0 Replies Latest reply on Jan 14, 2011 6:04 AM by capitainequebec
    FileStream problem with AIR deployment
    capitainequebec
      I use FileStream to load local XML file. When I test the desktop application directly from Flex everything is ok but when I install it with AIR, the application work but the file is not loaded. Here is the code I use:
      import flash.filesystem.*;
      var applicationDirectoryPath:File = File.applicationDirectory;
      var nativePathToApplicationDirectory:String = applicationDirectoryPath.nativePath.toString();
      nativePathToApplicationDirectory +=
      "/config_poste_temps.xml";
      var file:File = new File(nativePathToApplicationDirectory);
      var fs:FileStream = new FileStream();
      fs.open(file, FileMode.READ);
      var config:XML = XML(fs.readUTFBytes(fs.bytesAvailable));
      fs.close();
      plan.text = config.division;
      Regards
