your time...
      Process:         Adobe Audition [14842]
      Path:            /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
      Identifier:      com.adobe.Audition.4.0
      Version:         4.0x10 (4.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [144]
      Interval Since Last Report:          937546 sec
      Crashes Since Last Report:           33
      Per-App Interval Since Last Report:  23305 sec
      Per-App Crashes Since Last Report:   19
      Date/Time:       2011-01-13 15:30:15.369 +0000
      OS Version:      Mac OS X 10.5.8 (9L31a)
      Report Version:  6
      Anonymous UUID:  8122CE79-D601-4D1A-A0EA-B90F161FB2B3
      Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x00000000294cfdec
      Crashed Thread:  21
      Thread 0:
      0   libSystem.B.dylib             0x92093266 mach_msg_trap + 10
      1   libSystem.B.dylib             0x9209aa5c mach_msg + 72
      2   com.apple.CoreFoundation      0x96749e7e CFRunLoopRunSpecific + 1790
      3   com.apple.CoreFoundation      0x9674aaa8 CFRunLoopRunInMode + 88
      4   com.apple.HIToolbox           0x97b982ac RunCurrentEventLoopInMode + 283
      5   com.apple.HIToolbox           0x97b980c5 ReceiveNextEventCommon + 374
      6   com.apple.HIToolbox           0x97b97f39 BlockUntilNextEventMatchingListInMode + 106
      7   com.apple.AppKit              0x90b526d5 _DPSNextEvent + 657
      8   com.apple.AppKit              0x90b51f88 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
      9   com.apple.AppKit              0x90b4af9f -[NSApplication run] + 795
      10  com.adobe.exo.framework       0x01b97c87 exo::app::OS_AppBase::RunEventLoop() + 71
      11  AuUI                          0x036dc460 AudMacMain(int, char**) + 608
      12  com.adobe.Audition.4.0        0x00002ecd main + 93
      13  com.adobe.Audition.4.0        0x00002c66 start + 54
      Thread 1:
      0   libSystem.B.dylib             0x920c39c6 kevent + 10
      1   libSystem.B.dylib             0x920c4155 _pthread_start + 321
      2   libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 2:
      0   libSystem.B.dylib             0x9209a44e __semwait_signal + 10
      1   ...adobe.auscripting.framework 0x03379ea1 ScObjects::Thread::sleep(unsigned int) + 65
      2   ...adobe.auscripting.framework 0x03362483 ScObjects::BridgeTalkThread::run() + 179
      3   ...adobe.auscripting.framework 0x03379fce ScObjects::Thread::go(void*) + 174
      4   libSystem.B.dylib             0x920c4155 _pthread_start + 321
      5   libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 3:
      1   libSystem.B.dylib             0x920c4dcd pthread_cond_wait$UNIX2003 + 73
      2   ...ple.CoreServices.CarbonCore 0x978ccde3 TSWaitOnCondition + 126
      3   ...ple.CoreServices.CarbonCore 0x978abc36 TSWaitOnConditionTimedRelative + 202
      4   ...ple.CoreServices.CarbonCore 0x978cca60 MPWaitOnQueue + 208
      5   com.adobe.dvacore.framework   0x003b72fa dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      6   com.adobe.dvacore.framework   0x003b318a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      7   com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
      8   com.adobe.dvacore.framework   0x003afbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      9   com.adobe.dvacore.framework   0x003b0af0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      10  ...obe.boost_threads.framework 0x000686fd thread_proxy + 141
      11  libSystem.B.dylib             0x920c4155 _pthread_start + 321
      12  libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 4:
      Thread 5:
      3   com.apple.CoreFoundation      0x9674ab04 CFRunLoopRun + 84
      4   com.apple.DVCPROHDMuxer       0x1d8120fb AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 297
      5   libSystem.B.dylib             0x920c4155 _pthread_start + 321
      6   libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 6:
      4   com.apple.audio.CoreAudio     0x965e25f8 HALRunLoop::OwnThread(void*) + 160
      5   com.apple.audio.CoreAudio     0x965e2480 CAPThread::Entry(CAPThread*) + 96
      6   libSystem.B.dylib             0x920c4155 _pthread_start + 321
      7   libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 7:
      2   ....audio_hijack_server.hermes 0x061ef3cf ah_serv_loop + 161
      3   libSystem.B.dylib             0x920c4155 _pthread_start + 321
      4   libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      1   libSystem.B.dylib             0x920ea9f8 pthread_cond_timedwait$UNIX2003 + 72
      2   com.adobe.aubackend.framework 0x022b4a32 abe::afs::AudioFileSystem::CacheServices() + 322
      3   com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
