1. Re: EMC documentum configuration error
Raghu A Jan 14, 2011 5:00 AM (in response to Sunil Gupta)Can you please post the logs file as well. For turnkey installations it is available at C:\Adobe\Adobe LiveCycle ES2\jboss\server\lc_turnkey\log\server.log.
Also, do you have access to Adobe LiveCycle workbench?
2. Re: EMC documentum configuration error
Sunil Gupta Jan 15, 2011 11:02 PM (in response to Raghu A)Raghu,
Yes, surely i will send you log file.
But i am using weblogic.
Yes, I have access on workbench. Let me know if you need anything from workbench.
Sunil Gupta
4. Re: EMC documentum configuration error
Sunil Gupta Jan 18, 2011 10:46 AM (in response to Sunil Gupta)Please answer me something
5. Re: EMC documentum configuration error
Raghu A Jan 18, 2011 8:32 PM (in response to Sunil Gupta)Hi Sunil,
Sorry for being late on this. I was pre-occupied with some tasks so could not respond back early on.
I don't see any log file attached in here . Also, I'll need logs from both configuration Manager as well as from weblogic side. Do let me know in case you need more information regarding there locations.
Additionally, I inquired about the workbench because I wanted to give a shot towards re-installing Documentum DSC. However, I'll not advise you that unless I have look at the log files
Thanks and Regards,
Raghu
6. Re: EMC documentum configuration error
Sunil Gupta Jan 18, 2011 10:40 PM (in response to Raghu A)Thanks Raghu for Prompt Reply
Please find the log below from Configuration Manager. I skipped the step while configuring the EMC Documentum connector on Configure adobe livecycle es2 connector for EMC Documentum screen when i recieved error message "Update adobe livecycle es2 with documentum content server information :fail".
i finished the configuration after configuring the reader extension .
Please find the log below.
[2011-01-17 19:15:24,397], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.logging.LCMLogManager, Loaded log configuration file: /com/adobe/livecycle/lcm/logging/log.properties reloadIfConfigured=false
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [lcm.version=9.0.0.0.20091019.2.607963]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [lcm.homeDir=D:\Applications\Adobe\Adobe LiveCycle ES2\configurationManager\bin\..]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [java.specification.version=1.6]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [java.vm.version=14.1-b02]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [java.vm.vendor=Sun Microsystems Inc.]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [java.home=C:\Program Files (x86)\Java\jre6
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [java.class.version=50.0]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [os.arch=x86]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [os.name=Windows Server 2008]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [sun.os.patch.level=]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [os.version=6.1]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [sun.arch.data.model=32]
[2011-01-17 19:15:24,444], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [ip.stack=v4]
[2011-01-17 19:15:24,459], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [user.localhost=mumdmsdwinapp01/172.17.151.126]
[2011-01-17 19:15:24,459], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [user.name=dmstestadmin]
[2011-01-17 19:15:24,459], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [user.language=en]
[2011-01-17 19:15:24,459], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, Loading defaults from file: /defaults.properties
[2011-01-17 19:15:24,459], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, Loading user's last values from : ..\config\userValues.properties
[2011-01-17 19:15:24,553], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [lcm.targetApplicationServer=weblogic]
[2011-01-17 19:15:24,553], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [lcm.targetOperatingSystem=Windows]
[2011-01-17 19:15:24,553], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [lcm.targetOperatingSystemArch=x86_win32]
[2011-01-17 19:15:24,631], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, [install.version=9.0.0.0.20091022.1.605351]
[2011-01-17 19:15:25,005], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.LCMGUI, Language overridden to: en
[2011-01-17 19:15:25,005], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.LCMGUI, lcm.lang.selected=en
[2011-01-17 19:15:25,629], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, Loading config: /lcm-config.xml
[2011-01-17 19:15:28,219], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.util.NetUtils, Host check is local: true
[2011-01-17 19:15:29,670], INFO, Thread-5, com.adobe.livecycle.lcm.feature.samples.DeploySamplesDialog$SamplesInitThread, Initialization of samples started
[2011-01-17 19:15:29,670], INFO, Thread-5, com.adobe.livecycle.lcm.feature.samples.DeploySamplesDialog, Loading samples. LFS selection has changed or not previously loaded
[2011-01-17 19:15:29,701], INFO, Thread-5, com.adobe.livecycle.samples.SamplesManagerImpl, selectedSolutionComponents:[]
[2011-01-17 19:15:29,716], INFO, Thread-5, com.adobe.livecycle.samples.samplesconfig.SamplesRunSetup, lc8HomeDir :D:\Applications\Adobe\Adobe LiveCycle ES2\configurationManager\bin\..\..
[2011-01-17 19:15:29,716], INFO, Thread-5, com.adobe.livecycle.lcm.feature.samples.DeploySamplesDialog$SamplesInitThread, Initialization of samples completed
[2011-01-17 19:15:30,106], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.plugin.PluginLoader, Loading pluging ..\plugins\cs-plugin
[2011-01-17 19:15:30,153], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.CSPluginBootStrapper, Boostrapping GUI plugin...
[2011-01-17 19:15:30,762], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.CSDataManager, Loading config file: /amp-config.xml
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [authentication-service.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-branding-common.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-services.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-extensions.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-transformation-service.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-eventaction-service.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-webscripts-service.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [reviewtemplatecreation.amp,null,[]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [genericservice-action.amp,Generic Service Invocation,[ALC-LFS-Foundation]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-assemble-clipboard-items.amp,Dynamic Assembly Sample,[ALC-LFS-Output, ALC-LFS-PDFGenerator]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-datacapture-service.amp,Data Capture Sample,[ALC-LFS-Forms, ALC-LFS-ReaderExtensions]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-forms-integration.amp,LiveCycle Forms Integration,[ALC-LFS-Forms]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-native-repository-ref.amp,LiveCycle Repository Integration,[ALC-LFS-Foundation, ALC-LFS-Forms, ALC-LFS-ReaderExtensions]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [lc-review-and-commenting.amp,Review and Commenting,[ALC-LFS-Foundation, ALC-LFS-ProcessManagement, ALC-LFS-ReaderExtensions, ALC-LFS-PDFGenerator, ALC-LFS-Output]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [process_samples.amp,Process Samples,[ALC-LFS-ProcessManagement]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [rightsmanagement-action.amp,Rights Management Action,[ALC-LFS-RightsManagement]] parsed.
[2011-01-17 19:15:30,777], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.config.AMPConfigData, AMP [workspace-integration.amp,LiveCycle Workspace ES2 Integration,[ALC-LFS-ProcessManagement]] parsed.
[2011-01-17 19:15:31,261], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Loading help mappings from file: helpMapping.properties
[2011-01-17 19:15:31,261], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Help file missing for com.adobe.livecycle.lcm.feature.configureContentManager.ConfigureContentManagerDialog:/co nfigureContentManager.html
[2011-01-17 19:15:31,261], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Help file missing for com.adobe.livecycle.lcm.feature.expressTurnkey.WLTurnkeyDialog:/wlturnkeySettings.html
[2011-01-17 19:15:31,261], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.CSPluginBootStrapper, Boostrapping GUI plugin completed
[2011-01-17 19:15:31,261], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.plugin.PluginLoader, Loading pluging ..\plugins\documentum-plugin
[2011-01-17 19:15:31,308], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.DocumentumPluginBootstrapper, Boostrapping plugin...
[2011-01-17 19:15:31,323], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.DocumentumPluginBootstrapper, Dctm LFS Selected: true
[2011-01-17 19:15:31,557], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.DocumentumPluginBootstrapper, Boostrapping plugin completed
[2011-01-17 19:15:31,573], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.plugin.PluginLoader, Loading pluging ..\plugins\filenet-plugin
[2011-01-17 19:15:31,620], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.filenet.FilenetPluginBootstrapper, Boostrapping plugin...
[2011-01-17 19:15:31,620], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.filenet.FilenetPluginBootstrapper, Filenet LFS Selected: false
[2011-01-17 19:15:31,885], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Dialog com.adobe.livecycle.lcm.common.gui.JNDIPortDialog already mapped to a help file: com.adobe.livecycle.lcm.common.gui.JNDIPortDialog
[2011-01-17 19:15:31,885], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Dialog com.adobe.livecycle.lcm.common.gui.ConfigureECMESReleaseWaysDialog already mapped to a help file: com.adobe.livecycle.lcm.common.gui.ConfigureECMESReleaseWaysDialog
[2011-01-17 19:15:31,885], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Dialog com.adobe.livecycle.lcm.common.gui.TestConnectionAndServerStartDialog already mapped to a help file: com.adobe.livecycle.lcm.common.gui.TestConnectionAndServerStartDialog
[2011-01-17 19:15:31,885], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.filenet.FilenetPluginBootstrapper, Boostrapping plugin completed
[2011-01-17 19:15:31,885], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.plugin.PluginLoader, Loading pluging ..\plugins\ibmcm-plugin
[2011-01-17 19:15:31,947], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ibmcm.IBMCMPluginBootstrapper, Boostrapping plugin...
[2011-01-17 19:15:31,947], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ibmcm.IBMCMPluginBootstrapper, Dctm LFS Selected: true
[2011-01-17 19:15:31,947], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ibmcm.IBMCMPluginBootstrapper, IBM CM LFS Selected: false
[2011-01-17 19:15:31,947], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ibmcm.IBMCMPluginBootstrapper, Filenet LFS Selected: false
[2011-01-17 19:15:32,056], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Dialog com.adobe.livecycle.lcm.common.gui.ConfigureECMESReleaseWaysDialog already mapped to a help file: com.adobe.livecycle.lcm.common.gui.ConfigureECMESReleaseWaysDialog
[2011-01-17 19:15:32,056], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Dialog com.adobe.livecycle.lcm.common.gui.JNDIPortDialog already mapped to a help file: com.adobe.livecycle.lcm.common.gui.JNDIPortDialog
[2011-01-17 19:15:32,056], WARNING, AWT-EventQueue-0, com.adobe.livecycle.lcm.help.HelpManager, Dialog com.adobe.livecycle.lcm.common.gui.TestConnectionAndServerStartDialog already mapped to a help file: com.adobe.livecycle.lcm.common.gui.TestConnectionAndServerStartDialog
[2011-01-17 19:15:32,056], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ibmcm.IBMCMPluginBootstrapper, Boostrapping plugin completed
[2011-01-17 19:15:32,072], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.plugin.PluginLoader, Loading pluging ..\plugins\pdfg-plugin
[2011-01-17 19:15:32,134], INFO, AWT-EventQueue-0, com.adobe.pdfg.lcm.PDFGPluginBootstrapper, Boostrapping plugin...
[2011-01-17 19:15:32,134], INFO, AWT-EventQueue-0, com.adobe.pdfg.lcm.PDFGPluginBootstrapper, No appserver-specific plugin libraries found.
[2011-01-17 19:15:32,134], INFO, AWT-EventQueue-0, com.adobe.pdfg.lcm.PDFGPluginBootstrapper, Looking for classpath.xml in root of PDFG LCM plugin...
[2011-01-17 19:15:32,431], INFO, AWT-EventQueue-0, com.adobe.pdfg.lcm.PDFGPluginBootstrapper, Boostrapping plugin completed
[2011-01-17 19:15:32,431], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.plugin.PluginLoader, Loading pluging ..\plugins\upgrade-plugin
[2011-01-17 19:15:32,509], INFO, AWT-EventQueue-0, com.adobe.livecycle.upgrade.UpgradePluginBootstrapper, Searching for upgrade plugins ...
[2011-01-17 19:15:32,540], INFO, AWT-EventQueue-0, com.adobe.livecycle.upgrade.UpgradePluginBootstrapper, Looking for classpath.xml in root of adobe-upgrade.jar...
[2011-01-17 19:15:33,460], WARNING, AWT-EventQueue-0, com.adobe.livecycle.upgrade.UpgradePluginBootstrapper, PathElement entry [./LiveCycle_ES_SDK/client-libs/common/adobe-taskmanager-client-sdk.jar] of type [common] cannot be found.
[2011-01-17 19:15:33,523], INFO, AWT-EventQueue-0, com.adobe.livecycle.upgrade.UpgradeDataManager, Version: 9.0.0.0.20091020.1.222436
[2011-01-17 19:15:34,147], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.WelcomeDialog, onEntry()
[2011-01-17 19:15:37,033], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.WelcomeDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:15:37,033], INFO, AWT-EventQueue-0, com.adobe.livecycle.upgrade.gui.UpgradeModeSelectionDialog, onEntry()
[2011-01-17 19:15:38,250], INFO, AWT-EventQueue-0, com.adobe.livecycle.upgrade.gui.UpgradeModeSelectionDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:15:38,250], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.LiveCycleConfigSelectionDialog, onEntry()
[2011-01-17 19:15:40,949], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.LiveCycleConfigSelectionDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:15:40,949], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.LiveCycleConfigSelectionDialog, Selected LFSs : [ALC-LFS-Foundation, ALC-LFS-ConnectorEMCDocumentum, ALC-LFS-ContentServices, ALC-LFS-Output, ALC-LFS-Forms, ALC-LFS-BarcodedForms, ALC-LFS-DigitalSignatures, ALC-LFS-ReaderExtensions, ALC-LFS-ProcessManagement, ALC-LFS-RightsManagement]
[2011-01-17 19:15:40,949], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionPanel, onEntry()
[2011-01-17 19:15:45,878], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionPanel, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:15:45,878], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.util.NetUtils, Host check is local: true
[2011-01-17 19:15:45,878], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, onEntry()
[2011-01-17 19:15:47,547], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Starting processing
[2011-01-17 19:15:47,547], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsTask, Starting task: com.adobe.livecycle.lcm.feature.configureLC.MergeEarsTask@12467d8
[2011-01-17 19:15:47,563], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [0%, Copying archives]
[2011-01-17 19:15:48,842], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [5%, Collecting EARs for merging of adobe-livecycle-weblogic.ear]
[2011-01-17 19:15:48,842], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars, Merging ears (D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-lc-admin.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-lc-launchpad.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-launchpad-help.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-connectorforemcdocumentum.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentspace-help.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentspace-admin.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentservices-adminui.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-output-weblogic.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-convertpdf-weblogic.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-forms-weblogic.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-formdataintegration-weblogic.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-guides.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reader-extensions-servlet.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-readerext-help.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workspace-runtime.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workspace-help.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-edcserver-weblogic.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-rightsmgmt-help.ear) into (D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-core-weblogic.ear) output to (..\export\adobe-livecycle-weblogic.ear)
[2011-01-17 19:15:48,842], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [8%, Executing merge scripts for adobe-livecycle-weblogic.ear]
[2011-01-17 19:15:48,873], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Loading exclusion list: D:\Applications\Adobe\Adobe LiveCycle ES2\configurationManager\bin\..\scripts\assembly\excludes\core.excludes
[2011-01-17 19:15:59,856], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [11%, Merging in EAR adobe-lc-admin.ear]
[2011-01-17 19:15:59,856], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-lc-admin.ear
[2011-01-17 19:16:02,211], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [13%, Merging in EAR adobe-lc-launchpad.ear]
[2011-01-17 19:16:02,211], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-lc-launchpad.ear
[2011-01-17 19:16:02,430], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [16%, Merging in EAR adobe-launchpad-help.ear]
[2011-01-17 19:16:02,430], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-launchpad-help.ear
[2011-01-17 19:16:02,570], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [19%, Merging in EAR adobe-connectorforemcdocumentum.ear]
[2011-01-17 19:16:02,570], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-connectorforemcdocumentum.ear
[2011-01-17 19:16:02,773], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [22%, Merging in EAR adobe-contentspace-help.ear]
[2011-01-17 19:16:02,789], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentspace-help.ear
[2011-01-17 19:16:03,116], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [25%, Merging in EAR adobe-contentspace-admin.ear]
[2011-01-17 19:16:03,116], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentspace-admin.ear
[2011-01-17 19:16:03,428], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [28%, Merging in EAR adobe-contentservices-adminui.ear]
[2011-01-17 19:16:03,428], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentservices-adminui.ear
[2011-01-17 19:16:03,678], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [31%, Merging in EAR adobe-output-weblogic.ear]
[2011-01-17 19:16:03,678], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-output-weblogic.ear
[2011-01-17 19:16:04,848], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [34%, Merging in EAR adobe-convertpdf-weblogic.ear]
[2011-01-17 19:16:04,848], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-convertpdf-weblogic.ear
[2011-01-17 19:16:04,973], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [37%, Merging in EAR adobe-forms-weblogic.ear]
[2011-01-17 19:16:04,973], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-forms-weblogic.ear
[2011-01-17 19:16:09,216], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [40%, Merging in EAR adobe-formdataintegration-weblogic.ear]
[2011-01-17 19:16:09,216], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-formdataintegration-weblogic.ear
[2011-01-17 19:16:09,387], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [43%, Merging in EAR adobe-guides.ear]
[2011-01-17 19:16:09,387], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-guides.ear
[2011-01-17 19:16:09,512], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [46%, Merging in EAR adobe-reader-extensions-servlet.ear]
[2011-01-17 19:16:09,512], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reader-extensions-servlet.ear
[2011-01-17 19:16:10,183], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [49%, Merging in EAR adobe-readerext-help.ear]
[2011-01-17 19:16:10,183], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-readerext-help.ear
[2011-01-17 19:16:10,713], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [52%, Merging in EAR adobe-workspace-runtime.ear]
[2011-01-17 19:16:10,713], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workspace-runtime.ear
[2011-01-17 19:16:13,537], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [55%, Merging in EAR adobe-workspace-help.ear]
[2011-01-17 19:16:13,537], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workspace-help.ear
[2011-01-17 19:16:14,223], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [58%, Merging in EAR adobe-edcserver-weblogic.ear]
[2011-01-17 19:16:14,223], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-edcserver-weblogic.ear
[2011-01-17 19:16:17,328], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [61%, Merging in EAR adobe-rightsmgmt-help.ear]
[2011-01-17 19:16:17,328], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-rightsmgmt-help.ear
[2011-01-17 19:16:17,718], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [67%, Packaging EAR adobe-livecycle-weblogic.ear]
[2011-01-17 19:16:18,623], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Creating ear ..\export\adobe-livecycle-weblogic.ear from ..\working\configureLC\mergeTmp\merge
[2011-01-17 19:16:18,638], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Reading version from D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-core-weblogic.ear
[2011-01-17 19:16:38,887], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [70%, Merging LiveCycle EAR adobe-livecycle-weblogic.ear completed]
[2011-01-17 19:16:38,887], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [75%, Collecting EARs for merging of adobe-livecycle-native-weblogic-x86_win32.ear]
[2011-01-17 19:16:38,887], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars, Merging ears (D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-approvider-native-weblogic-x86_win32.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-forms-native-weblogic-x86_win32.ear,D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-convertpdf-native-weblogic-x86_win32.ear) into (D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-core-native-weblogic-x86_win32.ear) output to (..\export\adobe-livecycle-native-weblogic-x86_win32.ear)
[2011-01-17 19:16:38,887], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [75%, Executing merge scripts for adobe-livecycle-native-weblogic-x86_win32.ear]
[2011-01-17 19:16:39,605], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [76%, Merging in EAR adobe-approvider-native-weblogic-x86_win32.ear]
[2011-01-17 19:16:39,605], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-approvider-native-weblogic-x86_win32.ear
[2011-01-17 19:16:40,743], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [81%, Merging in EAR adobe-forms-native-weblogic-x86_win32.ear]
[2011-01-17 19:16:40,743], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-forms-native-weblogic-x86_win32.ear
[2011-01-17 19:16:45,018], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [86%, Merging in EAR adobe-convertpdf-native-weblogic-x86_win32.ear]
[2011-01-17 19:16:45,018], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Merging D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-convertpdf-native-weblogic-x86_win32.ear
