2 Replies Latest reply on Jan 13, 2011 5:16 PM by rottenuncle
    AS: Select odd & even table columns
    rottenuncle Level 1
      I'm trying to set up some fairly complicated table formatting and need to different text insets, strokes, etc to alternating columns. Can't seem to figure out how to select alternating columns. I tried the following:
      set myColumns to every column of myTable whose (index mod 2) = 0
      but got "error "Can’t make index into type number." number -1700 from index to number" despite the fact that the columns index is supposed to be an integer.
      Any ideas?
        • 1. Re: AS: Select odd & even table columns
          L. Guy O'Rojo Level 2
          You could process it one column at a time:
          tell application "Adobe InDesign CS4"
          activate
          tell document 1
          tell page 1
          tell page item 1 -- a text frame with a table in it
          set myColumns to {}
          tell table 1
          repeat with i from 1 to (count columns)
          if i mod 2 is 1 then -- odd column
          set myColumns to myColumns & (a reference to column i)
          select (a reference to column i) -- show selected column, or do whatever to this column
          delay 1 -- for demo purposes
          end if
          end repeat
          end tell
          end tell
          end tell
          end tell
          end tell
          return myColumns
          -->  {column 1 of table id 251 of text frame id 247 of page id 190 of spread id 185 of document "Untitled-1" of application "Adobe InDesign CS4", column 3 of table id 251 of text frame id 247 of page id 190 of spread id 185 of document "Untitled-1" of application "Adobe InDesign CS4"}
          • 2. Re: AS: Select odd & even table columns
            rottenuncle Level 1
            That's essentially what I ended up doing:
            tell myTable
            repeat with i from 1 to n    -- n = 1/2 column count
            set myOddColumn to column (2 * i - 1)
            tell myOddColumn
            set left inset of every cell ...
            set bottom inset of every cell ...
            set left edge stroke type ...
            etc...
            end tell
            set myEvenColumn to column (2 * i)
            tell myEvenColumn
            set right inset of every cell ...
            set right edge stroke type ...
            etc...
            end tell
            end repeat
            end tell