      4   com.adobe.dvacore.framework   0x003b738a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      5   com.adobe.dvacore.framework   0x003b318a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      6   com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
      7   com.adobe.dvacore.framework   0x003afbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      8   com.adobe.dvacore.framework   0x003b0af0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      9   ...obe.boost_threads.framework 0x000686fd thread_proxy + 141
      10  libSystem.B.dylib             0x920c4155 _pthread_start + 321
      11  libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 13:
      Thread 14:
      Thread 15:
      Thread 16:
      Thread 17:
      Thread 18:
      2   com.adobe.aubackend.framework 0x025029f0 abe::spectral::SpectralDataManager::Process() + 720
      Thread 19:
      0   libSystem.B.dylib             0x920932c6 semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x920c52af _pthread_cond_wait + 1244
      2   libSystem.B.dylib             0x920c6b33 pthread_cond_timedwait_relative_np + 47
      3   ...ple.CoreServices.CarbonCore 0x978abc62 TSWaitOnConditionTimedRelative + 246
      Thread 20:
      3   com.apple.audio.CoreAudio     0x965f1bdf CAGuard::WaitFor(unsigned long long) + 213
      4   com.apple.audio.CoreAudio     0x965f379a CAGuard::WaitUntil(unsigned long long) + 70
      5   com.apple.audio.CoreAudio     0x965f1f3f HP_IOThread::WorkLoop() + 759
      6   com.apple.audio.CoreAudio     0x965f1c43 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
      7   com.apple.audio.CoreAudio     0x965e2480 CAPThread::Entry(CAPThread*) + 96
      8   libSystem.B.dylib             0x920c4155 _pthread_start + 321
      9   libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 21 Crashed:
      0   com.adobe.aubackend.framework 0x023ed65f abe::AudioFadeComp::ProcessInplace(long long, abe::AudioBuffer*, long long, long long) + 1343
      1   com.adobe.aubackend.framework 0x023e4d40 abe::AudioClipRenderer::ProcessAudioData(long long, long long, long long) + 528
      2   com.adobe.aubackend.framework 0x023e1068 abe::AudioClipRenderer::GetAudioData(abe::AudioBuffer*, long long, long long, bool, bool) + 776
      3   com.adobe.aubackend.framework 0x024029cc abe::AudioRenderContentTrack::PrepInputData(long long, bool) + 588
      4   com.adobe.aubackend.framework 0x0240476e abe::AudioRenderTrack::GetAudioData(long long, abe::AudioBufferCache**, long long, bool, bool, bool) + 222
      5   com.adobe.aubackend.framework 0x024103c2 abe::AudioTrackGroupRenderer::ProcessAudioData() + 226
      6   com.adobe.aubackend.framework 0x024109b9 abe::AudioTrackGroupRenderer::GetAudioData(long long, long long, long long, abe::AudioBuffer*, bool, bool, bool) + 409
      7   com.adobe.aubackend.framework 0x02489dea abe::MultitrackSequenceRenderer::GetAudioData(long long, long long, float***, bool, bool, bool) + 282
      8   com.adobe.aubackend.framework 0x0229e036 abe::TrackMixdownOperation::DoProcess() + 694
      9   com.adobe.aubackend.framework 0x0225ec2b abe::AsyncOperation::ProcessStart(bool) + 779
      10  com.adobe.aubackend.framework 0x02268b3b boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, abe::AsyncOperation, bool>, boost::_bi::list2<boost::_bi::value<abe::AsyncOperation*>, boost::_bi::value<bool> > >, void>::invoke(boost::detail::function::function_buffer&) + 59
      11  com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
      12  com.adobe.dvacore.framework   0x003b738a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
      13  com.adobe.dvacore.framework   0x003b318a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      14  com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
      15  com.adobe.dvacore.framework   0x003afbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      16  com.adobe.dvacore.framework   0x003b0af0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      17  ...obe.boost_threads.framework 0x000686fd thread_proxy + 141
      18  libSystem.B.dylib             0x920c4155 _pthread_start + 321
      19  libSystem.B.dylib             0x920c4012 thread_start + 34
      Thread 22:
      Thread 23:
      Thread 24:
      Thread 25:
      2   libGLProgrammability.dylib    0x95d11b32 glvmDoWork + 162
      Thread 21 crashed with X86 Thread State (32-bit):
        eax: 0x22008c50  ebx: 0x023ed13a  ecx: 0x22008c50  edx: 0x294cfdec
        edi: 0x00000000  esi: 0x00000000  ebp: 0xb0ad64a8  esp: 0xb0ad6350
         ss: 0x0000001f  efl: 0x00010206  eip: 0x023ed65f   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
        cr2: 0x294cfdec
      Binary Images:
