Is there a way to keep the file name of an image file from being displayed when the cursor is rolled over the image?
I'm using RoboHelp 8.
Hi there
See if the thread below helps you sort it.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Hi Rick,
I checked out the link you sent and I tried deleting the alt="" tag. I then generated the package and got the same result. So RoboHelp is automatically displaying the name of the image file.
So I'm guessing it's a default behavior of RoboHelp 8.
Thanks for your help
Hi again
Question for you. What is your output? Where are you seeing the image presented?
* in a compiled CHM file
* in WebHelp
* in FlashHelp
* in AIR Help
And if you are looking at it in a browser, what is the browser type and version?
Cheers... Rick
Hi Rick,
It only happens in web help. I decided to look at the output html file in the folder.
I was able to delete the alt"filename.jpg" and it worked.
When RoboHelp 8 generates a package, it will automatically add alternate text. Leaving it as alt"" has no effect. You have to go into the output folder to make the change.
Mike