[2011-01-17 19:16:46,437], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [93%, Packaging EAR adobe-livecycle-native-weblogic-x86_win32.ear]
[2011-01-17 19:16:46,531], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Creating ear ..\export\adobe-livecycle-native-weblogic-x86_win32.ear from ..\working\configureLC\mergeTmp\merge
[2011-01-17 19:16:46,531], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEars2, Reading version from D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-core-weblogic.ear
[2011-01-17 19:16:55,064], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [94%, Merging LiveCycle EAR adobe-livecycle-native-weblogic-x86_win32.ear completed]
[2011-01-17 19:16:55,064], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [96%, Cleaning working directory]
[2011-01-17 19:16:55,158], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, Progress: [100%, Configuring EARs completed]
[2011-01-17 19:16:55,158], INFO, Thread-7, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsTask, Completing task: com.adobe.livecycle.lcm.feature.configureLC.MergeEarsTask@12467d8 isDone:true
[2011-01-17 19:17:03,660], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.MergeEarsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:17:03,660], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureFontsDialog, onEntry()
[2011-01-17 19:17:06,873], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureFontsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:17:06,873], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureLCTempDialog, onEntry()
[2011-01-17 19:17:07,919], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureLCTempDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:17:07,919], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureLiveCycle2Dialog, onEntry()
[2011-01-17 19:17:08,855], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureLiveCycle2Dialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:17:08,886], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, onEntry()
[2011-01-17 19:17:10,383], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Starting processing
[2011-01-17 19:17:10,383], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.ConfigureFontsTask, Starting task: com.adobe.livecycle.lcm.feature.configureLC.ConfigureFontsTask@1f1d038
[2011-01-17 19:17:10,383], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [0%, Setting up working directory]
[2011-01-17 19:17:10,399], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [4%, Copying adobe-livecycle-weblogic.ear to working directory]
[2011-01-17 19:17:10,976], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [23%, Extracting adobe-csa-config.jar from adobe-livecycle-weblogic.ear]
[2011-01-17 19:17:10,976], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, Processing archive: ..\working\core\adobe-livecycle-weblogic.ear for file: adobe-csa-config.jar
[2011-01-17 19:17:10,992], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, Found file and extracting: adobe-csa-config.jar to: ..\working\core\adobe-csa-config.jar
[2011-01-17 19:17:10,992], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, adobe-csa-config.jar extracted from ..\working\core\adobe-livecycle-weblogic.ear
[2011-01-17 19:17:10,992], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [33%, Extracting core-default-config.properties from adobe-csa-config.jar]
[2011-01-17 19:17:10,992], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, Processing archive: ..\working\core\adobe-csa-config.jar for file: core-default-config.properties
[2011-01-17 19:17:10,992], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, Found file and extracting: core-default-config.properties to: ..\working\core\core-default-config.properties
[2011-01-17 19:17:10,992], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, core-default-config.properties extracted from ..\working\core\adobe-csa-config.jar
[2011-01-17 19:17:11,007], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [42%, Updating properties in core-default-config.properties]
[2011-01-17 19:17:11,007], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [47%, Adding core-default-config.properties back to adobe-csa-config.jar]
[2011-01-17 19:17:11,007], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, Injecting '..\working\core\out\core-default-config.properties' into '..\working\core\adobe-csa-config.jar' with path prefix ''
[2011-01-17 19:17:11,039], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [57%, Creating license jar]
[2011-01-17 19:17:11,039], INFO, Thread-8, com.adobe.livecycle.lcm.util.LicensingArchiveUtil, Generating license jars
[2011-01-17 19:17:11,039], INFO, Thread-8, com.adobe.livecycle.lcm.util.LicensingArchiveUtil, Creating Jar: D:\Applications\Adobe\Adobe LiveCycle ES2\configurationManager\working\core\adobe-lfs-license.jar
[2011-01-17 19:17:11,210], INFO, Thread-8, com.adobe.livecycle.lcm.util.LicensingArchiveUtil, Jar created: D:\Applications\Adobe\Adobe LiveCycle ES2\configurationManager\working\core\adobe-lfs-license.jar
[2011-01-17 19:17:11,210], INFO, Thread-8, com.adobe.livecycle.lcm.util.LicensingArchiveUtil, Created jar: ..\working\core\adobe-lfs-license.jar
[2011-01-17 19:17:11,210], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [61%, Adding adobe-csa-config.jar back to adobe-livecycle-weblogic.ear]
[2011-01-17 19:17:11,210], INFO, Thread-8, com.adobe.livecycle.lcm.util.ZipJarUtil, Injecting '[..\working\core\out\adobe-csa-config.jar, ..\working\core\adobe-lfs-license.jar]' into '..\working\core\adobe-livecycle-weblogic.ear' with path prefix ''
[2011-01-17 19:17:32,692], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [80%, Updating adobe-livecycle-weblogic.ear in export directory]
[2011-01-17 19:17:33,238], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [90%, Cleaning working directory]
[2011-01-17 19:17:33,394], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [95%, Configuration of core complete]
[2011-01-17 19:17:38,198], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, Progress: [100%, Task Completed.]
[2011-01-17 19:17:38,198], INFO, Thread-8, com.adobe.livecycle.lcm.feature.configureLC.ConfigureFontsTask, Completing task: com.adobe.livecycle.lcm.feature.configureLC.ConfigureFontsTask@1f1d038 isDone:true
[2011-01-17 19:18:16,247], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureLC.PersistentDocStorageDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:18:16,247], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.feature.ConfigureContentManagerDialog, onEntry()
[2011-01-17 19:18:19,180], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.feature.ConfigureContentManagerDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:18:19,180], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, onEntry()
[2011-01-17 19:18:21,145], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Starting processing
[2011-01-17 19:18:21,145], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.task.ConfigureContentManagerTask, Starting task: com.adobe.livecycle.cs.lcm.task.ConfigureContentManagerTask@109851a
[2011-01-17 19:18:21,145], INFO, Thread-9, com.adobe.livecycle.cs.lcm.util.ConfigureContentManager, [useCustomDist=false]
[2011-01-17 19:18:21,161], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [0%, Setting up working directory]
[2011-01-17 19:18:21,161], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [1%, Copying adobe-contentservices.ear to working directory]
[2011-01-17 19:18:24,172], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [4%, Extracting contentservices.war from adobe-contentservices.ear]
[2011-01-17 19:18:24,172], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Processing archive: ..\working\contentServices\adobe-contentservices.ear for file: contentservices.war
[2011-01-17 19:18:24,172], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Found file and extracting: contentservices.war to: ..\working\contentServices\contentservices.war
[2011-01-17 19:18:24,764], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, contentservices.war extracted from ..\working\contentServices\adobe-contentservices.ear
[2011-01-17 19:18:24,764], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [16%, Extracting WEB-INF/classes/alfresco/extension/custom-repository.properties from authentication-service.amp]
[2011-01-17 19:18:24,764], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Processing archive: D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\authentication-service.amp for file: config/alfresco/extension/custom-repository.properties
[2011-01-17 19:18:24,796], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Found file and extracting: config/alfresco/extension/custom-repository.properties to: ..\working\contentServices\custom-repository.properties
[2011-01-17 19:18:24,796], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, config/alfresco/extension/custom-repository.properties extracted from D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\authentication-service.amp
[2011-01-17 19:18:24,811], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [18%, Updating properties in custom-repository.properties]
[2011-01-17 19:18:24,811], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [56%, Updating properties in contentservices.war]
[2011-01-17 19:18:24,827], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Injecting '[WEB-INF/classes/alfresco/extension/custom-repository.properties]' into '..\working\contentServices\contentservices.war
[2011-01-17 19:18:24,827], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Injecting [..\working\contentServices\custom-repository.properties] at [WEB-INF/classes/alfresco/extension/]
[2011-01-17 19:18:36,496], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [66%, Installing Optional LiveCycle AMPs]
[2011-01-17 19:18:36,496], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [67%, Installing genericservice-action.amp in contentservices.war]
[2011-01-17 19:18:40,848], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [68%, Installing lc-datacapture-service.amp in contentservices.war]
[2011-01-17 19:18:44,717], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [70%, Installing lc-forms-integration.amp in contentservices.war]
[2011-01-17 19:18:48,664], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [71%, Installing lc-native-repository-ref.amp in contentservices.war]
[2011-01-17 19:18:52,548], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [73%, Installing process_samples.amp in contentservices.war]
[2011-01-17 19:18:56,495], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [74%, Installing rightsmanagement-action.amp in contentservices.war]
[2011-01-17 19:19:00,364], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [76%, Installing workspace-integration.amp in contentservices.war]
[2011-01-17 19:19:04,310], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [76%, Installation of Optional LC AMPs Completed]
[2011-01-17 19:19:04,310], INFO, Thread-9, com.adobe.livecycle.cs.lcm.util.ConfigureContentManager, Closing merge session
[2011-01-17 19:19:06,198], INFO, Thread-9, com.adobe.livecycle.cs.lcm.util.ConfigureContentManager, Merge session closed.
[2011-01-17 19:19:06,198], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [98%, Adding contentservices.war back to adobe-contentservices.ear]
[2011-01-17 19:19:06,198], INFO, Thread-9, com.adobe.livecycle.lcm.util.ZipJarUtil, Injecting '..\working\contentServices\contentservices.war' into '..\working\contentServices\adobe-contentservices.ear' with path prefix ''
[2011-01-17 19:19:14,435], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [99%, Copying adobe-contentservices.ear into export directory]
[2011-01-17 19:19:14,622], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [100%, Cleaning working directory]
[2011-01-17 19:19:14,684], INFO, Thread-9, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, Progress: [100%, Configuration complete]
[2011-01-17 19:19:14,684], INFO, Thread-9, com.adobe.livecycle.cs.lcm.task.ConfigureContentManagerTask, Completing task: com.adobe.livecycle.cs.lcm.task.ConfigureContentManagerTask@109851a isDone:true
[2011-01-17 19:19:21,954], INFO, AWT-EventQueue-0, com.adobe.livecycle.cs.lcm.feature.ConfigureAMPsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:19:21,954], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.util.NetUtils, Host check is local: true
[2011-01-17 19:19:21,954], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.ConfigSummaryDialog, onEntry()
[2011-01-17 19:19:22,984], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.ConfigSummaryDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:19:22,999], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVTopologyDialog, onEntry()
[2011-01-17 19:19:22,999], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.util.NetUtils, Host check is local: true
[2011-01-17 19:19:40,113], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask, Starting task: com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask@16368e1
[2011-01-17 19:19:40,144], INFO, Thread-10, com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask, Testing connection using server info {server, MServer6, mumdmsdwinapp01, 7001, test_weblogic_admin, *******, D:/Applications/Oracle/Middleware/wlserver_10.3D:/Applications/Oracle/Middleware/wlserver _10.3}
[2011-01-17 19:19:40,300], INFO, Thread-10, com.adobe.livecycle.cdv.validator.WLValidator, Validating host and port
[2011-01-17 19:19:41,799], INFO, Thread-10, com.adobe.livecycle.cdv.validator.WLValidator, Validating server cluster:com.adobe.livecycle.cdv.AppServerTopologyInfo@6c279[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:19:42,844], INFO, Thread-10, com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask, Completing task: com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask@16368e1 isDone:true
[2011-01-17 19:19:43,250], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask, Stopping task: com.adobe.livecycle.lcm.feature.configureAS.TestAppServerConnectionTask@16368e1
[2011-01-17 19:19:44,092], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVTopologyDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:19:44,092], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.util.NetUtils, Host check is local: true
[2011-01-17 19:19:44,092], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVTaskSelectionDialog, onEntry()
[2011-01-17 19:19:45,324], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVTaskSelectionDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:19:45,324], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVJVMDialog, onEntry()
[2011-01-17 19:19:46,479], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVJVMDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:19:46,479], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVDataSourceDialog, onEntry()
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ConfigurationData, Loaded properties: {locateRequestTimeOutCORBA=300, CDVJVM.initHeapSize=256, totalTranLifetimeTimeout=300, requestTimeOutCORBA=360, requestTimeoutSOAP=1800, CDVJVM.maxPermGen=256, maxHeapSize=1024}
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ConfigurationData, Loaded properties: {stuckthreadmaxtime=1200, jtatimeout=300}
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ConfigurationData, Loaded properties: {capacityincrement_IDP_DS=1, dsTemplateName=DataSource_ora_5, dsImplClassName=oracle.jdbc.pool.OracleConnectionPoolDataSource, dbType=oracle, committype_RM_DS=OnePhaseCommit, maxcapacity_IDP_DS=30, providerDescription=Created by Adobe Livecycle configuration script., statementcachetype=LRU, dbconnectionpool=conpoolJDBC-oracle, cpAgedTimeout=0, dsUrl=jdbc:oracle:thin:@$dbServerName:$dbPortNumber:$dbName, initcapacity_IDP_DS=1, dsName=Livecycle - oracle, dbdriverclassname=oracle.jdbc.OracleDriver, dsStatementCacheSize=80, capacityincrement_RM_DS=1, statementcachesize_RM_DS=100, providerTemplateName=Oracle JDBC Driver(templates/system, dsHelperClass=com.ibm.websphere.rsadapter.Oracle10gDataStoreHelper, initcapacity_RM_DS=5, cpMinConnections_RM_DS=5, cpMaxConnections_RM_DS=20, dbSupportDriverNames=, statementcachesize_IDP_DS=80, dbDriverType=4, enabletwophasecommit=true, cpMinConnections_IDP_DS=1, cpReapTime=180, cpConnectionTimeout=1800, cpUnusedTimeout=180, cpMaxConnections_IDP_DS=30, maxcapacity_RM_DS=20, cpPurgePolicy=EntirePool, committype_IDP_DS=EmulateTwoPhaseCommit, dsMappingConfigAlias=DefaultPrincipalMapping}
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ConfigurationData, Loaded properties: {nativeLib=, cpReapTime=180, initcapacity_IDP_DS=1, cpMaxConnections_IDP_DS=30, dsEnable2Phase=true, cpAgedTimeout=0, providerDescription=Created by Adobe Livecycle configuration script., statementcachesize_IDP_DS=80, cpMinConnections_RM_DS=5, statementcachesize_RM_DS=100, maxcapacity_RM_DS=20, initcapacity_RM_DS=5, dsStatementCacheSize=80, alternativeDSImplClassName=com.microsoft.sqlserver.jdbc.SQLServerConnectionPoolDataSource , dsName=Livecycle - SQLServer, dbdriverclassname=SQLServerDriver, dsTemplateName=User-defined DataSource, capacityincrement_IDP_DS=1, cpPurgePolicy=EntirePool, alternativeDSJar=sqljdbc.jar, dsHelperClass=com.ibm.websphere.rsadapter.WSConnectJDBCDataStoreHelper, providerTemplateName=User-defined JDBC Provider(templates/system, cpMinConnections_IDP_DS=1, cpConnectionTimeout=1800, committype_IDP_DS=EmulateTwoPhaseCommit, alternativeDSHelperClass=com.ibm.websphere.rsadapter.GenericDataStoreHelper, dbDriverMaker=microsoft, dsImplClassName=com.ibm.websphere.jdbcx.sqlserver.SQLServerDataSource, maxcapacity_IDP_DS=30, dbSupportDriverNames=base.jar,util.jar,spy.jar,wlbase.jar,wlutil.jar, statementcachetype=LRU, dbType=SQLServer, dbDriverType=4 , cpUnusedTimeout=180, dbconnectionpool=conpoolJDBC-SQLServer, capacityincrement_RM_DS=1, dsMappingConfigAlias=DefaultPrincipalMapping, cpMaxConnections_RM_DS=20, committype_RM_DS=OnePhaseCommit }
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ConfigurationData, Loaded properties: {nativeLib=, cpReapTime=180, initcapacity_IDP_DS=1, cpMaxConnections_IDP_DS=30, cpAgedTimeout=0, providerDescription=Created by Adobe Livecycle configuration script., statementcachesize_IDP_DS=80, cpMinConnections_RM_DS=5, statementcachesize_RM_DS=100, maxcapacity_RM_DS=20, initcapacity_RM_DS=5, dsStatementCacheSize=80, dsName=Livecycle - DB2, dbdriverclassname=com.ibm.db2.jcc.DB2Driver, providerTemplateNameGeneric=DB2 Universal JDBC Driver Provider(, dsTemplateName=DataSource_DB2_UNI_1, capacityincrement_IDP_DS=1, cpPurgePolicy=EntirePool, dsHelperClass=, providerTemplateName=DB2 Universal JDBC Driver Provider(templates/system, cpMinConnections_IDP_DS=1, cpConnectionTimeout=1800, committype_IDP_DS=EmulateTwoPhaseCommit, dsImplClassName=com.ibm.db2.jcc.DB2ConnectionPoolDataSource, dsResultSetHoldability=1, maxcapacity_IDP_DS=30, dbSupportDriverNames=db2jcc_license_cu.jar, statementcachetype=LRU, dbType=DB2, dbDriverType=4 , cpUnusedTimeout=180, dbconnectionpool=conpoolJDBC-DB2, capacityincrement_RM_DS=1, dsMappingConfigAlias=DefaultPrincipalMapping, cpMaxConnections_RM_DS=20, committype_RM_DS=OnePhaseCommit}
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.ConfigurationData, Loaded properties: {nativeLib=, cpReapTime=180, initcapacity_com.celequest.metadata.metaDatasource=1, initcapacity_IDP_DS=1, cpMaxConnections_IDP_DS=30, dsEnable2Phase=true, cpAgedTimeout=0, maxcapacity_com.celequest.metadata.metaDatasource=20, providerDescription=Created by Adobe Livecycle configuration script., statementcachesize_IDP_DS=80, cpMinConnections_RM_DS=5, statementcachesize_RM_DS=100, maxcapacity_RM_DS=20, initcapacity_RM_DS=5, dsStatementCacheSize=10, dsName=Livecycle - MySQL, dbdriverclassname=com.mysql.jdbc.Driver, dsTemplateName=User-defined DataSource, capacityincrement_IDP_DS=1, cpPurgePolicy=FailingConnectionOnly, dsHelperClass=com.ibm.websphere.rsadapter.ConnectJDBCDataStoreHelper, providerTemplateName=User-defined JDBC Provider(templates/system, cpMinConnections_IDP_DS=1, cpConnectionTimeout=1800, committype_IDP_DS=EmulateTwoPhaseCommit, dsSelectMode=cursor, dsSendStringParametersAsUnicode=true, dsImplClassName=com.mysql.jdbc.jdbc2.optional.MysqlConnectionPoolDataSource, maxcapacity_IDP_DS=30, dbSupportDriverNames=, statementcachetype=LRU, dbType=MySQL, dbDriverType=4 , statementcachesize_com.celequest.metadata.metaDatasource=10, dbFactory=com.mysql.jdbc.jdbc2.optional.MysqlDataSourceFactory, cpUnusedTimeout=180, capacityincrement_com.celequest.metadata.metaDatasource=1, dbconnectionpool=conpoolJDBC-MySQL, committype_com.celequest.metadata.metaDatasource=None, capacityincrement_RM_DS=1, dsMappingConfigAlias=DefaultPrincipalMapping, cpMaxConnections_RM_DS=20, committype_RM_DS=OnePhaseCommit }
[2011-01-17 19:20:27,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask, Starting task: com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask@17d6336
[2011-01-17 19:20:27,070], INFO, Thread-13, com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask, Testing connection using db info {oracle, oracle.jdbc.OracleDriver, D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar, mumdmsdwinodb01, SEBADBDV, 1522, SYSTEM, ********}
[2011-01-17 19:20:27,288], INFO, Thread-13, com.adobe.livecycle.cdv.config.JDBCConfig, getting JDBC connection URL:jdbc:oracle:thin:@mumdmsdwinodb01:1522:SEBADBDV
[2011-01-17 19:20:32,171], INFO, Thread-13, com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask, Completing task: com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask@17d6336 isDone:true
[2011-01-17 19:20:32,202], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask, Stopping task: com.adobe.livecycle.lcm.feature.configureAS.TestDatabaseConnectionTask@17d6336
[2011-01-17 19:20:33,092], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVDataSourceDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:20:33,092], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, onEntry()
[2011-01-17 19:20:34,059], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Starting processing
[2011-01-17 19:20:34,059], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVConfigAppServerTask, Starting task: com.adobe.livecycle.lcm.feature.configureAS.CDVConfigAppServerTask@8b0942
[2011-01-17 19:20:34,074], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [0%, Validating target application server data is specified]
[2011-01-17 19:20:34,074], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [10%, Collecting some data from running target server]
[2011-01-17 19:20:34,090], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, getNodeManager
[2011-01-17 19:20:34,137], INFO, Thread-14, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:20:34,137], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [20%, Stopping target server]
[2011-01-17 19:20:34,137], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Stopping 'MServer6', force=false
[2011-01-17 19:20:34,152], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Invoking task 'shutdown' for server 'MServer6'
[2011-01-17 19:20:34,152], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'RUNNING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:20:39,160], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'SHUTTING_DOWN' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:20:44,168], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'SHUTDOWN' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:20:44,168], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server task 'shutdown' has completed for server 'MServer6'
[2011-01-17 19:20:44,183], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'SHUTDOWN' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:20:44,183], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server 'MServer6' successfully completed task 'shutdown'
