7 Replies Latest reply on Jan 15, 2011 4:56 AM by hamrio
    CS5 Design View
    hamrio
      Can anybody explain why so many elements that were displaying fine in CS4 now dissapear in CS5. For example h tags and Spry accordions?
        • 1. Re: CS5 Design View
          John Waller Adobe Community Professional & MVP
          Hard to comment without seeing your code. CS5 displays fine for me.
          • 2. Re: CS5 Design View
            MurraySummers Level 8
            CS5 is much more insistent that your code be valid than even CS4 was.  Invalid code can easily make things disappear from design view, and in a somewhat unexpected and potentially puzzling way.  Does your code validate?
            http://validator.w3.org
            • 3. Re: CS5 Design View
              hamrio Level 1
              Hi Murray
              http://www.stanthonys.org.uk/Consultants_by_speciality/audiology.html
              This is a typical page which I have just checked and validates both html and CSS
              • 4. Re: CS5 Design View
                Good work.  What do you see disappearing in design view in CS5?
                • 5. Re: CS5 Design View
                  hamrio Level 1
                  Hi Murray
                  These are the elements that do not display in Design view but will in Live View.
                  On the main accordion menu it's the h5 Tags:
                  <div class="AccordionPanel">
                            <div class="AccordionPanelTab style1">
                              <h5>INDEX (close tabs)</h5>
                            </div>
                  The h5 and h2 Tags within:
                  <div id="mainContent">
                      <div id="Audiology">
                  <h5>Consultants by speciality</h5>
                        <h2>Audiology</h2>
                  The strong Tag in Accordion2
                  <div id="Accordion2" class="Accordion">
                              <div class="AccordionPanelTab">
                              <strong>Click consultants tab for clinic details/profile</strong></div>
                  It seems that the h Tags and strong Tag are a problem is this correct?
                  • 6. Re: CS5 Design View
                    Not as far as I can tell - I can see all of those elements in CS5 Design view.  I might note that your <h5> tag in the main accordion menu is being masked by the absolutely positioned div you have placed above that location, but all of those elements seem visible to me....
                    Am I looking in the right place?
                    • 7. Re: CS5 Design View
                      hamrio Level 1
                      I appear to have solved my own problem and that of browserlabs and widgetbrowser.
                      I used Font Book to run through all my fonts, moved to the trash any problem fonts. This didn't make any difference in fact on froze dreamweaver.
                      BUT when I reimported the fonts ALL worked as it should, very strange, but hey, this is the wonderful world of computers.
                      Thanks for all your helpful comments.