          0x1000 -     0x2ff7 +com.adobe.Audition.4.0 4.0x10 (4.0) <1987e7d46a624ad70cc057aafbf937c0> /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
         0x12000 -    0x16ffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20090403) /Applications/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
         0x27000 -    0x43fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
         0x4e000 -    0x54fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.227407) <43fff5ddeb22ba79ada7ce764691a3fa> /Applications/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x66000 -    0x6dff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.227407) <a4543c73757687a80f82eda4399aa816> /Applications/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x7d000 -    0x87ffd +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.227407) <008d30f21fa52cb647d4b681c4271647> /Applications/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
         0x9a000 -    0x9bffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.227407) <b5f6001addb928d0200c784cea3867a1> /Applications/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
        0x180000 -   0x184ff3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.227407) <93cdd4aa187d5c061ba3ea414516018b> /Applications/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
        0x30b000 -   0x498fef +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.227407) <1a2036d523ca97dd1cc9197ca598b90a> /Applications/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x616000 -   0x978fff +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.227407) <4ccef8a1aef9a025e1270a8b053e76be> /Applications/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0xd1b000 -  0x1098ff3 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.227407) <c2ca6aaf79fb41dcecf29b5d05789e11> /Applications/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0x1607000 -  0x16b4fff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.227407) <35f0d2ff1aa9b4eb7c8686b3aa51a24c> /Applications/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
      0x1787000 -  0x17a9ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.227407) <b9489eb16251c8fa5abeb1d2835371f0> /Applications/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x17ca000 -  0x1829fff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.227407) <706687d199b2d6a66d776e61f9204ab6> /Applications/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x18b2000 -  0x190aff7 +AdobeXMP ??? (???) <fc80e7a2d150d5a89aee879b05153a34> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x1919000 -  0x19bfff3 +AdobeXMPFiles ??? (???) <cb814673a68c01e284a9500fa0d0e902> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x19fb000 -  0x1a8dfff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.227407) <8242b12a1da300979d673914f3525a8e> /Applications/Adobe Audition.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x1b26000 -  0x1b6ffff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.227407) <89dd2c457b7763be08abc65f62d8bb16> /Applications/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
      0x1b90000 -  0x1c3afff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.227407) <3afc9275fc8a12ba9dee12e06a84346f> /Applications/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
      0x1d34000 -  0x1d52ff3 +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.227407) <cefb69c22b6f48031e762a7c27db7365> /Applications/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
      0x1d7c000 -  0x1d87fff +com.adobe.aucore.framework 1.0 (1.0) <5138c72ad70915c9c7cf2dfb0bb63557> /Applications/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
      0x1d94000 -  0x1f6bff2 +com.adobe.audsp.framework 1.0 (1.0) <1d00c1bb22390682a7d47c0eb91d746f> /Applications/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
      0x1ffc000 -  0x2131fef +com.adobe.auaudiocomponents.framework 1.0 (1.0) <cad732eed001d483b0b0ddab3cb7632e> /Applications/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
      0x2229000 -  0x259dff7 +com.adobe.aubackend.framework 1.0 (1.0) <839c916a0b0135cb481d1a11b58a2708> /Applications/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
      0x28af000 -  0x28b6fff +com.adobe.dvaundo.framework dvaundo version 5.0.0 (5.0.0.227407) <c879499b14be2a58e3a916a22bcb8599> /Applications/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
      0x28c2000 -  0x2bf3fef +AuApplication ??? (???) <b85693ec7b9b8ff28224a867fdade88a> /Applications/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
      0x2ec2000 -  0x2fa5feb +com.adobe.auuitoolkit.framework 1.0 (1.0) <11fc973340404df97bad2aaf1c698681> /Applications/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