[2011-01-17 19:20:44,183], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [30%, Configuring JVM]
[2011-01-17 19:20:44,214], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLconf, Found existing server classpath [D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar;D:\Applications\Ad obe\Adobe LiveCycle ES2\lib\weblogic\pop3.jar;D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\webl ogic.jar;C:\Program Files (x86)\Java\jdk1.6.0_15\lib\tools.jar]
[2011-01-17 19:20:44,214], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [30%, Updating classpath [D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar;D:\Applications\Ad obe\Adobe LiveCycle ES2\lib\weblogic\pop3.jar;D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\webl ogic.jar;C:\Program Files (x86)\Java\jdk1.6.0_15\lib\tools.jar]]
[2011-01-17 19:20:44,214], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLconf, Setting EnforceValidBasicAuthCredentials=false
[2011-01-17 19:20:44,932], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLServerConfig, start config the domain
[2011-01-17 19:20:44,948], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLServerConfig, Found existing server args [-Dadobeidp.RootDirectory=D:\Applications\Oracle\Middleware\user_projects\domains\test_do main\. -Dfile.encoding=utf8 -Djava.net.preferIPv4Stack=true -Djava.security.policy=D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\weblogi c.policy -Xms256m -Xmx1792m]
[2011-01-17 19:20:44,948], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [30%, Updating jvm arguments [MServer6 : -Dadobeidp.RootDirectory=D:\Applications\Oracle\Middleware\user_projects\domains\test_dom ain\. -Dfile.encoding=utf8 -Djava.net.preferIPv4Stack=true -Djava.security.policy=D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\weblogi c.policy -Xms256m -Xmx1792m]]
[2011-01-17 19:20:45,119], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [60%, Configuring Datasource]
[2011-01-17 19:20:45,119], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLconf, Config datasource [com.adobe.livecycle.cdv.ConfigDBInfo@1e52e89]
[2011-01-17 19:20:45,135], INFO, Thread-14, com.adobe.livecycle.cdv.validator.DBValidator, Validating Database [oracle , null , mumdmsdwinodb01 , IDP_DS , 1522 , SYSTEM, ********]
[2011-01-17 19:20:45,150], INFO, Thread-14, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:20:45,150], INFO, Thread-14, com.adobe.livecycle.cdv.config.JDBCConfig, getting JDBC connection URL:jdbc:oracle:thin:@mumdmsdwinodb01:1522:SEBADBDV
[2011-01-17 19:20:45,338], INFO, Thread-14, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:20:45,338], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [60%, Creating datasource [IDP_DS : IDP_DS]]
[2011-01-17 19:20:45,369], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLconf, Found existing server classpath [D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar;D:\Applications\Ad obe\Adobe LiveCycle ES2\lib\weblogic\pop3.jar;D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\webl ogic.jar;C:\Program Files (x86)\Java\jdk1.6.0_15\lib\tools.jar]
[2011-01-17 19:20:45,369], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [60%, Updating classpath [D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar;D:\Applications\Ad obe\Adobe LiveCycle ES2\lib\weblogic\pop3.jar;D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\webl ogic.jar;C:\Program Files (x86)\Java\jdk1.6.0_15\lib\tools.jar]]
[2011-01-17 19:20:45,618], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLconf, Config datasource [com.adobe.livecycle.cdv.ConfigDBInfo@128f4d0]
[2011-01-17 19:20:45,618], INFO, Thread-14, com.adobe.livecycle.cdv.validator.DBValidator, Validating Database [oracle , null , mumdmsdwinodb01 , RM_DS , 1522 , SYSTEM, ********]
[2011-01-17 19:20:45,618], INFO, Thread-14, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:20:45,634], INFO, Thread-14, com.adobe.livecycle.cdv.config.JDBCConfig, getting JDBC connection URL:jdbc:oracle:thin:@mumdmsdwinodb01:1522:SEBADBDV
[2011-01-17 19:20:45,790], INFO, Thread-14, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:20:45,806], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [60%, Creating datasource [RM_DS : EDC_DS]]
[2011-01-17 19:20:45,821], INFO, Thread-14, com.adobe.livecycle.cdv.config.WLconf, Found existing server classpath [D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar;D:\Applications\Ad obe\Adobe LiveCycle ES2\lib\weblogic\pop3.jar;D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\webl ogic.jar;C:\Program Files (x86)\Java\jdk1.6.0_15\lib\tools.jar]
[2011-01-17 19:20:45,821], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [60%, Updating classpath [D:\Applications\Oracle\Middleware\wlserver_10.3\server\lib\ojdbc6.jar;D:\Applications\Ad obe\Adobe LiveCycle ES2\lib\weblogic\pop3.jar;D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\webl ogic.jar;C:\Program Files (x86)\Java\jdk1.6.0_15\lib\tools.jar]]
[2011-01-17 19:20:46,008], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [90%, Starting target server]
[2011-01-17 19:20:46,008], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Starting 'MServer6'
[2011-01-17 19:20:46,008], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Invoking task 'start' for server 'MServer6'
[2011-01-17 19:20:46,164], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:20:51,172], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:20:56,180], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:01,421], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:06,429], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:11,436], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:16,444], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:21,452], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:26,459], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:31,467], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:36,475], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:41,482], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:46,490], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:51,497], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:21:56,505], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:01,513], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:06,520], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:11,528], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:16,535], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:21,543], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:26,551], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:31,558], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:36,566], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:41,573], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:46,581], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:51,589], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:22:56,596], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:01,604], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:06,611], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:11,619], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:16,627], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:21,634], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:26,642], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:31,650], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:36,657], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:41,665], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:46,672], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:51,680], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:23:56,688], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:01,695], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:06,703], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:11,710], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:16,718], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:21,726], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:26,733], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:31,741], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:36,748], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:41,756], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:46,764], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:51,771], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:24:56,779], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:01,786], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:06,794], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:11,802], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:16,809], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:21,817], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:26,825], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:31,832], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:36,840], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:41,847], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:46,855], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:51,863], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:25:56,870], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:01,878], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:06,885], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:11,893], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:16,901], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:21,908], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:26,916], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:31,923], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:36,931], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:41,939], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:46,946], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:51,954], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:26:56,961], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:01,969], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:06,977], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:11,984], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:16,992], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:22,000], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:27,007], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:32,015], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:37,022], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:42,030], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:47,038], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:52,045], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'STARTING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:57,053], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server state for 'MServer6' is 'RUNNING' using mBean 'com.bea:Name=MServer6,Type=ServerLifeCycleRuntime'
[2011-01-17 19:27:57,053], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server task 'start' has completed for server 'MServer6'
[2011-01-17 19:27:57,053], INFO, Thread-14, com.adobe.livecycle.cdv.control.WLControl, Server 'MServer6' successfully completed task 'start'
[2011-01-17 19:27:57,053], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, Progress: [100%, Configuration of application server completed]
[2011-01-17 19:27:57,053], INFO, Thread-14, com.adobe.livecycle.lcm.feature.configureAS.CDVConfigAppServerTask, Completing task: com.adobe.livecycle.lcm.feature.configureAS.CDVConfigAppServerTask@8b0942 isDone:true
[2011-01-17 19:28:15,648], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVASConfigurationDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:28:15,648], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, onEntry()
[2011-01-17 19:28:18,815], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, Starting processing
[2011-01-17 19:28:18,815], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateConfigAppServerTask, Starting task: com.adobe.livecycle.lcm.feature.configureAS.CDVValidateConfigAppServerTask@13b732a
[2011-01-17 19:28:18,815], INFO, Thread-15, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, Progress: [0%, Validating Application Server Configuration]
[2011-01-17 19:28:18,815], INFO, Thread-15, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, Progress: [0%, Validating target application server data...]
[2011-01-17 19:28:18,830], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Validating host and port
[2011-01-17 19:28:18,830], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Validating server cluster:com.adobe.livecycle.cdv.AppServerTopologyInfo@969081[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:28:18,830], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Validating Version:com.adobe.livecycle.cdv.AppServerTopologyInfo@969081[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:28:18,846], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Application Server Version = 10.3.3.0
[2011-01-17 19:28:18,846], INFO, Thread-15, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, Progress: [15%, Validating JVM...]
[2011-01-17 19:28:18,862], INFO, Thread-15, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:28:18,877], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Validating JVM:com.adobe.livecycle.cdv.AppServerTopologyInfo@969081[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:28:18,877], INFO, Thread-15, com.adobe.livecycle.cdv.config.WLServerConfig, Found existing server args [-Dadobeidp.RootDirectory=D:\Applications\Oracle\Middleware\user_projects\domains\test_do main\. -Dfile.encoding=utf8 -Djava.net.preferIPv4Stack=true -Djava.security.policy=D:/Applications/Oracle/Middleware/wlserver_10.3\server\lib\weblogi c.policy -Xms256m -Xmx1792m]
[2011-01-17 19:28:18,877], INFO, Thread-15, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, Progress: [45%, Validating datasource...]
[2011-01-17 19:28:18,877], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Validating datasource:com.adobe.livecycle.cdv.ConfigDBInfo@ce9fda
[2011-01-17 19:28:18,908], INFO, Thread-15, com.adobe.livecycle.cdv.util.JNDIInitialContext, Connecting to JNDI service at: t3://mumdmsdwinapp01:7008
[2011-01-17 19:28:18,924], INFO, Thread-15, com.adobe.livecycle.cdv.validator.DSValidator, Validating Datasource: IDP_DS
[2011-01-17 19:28:23,276], INFO, Thread-15, com.adobe.livecycle.cdv.validator.WLValidator, Validating datasource:com.adobe.livecycle.cdv.ConfigDBInfo@d24c94
[2011-01-17 19:28:23,276], INFO, Thread-15, com.adobe.livecycle.cdv.util.JNDIInitialContext, Connecting to JNDI service at: t3://mumdmsdwinapp01:7008
[2011-01-17 19:28:23,276], INFO, Thread-15, com.adobe.livecycle.cdv.validator.DSValidator, Validating Datasource: EDC_DS
[2011-01-17 19:28:23,417], WARNING, Thread-15, ValidatorResponseLog, Validating target application server data...
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateVersion - Version: Actual Value=10.3.3.0 Expected Value=10.3.0.0
[2011-01-17 19:28:23,417], WARNING, Thread-15, ValidatorResponseLog, Validating JVM...
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateDomainMBean - JTA-TimeoutSeconds: Actual Value=300 Expected Value=300
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateServerMBean - StuckThreadMaxTime: Actual Value=1200 Expected Value=1200
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateJVM - -Dadobeidp.RootDirectory: Actual Value=D:/Applications/Oracle/Middleware/user_projects/domains/test_domain/. Expected Value=D:/Applications/Oracle/Middleware/user_projects/domains/test_domain/.
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateJVM - -Dfile.encoding: Actual Value=utf8 Expected Value=utf8
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateJVM - -Djava.net.preferIPv4Stack: Actual Value=true Expected Value=true
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateJVM - -Djava.security.policy: Actual Value=D:/Applications/Oracle/Middleware/wlserver_10.3/server/lib/weblogic.policy Expected Value=D:/Applications/Oracle/Middleware/wlserver_10.3/server/lib/weblogic.policy
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateJVM - -Xmx: Actual Value=1792 Expected Value=1792
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = validateJVM - -Xms: Actual Value=256 Expected Value=256
[2011-01-17 19:28:23,417], WARNING, Thread-15, ValidatorResponseLog, Validating datasource...
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = constructDSValidator - Datasource: Actual Value=IDP_DS Expected Value=IDP_DS
[2011-01-17 19:28:23,417], INFO, Thread-15, ValidatorResponseLog, Pass - Validation = constructDSValidator - Datasource: Actual Value=RM_DS Expected Value=EDC_DS
[2011-01-17 19:28:23,417], INFO, Thread-15, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, Progress: [100%, Validating Application Server Configuration Complete]
[2011-01-17 19:28:23,417], INFO, Thread-15, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateConfigAppServerTask, Completing task: com.adobe.livecycle.lcm.feature.configureAS.CDVValidateConfigAppServerTask@13b732a isDone:true
[2011-01-17 19:28:27,067], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureAS.CDVValidateASConfigurationDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:28:27,067], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployIVSEARsDialog, onEntry()
[2011-01-17 19:28:28,955], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployIVSEARsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:28:28,955], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, onEntry()
[2011-01-17 19:28:32,730], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Starting processing
[2011-01-17 19:28:32,730], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployEARsTask, Starting task: com.adobe.livecycle.lcm.feature.deployment.DeployEARsTask@104de3e
[2011-01-17 19:28:32,746], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [0%, Deploying ..\export\adobe-livecycle-weblogic.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:28:32,746], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [0%, Stopping associated application adobe-livecycle-weblogic if deployed and running.]
[2011-01-17 19:28:32,746], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-livecycle-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:28:39,142], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-livecycle-weblogic on Target: MServer6
[2011-01-17 19:28:39,859], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@198bfe3
[2011-01-17 19:28:43,915], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:28:43,915], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:28:43,915], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [3%, Un-deploying associated application adobe-livecycle-weblogic if deployed.]
[2011-01-17 19:28:43,915], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-livecycle-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:28:44,508], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-livecycle-weblogic on MServer6
[2011-01-17 19:28:44,602], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@169cac1
[2011-01-17 19:29:10,779], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:29:10,779], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:29:10,779], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [7%, Deploying ..\export\adobe-livecycle-weblogic.ear as application adobe-livecycle-weblogic.]
[2011-01-17 19:29:10,779], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-livecycle-weblogic ear: adobe-livecycle-weblogic.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:29:10,779], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:29:38,687], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@1c94ba
[2011-01-17 19:34:38,535], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:34:38,535], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:34:38,535], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [10%, Starting associated application adobe-livecycle-weblogic.]
[2011-01-17 19:34:38,535], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-livecycle-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:34:43,512], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:34:47,833], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [14%, Deploying ..\export\adobe-livecycle-native-weblogic-x86_win32.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:34:47,833], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [14%, Stopping associated application adobe-livecycle-native-weblogic-x86_win32 if deployed and running.]
[2011-01-17 19:34:47,833], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-livecycle-native-weblogic-x86_win32 on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:34:52,450], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-livecycle-native-weblogic-x86_win32 on Target: MServer6
[2011-01-17 19:34:52,528], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@1f380a
[2011-01-17 19:34:54,541], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:34:54,541], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:34:54,541], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [17%, Un-deploying associated application adobe-livecycle-native-weblogic-x86_win32 if deployed.]
[2011-01-17 19:34:54,541], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-livecycle-native-weblogic-x86_win32 on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:34:59,408], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-livecycle-native-weblogic-x86_win32 on MServer6
[2011-01-17 19:34:59,455], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@1e8611a
[2011-01-17 19:35:01,467], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:35:01,467], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:35:01,467], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [21%, Deploying ..\export\adobe-livecycle-native-weblogic-x86_win32.ear as application adobe-livecycle-native-weblogic-x86_win32.]
[2011-01-17 19:35:01,467], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-livecycle-native-weblogic-x86_win32 ear: adobe-livecycle-native-weblogic-x86_win32.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:35:01,467], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:35:13,339], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@1232a82
[2011-01-17 19:35:19,376], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:35:19,376], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:35:19,376], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [24%, Starting associated application adobe-livecycle-native-weblogic-x86_win32.]
[2011-01-17 19:35:19,376], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-livecycle-native-weblogic-x86_win32 on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:35:24,321], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:35:28,486], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [28%, Deploying ..\export\adobe-contentservices.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:35:28,486], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [28%, Stopping associated application adobe-contentservices if deployed and running.]
[2011-01-17 19:35:28,486], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-contentservices on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:35:33,135], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-contentservices on Target: MServer6
[2011-01-17 19:35:33,307], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@437954
[2011-01-17 19:35:35,319], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:35:35,319], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:35:35,319], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [31%, Un-deploying associated application adobe-contentservices if deployed.]
