0 Replies Latest reply on Jan 13, 2011 11:27 AM by tda2
    Connection issue
    tda2
      HI,
      I'm not able to get a website connected to Contribute - this is first time running into this issue.
      I'm using IIS 6 - the site is on a dedicated ip address setup with FTP access. I am able to connect to this site using Filezilla.
      When i try to connect in Contribute - i get the following:
      Upload a File Test:  REMOTE_IO_ERROR - Error reading or writing remote resource
      and when i use the FTP checker/tester - i get the following:
      ======================== Test Results ==========================
      NOTE: Microsoft FTP Service has been detected.
      For more information on FTP server compatibility issues, please see:
      http://www.macromedia.com/support/contribute/ts/documents/ftp_info.htm
      Login:  SUCCESS!
      Directory Listing Test:  SUCCESS!
      Make Directory Test:  SUCCESS!
      Change Directory Test:  SUCCESS!
      Upload a File Test:  Unkown error was thrown
      .Please send this code to Macromedia:  19
      -------------------------------- FTP log from the last operation -------------------------------
      > CWD /mm_diagnose
      < 250 CWD command successful.
      > PORT 10,0,0,16,216,217
      < 200 Port command successful.
      > TYPE I
      < 200 Type set to I.
      > STOR upload_test1_reg_.mm
      < 150-Scanning file for viruses
      < 150-There'll be a delay while we scan for viruses
      < 150 Data connection already open; Transfer starting.
      < 221-Uploading file
      < 221 Transfer complete.
      Cleaning Test Directory:  Due to the previous error, the application failed to clean up the test folder.
      In order to run a clean test,
      please go to the directory you specified and manually remove the folder called "mm_diagnose."
      If you are using an anonymous account without delete permissions,
      the Contribute delete page operation will not function properly.
      > CWD /
      > RMD mm_diagnose
      < 550 mm_diagnose: The directory is not empty.
      > CWD /mm_diagnose
      > PORT 10,0,0,16,216,218
      > TYPE A
      < 200 Type set to A.
      > LIST
      < 125 Data connection already open; Transfer starting.
      < 01-13-11  02:20PM                   27 upload_test1_reg_.mm
      < 226 Transfer complete.
      Thank you!