      0x30ed000 -  0x3185ffb +AdobeExtendScript ??? (???) <46913918dc81801b64ca20859142b7cd> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x31e4000 -  0x326aff7 +com.adobe.AdobeScCore ScCore 4.0.5 (4.0.5.3233) <c43541af83a7e11d50fb1ec7d6120ae9> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x32ab000 -  0x33bcffb +com.adobe.auscripting.framework 1.0 (1.0) <9f05f5c5d1da4c5fe8caef6062622853> /Applications/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
      0x3545000 -  0x35b4fff +com.adobe.auaudiocomponentsui.framework 1.0 (1.0) <fb33d5f05dd9cd3d4fdb97354b9b1c97> /Applications/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponen tsUI
      0x3652000 -  0x3fcdfef +AuUI ??? (???) <2a0283cad85fb9078c85f1a53e4c902d> /Applications/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
      0x48e4000 -  0x4923fff  com.apple.vmutils 4.1 (104) <ce02dba5e2e99fa2eb41a81bc9680985> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x4945000 -  0x494fff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.227407) <c782506aeb8b535f9faadd68c619dc75> /Applications/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0x4963000 -  0x49e0fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.227407) <f3cc925c22446042fa7d27b548cd668a> /Applications/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0x4a45000 -  0x4b19fef +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.227407) <dbd4a2d42153724edb7ae7cef3f4298e> /Applications/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
      0x4c13000 -  0x4c32fed  com.apple.audio.CoreAudioKit 1.5 (1.5) <585f5ec95dc8f1efe51d820be84d53a6> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
      0x4c44000 -  0x4d2cccb +iZBase ??? (???) <773f066f8fbe4947ba51d3a1bc62d2e1> /Applications/Adobe Audition.app/Contents/Frameworks/iZBase.framework/Versions/A/iZBase
      0x4da9000 -  0x4e0de48 +iZDSPBase ??? (???) <c1575f2ece4643ad8f48d15b7097f082> /Applications/Adobe Audition.app/Contents/Frameworks/iZDSPBase.framework/Versions/A/iZDSPBase
      0x4e26000 -  0x4ebc3a6 +iZotope_Radius ??? (???) <b6af5a0a6cfd429884509fd830471654> /Applications/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
      0x4ef9000 -  0x4f4fffb +com.adobe.headlights.LogSessionFramework ??? (2.1.0.1075) <abe97aafc5a9c72963d973ffb791bde2> /Applications/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x4f98000 -  0x5226fec +libxerces-c-3.0.dylib ??? (???) <cde6ff466d9a55b97df8ceb48ebb54b9> /Applications/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x53a9000 -  0x53d6ffb  libcurl.4.dylib ??? (???) <e70ed3c4c3a9ab52cca43930b038b2b8> /usr/lib/libcurl.4.dylib
      0x53e1000 -  0x5504ff7 +AdobeACE ??? (???) <6b4856dc3d41cef7cb70d02eea97b8d2> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x5527000 -  0x5c01ff3 +AdobeAGM ??? (???) <fe943b4ded58f7538ae854e753a773bd> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x5cc6000 -  0x5ce3ff7 +AdobeBIB ??? (???) <6cc35acf5ccd1509b4bb3b48ad140526> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x5cea000 -  0x5d10ffb +AdobeBIBUtils ??? (???) <b9888beea93950e31cd33313ac14a073> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x5d17000 -  0x6046ff3 +com.adobe.CoolType AdobeCoolType 5.10.7.10201 (5.10.7.10201) <6810a678b1dff96d256025ae3fda923a> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x6098000 -  0x6105ffb +com.adobe.amtlib amtlib 3.5.0.34 (3.5.0.34) <8c1ebc9eddff660b03fb196ce8a4ced8> /Applications/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x611c000 -  0x611fff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <ffddab7a220f7344f12b010ca0c41dab> /Applications/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x61ea000 -  0x61f6ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.7 (2.2.7) <ed8425ef125abdc9e8620a9f431af3d9> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
      0x67d4000 -  0x67d4ff7 +net.sourceforge.SafariAdBlockLoader 0.4.0 RC3 (0.4.0 RC3) <8e9a66419ce75416dc84883db8bafdda> /Library/InputManagers/Safari AdBlock/Safari AdBlock Loader.bundle/Contents/MacOS/Safari AdBlock Loader
      0x17ef3000 - 0x182dafff  com.apple.RawCamera.bundle 3.4.0 (545) <46f9387243c4db157889522a00d16c32> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x1a67d000 - 0x1a6b0fe3 +com.adobe.pip ??? (5.5.0.0) <6fcbb4c57eef1af802c638e429e66ea9> /Applications/Adobe Audition.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
      0x1a6bb000 - 0x1a722fe7 +com.adobe.amt.services AMTServices 3.5.0.34 (BuildVersion: 3.5; BuildDate: Tue Sep 14 2010 21:49:00) (3.5.0.34) <f56d7855b0f74e7e1997d4fc2f5acb2d> /Applications/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x1a843000 - 0x1a845ffe  com.apple.AutomatorCMM 1.1 (162) <413d7e87f90ba14adf2c2a08af448666> /System/Library/Contextual Menu Items/AutomatorCMM.plugin/Contents/MacOS/AutomatorCMM