[2011-01-17 19:35:35,319], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-contentservices on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:35:40,124], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-contentservices on MServer6
[2011-01-17 19:35:40,171], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@14f402a
[2011-01-17 19:35:46,208], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:35:46,208], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:35:46,208], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [35%, Deploying ..\export\adobe-contentservices.ear as application adobe-contentservices.]
[2011-01-17 19:35:46,208], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-contentservices ear: adobe-contentservices.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:35:46,208], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:35:57,783], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@1b89aec
[2011-01-17 19:37:54,518], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:37:54,518], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:37:54,518], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [38%, Starting associated application adobe-contentservices.]
[2011-01-17 19:37:54,518], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-contentservices on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:37:59,042], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:38:03,176], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [42%, Deploying ..\export\adobe-assembler-ivs.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:38:03,176], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [42%, Stopping associated application adobe-assembler-ivs if deployed and running.]
[2011-01-17 19:38:03,176], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-assembler-ivs on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:07,903], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-assembler-ivs on Target: MServer6
[2011-01-17 19:38:07,950], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@11a7d4c
[2011-01-17 19:38:09,978], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:38:09,978], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:38:09,978], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [45%, Un-deploying associated application adobe-assembler-ivs if deployed.]
[2011-01-17 19:38:09,978], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-assembler-ivs on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:14,564], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-assembler-ivs on MServer6
[2011-01-17 19:38:14,595], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@b306b
[2011-01-17 19:38:16,608], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:38:16,608], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:38:16,608], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [49%, Deploying ..\export\adobe-assembler-ivs.ear as application adobe-assembler-ivs.]
[2011-01-17 19:38:16,608], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-assembler-ivs ear: adobe-assembler-ivs.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:16,608], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:38:16,935], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@4734d0
[2011-01-17 19:38:18,948], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:38:18,948], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:38:18,948], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [53%, Starting associated application adobe-assembler-ivs.]
[2011-01-17 19:38:18,948], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-assembler-ivs on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:23,722], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:38:27,419], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [57%, Deploying ..\export\adobe-output-ivs-weblogic.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:38:27,419], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [57%, Stopping associated application adobe-output-ivs-weblogic if deployed and running.]
[2011-01-17 19:38:27,419], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-output-ivs-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:31,568], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-output-ivs-weblogic on Target: MServer6
[2011-01-17 19:38:31,631], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@4dcbee
[2011-01-17 19:38:33,643], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:38:33,643], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:38:33,643], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [60%, Un-deploying associated application adobe-output-ivs-weblogic if deployed.]
[2011-01-17 19:38:33,643], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-output-ivs-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:38,308], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-output-ivs-weblogic on MServer6
[2011-01-17 19:38:38,354], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@234c82
[2011-01-17 19:38:40,367], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:38:40,367], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:38:40,367], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [64%, Deploying ..\export\adobe-output-ivs-weblogic.ear as application adobe-output-ivs-weblogic.]
[2011-01-17 19:38:40,367], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-output-ivs-weblogic ear: adobe-output-ivs-weblogic.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:40,367], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:38:41,490], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@79017e
[2011-01-17 19:38:47,527], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:38:47,527], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:38:47,527], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [67%, Starting associated application adobe-output-ivs-weblogic.]
[2011-01-17 19:38:47,527], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-output-ivs-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:38:52,160], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:38:56,060], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [71%, Deploying ..\export\adobe-forms-ivs-weblogic.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:38:56,060], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [71%, Stopping associated application adobe-forms-ivs-weblogic if deployed and running.]
[2011-01-17 19:38:56,060], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-forms-ivs-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:00,553], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-forms-ivs-weblogic on Target: MServer6
[2011-01-17 19:39:00,631], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@edbb2b
[2011-01-17 19:39:02,644], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:39:02,644], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:39:02,644], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [74%, Un-deploying associated application adobe-forms-ivs-weblogic if deployed.]
[2011-01-17 19:39:02,644], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-forms-ivs-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:07,199], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-forms-ivs-weblogic on MServer6
[2011-01-17 19:39:07,246], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@b688d4
[2011-01-17 19:39:09,258], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:39:09,258], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:39:09,258], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [78%, Deploying ..\export\adobe-forms-ivs-weblogic.ear as application adobe-forms-ivs-weblogic.]
[2011-01-17 19:39:09,258], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-forms-ivs-weblogic ear: adobe-forms-ivs-weblogic.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:09,258], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:39:10,100], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@192af48
[2011-01-17 19:39:14,156], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:39:14,156], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:39:14,156], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [81%, Starting associated application adobe-forms-ivs-weblogic.]
[2011-01-17 19:39:14,156], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-forms-ivs-weblogic on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:18,883], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:39:22,830], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [85%, Deploying ..\export\adobe-workspace-client.ear to MServer6@mumdmsdwinapp01]
[2011-01-17 19:39:22,830], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [85%, Stopping associated application adobe-workspace-client if deployed and running.]
[2011-01-17 19:39:22,830], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Stopping application: adobe-workspace-client on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:27,307], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, stop App:adobe-workspace-client on Target: MServer6
[2011-01-17 19:39:27,370], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: stop on: weblogic.deploy.api.spi.status.ProgressObjectImpl@d98e8c
[2011-01-17 19:39:29,382], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: stop State: completed
[2011-01-17 19:39:29,382], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, The application has been stopped.
[2011-01-17 19:39:29,382], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [88%, Un-deploying associated application adobe-workspace-client if deployed.]
[2011-01-17 19:39:29,382], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying application: adobe-workspace-client on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:34,031], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Undeploying App: adobe-workspace-client on MServer6
[2011-01-17 19:39:34,078], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: undeploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@d1b7a
[2011-01-17 19:39:36,106], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: undeploy State: completed
[2011-01-17 19:39:36,106], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been undeployed.
[2011-01-17 19:39:36,106], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [92%, Deploying ..\export\adobe-workspace-client.ear as application adobe-workspace-client.]
[2011-01-17 19:39:36,106], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Deploying application: adobe-workspace-client ear: adobe-workspace-client.ear on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:36,106], INFO, Thread-16, com.adobe.livecycle.cdv.util.CDVUtil, Host isLocal check for 'mumdmsdwinapp01': true
[2011-01-17 19:39:37,525], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Executing: deploy on: weblogic.deploy.api.spi.status.ProgressObjectImpl@1b82a39
[2011-01-17 19:39:41,550], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Wait: deploy State: completed
[2011-01-17 19:39:41,550], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Application has been deployed.
[2011-01-17 19:39:41,550], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [96%, Starting associated application adobe-workspace-client.]
[2011-01-17 19:39:41,550], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, Starting application: adobe-workspace-client on: com.adobe.livecycle.cdv.AppServerTopologyInfo@100b22b[mumdmsdwinapp01:7001, MServer6]
[2011-01-17 19:39:46,012], INFO, Thread-16, com.adobe.livecycle.cdv.deployer.WLDeployer, No apps found that could be started.
[2011-01-17 19:39:50,099], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, Progress: [100%, Deployment completed]
[2011-01-17 19:39:50,099], INFO, Thread-16, com.adobe.livecycle.lcm.feature.deployment.DeployEARsTask, Completing task: com.adobe.livecycle.lcm.feature.deployment.DeployEARsTask@104de3e isDone:true
[2011-01-17 19:40:48,147], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployEARsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:40:48,162], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, onEntry()
[2011-01-17 19:40:51,360], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Starting processing
[2011-01-17 19:40:51,376], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Starting task: com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask@1f432b9
[2011-01-17 19:40:51,391], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.FetchTasksClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?fetchTasks=true&responseLocale=en]
[2011-01-17 19:40:51,454], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [0%, Bootstrapping UserManager]
[2011-01-17 19:40:51,454], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Progress: Task[1/6, Bootstrapping UserManager] Step[1/1, Invoking component bootstrapper]
[2011-01-17 19:40:51,454], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.BootstrapRequestClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?responseType=client&bootstrapper= UM&step=bootstrap&host=mumdmsdwinapp01&port=7008&responseLocale=en]
[2011-01-17 19:40:52,593], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [16%, Bootstrapping Core]
[2011-01-17 19:40:52,593], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Progress: Task[2/6, Bootstrapping Core] Step[1/1, Invoking component bootstrapper]
[2011-01-17 19:40:52,593], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.BootstrapRequestClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?responseType=client&bootstrapper= CORE&step=bootstrap&host=mumdmsdwinapp01&port=7008&responseLocale=en]
[2011-01-17 19:40:52,639], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [33%, Bootstrapping PersistentObjectFramework]
[2011-01-17 19:40:52,639], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Progress: Task[3/6, Bootstrapping PersistentObjectFramework] Step[1/1, Invoking component bootstrapper]
[2011-01-17 19:40:52,639], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.BootstrapRequestClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?responseType=client&bootstrapper= POF&step=bootstrap&host=mumdmsdwinapp01&port=7008&responseLocale=en]
[2011-01-17 19:40:53,685], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [50%, Bootstrapping DocumentServiceContainer]
[2011-01-17 19:40:53,700], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Progress: Task[4/6, Bootstrapping DocumentServiceContainer] Step[1/1, Invoking component bootstrapper]
[2011-01-17 19:40:53,700], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.BootstrapRequestClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?responseType=client&bootstrapper= DSC&step=bootstrap&host=mumdmsdwinapp01&port=7008&responseLocale=en]
[2011-01-17 19:40:53,856], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [66%, Bootstrapping TrustStore]
[2011-01-17 19:40:53,856], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Progress: Task[5/6, Bootstrapping TrustStore] Step[1/1, Invoking component bootstrapper]
[2011-01-17 19:40:53,856], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.BootstrapRequestClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?responseType=client&bootstrapper= TS&step=bootstrap&host=mumdmsdwinapp01&port=7008&responseLocale=en]
[2011-01-17 19:40:53,872], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [83%, Bootstrapping ProcessEngine]
[2011-01-17 19:40:53,872], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Progress: Task[6/6, Bootstrapping ProcessEngine] Step[1/1, Invoking component bootstrapper]
[2011-01-17 19:40:53,872], INFO, Thread-96, com.adobe.livecycle.bootstrap.client.BootstrapRequestClient, Invoking [http://mumdmsdwinapp01:7008/adobe-bootstrapper/bootstrap?responseType=client&bootstrapper= WF&step=bootstrap&host=mumdmsdwinapp01&port=7008&responseLocale=en]
[2011-01-17 19:40:54,059], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask, Completing task: com.adobe.livecycle.lcm.feature.bootstrap.BootstrapTask@1f432b9 isDone:true
[2011-01-17 19:40:54,059], INFO, Thread-96, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, Progress: [100%, Bootstrapping complete]
[2011-01-17 19:40:55,338], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.bootstrap.BootstrapDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:40:55,338], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.LiveCycleServerInfoDialog, onEntry()
[2011-01-17 19:41:15,571], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask, Starting task: com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask@506a4e
[2011-01-17 19:41:15,587], INFO, Thread-97, com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask, Testing connection using server info {weblogic, mumdmsdwinapp01, 7008, administrator, ********}
[2011-01-17 19:41:15,603], INFO, Thread-97, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, LC Connection properties: {DSC_SERVER_TYPE=WebLogic, DSC_DEFAULT_SOAP_ENDPOINT=http://mumdmsdwinapp01:7008, DSC_TRANSPORT_PROTOCOL=SOAP, DSC_CREDENTIAL_PASSWORD=********, DSC_CREDENTIAL_USERNAME=administrator, }
[2011-01-17 19:41:15,696], INFO, Thread-97, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, Validating connection...
[2011-01-17 19:41:19,378], INFO, Thread-97, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, Validating connection...
[2011-01-17 19:41:24,666], INFO, Thread-97, com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask, Completing task: com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask@506a4e isDone:true
[2011-01-17 19:41:24,775], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask, Stopping task: com.adobe.livecycle.lcm.feature.lcServer.TestLCServerInfoTask@506a4e
[2011-01-17 19:41:27,069], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.LiveCycleServerInfoDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:41:27,069], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureCMB.ConfigureCMBDialog, onEntry()
[2011-01-17 19:41:31,842], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureCMB.ConfigureCMBDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:41:31,842], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, onEntry()
[2011-01-17 19:42:07,083], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Starting processing
[2011-01-17 19:42:07,083], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, LC Connection properties: {DSC_SERVER_TYPE=WebLogic, DSC_DEFAULT_SOAP_ENDPOINT=http://mumdmsdwinapp01:7008, DSC_TRANSPORT_PROTOCOL=SOAP, DSC_CREDENTIAL_PASSWORD=********, DSC_CREDENTIAL_USERNAME=administrator, }
[2011-01-17 19:42:07,083], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, Validating connection...
[2011-01-17 19:42:08,596], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsTask, Starting task: com.adobe.livecycle.lcm.feature.deployment.DeployDSCsTask@1d0bf0e
[2011-01-17 19:42:08,596], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [0%, Loading state from service container ]
[2011-01-17 19:42:10,328], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [0%, Deploying DSC adobe-pdfservices-dsc.jar]
[2011-01-17 19:42:10,374], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-pdfservices-dsc.jar, com.adobe.PDFServices, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,406], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [0%, DSC already running adobe-pdfservices-dsc.jar]
[2011-01-17 19:42:10,406], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.PDFServices:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,406], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [0%, Deploying DSC adobe-ejbprovider-dsc.jar]
[2011-01-17 19:42:10,421], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-ejbprovider-dsc.jar, com.adobe.idp.dsc.provider.service.ejb.EJB, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,421], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [0%, DSC already running adobe-ejbprovider-dsc.jar]
[2011-01-17 19:42:10,421], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.provider.service.ejb.EJB:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,421], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [2%, Deploying DSC adobe-soapConnector-dsc.jar]
[2011-01-17 19:42:10,437], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-soapConnector-dsc.jar, com.adobe.idp.dsc.provider.service.soap.SOAP, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,437], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [2%, DSC already running adobe-soapConnector-dsc.jar]
[2011-01-17 19:42:10,437], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.provider.service.soap.SOAP:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,437], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [3%, Deploying DSC adobe-restConnector-dsc.jar]
[2011-01-17 19:42:10,452], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-restConnector-dsc.jar, com.adobe.idp.dsc.provider.service.rest.REST, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,468], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [3%, DSC already running adobe-restConnector-dsc.jar]
[2011-01-17 19:42:10,468], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.provider.service.rest.REST:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,468], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [5%, Deploying DSC adobe-remotingConnector-dsc.jar]
[2011-01-17 19:42:10,484], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-remotingConnector-dsc.jar, com.adobe.idp.dsc.provider.service.lcr.Remoting, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,499], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [5%, DSC already running adobe-remotingConnector-dsc.jar]
[2011-01-17 19:42:10,499], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.provider.service.lcr.Remoting:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,499], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [5%, Deploying DSC adobe-usermanager-dsc.jar]
[2011-01-17 19:42:10,499], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-usermanager-dsc.jar, com.adobe.idp.um.dsc.UserManagerComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,515], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [5%, DSC already running adobe-usermanager-dsc.jar]
[2011-01-17 19:42:10,515], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.um.dsc.UserManagerComponent:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,515], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [7%, Deploying DSC adobe-usermanager-util-dsc.jar]
[2011-01-17 19:42:10,530], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-usermanager-util-dsc.jar, com.adobe.idp.um.dsc.UserManagerUtilComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,546], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [7%, DSC already running adobe-usermanager-util-dsc.jar]
[2011-01-17 19:42:10,546], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.um.dsc.UserManagerUtilComponent:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,546], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [8%, Deploying DSC adobe-jobmanager-dsc.jar]
[2011-01-17 19:42:10,562], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-jobmanager-dsc.jar, com.adobe.idp.jobmanager.service.JobManagerComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,577], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [8%, DSC already running adobe-jobmanager-dsc.jar]
[2011-01-17 19:42:10,577], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.jobmanager.service.JobManagerComponent:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,577], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [10%, Deploying DSC adobe-scheduler-weblogic-dsc.jar]
[2011-01-17 19:42:10,608], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-scheduler-weblogic-dsc.jar, com.adobe.idp.scheduler.SchedulerService, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,624], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [10%, DSC already running adobe-scheduler-weblogic-dsc.jar]
[2011-01-17 19:42:10,624], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.scheduler.SchedulerService:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,624], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [11%, Deploying DSC adobe-cacheservice-dsc.jar]
[2011-01-17 19:42:10,640], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-cacheservice-dsc.jar, com.adobe.livecycle.cache.service.CacheService, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,640], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [11%, DSC already running adobe-cacheservice-dsc.jar]
[2011-01-17 19:42:10,640], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.cache.service.CacheService:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,640], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [12%, Deploying DSC adobe-event-dsc.jar]
[2011-01-17 19:42:10,686], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-event-dsc.jar, com.adobe.idp.event.EventManagement, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,702], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [12%, DSC already running adobe-event-dsc.jar]
[2011-01-17 19:42:10,702], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.event.EventManagement:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,702], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [13%, Deploying DSC adobe-emailprovider-dsc.jar]
[2011-01-17 19:42:10,733], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-emailprovider-dsc.jar, com.adobe.idp.dsc.provider.service.email.Email, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,764], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [13%, DSC already running adobe-emailprovider-dsc.jar]
[2011-01-17 19:42:10,764], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.provider.service.email.Email:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,764], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [15%, Deploying DSC adobe-fileprovider-dsc.jar]
[2011-01-17 19:42:10,796], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-fileprovider-dsc.jar, com.adobe.idp.dsc.provider.service.file.WatchedFolder, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,796], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [15%, DSC already running adobe-fileprovider-dsc.jar]
[2011-01-17 19:42:10,811], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.provider.service.file.WatchedFolder:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,811], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [16%, Deploying DSC adobe-truststore-dsc.jar]
[2011-01-17 19:42:10,827], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-truststore-dsc.jar, com.adobe.truststore.dsc.TrustStoreComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,827], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [16%, DSC already running adobe-truststore-dsc.jar]
[2011-01-17 19:42:10,827], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.truststore.dsc.TrustStoreComponent:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,827], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [17%, Deploying DSC adobe-workflow-dsc.jar]
[2011-01-17 19:42:10,874], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workflow-dsc.jar, com.adobe.idp.workflow.dsc.service.WorkflowDSC, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,889], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [17%, DSC already running adobe-workflow-dsc.jar]
[2011-01-17 19:42:10,889], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.workflow.dsc.service.WorkflowDSC:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,889], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [18%, Deploying DSC adobe-repository-dsc.jar]
[2011-01-17 19:42:10,936], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-repository-dsc.jar, com.adobe.repository.bindings.dsc.RepositoryService, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:10,952], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [18%, DSC already running adobe-repository-dsc.jar]
[2011-01-17 19:42:10,952], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.repository.bindings.dsc.RepositoryService:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:10,952], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [20%, Deploying DSC adobe-repository-provider-dsc.jar]
