5 Replies Latest reply on Jan 16, 2011 8:22 AM by Boing...
    Can't see vray render elements in after effects.
    Boing...
      Not too sure where to post this so i'm placing it in various forums, I'm working with 3Ds Max 2011, Vray 1.5 sp5 and After Effects CS4.
      I want to save a render with various render elements such as zdepth, material and object ID etc all saved into a single .exr file so i can bring animations into After Effects and do DOF changes and colour changes quickly. The problem is that if i render the image and do a manual save as an exr it won't show any of the vray render elements when i bring it into AE.
      If i set it to auto save as a Vray raw image but change the extension from vrimg to exr then it saves all the render elements but I lose the 'save as exr' dialogue box where i can chose bit depth and compression type.
      If I render the image and save manually as an exr then i have all that but it won't save vray render elements, after using extractor the screen is just black.
      In short i just want to be able to 'save as' an .exr and be able to see my render elements in the render, i've posted some screen caps below to show everything is as should be, any help is appreciated.
      All elements present in render window
      All elements active and selected in .exr save window.
      After effects recognises the channels on import
      Extractor recognises the channels
      But the screen is black afer using extractor, the layer is in there as can be seen when it's moved out of position
        • 1. Re: Can't see vray render elements in after effects.
          fnordware Level 3
          Hmmm, it looks like you're doing everything correctly. Vray seems to think that pass will have some information in it, but in the file it appears to be black.
          Can you post the EXR file or email it to me?
          Brendan (EXR plug-in author)
          info@fnordware.com
          • 2. Re: Can't see vray render elements in after effects.
            fnordware Level 3
            BTW, another thing you might try is checking the box in Max telling the renderer to save to a file, rather than rendering to the virtual frame buffer and then clicking the button to Save As.
            I think I remember losing the channels when doing it that way, which seems odd because Max is showing you the channels right there.
            You also might test with the Max Scanline renderer to see if you get the channels in the EXR.
            Brendan
            • 3. Re: Can't see vray render elements in after effects.
              Boing... Level 1
              fnordware, thanks i've put the files on megaupload, the links are below. i tried doing an auto save as you suggested but to no avail, as i say it will work if i tell max to save as a vray raw image and just change the extension but not as a simple 'save as'.
              I've simplified these files, they should only have an rgb, an alpha and a zdepth. Anything you can give me will be much appreciated.
              Raw image with ext change (works)
              http://www.megaupload.com/?d=X2256DGR
              'save as' (does not work)
              http://www.megaupload.com/?d=CLW6GHT2
              By the way i don't have the proexr plugin if that makes any difference but i think that's just to be able to see and select the channels like photoshop layers.
              • 4. Re: Can't see vray render elements in after effects.
                fnordware Level 3
                Thanks for the files. You don't need to download ProEXR to use these kinds of files in After Effects—the AE plug-ins in ProEXR come pre-installed with CS4 and CS5.
                In the first file you provided, I see a "Z" channel that has good information in it. In the second, I see "VRayZDepth" channels, but they're simply black. I checked this with other readers, so it's not that After Effects is reading the file wrong, it's just that the channels are black. It's a problem with how Max/Vray is being set up (or a bug - I've had many bugs rendering these channels with Max before).
                When using Vray, do you output the file differently than you would using Scanline or Mental Ray?
                Brendan
                • 5. Re: Can't see vray render elements in after effects.
                  Boing... Level 1
                  Good idea, i tried it with scanline and Mental ray just doing a standard, automatic "save as" with a zdepth and it works which would point the finger at vray for misbehaving.
                  However when i go to the scanline/mental ray render window and try to save it manually as an exr i get the same issue, channels all showing up in AE but a black screen. The file size is lower on the manual save than on the automatic one though which suggests the info simply isn't there.
                  however, as max is performing the automatic 'save as' with other render engine but not vray it at least narrows things down.