      0x1a854000 - 0x1a87dfeb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <e0f7666b921dc4d663b3e8b445d26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x1d21c000 - 0x1d28cfeb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36d53a2c0dab34c648c749d2ecf52d0d> /Applications/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
      0x1d2e9000 - 0x1d2eefff  com.apple.DictionaryServiceComponent 1.1 (1.1) <fc3321c414eddc46ff6cd774ab7dd0dd> /System/Library/Components/DictionaryService.component/Contents/MacOS/DictionaryService
      0x1d2f8000 - 0x1d2fbfef  com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
      0x1d49b000 - 0x1d49efff  com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <51c811377017028f8904ad779e6a1344> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x1d4a4000 - 0x1d4aafff  com.apple.audio.AppleHDAHALPlugIn 1.7.1 (1.7.1a2) <a0a4389b5ac52ab84397d2b25c9d3b9c> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x1d50d000 - 0x1d572fde  com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
      0x1d592000 - 0x1d5d8fc3  com.apple.motion.component 1.0 (1.0) <77973a134e79426f853f2318e52a2207> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
      0x1d5de000 - 0x1d5e102f +Motion ??? (???) <b5e862eee0ff4f86a78998e3e601a18c> /Library/Frameworks/Motion.framework/Versions/A/Motion
      0x1d636000 - 0x1d68cfd6  com.apple.DVCPROHDAudio 1.3 (1.3) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
      0x1d6c8000 - 0x1d6c9fe1  com.apple.textencoding.unicode 2.2 (2.2) <09ac11c81bf4e673a30cc364868fdc11> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x1d800000 - 0x1d84afec  com.apple.DVCPROHDMuxer 1.3 (1.3) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
      0x1fc19000 - 0x1fc32fef +com.adobe.AmioWav.bundle 1.0 (1.0) <1e0d749db1d07cd16b262ae69b9129e8> /Applications/Adobe Audition.app/Contents/Amio Plug-Ins/AmioWav.bundle/Contents/MacOS/AmioWav
      0x1fcea000 - 0x1fcebff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
      0x1fee2000 - 0x1fef9fff +com.adobe.AmioAiff.bundle 1.0 (1.0) <1f5ef60f03806900232f1602a94fdf49> /Applications/Adobe Audition.app/Contents/Amio Plug-Ins/AmioAiff.bundle/Contents/MacOS/AmioAiff
      0x21022000 - 0x21023ffd  com.apple.BluetoothMenu 2.1.8 (2.1.8f2) /System/Library/Contextual Menu Items/BluetoothContextualMenu.plugin/Contents/MacOS/BluetoothContextualMenu
      0x21028000 - 0x21028fff +com.parallels.cmplugin ParallelsCM version 1.0 (1.0) /Library/Contextual Menu Items/ParallelsCM.plugin/Contents/MacOS/ParallelsCM
      0x211f0000 - 0x211f5fff +com.roxio.ToastItPlugin ToastIt 1.1.2 (build 18) (1.1.2) <271b940259dab4f545540356099bd7bb> /Users/mario/Library/Contextual Menu Items/ToastIt.plugin/Contents/MacOS/ToastIt
      0x2159a000 - 0x2159cfff  com.apple.BezelServicesFW 1.4.9212 (1.4.9212) /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
      0x22533000 - 0x22581ffb +com.adobe.SesxNative.bundle 1.0 (1.0) <d95f8cb996fee515fd1035e0020fbddf> /Applications/Adobe Audition.app/Contents/Session Plug-Ins/SesxNative.bundle/Contents/MacOS/SesxNative
      0x2395d000 - 0x239d4ff2 +com.izotope.audioplugins.VST.TubeCompressor 1.0.0 (1.0.0b997) <4c4e2245164809ff4047437eb6f02745> /Applications/Adobe Audition.app/Contents/Plug-Ins/VST/TubeModeledCompressor.vst/Contents/MacOS/PluginHooksVS T
      0x239f0000 - 0x23cb2fee +TubeModeledCompressorCore ??? (???) <611a069b7c588bc57ef3be2fb516c002> /Applications/Adobe Audition.app/Contents/Plug-Ins/VST/TubeModeledCompressor.vst/Contents/Resources/TubeModel edCompressorCore.bundle/Contents/MacOS/TubeModeledCompressorCore
      0x24242000 - 0x242b9ff2 +com.izotope.audioplugins.VST.DeHummer 1.0.0 (1.0.0b997) <4c4e2245164809ff4047437eb6f02745> /Applications/Adobe Audition.app/Contents/Plug-Ins/VST/DeHummer.vst/Contents/MacOS/PluginHooksVST
      0x243dd000 - 0x24916ff6 +DeHummerCore ??? (???) <688f9e1c8ed37243938fe77752943a86> /Applications/Adobe Audition.app/Contents/Plug-Ins/VST/DeHummer.vst/Contents/Resources/DeHummerCore.bundle/Co ntents/MacOS/DeHummerCore
      0x24c00000 - 0x24c77ff2 +com.izotope.audioplugins.VST.VocalEnhance 1.0.1 (1.0.1b997) <4c4e2245164809ff4047437eb6f02745> /Applications/Adobe Audition.app/Contents/Plug-Ins/VST/VocalEnhancer.vst/Contents/MacOS/PluginHooksVST
      0x24d5f000 - 0x25298ffe +VocalEnhancerCore ??? (???) <8bda86623db68034e738e98699c319e3> /Applications/Adobe Audition.app/Contents/Plug-Ins/VST/VocalEnhancer.vst/Contents/Resources/VocalEnhancerCore .bundle/Contents/MacOS/VocalEnhancerCore
      0x2636c000 - 0x26379fe7 +com.getdropbox.finderplugin ??? (169) <dc86a4751c477285d1dc52a50d0321a7> /Users/mario/Library/Contextual Menu Items/DropboxPlugin.plugin/Contents/MacOS/DropboxPlugin