[2011-01-17 19:42:11,014], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-repository-provider-dsc.jar, com.adobe.repository.bindings.dsc.RepositoryProviderService, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,030], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [20%, DSC already running adobe-repository-provider-dsc.jar]
[2011-01-17 19:42:11,030], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.repository.bindings.dsc.RepositoryProviderService:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,030], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [21%, Deploying DSC adobe-applicationmanager-dsc.jar]
[2011-01-17 19:42:11,092], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-applicationmanager-dsc.jar, com.adobe.idp.applicationmanager.service.ApplicationManagerComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,092], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [21%, DSC already running adobe-applicationmanager-dsc.jar]
[2011-01-17 19:42:11,092], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.applicationmanager.service.ApplicationManagerComponent:9.0.0.0.20091021.1.2 23425
[2011-01-17 19:42:11,092], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [22%, Deploying DSC adobe-businesscalendar-dsc.jar]
[2011-01-17 19:42:11,123], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-businesscalendar-dsc.jar, com.adobe.idp.BusinessCalendar, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,139], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [22%, DSC already running adobe-businesscalendar-dsc.jar]
[2011-01-17 19:42:11,139], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.BusinessCalendar:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,139], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [23%, Deploying DSC adobe-email-dsc.jar]
[2011-01-17 19:42:11,154], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-email-dsc.jar, com.adobe.livecycle.Email, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,170], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [23%, DSC already running adobe-email-dsc.jar]
[2011-01-17 19:42:11,170], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.Email:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,170], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [25%, Deploying DSC adobe-fileutils-dsc.jar]
[2011-01-17 19:42:11,186], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-fileutils-dsc.jar, com.adobe.livecycle.FileUtils, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,201], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [25%, DSC already running adobe-fileutils-dsc.jar]
[2011-01-17 19:42:11,201], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.FileUtils:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,201], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [26%, Deploying DSC adobe-ftp-dsc.jar]
[2011-01-17 19:42:11,232], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-ftp-dsc.jar, com.adobe.livecycle.FTP, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,232], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [26%, DSC already running adobe-ftp-dsc.jar]
[2011-01-17 19:42:11,232], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.FTP:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,232], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [28%, Deploying DSC adobe-jdbc-dsc.jar]
[2011-01-17 19:42:11,264], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-jdbc-dsc.jar, com.adobe.livecycle.JDBC, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,279], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [28%, DSC already running adobe-jdbc-dsc.jar]
[2011-01-17 19:42:11,279], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.JDBC:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,279], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [28%, Deploying DSC adobe-jms-dsc.jar]
[2011-01-17 19:42:11,295], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-jms-dsc.jar, com.adobe.livecycle.JMS, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,310], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [28%, DSC already running adobe-jms-dsc.jar]
[2011-01-17 19:42:11,310], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.JMS:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,310], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [30%, Deploying DSC adobe-ldap-dsc.jar]
[2011-01-17 19:42:11,326], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-ldap-dsc.jar, com.adobe.livecycle.LDAP, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,342], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [30%, DSC already running adobe-ldap-dsc.jar]
[2011-01-17 19:42:11,342], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.LDAP:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,342], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [31%, Deploying DSC adobe-variablelogger-dsc.jar]
[2011-01-17 19:42:11,373], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-variablelogger-dsc.jar, com.adobe.livecycle.VariableLogger, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,388], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [31%, DSC already running adobe-variablelogger-dsc.jar]
[2011-01-17 19:42:11,388], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.VariableLogger:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,388], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [33%, Deploying DSC adobe-webservice-dsc.jar]
[2011-01-17 19:42:11,420], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-webservice-dsc.jar, com.adobe.livecycle.WebService, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,451], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [33%, DSC already running adobe-webservice-dsc.jar]
[2011-01-17 19:42:11,451], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.WebService:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,451], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [34%, Deploying DSC adobe-xslt-dsc.jar]
[2011-01-17 19:42:11,466], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-xslt-dsc.jar, com.adobe.livecycle.XSLT, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,482], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [34%, DSC already running adobe-xslt-dsc.jar]
[2011-01-17 19:42:11,482], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.XSLT:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,482], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [35%, Deploying DSC adobe-auditworkflow-dsc.jar]
[2011-01-17 19:42:11,498], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-auditworkflow-dsc.jar, com.adobe.idp.auditworkflow.dsc.service.AuditWorkflowDSC, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,498], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [35%, DSC already running adobe-auditworkflow-dsc.jar]
[2011-01-17 19:42:11,498], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.auditworkflow.dsc.service.AuditWorkflowDSC:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,498], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [36%, Deploying DSC adobe-lcdsutil-dsc.jar]
[2011-01-17 19:42:11,513], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-lcdsutil-dsc.jar, com.adobe.idp.dsc.lcdsutil.LCDSUtil, #VERSION]
[2011-01-17 19:42:11,529], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [36%, DSC already running adobe-lcdsutil-dsc.jar]
[2011-01-17 19:42:11,529], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.lcdsutil.LCDSUtil:#VERSION
[2011-01-17 19:42:11,529], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [38%, Deploying DSC adobe-backup-restore-dsc.jar]
[2011-01-17 19:42:11,544], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-backup-restore-dsc.jar, com.adobe.idp.backup.dsc.BackupRestoreService, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,560], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [38%, DSC already running adobe-backup-restore-dsc.jar]
[2011-01-17 19:42:11,560], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.backup.dsc.BackupRestoreService:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,560], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [39%, Deploying DSC adobe-usermanager-lookup-dsc.jar]
[2011-01-17 19:42:11,576], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-usermanager-lookup-dsc.jar, com.adobe.idp.dsc.um.lookup.UserManagerLookUp, 9.0.0.0.20091022.1.223347]
[2011-01-17 19:42:11,591], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [39%, DSC already running adobe-usermanager-lookup-dsc.jar]
[2011-01-17 19:42:11,591], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.dsc.um.lookup.UserManagerLookUp:9.0.0.0.20091022.1.223347
[2011-01-17 19:42:11,591], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [40%, Deploying DSC adobe-workbench-registry-dsc.jar]
[2011-01-17 19:42:11,607], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workbench-registry-dsc.jar, com.adobe.idp.workbench.DesignTimeRegistryComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,622], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [40%, DSC already running adobe-workbench-registry-dsc.jar]
[2011-01-17 19:42:11,622], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.workbench.DesignTimeRegistryComponent:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,622], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [42%, Deploying DSC adobe-designtime-dsc.jar]
[2011-01-17 19:42:11,654], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-designtime-dsc.jar, com.adobe.livecycle.design.DesigntimeComponent, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,654], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [42%, DSC already running adobe-designtime-dsc.jar]
[2011-01-17 19:42:11,654], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.design.DesigntimeComponent:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,654], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [43%, Deploying DSC adobe-datacaptureinterface-dsc.jar]
[2011-01-17 19:42:11,669], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-datacaptureinterface-dsc.jar, com.adobe.datacaptureinterface.dsc.DataCaptureInterfaceDCI, 1.0]
[2011-01-17 19:42:11,685], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [43%, DSC already running adobe-datacaptureinterface-dsc.jar]
[2011-01-17 19:42:11,685], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.datacaptureinterface.dsc.DataCaptureInterfaceDCI:1.0
[2011-01-17 19:42:11,685], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [45%, Deploying DSC adobe-datatypes-util-dsc.jar]
[2011-01-17 19:42:11,700], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-datatypes-util-dsc.jar, com.adobe.livecycle.DataTypesUtility, 1.0]
[2011-01-17 19:42:11,700], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [45%, DSC already running adobe-datatypes-util-dsc.jar]
[2011-01-17 19:42:11,700], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.DataTypesUtility:1.0
[2011-01-17 19:42:11,700], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [45%, Deploying DSC adobe-licensemanager-dsc.jar]
[2011-01-17 19:42:11,716], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-licensemanager-dsc.jar, com.adobe.licenseManager.service.LicenseManagerComponent, 1.0]
[2011-01-17 19:42:11,732], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [45%, DSC already running adobe-licensemanager-dsc.jar]
[2011-01-17 19:42:11,732], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.licenseManager.service.LicenseManagerComponent:1.0
[2011-01-17 19:42:11,732], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [47%, Deploying DSC adobe-usermanager-saml-dsc.jar]
[2011-01-17 19:42:11,747], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-usermanager-saml-dsc.jar, com.adobe.idp.um.dsc.SamlAuthProvider, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,763], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [47%, DSC already running adobe-usermanager-saml-dsc.jar]
[2011-01-17 19:42:11,763], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.um.dsc.SamlAuthProvider:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,763], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [47%, Deploying DSC adobe-userlist-dsc.jar]
[2011-01-17 19:42:11,778], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-userlist-dsc.jar, com.adobe.livecycle.userlist.dsc.Userlist, 9.0.0.0.20091021.1.223425]
[2011-01-17 19:42:11,778], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [47%, DSC already running adobe-userlist-dsc.jar]
[2011-01-17 19:42:11,778], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.userlist.dsc.Userlist:9.0.0.0.20091021.1.223425
[2011-01-17 19:42:11,778], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [50%, Deploying DSC adobe-launchpad-dsc.jar]
[2011-01-17 19:42:11,810], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-launchpad-dsc.jar, com.adobe.livecycle.launchpad.dsc.LaunchPadService, 9.0.0.0.20091021.3.127105]
[2011-01-17 19:42:11,825], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [50%, DSC already running adobe-launchpad-dsc.jar]
[2011-01-17 19:42:11,825], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.launchpad.dsc.LaunchPadService:9.0.0.0.20091021.3.127105
[2011-01-17 19:42:11,825], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [51%, Deploying DSC adobe-connectorforemcdocumentum-dsc.jar]
[2011-01-17 19:42:11,888], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-connectorforemcdocumentum-dsc.jar, com.adobe.livecycle.ConnectorforEMCDocumentum, 9.0.0.0.20091019.2.126508]
[2011-01-17 19:42:11,919], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [51%, DSC already running adobe-connectorforemcdocumentum-dsc.jar]
[2011-01-17 19:42:11,919], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.ConnectorforEMCDocumentum:9.0.0.0.20091019.2.126508
[2011-01-17 19:42:11,919], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [52%, Deploying DSC adobe-pdfutility-dsc.jar]
[2011-01-17 19:42:11,950], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-pdfutility-dsc.jar, com.adobe.livecycle.PDFUtility, 9.0.0.0.20091019.1.220522]
[2011-01-17 19:42:11,966], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [52%, DSC already running adobe-pdfutility-dsc.jar]
[2011-01-17 19:42:11,966], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.PDFUtility:9.0.0.0.20091019.1.220522
[2011-01-17 19:42:11,966], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [53%, Deploying DSC adobe-assembler-dsc.jar]
[2011-01-17 19:42:11,997], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-assembler-dsc.jar, com.adobe.livecycle.Assembler, 9.0.0.0.20091019.2.222756]
[2011-01-17 19:42:12,012], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [53%, DSC already running adobe-assembler-dsc.jar]
[2011-01-17 19:42:12,012], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.Assembler:9.0.0.0.20091019.2.222756
[2011-01-17 19:42:12,012], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [55%, Deploying DSC adobe-contentservices-dsc.jar]
[2011-01-17 19:42:12,075], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-contentservices-dsc.jar, com.adobe.livecycle.ContentServices, 9.0.0.0.20091020.1.126807]
[2011-01-17 19:42:12,090], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [55%, DSC already running adobe-contentservices-dsc.jar]
[2011-01-17 19:42:12,090], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.ContentServices:9.0.0.0.20091020.1.126807
[2011-01-17 19:42:12,090], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [56%, Deploying DSC adobe-reviewandcommenting-dsc.jar]
[2011-01-17 19:42:12,137], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reviewandcommenting-dsc.jar, com.adobe.livecycle.ReviewAndCommenting, 9.0.0.0.20091020.1.126807]
[2011-01-17 19:42:12,153], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [56%, DSC already running adobe-reviewandcommenting-dsc.jar]
[2011-01-17 19:42:12,153], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.ReviewAndCommenting:9.0.0.0.20091020.1.126807
[2011-01-17 19:42:12,153], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [57%, Deploying DSC adobe-output-dsc.jar]
[2011-01-17 19:42:12,200], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-output-dsc.jar, com.adobe.livecycle.Output, 9.0.0.0.20091019.2.604198]
[2011-01-17 19:42:12,215], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [57%, DSC already running adobe-output-dsc.jar]
[2011-01-17 19:42:12,215], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.Output:9.0.0.0.20091019.2.604198
[2011-01-17 19:42:12,215], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [58%, Deploying DSC adobe-encryption-dsc.jar]
[2011-01-17 19:42:12,262], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-encryption-dsc.jar, com.adobe.livecycle.Encryption, 9.0.0.0.20091020.1.126514]
[2011-01-17 19:42:12,278], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [58%, DSC already running adobe-encryption-dsc.jar]
[2011-01-17 19:42:12,278], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.Encryption:9.0.0.0.20091020.1.126514
[2011-01-17 19:42:12,278], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [60%, Deploying DSC adobe-convertpdf-dsc.jar]
[2011-01-17 19:42:12,293], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-convertpdf-dsc.jar, com.adobe.livecycle.ConvertPDF, 9.0.0.0.20091019.2.604198]
[2011-01-17 19:42:12,309], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [60%, DSC already running adobe-convertpdf-dsc.jar]
[2011-01-17 19:42:12,309], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.ConvertPDF:9.0.0.0.20091019.2.604198
[2011-01-17 19:42:12,309], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [61%, Deploying DSC adobe-docconverter-dsc.jar]
[2011-01-17 19:42:12,324], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-docconverter-dsc.jar, com.adobe.livecycle.DocConverter, 9.0.0.0.20091019.2.222756]
[2011-01-17 19:42:12,340], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [61%, DSC already running adobe-docconverter-dsc.jar]
[2011-01-17 19:42:12,340], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.DocConverter:9.0.0.0.20091019.2.222756
[2011-01-17 19:42:12,340], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [62%, Deploying DSC adobe-forms-dsc.jar]
[2011-01-17 19:42:12,387], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-forms-dsc.jar, com.adobe.livecycle.Forms, 9.0.0.0.20091019.2.604198]
[2011-01-17 19:42:12,402], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [62%, DSC already running adobe-forms-dsc.jar]
[2011-01-17 19:42:12,402], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.Forms:9.0.0.0.20091019.2.604198
[2011-01-17 19:42:12,402], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [63%, Deploying DSC adobe-formdataintegration-dsc.jar]
[2011-01-17 19:42:12,434], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-formdataintegration-dsc.jar, com.adobe.livecycle.FormDataIntegration, 9.0.0.0.20091019.2.604198]
[2011-01-17 19:42:12,434], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [63%, DSC already running adobe-formdataintegration-dsc.jar]
[2011-01-17 19:42:12,434], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.FormDataIntegration:9.0.0.0.20091019.2.604198
[2011-01-17 19:42:12,434], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [65%, Deploying DSC adobe-guides-dsc.jar]
[2011-01-17 19:42:12,449], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-guides-dsc.jar, com.adobe.livecycle.guides.dsc.Guides, 9.0.0.0.20091020.1.606803]
[2011-01-17 19:42:12,465], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [65%, DSC already running adobe-guides-dsc.jar]
[2011-01-17 19:42:12,465], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.guides.dsc.Guides:9.0.0.0.20091020.1.606803
[2011-01-17 19:42:12,465], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [66%, Deploying DSC adobe-barcodedforms-dsc.jar]
[2011-01-17 19:42:12,496], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-barcodedforms-dsc.jar, com.adobe.livecycle.BarcodedForms, 9.0.0.0.20091020.1.126002]
[2011-01-17 19:42:12,512], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [66%, DSC already running adobe-barcodedforms-dsc.jar]
[2011-01-17 19:42:12,512], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.BarcodedForms:9.0.0.0.20091020.1.126002
[2011-01-17 19:42:12,512], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [68%, Deploying DSC adobe-signatures-dsc.jar]
[2011-01-17 19:42:12,558], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-signatures-dsc.jar, com.adobe.livecycle.Signatures, 9.0.0.0.20091020.1.126525]
[2011-01-17 19:42:12,605], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [68%, DSC already running adobe-signatures-dsc.jar]
[2011-01-17 19:42:12,605], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.Signatures:9.0.0.0.20091020.1.126525
[2011-01-17 19:42:12,605], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [68%, Deploying DSC adobe-reader-extensions-dsc.jar]
[2011-01-17 19:42:12,652], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reader-extensions-dsc.jar, com.adobe.livecycle.ReaderExtensions, 9.0.0.0.20091020.1.221784]
[2011-01-17 19:42:12,668], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [68%, DSC already running adobe-reader-extensions-dsc.jar]
[2011-01-17 19:42:12,668], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.ReaderExtensions:9.0.0.0.20091020.1.221784
[2011-01-17 19:42:12,668], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [70%, Deploying DSC adobe-taskmanager-dsc.jar]
[2011-01-17 19:42:12,699], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-taskmanager-dsc.jar, com.adobe.idp.taskmanager.dsc.service.TaskManagerDSC, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,714], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [70%, DSC already running adobe-taskmanager-dsc.jar]
[2011-01-17 19:42:12,714], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.taskmanager.dsc.service.TaskManagerDSC:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,714], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [71%, Deploying DSC adobe-userservice8-dsc.jar]
[2011-01-17 19:42:12,746], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-userservice8-dsc.jar, com.adobe.idp.taskmanager.dsc.service.UserService8DSC, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,792], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [71%, DSC already running adobe-userservice8-dsc.jar]
[2011-01-17 19:42:12,792], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.taskmanager.dsc.service.UserService8DSC:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,792], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [73%, Deploying DSC adobe-lc-pm-mobile-dsc.jar]
[2011-01-17 19:42:12,824], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-lc-pm-mobile-dsc.jar, com.adobe.livecycle.pm.mobile, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,824], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [73%, DSC already running adobe-lc-pm-mobile-dsc.jar]
[2011-01-17 19:42:12,824], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.pm.mobile:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,824], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [73%, Deploying DSC adobe-tasknotification-dsc.jar]
[2011-01-17 19:42:12,839], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-tasknotification-dsc.jar, com.adobe.livecycle.notification.TaskNotificationComponent, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,855], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [73%, DSC already running adobe-tasknotification-dsc.jar]
[2011-01-17 19:42:12,855], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.notification.TaskNotificationComponent:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,855], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [75%, Deploying DSC adobe-tasksharing-dsc.jar]
[2011-01-17 19:42:12,870], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-tasksharing-dsc.jar, com.adobe.idp.taskmanager.sharetasks.ShareTaskDSC, 1.0]
[2011-01-17 19:42:12,870], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [75%, DSC already running adobe-tasksharing-dsc.jar]
[2011-01-17 19:42:12,870], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.idp.taskmanager.sharetasks.ShareTaskDSC:1.0
[2011-01-17 19:42:12,870], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [76%, Deploying DSC adobe-workspacepersistence-dsc.jar]
[2011-01-17 19:42:12,886], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-workspacepersistence-dsc.jar, com.adobe.workspace.persistence, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,902], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [76%, DSC already running adobe-workspacepersistence-dsc.jar]
[2011-01-17 19:42:12,902], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.workspace.persistence:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,902], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [78%, Deploying DSC adobe-augmentform-dsc.jar]
[2011-01-17 19:42:12,933], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-augmentform-dsc.jar, com.adobe.livecycle.AugmentForm, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,933], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [78%, DSC already running adobe-augmentform-dsc.jar]
[2011-01-17 19:42:12,933], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.AugmentForm:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,933], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [79%, Deploying DSC adobe-remoteevents-dsc.jar]
[2011-01-17 19:42:12,980], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-remoteevents-dsc.jar, com.adobe.livecycle.events.RemoteEvents, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:12,995], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [79%, DSC already running adobe-remoteevents-dsc.jar]
[2011-01-17 19:42:12,995], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.events.RemoteEvents:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:12,995], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [80%, Deploying DSC adobe-queuesharing-dsc.jar]
[2011-01-17 19:42:13,011], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-queuesharing-dsc.jar, com.adobe.workspace.queuesharing, 9.0.0.0.20091020.1.606420]
[2011-01-17 19:42:13,011], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [80%, DSC already running adobe-queuesharing-dsc.jar]
[2011-01-17 19:42:13,011], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.workspace.queuesharing:9.0.0.0.20091020.1.606420
[2011-01-17 19:42:13,011], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [81%, Deploying DSC adobe-rightsmanagement-weblogic-dsc.jar]
[2011-01-17 19:42:13,042], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-rightsmanagement-weblogic-dsc.jar, com.adobe.livecycle.RightsManagement, 9.0.0.0.20091019.1.222918]
[2011-01-17 19:42:13,058], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [81%, DSC already running adobe-rightsmanagement-weblogic-dsc.jar]
[2011-01-17 19:42:13,058], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.RightsManagement:9.0.0.0.20091019.1.222918
[2011-01-17 19:42:13,058], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [83%, Deploying DSC adobe-apsscheduler-weblogic-dsc.jar]
[2011-01-17 19:42:13,073], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Installing DSC [D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-apsscheduler-weblogic-dsc.jar, com.adobe.livecycle.rightsmanagement.scheduler, 9.0.0.0.20091019.1.222918]
[2011-01-17 19:42:13,089], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [83%, DSC already running adobe-apsscheduler-weblogic-dsc.jar]
[2011-01-17 19:42:13,089], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC already installed. Skipping update for: com.adobe.livecycle.rightsmanagement.scheduler:9.0.0.0.20091019.1.222918
[2011-01-17 19:42:13,089], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [85%, Deployment completed]
[2011-01-17 19:42:13,089], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCAs for LFSs [ALC-LFS-Foundation, ALC-LFS-ConnectorEMCDocumentum, ALC-LFS-ContentServices, ALC-LFS-Output, ALC-LFS-Forms, ALC-LFS-BarcodedForms, ALC-LFS-DigitalSignatures, ALC-LFS-ReaderExtensions, ALC-LFS-ProcessManagement, ALC-LFS-RightsManagement]
[2011-01-17 19:42:13,089], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [85%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-livecycle-launchpad.lca.]
[2011-01-17 19:42:13,089], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-livecycle-launchpad.lca
[2011-01-17 19:42:15,820], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Applications found [LaunchPad Assets (system):9,Process Management Email (system):9,ReviewAndCommenting (system):9,Adobe Navigators (system):9,PrintPDFPackage:9,Process Management (system):9,Share Tasks For Shared Queues:9,Guides (system):9,LaunchPad (system):9]
[2011-01-17 19:42:15,820], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-livecycle-launchpad.lca
[2011-01-17 19:42:30,312], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [86%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-launchpad-assets.lca.]
[2011-01-17 19:42:30,312], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-launchpad-assets.lca
[2011-01-17 19:42:30,359], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-launchpad-assets.lca
[2011-01-17 19:43:04,227], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [88%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-navigators.lca.]
[2011-01-17 19:43:04,227], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-navigators.lca
[2011-01-17 19:43:04,258], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-navigators.lca
[2011-01-17 19:43:16,270], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [89%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reviewandcommenting.lca.]
[2011-01-17 19:43:16,270], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reviewandcommenting.lca
[2011-01-17 19:43:16,301], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-reviewandcommenting.lca
[2011-01-17 19:43:30,341], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [91%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-printPDFPackage.lca.]
[2011-01-17 19:43:30,341], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-printPDFPackage.lca
[2011-01-17 19:43:30,357], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-printPDFPackage.lca
[2011-01-17 19:43:31,012], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [93%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-guides.lca.]
[2011-01-17 19:43:31,012], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-guides.lca
[2011-01-17 19:43:31,074], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-guides.lca
[2011-01-17 19:44:23,054], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [94%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-emailNotification.lca.]
[2011-01-17 19:44:23,054], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-emailNotification.lca
[2011-01-17 19:44:23,069], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-emailNotification.lca
[2011-01-17 19:44:31,571], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [96%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-share-forwarded-tasks-to-shared-queue-users.lca.]
[2011-01-17 19:44:31,571], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-share-forwarded-tasks-to-shared-queue-users.lca
[2011-01-17 19:44:31,587], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-share-forwarded-tasks-to-shared-queue-users.lca
[2011-01-17 19:44:31,727], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [98%, Deploying D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-process-management-system.lca.]
[2011-01-17 19:44:31,727], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Deploying LCA D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-process-management-system.lca
[2011-01-17 19:44:31,758], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, LCA already imported with status: 9. LCA will be re-imported D:\Applications\Adobe\Adobe LiveCycle ES2\deploy\adobe-process-management-system.lca
[2011-01-17 19:44:56,765], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, Progress: [100%, Deployment Completed.]
[2011-01-17 19:44:56,765], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsTask, Completing task: com.adobe.livecycle.lcm.feature.deployment.DeployDSCsTask@1d0bf0e isDone:true
[2011-01-17 19:45:39,884], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.DeployDSCsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:45:39,884], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, onEntry()
[2011-01-17 19:45:41,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Starting processing
[2011-01-17 19:45:41,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, LC Connection properties: {DSC_SERVER_TYPE=WebLogic, DSC_DEFAULT_SOAP_ENDPOINT=http://mumdmsdwinapp01:7008, DSC_TRANSPORT_PROTOCOL=SOAP, DSC_CREDENTIAL_PASSWORD=********, DSC_CREDENTIAL_USERNAME=administrator, }
[2011-01-17 19:45:41,054], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, Validating connection...
[2011-01-17 19:45:42,754], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentTask, Starting task: com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentTask@a4889f
[2011-01-17 19:45:42,770], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [0%, Loading state from service container ]
[2011-01-17 19:45:44,423], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [0%, Validating DSC deployment adobe-pdfservices-dsc.jar]
[2011-01-17 19:45:44,439], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [0%, DSC status: Running]
[2011-01-17 19:45:44,439], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [0%, Validating DSC deployment adobe-ejbprovider-dsc.jar]
[2011-01-17 19:45:44,439], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [2%, Validating DSC deployment adobe-soapConnector-dsc.jar]
[2011-01-17 19:45:44,454], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [2%, DSC status: Running]
[2011-01-17 19:45:44,454], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [3%, Validating DSC deployment adobe-restConnector-dsc.jar]
[2011-01-17 19:45:44,470], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [3%, DSC status: Running]
[2011-01-17 19:45:44,470], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [5%, Validating DSC deployment adobe-remotingConnector-dsc.jar]
[2011-01-17 19:45:44,470], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [5%, DSC status: Running]
[2011-01-17 19:45:44,470], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [6%, Validating DSC deployment adobe-usermanager-dsc.jar]
[2011-01-17 19:45:44,486], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [6%, DSC status: Running]
[2011-01-17 19:45:44,486], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [8%, Validating DSC deployment adobe-usermanager-util-dsc.jar]
[2011-01-17 19:45:44,501], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [8%, DSC status: Running]
[2011-01-17 19:45:44,501], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [9%, Validating DSC deployment adobe-jobmanager-dsc.jar]
[2011-01-17 19:45:44,501], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [9%, DSC status: Running]
[2011-01-17 19:45:44,501], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [10%, Validating DSC deployment adobe-scheduler-weblogic-dsc.jar]
[2011-01-17 19:45:44,517], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [10%, DSC status: Running]
[2011-01-17 19:45:44,517], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [11%, Validating DSC deployment adobe-cacheservice-dsc.jar]
[2011-01-17 19:45:44,532], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [11%, DSC status: Running]
[2011-01-17 19:45:44,532], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [13%, Validating DSC deployment adobe-event-dsc.jar]
[2011-01-17 19:45:44,548], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [13%, DSC status: Running]
[2011-01-17 19:45:44,548], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [14%, Validating DSC deployment adobe-emailprovider-dsc.jar]
[2011-01-17 19:45:44,564], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [14%, DSC status: Running]
[2011-01-17 19:45:44,564], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [16%, Validating DSC deployment adobe-fileprovider-dsc.jar]
[2011-01-17 19:45:44,564], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [16%, DSC status: Running]
[2011-01-17 19:45:44,564], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [17%, Validating DSC deployment adobe-truststore-dsc.jar]
[2011-01-17 19:45:44,579], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [17%, DSC status: Running]
[2011-01-17 19:45:44,579], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [18%, Validating DSC deployment adobe-workflow-dsc.jar]
[2011-01-17 19:45:44,610], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [18%, DSC status: Running]
[2011-01-17 19:45:44,610], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [19%, Validating DSC deployment adobe-repository-dsc.jar]
[2011-01-17 19:45:44,626], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [19%, DSC status: Running]
[2011-01-17 19:45:44,626], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [21%, Validating DSC deployment adobe-repository-provider-dsc.jar]
[2011-01-17 19:45:44,642], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [21%, DSC status: Running]
[2011-01-17 19:45:44,642], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [22%, Validating DSC deployment adobe-applicationmanager-dsc.jar]
[2011-01-17 19:45:44,642], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [22%, DSC status: Running]
[2011-01-17 19:45:44,642], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [24%, Validating DSC deployment adobe-businesscalendar-dsc.jar]
[2011-01-17 19:45:44,657], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [24%, DSC status: Running]
[2011-01-17 19:45:44,657], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [25%, Validating DSC deployment adobe-email-dsc.jar]
[2011-01-17 19:45:44,673], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [25%, DSC status: Running]
[2011-01-17 19:45:44,673], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [27%, Validating DSC deployment adobe-fileutils-dsc.jar]
[2011-01-17 19:45:44,688], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [27%, DSC status: Running]
[2011-01-17 19:45:44,688], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [27%, Validating DSC deployment adobe-ftp-dsc.jar]
[2011-01-17 19:45:44,704], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [27%, DSC status: Running]
[2011-01-17 19:45:44,704], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [29%, Validating DSC deployment adobe-jdbc-dsc.jar]
[2011-01-17 19:45:44,720], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [29%, DSC status: Running]
[2011-01-17 19:45:44,720], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [30%, Validating DSC deployment adobe-jms-dsc.jar]
[2011-01-17 19:45:44,735], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [30%, DSC status: Running]
[2011-01-17 19:45:44,735], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [32%, Validating DSC deployment adobe-ldap-dsc.jar]
[2011-01-17 19:45:44,751], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [32%, DSC status: Running]
[2011-01-17 19:45:44,766], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [33%, Validating DSC deployment adobe-variablelogger-dsc.jar]
[2011-01-17 19:45:44,766], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [33%, DSC status: Running]
[2011-01-17 19:45:44,766], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [35%, Validating DSC deployment adobe-webservice-dsc.jar]
[2011-01-17 19:45:44,782], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [35%, DSC status: Running]
[2011-01-17 19:45:44,782], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [36%, Validating DSC deployment adobe-xslt-dsc.jar]
[2011-01-17 19:45:44,798], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [36%, DSC status: Running]
[2011-01-17 19:45:44,798], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [37%, Validating DSC deployment adobe-auditworkflow-dsc.jar]
[2011-01-17 19:45:44,798], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [37%, DSC status: Running]
[2011-01-17 19:45:44,798], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [38%, Validating DSC deployment adobe-lcdsutil-dsc.jar]
[2011-01-17 19:45:44,813], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [38%, DSC status: Running]
[2011-01-17 19:45:44,813], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [40%, Validating DSC deployment adobe-backup-restore-dsc.jar]
[2011-01-17 19:45:44,813], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [40%, DSC status: Running]
[2011-01-17 19:45:44,829], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [41%, Validating DSC deployment adobe-usermanager-lookup-dsc.jar]
[2011-01-17 19:45:44,829], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [41%, DSC status: Running]
[2011-01-17 19:45:44,829], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [43%, Validating DSC deployment adobe-workbench-registry-dsc.jar]
[2011-01-17 19:45:44,844], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [43%, DSC status: Running]
[2011-01-17 19:45:44,844], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [45%, Validating DSC deployment adobe-designtime-dsc.jar]
[2011-01-17 19:45:44,844], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [45%, DSC status: Running]
[2011-01-17 19:45:44,860], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [45%, Validating DSC deployment adobe-datacaptureinterface-dsc.jar]
[2011-01-17 19:45:44,860], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [45%, DSC status: Running]
[2011-01-17 19:45:44,860], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [47%, Validating DSC deployment adobe-datatypes-util-dsc.jar]
[2011-01-17 19:45:44,876], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [47%, DSC status: Running]
[2011-01-17 19:45:44,876], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [48%, Validating DSC deployment adobe-licensemanager-dsc.jar]
[2011-01-17 19:45:44,876], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [48%, DSC status: Running]
[2011-01-17 19:45:44,876], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [50%, Validating DSC deployment adobe-usermanager-saml-dsc.jar]
[2011-01-17 19:45:44,891], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [50%, DSC status: Running]
[2011-01-17 19:45:44,891], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [50%, Validating DSC deployment adobe-userlist-dsc.jar]
[2011-01-17 19:45:44,907], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [50%, DSC status: Running]
[2011-01-17 19:45:44,907], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [53%, Validating DSC deployment adobe-launchpad-dsc.jar]
[2011-01-17 19:45:44,907], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [53%, DSC status: Running]
[2011-01-17 19:45:44,907], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [54%, Validating DSC deployment adobe-connectorforemcdocumentum-dsc.jar]
[2011-01-17 19:45:44,922], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [54%, DSC status: Running]
[2011-01-17 19:45:44,922], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [55%, Validating DSC deployment adobe-pdfutility-dsc.jar]
[2011-01-17 19:45:44,954], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [55%, DSC status: Running]
[2011-01-17 19:45:44,954], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [56%, Validating DSC deployment adobe-assembler-dsc.jar]
[2011-01-17 19:45:44,954], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [56%, DSC status: Running]
[2011-01-17 19:45:44,954], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [58%, Validating DSC deployment adobe-contentservices-dsc.jar]
[2011-01-17 19:45:44,969], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [58%, DSC status: Running]
[2011-01-17 19:45:44,985], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [59%, Validating DSC deployment adobe-reviewandcommenting-dsc.jar]
[2011-01-17 19:45:44,985], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [59%, DSC status: Running]
[2011-01-17 19:45:44,985], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [61%, Validating DSC deployment adobe-output-dsc.jar]
[2011-01-17 19:45:45,000], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [61%, DSC status: Running]
[2011-01-17 19:45:45,000], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [62%, Validating DSC deployment adobe-encryption-dsc.jar]
[2011-01-17 19:45:45,016], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [62%, DSC status: Running]
[2011-01-17 19:45:45,016], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [63%, Validating DSC deployment adobe-convertpdf-dsc.jar]
[2011-01-17 19:45:45,032], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [63%, DSC status: Running]
[2011-01-17 19:45:45,032], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [64%, Validating DSC deployment adobe-docconverter-dsc.jar]
[2011-01-17 19:45:45,032], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [64%, DSC status: Running]
[2011-01-17 19:45:45,032], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [66%, Validating DSC deployment adobe-forms-dsc.jar]
[2011-01-17 19:45:45,063], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [66%, DSC status: Running]
[2011-01-17 19:45:45,063], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [67%, Validating DSC deployment adobe-formdataintegration-dsc.jar]
[2011-01-17 19:45:45,063], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [67%, DSC status: Running]
[2011-01-17 19:45:45,063], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [69%, Validating DSC deployment adobe-guides-dsc.jar]
[2011-01-17 19:45:45,078], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [69%, DSC status: Running]
[2011-01-17 19:45:45,078], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [70%, Validating DSC deployment adobe-barcodedforms-dsc.jar]
[2011-01-17 19:45:45,094], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [70%, DSC status: Running]
[2011-01-17 19:45:45,094], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [72%, Validating DSC deployment adobe-signatures-dsc.jar]
[2011-01-17 19:45:45,110], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [72%, DSC status: Running]
[2011-01-17 19:45:45,110], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [72%, Validating DSC deployment adobe-reader-extensions-dsc.jar]
[2011-01-17 19:45:45,125], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [72%, DSC status: Running]
[2011-01-17 19:45:45,125], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [74%, Validating DSC deployment adobe-taskmanager-dsc.jar]
[2011-01-17 19:45:45,141], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [74%, DSC status: Running]
[2011-01-17 19:45:45,141], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [75%, Validating DSC deployment adobe-userservice8-dsc.jar]
[2011-01-17 19:45:45,156], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [75%, DSC status: Running]
[2011-01-17 19:45:45,156], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [77%, Validating DSC deployment adobe-lc-pm-mobile-dsc.jar]
[2011-01-17 19:45:45,172], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [77%, DSC status: Running]
[2011-01-17 19:45:45,172], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [78%, Validating DSC deployment adobe-tasknotification-dsc.jar]
[2011-01-17 19:45:45,172], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [78%, DSC status: Running]
[2011-01-17 19:45:45,172], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [80%, Validating DSC deployment adobe-tasksharing-dsc.jar]
[2011-01-17 19:45:45,188], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [80%, DSC status: Running]
[2011-01-17 19:45:45,188], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [81%, Validating DSC deployment adobe-workspacepersistence-dsc.jar]
[2011-01-17 19:45:45,203], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [81%, DSC status: Running]
[2011-01-17 19:45:45,203], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [82%, Validating DSC deployment adobe-augmentform-dsc.jar]
[2011-01-17 19:45:45,203], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [82%, DSC status: Running]
[2011-01-17 19:45:45,203], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [83%, Validating DSC deployment adobe-remoteevents-dsc.jar]
[2011-01-17 19:45:45,219], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [83%, DSC status: Running]
[2011-01-17 19:45:45,219], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [85%, Validating DSC deployment adobe-queuesharing-dsc.jar]
[2011-01-17 19:45:45,219], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [85%, DSC status: Running]
[2011-01-17 19:45:45,219], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [86%, Validating DSC deployment adobe-rightsmanagement-weblogic-dsc.jar]
[2011-01-17 19:45:45,250], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [86%, DSC status: Running]
[2011-01-17 19:45:45,250], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [88%, Validating DSC deployment adobe-apsscheduler-weblogic-dsc.jar]
[2011-01-17 19:45:45,250], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [88%, DSC status: Running]
[2011-01-17 19:45:45,250], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [90%, DSC Deployment validation completed]
[2011-01-17 19:45:45,250], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment for LFSs [ALC-LFS-Foundation, ALC-LFS-ConnectorEMCDocumentum, ALC-LFS-ContentServices, ALC-LFS-Output, ALC-LFS-Forms, ALC-LFS-BarcodedForms, ALC-LFS-DigitalSignatures, ALC-LFS-ReaderExtensions, ALC-LFS-ProcessManagement, ALC-LFS-RightsManagement]
[2011-01-17 19:45:45,266], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [90%, Validating adobe-livecycle-launchpad.lca.]