      0x263ac000 - 0x26531fe3  GLEngine ??? (???) <945546cdf016a4e5cbbf2ad1bccd0ab4> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x2655f000 - 0x268c8fe8  com.apple.GeForce8xxxGLDriver 1.5.48 (5.4.8) <880ed3155078052260ade6e705c9ca64> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
      0x26c03000 - 0x26c1fff7  GLRendererFloat ??? (???) <7b68e0fde5d97927d5407221bdf8ace0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
      0x27cdd000 - 0x27d52ff7  com.apple.Bluetooth 2.1.9 (2.1.9f10) <d70a88066ebf7eb8071781f686caced3> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
      0x27da1000 - 0x27da6fff  com.apple.FolderActionsMenu 1.3.2 (1.3.2) <9305ccde37dcf5329fd9faea1db1f153> /System/Library/Contextual Menu Items/FolderActionsMenu.plugin/Contents/MacOS/FolderActionsMenu
      0x27dad000 - 0x27db7ff7 +com.AmuseInc.MyLivingDesktop 4.03 (4.03) <8e8dd4cb93d249f1f2ee6c11eb51bb50> /Library/Contextual Menu Items/My Living Desktop.plugin/Contents/MacOS/My Living Desktop
      0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
      0x90003000 - 0x90413fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x90414000 - 0x90424fff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <273d96ff861dc68be659c07ef56f599a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x90458000 - 0x90af8fef  com.apple.CoreGraphics 1.409.7 (???) <7b65edcce394f39b6a1954d5e30bc34c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x90af9000 - 0x90afbff5  libRadiance.dylib ??? (???) <276f13ab6429e05b093a8dda251e3b53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x90afc000 - 0x90b11ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x90b12000 - 0x91310fef  com.apple.AppKit 6.5.9 (949.54) <4df5d2e2271175452103f789b4f4d8a8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x91317000 - 0x91642ff6  com.apple.QuickTime 7.6.9 (1680.9) <024f122335016a54f8e59ddb4c79901d> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x91643000 - 0x91647fff  libGIF.dylib ??? (???) <36f7b0255a81d97c7b360c3b11b4e462> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x9164b000 - 0x91651fff  com.apple.print.framework.Print 218.0.3 (220.2) <0b70ba17cbbe4d62a00bec91c8cc675e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x917b6000 - 0x917b6ff8  com.apple.ApplicationServices 34 (34) <ee7bdf593da050bb30c7a1fc446eb8a6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x91814000 - 0x91814fff  com.apple.Carbon 136 (136) <2ea8decb44f41c4f2fc6fe93e0a53174> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x91888000 - 0x91c46fea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x91c4c000 - 0x91ca6ff7  com.apple.CoreText 2.0.5 (???) <5483518a613464d043455ac661a9dcbe> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x91ca7000 - 0x91d03ff7  com.apple.htmlrendering 68 (1.1.3) <1c5c0c417891b920dfe139385fc6c155> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x91d8f000 - 0x91db7ff7  com.apple.shortcut 1.0.1 (1.0) <a452d3f7feae073a12718c2bc553c575> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x91db8000 - 0x91e68fff  edu.mit.Kerberos 6.0.14 (6.0.14) <673f107cdae80c084774a27bc7bc46c1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x91e69000 - 0x91e7ffff  com.apple.DictionaryServices 1.0.0 (1.0.0) <7d20b8d1fb238c3e71d0fa6fda18c4f7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x91e80000 - 0x91e87ff7  libCGATS.A.dylib ??? (???) <29154398dbefc2a1a97715e5af1e3552> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGATS.A.dylib
      0x91e88000 - 0x91f07ff5  com.apple.SearchKit 1.2.2 (1.2.2) <3b5f3ab6a363a4d8a2bbbf74213ab0e5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x91f57000 - 0x91f57ffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x91f58000 - 0x92091ff7  libicucore.A.dylib ??? (???) <f2819243b278259b9a622ea111ea5fd6> /usr/lib/libicucore.A.dylib
      0x92092000 - 0x921f9ff3  libSystem.B.dylib ??? (???) <c8f52e158bf540cc000146ca8a705958> /usr/lib/libSystem.B.dylib
      0x92cfe000 - 0x92d88ff7  com.apple.DesktopServices 1.4.9 (1.4.9) <f5e51a76d315798371b3dd35a4d46d6c> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x92d8a000 - 0x92e51ff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x9320f000 - 0x93260ff7  com.apple.HIServices 1.7.1 (???) <ba7fd0ede540a0da08db027f87efbd60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x9329e000 - 0x932d5fff  com.apple.SystemConfiguration 1.9.2 (1.9.2) <eab546255ac099b9616df999c9359d0e> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x932d6000 - 0x93310fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x93311000 - 0x9331fffd  libz.1.dylib ??? (???) <a98b3b221a72b54faf73ded3dd7000e5> /usr/lib/libz.1.dylib
      0x93320000 - 0x933adff7  com.apple.framework.IOKit 1.5.2 (???) <7a3cc24f78f93931731203854ae0d891> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x933ae000 - 0x93435ff7  libsqlite3.0.dylib ??? (???) <7d1fcfae937da95c7d2b9bdea57e6dc0> /usr/lib/libsqlite3.0.dylib
      0x93436000 - 0x934ddfec  com.apple.CFNetwork 438.16 (438.16) <dbf00ca36a09edfae60ec44f9d7a9ef9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x9365d000 - 0x936a6fef  com.apple.Metadata 10.5.8 (398.26) <e4d268ea45379200f03cdc7c8bedae6f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x936a7000 - 0x936b3ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x9377e000 - 0x93825feb  com.apple.QD 3.11.57 (???) <35f058678972d42b88ebdf652df79956> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x93826000 - 0x93829fff  com.apple.help 1.1 (36) <1a25a8fbb49a830efb31d5c0a52939cd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x93aa0000 - 0x93aacffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x93aad000 - 0x93c7eff3  com.apple.security 5.0.6 (37592) <0b25e1e4cc34431630f01edb3fdf54d1> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x93caf000 - 0x93cb6fe9  libgcc_s.1.dylib ??? (???) <e280ddf3f5fb3049e674edcb109f389a> /usr/lib/libgcc_s.1.dylib
      0x93d9a000 - 0x93e82ff3  com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x94008000 - 0x94009ffc  libffi.dylib ??? (???) <eaf10b99a3fbc4920b175809407466c0> /usr/lib/libffi.dylib
      0x9407e000 - 0x9410bff7  com.apple.LaunchServices 292 (292) <a41286c7c1eb20ffd5cc796f791070f0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x9410c000 - 0x9414bfef  libTIFF.dylib ??? (???) <a5991d757f0c17a9bb8b1bcb14ab9ec0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x9414c000 - 0x9414cffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
      0x94153000 - 0x94205ffb  libcrypto.0.9.7.dylib ??? (???) <d02f7e5b8a68813bb7a77f5edb34ff9d> /usr/lib/libcrypto.0.9.7.dylib
      0x94206000 - 0x94206ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x94207000 - 0x942e7fff  libobjc.A.dylib ??? (???) <d1469bf9fe852864d4fff185c72768e8> /usr/lib/libobjc.A.dylib
      0x951e9000 - 0x95216feb  libvDSP.dylib ??? (???) <4daafed78a471133ec30b3ae634b6d3e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x95217000 - 0x95242fe7  libauto.dylib ??? (???) <2e44c523b851e8e25f05d13a48070a58> /usr/lib/libauto.dylib
      0x95400000 - 0x95402fff  com.apple.securityhi 3.0 (30817) <db23f4bad9f63a606468a4047a69b945> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x95403000 - 0x9540bfff  com.apple.DiskArbitration 2.2.1 (2.2.1) <2664eeb3a4d0c95a21c089892a0ae8d0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x9540c000 - 0x9540cffa  com.apple.CoreServices 32 (32) <373d6a888f9204641f313bc6070ae065> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x9540d000 - 0x9542aff7  com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x956d2000 - 0x9574cff8  com.apple.print.framework.PrintCore 5.5.4 (245.6) <3839795086b6857d3c60064dce8702b5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x95946000 - 0x9594ffff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <da2d8411921a3fd8bc898dc753b7f3ee> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x95950000 - 0x95950ffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x95951000 - 0x959aaff7  libGLU.dylib ??? (???) <a08a753efc35f8a27f9c8f938fa01101> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x95a02000 - 0x95a95fff  com.apple.ink.framework 101.3 (86) <d4c85b5cafa8027fff042b84a8be71dc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x95c2d000 - 0x95ce8fe3  com.apple.CoreServices.OSServices 228.1 (228.1) <76fdc146b4d9937f9c5cbaa1512e0023> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x95ce9000 - 0x95ce9ff8  com.apple.Cocoa 6.5 (???) <a1bc9247cf65c20f1a44d0973cbe649c> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x95cea000 - 0x961bbf76  libGLProgrammability.dylib ??? (???) <bf7fb226cbb412edfa377537c3e35877> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x961f3000 - 0x9620eff3  libPng.dylib ??? (???) <c0791798fb92acc136c250a373449359> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x96227000 - 0x9622effe  libbsm.dylib ??? (???) <fa7ae5f1a621d9b69e7e18747c9405fb> /usr/lib/libbsm.dylib
      0x96323000 - 0x96347feb  libssl.0.9.7.dylib ??? (???) <5b29af782be5894be8b336c9c73c18b6> /usr/lib/libssl.0.9.7.dylib
      0x96348000 - 0x963c5fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x963c6000 - 0x964a7ff7  libxml2.2.dylib ??? (???) <b3bc0b280c36aa17ac477b4da56cd038> /usr/lib/libxml2.2.dylib