[2011-01-17 19:45:45,266], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-livecycle-launchpad.lca
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Applications found [Adobe Navigators (system):9,Process Management (system):9,Guides (system):9,LaunchPad (system):9,ReviewAndCommenting (system):9,PrintPDFPackage:9,Share Tasks For Shared Queues:9,Process Management Email (system):9,LaunchPad Assets (system):9]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [90%, Validation successful. adobe-livecycle-launchpad.lca is deployed.]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [91%, Validating adobe-launchpad-assets.lca.]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-launchpad-assets.lca
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [91%, Validation successful. adobe-launchpad-assets.lca is deployed.]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [92%, Validating adobe-navigators.lca.]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-navigators.lca
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [92%, Validation successful. adobe-navigators.lca is deployed.]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [93%, Validating adobe-reviewandcommenting.lca.]
[2011-01-17 19:45:46,202], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-reviewandcommenting.lca
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [93%, Validation successful. adobe-reviewandcommenting.lca is deployed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [94%, Validating adobe-printPDFPackage.lca.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-printPDFPackage.lca
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [94%, Validation successful. adobe-printPDFPackage.lca is deployed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [95%, Validating adobe-guides.lca.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-guides.lca
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [95%, Validation successful. adobe-guides.lca is deployed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [96%, Validating adobe-emailNotification.lca.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-emailNotification.lca
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [96%, Validation successful. adobe-emailNotification.lca is deployed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [97%, Validating adobe-share-forwarded-tasks-to-shared-queue-users.lca.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-share-forwarded-tasks-to-shared-queue-users.lca
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [97%, Validation successful. adobe-share-forwarded-tasks-to-shared-queue-users.lca is deployed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [98%, Validating adobe-process-management-system.lca.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.DeployLCAs, Validating LCA deployment adobe-process-management-system.lca
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [98%, Validation successful. adobe-process-management-system.lca is deployed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, Progress: [100%, Validation Completed.]
[2011-01-17 19:45:46,217], INFO, Thread-99, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentTask, Completing task: com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentTask@a4889f isDone:true
[2011-01-17 19:45:48,526], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.deployment.ValidateDSCDeploymentDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:45:48,526], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionConfigureServicesPanel, onEntry()
[2011-01-17 19:46:03,799], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionConfigureServicesPanel, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:46:03,799], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog, onEntry()
[2011-01-17 19:46:10,179], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask, Starting task: com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask@169b2bf
[2011-01-17 19:46:12,238], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask, Stopping task: com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask@169b2bf
[2011-01-17 19:46:52,642], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: PREVIOUS)
[2011-01-17 19:46:52,642], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionConfigureServicesPanel, onEntry()
[2011-01-17 19:46:54,218], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionConfigureServicesPanel, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:46:54,218], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog, onEntry()
[2011-01-17 19:46:55,388], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask, Starting task: com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask@9f7e90
[2011-01-17 19:46:56,917], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask, Stopping task: com.adobe.livecycle.lcm.common.gui.JNDIPortDialog$TestConnectionTask@9f7e90
[2011-01-17 19:46:57,681], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:46:57,681], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumJarDialog, onEntry()
[2011-01-17 19:47:10,114], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Starting processing
[2011-01-17 19:47:10,114], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.tasks.FindJarTask, Starting task: com.adobe.livecycle.lcm.common.tasks.FindJarTask@10bac4a
[2011-01-17 19:47:10,130], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [0%, Starting jar Verification process]
[2011-01-17 19:47:10,130], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [0%, Verifying availability of D:\Applications\DMS_client_app\webtop/Shared/dfc.jar ]
[2011-01-17 19:47:10,130], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [0%, dfc.jar not found at default location D:\Applications\DMS_client_app\webtop/Shared/dfc.jar. Making a recursive search for the jar file in D:\Applications\DMS_client_app\webtop]
[2011-01-17 19:47:10,832], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarAPI, Found the file at location: D:\Applications\DMS_client_app\webtop\WEB-INF\lib\dfc.jar
[2011-01-17 19:47:10,832], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [0%, Succesfully located D:\Applications\DMS_client_app\webtop\WEB-INF\lib\dfc.jar]
[2011-01-17 19:47:10,941], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [16%, Verifying availability of D:\Applications\DMS_client_app\webtop/Shared/aspectjrt.jar ]
[2011-01-17 19:47:10,941], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [16%, aspectjrt.jar not found at default location D:\Applications\DMS_client_app\webtop/Shared/aspectjrt.jar. Making a recursive search for the jar file in D:\Applications\DMS_client_app\webtop]
[2011-01-17 19:47:11,596], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarAPI, Found the file at location: D:\Applications\DMS_client_app\webtop\WEB-INF\lib\aspectjrt.jar
[2011-01-17 19:47:11,596], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [16%, Succesfully located D:\Applications\DMS_client_app\webtop\WEB-INF\lib\aspectjrt.jar]
[2011-01-17 19:47:11,705], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [33%, Verifying availability of D:\Applications\DMS_client_app\webtop/Shared/jaxb-api.jar ]
[2011-01-17 19:47:11,705], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [33%, jaxb-api.jar not found at default location D:\Applications\DMS_client_app\webtop/Shared/jaxb-api.jar. Making a recursive search for the jar file in D:\Applications\DMS_client_app\webtop]
[2011-01-17 19:47:12,392], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarAPI, Found the file at location: D:\Applications\DMS_client_app\webtop\WEB-INF\lib\jaxb-api.jar
[2011-01-17 19:47:12,392], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [33%, Succesfully located D:\Applications\DMS_client_app\webtop\WEB-INF\lib\jaxb-api.jar]
[2011-01-17 19:47:12,501], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [50%, Verifying availability of D:\Applications\DMS_client_app\webtop/Shared/configservice-impl.jar ]
[2011-01-17 19:47:12,501], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [50%, configservice-impl.jar not found at default location D:\Applications\DMS_client_app\webtop/Shared/configservice-impl.jar. Making a recursive search for the jar file in D:\Applications\DMS_client_app\webtop]
[2011-01-17 19:47:13,125], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarAPI, Found the file at location: D:\Applications\DMS_client_app\webtop\WEB-INF\lib\configservice-impl.jar
[2011-01-17 19:47:13,125], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [50%, Succesfully located D:\Applications\DMS_client_app\webtop\WEB-INF\lib\configservice-impl.jar]
[2011-01-17 19:47:13,234], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [66%, Verifying availability of D:\Applications\DMS_client_app\webtop/Shared/configservice-api.jar ]
[2011-01-17 19:47:13,234], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [66%, configservice-api.jar not found at default location D:\Applications\DMS_client_app\webtop/Shared/configservice-api.jar. Making a recursive search for the jar file in D:\Applications\DMS_client_app\webtop]
[2011-01-17 19:47:13,936], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarAPI, Found the file at location: D:\Applications\DMS_client_app\webtop\WEB-INF\lib\configservice-api.jar
[2011-01-17 19:47:13,936], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [66%, Succesfully located D:\Applications\DMS_client_app\webtop\WEB-INF\lib\configservice-api.jar]
[2011-01-17 19:47:14,045], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [83%, Verifying availability of D:\Applications\DMS_client_app\webtop/Shared/log4j.jar ]
[2011-01-17 19:47:14,045], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [83%, log4j.jar not found at default location D:\Applications\DMS_client_app\webtop/Shared/log4j.jar. Making a recursive search for the jar file in D:\Applications\DMS_client_app\webtop]
[2011-01-17 19:47:14,747], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarAPI, Found the file at location: D:\Applications\DMS_client_app\webtop\WEB-INF\lib\log4j.jar
[2011-01-17 19:47:14,841], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [83%, Succesfully located D:\Applications\DMS_client_app\webtop\WEB-INF\lib\log4j.jar]
[2011-01-17 19:47:14,950], INFO, Thread-102, com.adobe.livecycle.lcm.documentum.gui.DocumentumActionDialog, Progress: [100%, Jar Verification job completed successfully]
[2011-01-17 19:47:14,950], INFO, Thread-102, com.adobe.livecycle.lcm.common.tasks.FindJarTask, Completing task: com.adobe.livecycle.lcm.common.tasks.FindJarTask@10bac4a isDone:true
[2011-01-17 19:47:21,331], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumJarDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:47:21,331], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumAdminuiDataDialog, onEntry()
[2011-01-17 19:48:10,018], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumAdminuiDataDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:48:10,018], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, onEntry()
[2011-01-17 19:48:11,610], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, Starting processing
[2011-01-17 19:48:11,625], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask, Starting task: com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask@85e531
[2011-01-17 19:48:11,625], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Starting task: com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask@1bdba73
[2011-01-17 19:48:11,625], INFO, Thread-104, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI, Starting with Adminui Settings Configuration job...Documentum
[2011-01-17 19:48:11,625], INFO, Thread-104, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, LC Connection properties: {DSC_SERVER_TYPE=WebLogic, DSC_DEFAULT_SOAP_ENDPOINT=http://mumdmsdwinapp01:7008, DSC_TRANSPORT_PROTOCOL=SOAP, DSC_CREDENTIAL_PASSWORD=********, DSC_CREDENTIAL_USERNAME=administrator, }
[2011-01-17 19:48:11,641], INFO, Thread-104, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, Validating connection...
[2011-01-17 19:48:11,641], INFO, Thread-103, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, Starting with configuration of adobe-component-ext.properties file...
[2011-01-17 19:48:11,641], INFO, Thread-103, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, Working on the copy present in [ adobe-component-ext.properties ].
[2011-01-17 19:48:11,656], INFO, Thread-103, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, [ adobe-component-ext.properties ] saved successfully.
[2011-01-17 19:48:11,656], INFO, Thread-103, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, Changes to adobe-component-ext.properties file completed.
[2011-01-17 19:48:11,656], INFO, Thread-103, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, Progress: [50%, Changes to adobe-component-ext.properties file completed successfully.]
[2011-01-17 19:48:11,656], INFO, Thread-103, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask, Completing task: com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask@85e531 isDone:true
[2011-01-17 19:48:13,700], SEVERE, Thread-104, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, java.lang.NullPointerException
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI.encryptData(UpdateAdminuiSe ttingsAPI.java:231)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI.encryptPassword(UpdateAdmin uiSettingsAPI.java:220)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI.configureUpdateAdminuiSetti ngsDocumentumAPI(UpdateAdminuiSettingsAPI.java:178)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask$ActualTask.configureUpdate AdminuiSettings(UpdateAdminuiSettingsTask.java:166)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask$ActualTask.<init>(UpdateAd minuiSettingsTask.java:135)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask$1.construct(UpdateAdminuiS ettingsTask.java:71)
at com.adobe.livecycle.lcm.core.tasks.SwingWorker$2.run(SwingWorker.java:114)
at java.lang.Thread.run(Unknown Source)[2011-01-17 19:48:13,700], SEVERE, Thread-104, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Task failed
[2011-01-17 19:49:37,784], SEVERE, Thread-104, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Task failed
[2011-01-17 19:49:37,784], INFO, Thread-104, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, Progress: [50%, Adminui Settings configuration to Adobe UM Preferences FAILED.]
[2011-01-17 19:49:37,784], INFO, Thread-104, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Completing task: com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask@1bdba73 isDone:true
[2011-01-17 19:50:18,859], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, Starting processing
[2011-01-17 19:50:18,875], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask, Starting task: com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask@85e531
[2011-01-17 19:50:18,875], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Starting task: com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask@1bdba73
[2011-01-17 19:50:18,875], INFO, Thread-105, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, Starting with configuration of adobe-component-ext.properties file...
[2011-01-17 19:50:18,875], INFO, Thread-105, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, Working on the copy present in [ adobe-component-ext.properties ].
[2011-01-17 19:50:18,890], INFO, Thread-105, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, [ adobe-component-ext.properties ] saved successfully.
[2011-01-17 19:50:18,890], INFO, Thread-105, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtAPI, Changes to adobe-component-ext.properties file completed.
[2011-01-17 19:50:18,875], INFO, Thread-106, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI, Starting with Adminui Settings Configuration job...Documentum
[2011-01-17 19:50:18,890], INFO, Thread-105, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, Progress: [50%, Changes to adobe-component-ext.properties file completed successfully.]
[2011-01-17 19:50:18,890], INFO, Thread-105, com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask, Completing task: com.adobe.livecycle.lcm.common.tasks.UpdateAdobeComponentExtTask@85e531 isDone:true
[2011-01-17 19:50:19,171], SEVERE, Thread-106, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, java.lang.NullPointerException
at java.lang.Thread.run(Unknown Source)[2011-01-17 19:50:19,171], SEVERE, Thread-106, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Task failed
[2011-01-17 19:50:22,541], SEVERE, Thread-106, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Task failed
[2011-01-17 19:50:22,541], INFO, Thread-106, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, Progress: [50%, Adminui Settings configuration to Adobe UM Preferences FAILED.]
[2011-01-17 19:50:22,541], INFO, Thread-106, com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask, Completing task: com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask@1bdba73 isDone:true
[2011-01-17 19:50:29,951], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: PREVIOUS)
[2011-01-17 19:50:29,951], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumAdminuiDataDialog, onEntry()
[2011-01-17 19:50:30,699], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumAdminuiDataDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: PREVIOUS)
[2011-01-17 19:50:30,699], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumJarDialog, onEntry()
[2011-01-17 19:50:31,495], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.documentum.gui.DocumentumJarDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: PREVIOUS)
[2011-01-17 19:50:31,495], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog, onEntry()
[2011-01-17 19:50:32,509], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.common.gui.JNDIPortDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: PREVIOUS)
[2011-01-17 19:50:32,509], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionConfigureServicesPanel, onEntry()
[2011-01-17 19:50:34,974], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.TaskSelectionConfigureServicesPanel, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:50:34,974], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.util.NetUtils, Host check is local: true
[2011-01-17 19:50:34,974], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureRE.ConfigureREDialog, onEntry()
[2011-01-17 19:54:03,016], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureRE.ConfigureREDialog, Starting processing
[2011-01-17 19:54:03,016], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureRE.ConfigureRETask, Starting task: com.adobe.livecycle.lcm.feature.configureRE.ConfigureRETask@730e4b
[2011-01-17 19:54:03,016], INFO, Thread-107, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, LC Connection properties: {DSC_SERVER_TYPE=WebLogic, DSC_DEFAULT_SOAP_ENDPOINT=http://mumdmsdwinapp01:7008, DSC_TRANSPORT_PROTOCOL=SOAP, DSC_CREDENTIAL_PASSWORD=********, DSC_CREDENTIAL_USERNAME=administrator, }
[2011-01-17 19:54:03,016], INFO, Thread-107, com.adobe.livecycle.lcm.feature.lcServer.LCServerConnector, Validating connection...
[2011-01-17 19:54:05,496], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureREDialog, Progress: [10%, Checking if credential already exists.]
[2011-01-17 19:54:05,496], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureRE, doesCredentialExist, checking for credential with alias sebiTestEnvReaderExtn
[2011-01-17 19:54:05,949], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureRE, Failed to find credential with alias sebiTestEnvReaderExtn
[2011-01-17 19:54:05,949], WARNING, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureRETask, Can't determine if credential already exists. Will ignore and proceed to import.Failed to find credential with alias sebiTestEnvReaderExtn
[2011-01-17 19:54:05,949], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureREDialog, Progress: [30%, Importing credential.]
[2011-01-17 19:54:05,949], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureRE, importCredential, importing D:\Applications\Adobe\Adobe LiveCycle ES2\configurationManager\readerExtensionLicence\0007586.pfx with alias sebiTestEnvReaderExtn
[2011-01-17 19:54:06,853], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureREDialog, Progress: [100%, Task completed.]
[2011-01-17 19:54:06,853], INFO, Thread-107, com.adobe.livecycle.lcm.feature.configureRE.ConfigureRETask, Completing task: com.adobe.livecycle.lcm.feature.configureRE.ConfigureRETask@730e4b isDone:true
[2011-01-17 19:54:11,159], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.feature.configureRE.ConfigureREDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:54:11,159], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.HTMLSummaryDialog, onEntry()
[2011-01-17 19:54:14,295], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.HTMLSummaryDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: NEXT)
[2011-01-17 19:54:14,295], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.HTMLNextStepsDialog, onEntry()
[2011-01-17 19:54:15,683], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.gui.dialogs.HTMLNextStepsDialog, onExit(com.adobe.livecycle.lcm.gui.LCMDialogExitEvent: CLOSE)
[2011-01-17 19:54:15,683], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, Saving user values to ..\config\userValues.properties
[2011-01-17 19:54:15,714], INFO, AWT-EventQueue-0, com.adobe.livecycle.lcm.core.LCMDataManager, Saving user values for CLI to ..\config\userValuesForCLI.properties
[2011-01-17 19:42:13,058], INFO, Thread-98, com.adobe.livecycle.lcm.feature.deployment.Deplo -
7. Re: EMC documentum configuration error
Sunil Gupta Jan 18, 2011 10:43 PM (in response to Raghu A)Also
Please find the log file of used weblogic managed server below.
####<19 Jan, 2011 10:54:37 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0A86C49E3C810C58438C> <> <1295414677364> <BEA-000000> <Exception in decrypting the password : null>
####<19 Jan, 2011 10:54:37 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0A86C49E3C810C58438C> <> <1295414677364> <BEA-000000> <Ignoring the exception and returning null>
####<19 Jan, 2011 10:54:38 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0AEEC49E3C810C58438C> <> <1295414678752> <BEA-000000> <Exception in decrypting the password : null>
####<19 Jan, 2011 10:54:38 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0AEEC49E3C810C58438C> <> <1295414678784> <BEA-000000> <Ignoring the exception and returning null>
####<19 Jan, 2011 10:54:42 AM IST> <Info> <EJB> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0B3EC49E3C810C58438C> <> <1295414682637> <BEA-010227> <EJB Exception occurred during invocation from home or business: com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_HomeImpl@81731ce threw exception: java.lang.NullPointerException>
####<19 Jan, 2011 10:56:29 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0DB8C49E3C810C58438C> <> <1295414789700> <BEA-000000> <Exception in decrypting the password : null>
####<19 Jan, 2011 10:56:29 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0DB8C49E3C810C58438C> <> <1295414789700> <BEA-000000> <Ignoring the exception and returning null>
####<19 Jan, 2011 10:56:30 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0DFCC49E3C810C58438C> <> <1295414790885> <BEA-000000> <Exception in decrypting the password : null>
####<19 Jan, 2011 10:56:30 AM IST> <Info> <com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_Impl> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0DFCC49E3C810C58438C> <> <1295414790885> <BEA-000000> <Ignoring the exception and returning null>
####<19 Jan, 2011 10:56:35 AM IST> <Info> <EJB> <mumdmsdwinapp01> <MServer6> <[ACTIVE] ExecuteThread: '5' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-0E4CC49E3C810C58438C> <> <1295414795472> <BEA-010227> <EJB Exception occurred during invocation from home or business: com.adobe.dctmconnector.config.DctmConnectorConfigEJB_tdpokr_HomeImpl@81731ce threw exception: java.lang.NullPointerException> -
8. Re: EMC documentum configuration error
Sunil Gupta Jan 18, 2011 10:48 PM (in response to Raghu A)Yes, I am able to access/connect to adobe WorkBench also.