      0x964a8000 - 0x964b3fe7  libCSync.A.dylib ??? (???) <06652e36188190ec04d294f49c68f28a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x964f9000 - 0x965c4fef  com.apple.ColorSync 4.5.3 (4.5.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x965c5000 - 0x96642feb  com.apple.audio.CoreAudio 3.1.2 (3.1.2) <782a08c44be4698597f4bbd79cac21c6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x96643000 - 0x966d6ff3  com.apple.ApplicationServices.ATS 3.8 (???) <e61b0945da6ab368348a927f7428ad67> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x966d7000 - 0x9680afe7  com.apple.CoreFoundation 6.5.7 (476.19) <a332c8f45529ee26d2e9c36d0c723bad> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x969ae000 - 0x969b3fff  com.apple.CommonPanels 1.2.4 (85) <c135f02edd6b2e2864311e0b9d08a98d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x969d3000 - 0x96a14fe7  libRIP.A.dylib ??? (???) <378694b494a02de1b0c812da572579d2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x96a15000 - 0x96a39fff  libxslt.1.dylib ??? (???) <f0872c9ba3c17861fba8c45a3647cee1> /usr/lib/libxslt.1.dylib
      0x96a3a000 - 0x96a52fff  com.apple.openscripting 1.2.8 (???) <a6b446eb8ec7844096df5fb9002f5c7b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x96a53000 - 0x96ba5ff3  com.apple.audio.toolbox.AudioToolbox 1.5.3 (1.5.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x96ba6000 - 0x96ba6ffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x96be2000 - 0x96c24fef  com.apple.NavigationServices 3.5.2 (163) <72cdc9d21f6690837870923e7b8ca358> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x96c57000 - 0x96c73ff3  com.apple.CoreVideo 1.6.1 (48.6) <186cb311c17ea8714e918273c86d3c13> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x96c84000 - 0x97021fef  com.apple.QuartzCore 1.5.8 (1.5.8) <8dc9ad0616bf56ebba60d6353737ac4e> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x97022000 - 0x97032ffc  com.apple.LangAnalysis 1.6.5 (1.6.5) <d057feb38163121ffd871c564c692804> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x97033000 - 0x97071fff  libGLImage.dylib ??? (???) <b154e14c351ddc950d5228819201435e> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x97072000 - 0x97076fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
      0x97077000 - 0x970a0fff  libcups.2.dylib ??? (???) <2b0ab6b9fa1957ee940835d0cfd42894> /usr/lib/libcups.2.dylib
      0x970a1000 - 0x970bffff  libresolv.9.dylib ??? (???) <39f6d8651f3dca7a1534fa04322e6763> /usr/lib/libresolv.9.dylib
      0x970c0000 - 0x97208ff7  com.apple.ImageIO.framework 2.0.7 (2.0.7) <acf821a3c418fdc86ef02b654366f5f6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x973d8000 - 0x973f7ffa  libJPEG.dylib ??? (???) <d23f3f3b9d168bf32f89449f83fa07f7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x97471000 - 0x97478fff  com.apple.agl 3.0.9 (AGL-3.0.9) <d64d715dab8565014f5e2f239fd2410c> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x97479000 - 0x974a8fe3  com.apple.AE 402.3 (402.3) <aee412511c8725cd1a2cfb6501316bd5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x974aa000 - 0x974b7fe7  com.apple.opengl 1.5.10 (1.5.10) <95c3d857570a137d0e8285c9eafa1112> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x974b8000 - 0x97734fe7  com.apple.Foundation 6.5.9 (677.26) <c68b3cff7864959becfc7fd1a384f925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x97735000 - 0x97792ffb  libstdc++.6.dylib ??? (???) <7d389389a99ce696726cf4c8980cc505> /usr/lib/libstdc++.6.dylib
      0x97882000 - 0x97b5cff3  com.apple.CoreServices.CarbonCore 786.16 (786.16) <60b518e4ad02b91826240199a6311286> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x97b5d000 - 0x97b67feb  com.apple.audio.SoundManager 3.9.2 (3.9.2) <df077a8048afc3075c6f2d9e7780e78e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x97b68000 - 0x97e70fe7  com.apple.HIToolbox 1.5.6 (???) <eece3cb8aa0a4e6843fcc1500aca61c5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0xba900000 - 0xba916fff  libJapaneseConverter.dylib ??? (???) <b9aea83b1cd97f3230999ebfcbf63e7c> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
      0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
        • 1. Re: One more problem
          grimflea Level 1
          I also just normalised a file and it turned out with the most horrid distortion... something I can't seem to be able to undo as the imported source file was changed, so I have to re-import another copy of the wav.
          • 2. Re: One more problem
            _durin_ Adobe Employee
            Could you e-mail the .sesx session file to audbugs@adobe.com?  (Don't send the media - just the session file.)  I'd like to take a look and see if I can reproduce this issue.
            In the meantime, what audio device are you using?  The public beta certainly contained some bugs, but nothing I'm aware of that should be causing such problems.
            Thanks.