When i select adobe livecycle repository from adminUi console, then i am able to create/import applicaitons from repository.
but when i select EMD documentum repository form adminUi console, then i am not able to create/import any application.
though when i select any repository from adminui console and save it it throughs error "Could not find the Livecycle Documentum Connector Component".
Regards
Sunil Gupta
9. Re: EMC documentum configuration error
Sunil Gupta Jan 18, 2011 10:55 PM (in response to Raghu A)Raghu,
I see issue in configuration manager log file at below sections
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI.configu reUpdateAdminuiSettingsDocumentumAPI(UpdateAdminuiSettingsAPI.java:178 )
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask$Actual Task.configureUpdateAdminuiSettings(UpdateAdminuiSettingsTask.java:166 )
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask$Actual Task.<init>(UpdateAdminuiSettingsTask.java:135)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsTask$1.cons truct(UpdateAdminuiSettingsTask.java:71)
at com.adobe.livecycle.lcm.core.tasks.SwingWorker$2.run(SwingWorker.java :114)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI.encrypt Data(UpdateAdminuiSettingsAPI.java:231)
at com.adobe.livecycle.lcm.common.tasks.UpdateAdminuiSettingsAPI.encrypt Password(UpdateAdminuiSettingsAPI.java:220)
[2011-01-17 19:50:22,541], INFO, Thread-106, com.adobe.livecycle.lcm.documentum.gui.ConfigureDocumentumActionDialo g, Progress: [50%, Adminui Settings configuration to Adobe UM Preferences FAILED.] -
10. Re: EMC documentum configuration error
Raghu A Jan 18, 2011 10:57 PM (in response to Sunil Gupta)To get rid of this at the earliest I think you should install Documentum DSC once again from Workbench. Do let me know if that works.
11. Re: EMC documentum configuration error
Raghu A Jan 18, 2011 11:23 PM (in response to Sunil Gupta)but when i select EMD documentum repository form adminUi console, then i am not able to create/import any application.
Please don't do that. That's a deprecated functionality. Its better to switch towards Content Repository Connector (CRC) service instead of Repository Service. You can perform all the operations which you would get using CRC service as well.
12. Re: EMC documentum configuration error
Sunil Gupta Jan 19, 2011 2:53 AM (in response to Raghu A)Raghu,
What is Documentum DSC?
Could you tell me from where i can find Documentum DSC ?
what is the procedure to install docuementum DSC using workbench?
Thanks in advance
Sunil Gupta
13. Re: EMC documentum configuration error
Raghu A Jan 19, 2011 3:25 AM (in response to Sunil Gupta)Documentum DSC refers to the following:-
<LiveCycle_Install>\deploy\adobe-connectorforemcdocumentum-dsc.jar
Follow these steps:-
1. Login to workbench.
2. Go to Components View.
3. Look for Connector For EMCDocumentum and right click on it.
4. Click on Stop Component.
5. Right Click on it once again and select Uninstall Component.
6. After uninstalling right click and select Install Component.
6. Browse to the directory that contains the above jar file.
7. Select the jar file and let workbench install the component.
8. Once done right click and select Start Component.
Disclaimer: I hope you are experimenting all these on a development server and in no case this is a production machine
14. Re: EMC documentum configuration error
Sunil Gupta Jan 19, 2011 5:53 AM (in response to Raghu A)Raghu,
Yes, this is development server only.
I followed the steps which you mentioed to re-install DSC. But still i am facing the same issue.
i have on more question.. How do i test that i am able to access documentum repository or configuration with documentum is completed.?
Regards
Sunil
15. Re: EMC documentum configuration error
Sunil Gupta Feb 2, 2011 9:17 PM (in response to Raghu A)Hi Raghu,
Did you find any solution for above mentioned issue. Please let me try any other of your idea/suggestion.
Regards
Sunil Gupta
16. Re: EMC documentum configuration error
rajan.chidambaram1 Mar 14, 2012 6:59 PM (in response to Sunil Gupta)Sunil,
I am on the same boat as you are. Were you able to solev this problem at all.
Cheers
Rajan
17. Re: EMC documentum configuration error
pgakhar Mar 15, 2012 12:35 AM (in response to rajan.chidambaram1)Hi Rajan,
What is the error that you are getting? please provide lcm and server log. Also please tell me the platform you are on i.e. which OS, appserver and db.
which version of documentum you are trying to configure?
18. Re: EMC documentum configuration error
rajan.chidambaram1 Mar 15, 2012 1:20 PM (in response to pgakhar)pghakar,
The environment is as follows:
ADEP
OS: Windows 2008 Enterprise Edition
App Server: IBM WAS 7.0.0.19
db: Oracle 11GR2 on Solaris
Documentum Content Server 6.7 SP1
The configuration settings have been provided for the EMC Documentum Connector as suggested in the following url.
I am unable to start the following services
EMCDocumentumContentRepositoryConnector
EMCDocumentumRepositoryProvider.
The error message encountered while trying to start EMCDocumentumRepositoryProvider is as follows
ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
[3/15/12 13:11:05:537 PDT] 00000113 DocumentumPro A on Start of Service = EMCDocumentumRepositoryProvider
[3/15/12 13:11:05:537 PDT] 00000113 LocalExceptio E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "doRequiresNew" on bean "BeanId(LiveCycleES3#adobe-dscf.jar#EjbTransactionCMTAdapter, null)". Exception data: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException
at java.lang.J9VMInternals.verifyImpl(Native Method)
at java.lang.J9VMInternals.verify(J9VMInternals.java:72)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:134)
at com.adobe.livecycle.documentumservice.impl.DocumentumProviderServiceLifeCycleImpl.assertD ocumentumConnection(DocumentumProviderServiceLifeCycleImpl.java:48)
at com.adobe.livecycle.documentumservice.impl.DocumentumProviderServiceLifeCycleImpl.onStart (DocumentumProviderServiceLifeCycleImpl.java:34)
at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl$31.doInTransaction(ServiceReg istryImpl.java:1941)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:299)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doRequiresNew(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.start(ServiceRegistryImpl.jav a:1939)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionBMTAdapter_ 3af08fdf.doBMT(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:165)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:131)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:167)
at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.invoke(ServiceRegistryCli ent.java:996)
at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.invoke(ServiceRegistryCli ent.java:991)
at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.start(ServiceRegistryClie nt.java:632)
at com.adobe.repository.ui.aac.struts.actions.StartServiceConfigurationsAction.execute(Start ServiceConfigurationsAction.java:110)
at com.adobe.repository.ui.aac.struts.actions.CommandProcessorAction.execute(CommandProcesso rAction.java:228)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:738)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:831)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1657)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1597)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:131)
at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:86)
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java: 188)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:116)
at com.adobe.repository.ui.aac.AacServletFilter.doFilter(AacServletFilter.java:137)
at com.adobe.framework.SecurityFilter.doFilter(SecurityFilter.java:206)
at com.adobe.framework.SessionBundleFilter.doFilter(SessionBundleFilter.java:135)
at com.adobe.repository.ui.aac.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java :76)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(WebAppFilterChain.java:77)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:908)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:934)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:502)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java: 179)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.jav a:91)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:864)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1583)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:186)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink .java:452)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.jav a:511)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java: 305)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.jav a:83)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionLi stener.java:165)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1604)
Caused by: java.lang.ClassNotFoundException: Class name com.documentum.fc.common.DfException from package com.documentum.fc.common not found.
at java.lang.Throwable.<init>(Throwable.java:80)
at java.lang.ClassNotFoundException.<init>(ClassNotFoundException.java:76)
at com.adobe.idp.dsc.DSContainerSearchPolicy.searchClassUsingParentLast(DSContainerSearchPol icy.java:323)
at com.adobe.idp.dsc.DSContainerSearchPolicy.findClass(DSContainerSearchPolicy.java:200)
at org.ungoverned.moduleloader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:619)
... 91 more
[3/15/12 13:11:05:537 PDT] 00000113 ServiceRegist E ServiceRegistryImpl:start(EMCDocumentumRepositoryProvider, 1.0):com.ibm.ws.exception.WsEJBException(nested exception is: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException)
[3/15/12 13:11:05:553 PDT] 00000113 ServiceRegist E TRAS0014I: The following exception was logged com.ibm.ws.exception.WsEJBException: nested exception is: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException
at com.ibm.ejs.container.LocalExceptionMappingStrategy.mapException(LocalExceptionMappingStr ategy.java:271)
at com.ibm.ejs.container.LocalExceptionMappingStrategy.setUncheckedException(LocalExceptionM appingStrategy.java:532)
at com.ibm.ejs.container.EJSDeployedSupport.setUncheckedLocalException(EJSDeployedSupport.ja va:582)
Caused by: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException
... 83 more
... 91 more
[3/15/12 13:11:05:553 PDT] 00000113 LocalExceptio E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "doBMT" on bean "BeanId(LiveCycleES3#adobe-dscf.jar#EjbTransactionBMTAdapter, null)". Exception data: ALC-DSC-099-000: com.adobe.idp.dsc.DSCRuntimeException: java.lang.ClassNotFoundException: Class name com.documentum.fc.common.DfException from package com.documentum.fc.common not found.
at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.start(ServiceRegistryImpl.jav a:1980)
Caused by: com.ibm.ws.exception.WsEJBException: nested exception is: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException
... 79 more
... 83 more
... 91 more
[3/15/12 13:11:05:553 PDT] 00000113 LocalTranCoor E WLTC0017E: Resources rolled back due to setRollbackOnly() being called.
[3/15/12 13:11:05:553 PDT] 00000113 actions E failed.to.start.service
[3/15/12 13:11:05:553 PDT] 00000113 actions E TRAS0014I: The following exception was logged ALC-DSC-099-000: com.adobe.idp.dsc.DSCRuntimeException: java.lang.ClassNotFoundException: Class name com.documentum.fc.common.DfException from package com.documentum.fc.common not found.
... 79 more
... 83 more
... 91 more
[3/15/12 13:11:05:553 PDT] 00000113 actions E aac.action.unknownerror
[3/15/12 13:11:05:553 PDT] 00000113 actions E TRAS0014I: The following exception was logged com.adobe.repository.ui.aac.AacException: ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
at com.adobe.repository.ui.aac.struts.actions.StartServiceConfigurationsAction.execute(Start ServiceConfigurationsAction.java:133)
The error message encountered while trying to start EMCDocumentumContentRepositoryConnector is as follows
[3/15/12 13:16:45:100 PDT] 0000018b DocumentumPro A on Start of Service = EMCDocumentumContentRepositoryConnector
[3/15/12 13:16:45:100 PDT] 0000018b LocalExceptio E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "doRequiresNew" on bean "BeanId(LiveCycleES3#adobe-dscf.jar#EjbTransactionCMTAdapter, null)". Exception data: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(HttpInboundLink.java:276)
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.sendToDiscriminators(NewConn ectionInitialReadCallback.java:214)
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.complete(NewConnectionInitia lReadCallback.java:113)
... 93 more
[3/15/12 13:16:45:100 PDT] 0000018b ServiceRegist E ServiceRegistryImpl:start(EMCDocumentumContentRepositoryConnector, 1.0):com.ibm.ws.exception.WsEJBException(nested exception is: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException)
[3/15/12 13:16:45:100 PDT] 0000018b ServiceRegist E TRAS0014I: The following exception was logged com.ibm.ws.exception.WsEJBException: nested exception is: java.lang.NoClassDefFoundError: com.documentum.fc.common.DfException
... 85 more
... 93 more
[3/15/12 13:16:45:100 PDT] 0000018b LocalExceptio E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "doBMT" on bean "BeanId(LiveCycleES3#adobe-dscf.jar#EjbTransactionBMTAdapter, null)". Exception data: ALC-DSC-099-000: com.adobe.idp.dsc.DSCRuntimeException: java.lang.ClassNotFoundException: Class name com.documentum.fc.common.DfException from package com.documentum.fc.common not found.
... 81 more
... 85 more
... 93 more
[3/15/12 13:16:45:116 PDT] 0000018b LocalTranCoor E WLTC0017E: Resources rolled back due to setRollbackOnly() being called.
[3/15/12 13:16:45:116 PDT] 0000018b actions E failed.to.start.service
[3/15/12 13:16:45:116 PDT] 0000018b actions E TRAS0014I: The following exception was logged ALC-DSC-099-000: com.adobe.idp.dsc.DSCRuntimeException: java.lang.ClassNotFoundException: Class name com.documentum.fc.common.DfException from package com.documentum.fc.common not found.
... 81 more
... 85 more
... 93 more
[3/15/12 13:16:45:116 PDT] 0000018b actions E aac.action.unknownerror
[3/15/12 13:16:45:116 PDT] 0000018b actions E TRAS0014I: The following exception was logged com.adobe.repository.ui.aac.AacException: ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
I also tried Raghu's instruction regarding reinstalling Documentum DSC
- Login to workbench.
- Go to Components View.
- Look for Connector For EMCDocumentum and right click on it.
- Click on Stop Component.
- Right Click on it once again and select Uninstall Component.
- After uninstalling right click and select Install Component.
- Browse to the directory that contains the above jar file.
- Select the jar file and let workbench install the component.
- Once done right click and select Start Component.
Please let me know if you need any more information.
Rajan
19. Re: EMC documentum configuration error
pgakhar Mar 15, 2012 11:42 PM (in response to rajan.chidambaram1)Only Documentum versions 6.0 and 6.5 are certified with ADEP. Documentum version 6.7 SP1 is certified with Adobe LiveCycle ES3 release.
Is this a development setup? If yes, i would recommend you to use Adobe LiveCycle ES3. For configuring documentum 6.7 SP1 with LiveCycle ES3 follow the link
20. Re: EMC documentum configuration error
rajan.chidambaram1 Mar 16, 2012 11:42 AM (in response to pgakhar)Thanks pgakhar.
I followed the instructions for Documentum 6.7 SP1 and was able to start the services
Thanks a bunch for helping me out.
Rajan
21. Re: EMC documentum configuration error
sams1884 Jun 5, 2012 2:03 PM (in response to rajan.chidambaram1)I am having the same issue and but I have errors like " noclassdeffounderror: ...fc.client.DfClient".
Just wonder on the the host where ALC server is installed, we need to install Documentum DFC, any other components from EMC is needed?
Sam
22. Re: EMC documentum configuration error
TundraSteve Jun 6, 2012 4:54 AM (in response to sams1884)Yes you do need to install dfc, refer to the installation guide as it shows what is needed to be installed and configured
23. Re: EMC documentum configuration error
sams1884 Jun 6, 2012 8:03 AM (in response to TundraSteve)I know and I had DFC installed. I wonder why I still get errors such as:
DSCRuntimeException: ... NoClassDefFoundError: Could not initialize class com.documentum.fc.client.DfClient.
I have two services components:
EMCDocumentumContentRepositoryConnector:1.0
and
EMCDocumentumRepositoryProvider:1.0 stopped.
24. Re: EMC documentum configuration error
TundraSteve Jun 6, 2012 8:12 AM (in response to sams1884)Typically when I see this error it's because the adobe-component-ext.properties isn't found or isn't configured properly
25. Re: EMC documentum configuration error
sams1884 Jun 6, 2012 9:56 AM (in response to TundraSteve)I have it under jboss/bin. The only thing different is that I installed the DFC over E: drive not the C: drive as typically installed. I know it's a class loading issue.
26. Re: EMC documentum configuration error
pgakhar Jun 6, 2012 8:35 PM (in response to sams1884)can you please post contents of your adobe-component-ext.properties file. I think you might be using "\" in the path names. try replacing them with "/".
27. Re: EMC documentum configuration error
sams1884 Jun 8, 2012 8:29 AM (in response to pgakhar)Hi pgakhar,
I am not able to reply from my email. Could you please tell me an email I can send the properties and log file? Or please make a comment here. I am using "/" and I am really puzzled.
Sam
29. Re: EMC documentum configuration error
pgakhar Jun 10, 2012 11:44 PM (in response to pgakhar)Sams1884,
Please provide the application server logs and the contents of adobe-component-ext.properties file.
The contents of the adobe-component-ext.properties for documentum 6.7SP1 should be like the below (in one single line):-
com.adobe.livecycle.ConnectorforEMCDocumentum.ext=C:/Program Files/Documentum/Shared/dfc.jar,C:/Program Files/Documentum/Shared/aspectjrt.jar,C:/Program Files/Documentum/Shared/jaxb-api.jar,C:/Program Files/Documentum/Shared/configservice-impl.jar,C:/Program Files/Documentum/Shared/configservice-api.jar,C:/Program Files/Documentum/Shared/log4j.jar,C:/Program Files/Documentum/Shared/commons-codec-1.3.jar,C:/Program Files/Documentum/Shared/commons-lang-2.4.jar
Please also check the spellings of the file name. It should be exactly "adobe-component-ext.properties".
In one of your messages above, you said that you have two services for documentum. You should be able to see the below services in LiveCycle adminui. If not, you have some faulty installation, please run the LCM again.
31. Re: EMC documentum configuration error
pgakhar Jun 11, 2012 5:08 AM (in response to sams1884)No attachment or link. Please attach again.
33. Re: EMC documentum configuration error
pgakhar Jun 11, 2012 5:42 AM (in response to sams1884)For attaching the files, please use the browser and open http://forums.adobe.com/message/4482229#4482229 . Then click reply at the bottom and click on Use advanced editor. Hope you are not still replying from your mail box?
35. Re: EMC documentum configuration error
pgakhar Jun 11, 2012 6:02 AM (in response to sams1884)Use the browse button in the red oval.
i am attaching my adobe-component-ext.properties file using it. Let's see whether you get it or not.
adobe-component-ext.properties.zip 374 bytes
37. Re: EMC documentum configuration error
sams1884 Jun 12, 2012 4:50 AM (in response to pgakhar)No. I don't have it. Is it because I am only a community member, or because of my browser? I posted two images. My property file is the same as yours as I checked.
Sam
Please Can anybody show me how to upload any files in or how to copy and paste? Thanks a lot.
38. Re: EMC documentum configuration error
pgakhar Jun 13, 2012 2:29 AM (in response to sams1884)If you are unable to upload the log files. please copy the text in the message itself.
39. Re: EMC documentum configuration error
pgakhar Jun 13, 2012 9:44 PM (in response to pgakhar)Users cannot upload files to our forums. you should use acrobat.com or yousendit.com or drop box or something like that to share files.
