2 Replies Latest reply on Jan 17, 2011 9:43 AM by yalp.com.br
    AS3 SRT Subtitle in SWF
    yalp.com.br Level 1
      Hi all,
      I've been looking at some tutorials in how to add SRT subtitles in flash. I found this grea article in base42 but i'm not finding a way to make it work can anyone give me a hand in how this works?
      PLS HELP!!!
      Let's say I have 4 files
      movie.fla (movie.swf)
      // I need to make the subtitle SRT show on the textBox_txt during my animation (timeline)
      import flash.external.ExternalInterface;
      var urlParser =  ExternalInterface.call ("nl.inlet42.data.subtitles.SubTitleData");
      var minhaLegenda:SubtitleParser = new SubtitleParser(urlParser);
      var urlData = ExternalInterface.call ("nl.inlet42.data.subtitles.SubTitleData");
      var carregaLegenda:SubTitleData = new SubTitleData(urlData);
      textBox_txt.text = subtitle.srt
      subtitle.srt
      1
      00:00:20,000 --> 00:00:24,400
      In connection with a dramatic increase
      in crime in certain neighbourhoods,
      2
      00:00:24,600 --> 00:00:27,800
      the government is implementing a new policy...
      SubtitleParser.as
      package nl.inlet42.data.subtitles {
            *     @author Jankees.van.Woezik
           public class SubtitleParser {
                public static function parseSRT(data : String) : Array {
                     var result : Array = new Array();
                     var lines : Array;
                     var translation : SubTitleData;
                     var blocks : Array = data.split(/^[0-9]+$/gm);
                     for each (var block : String in blocks) {
                          translation = new SubTitleData();
                          lines = block.split('\n');
                          for each (var line : String in lines) {
                               //all lines in a translation block
                               if(trim(line) != "") {
                                    if(line.match("-->")) {
                                         //timecodes line
                                         var timecodes : Array = line.split(/[ ]+-->[ ]+/gm);
                                         if(timecodes.length != 2) {
                                              trace("Translation error, something wrong with the start or end time");
                                         } else {
                                              translation.start = stringToSeconds(timecodes[0]);
                                              translation.end = stringToSeconds(timecodes[1]);
                                              translation.duration = translation.end - translation.start;
                                              if(translation.duration < 0) {
                                    } else {
                                         //translation line
                                         if(translation.text.length != 0) line = "\n" + trim(line);
                                         translation.text += line;
                          result.push(translation);
                     return result;
                public static function trim(p_string : String) : String {
                     if (p_string == null) {
                          return '';
                     return p_string.replace(/^\s+|\s+$/g, '');
                 * Convert a string to seconds, with these formats supported:
                 * 00:03:00.1 / 03:00.1 / 180.1s / 3.2m / 3.2h / 00:01:53,800
                 * Special thanks to Thijs Broerse of Media Monks!
                public static function stringToSeconds(string : String) : Number {
                     var arr : Array = string.split(':');
                     var sec : Number = 0;
                     if (string.substr(-1) == 's') {
                          sec = Number(string.substr(0, string.length - 1));
                     }else if (string.substr(-1) == 'm') {
                          sec = Number(string.substr(0, string.length - 1)) * 60;
                     }else if(string.substr(-1) == 'h') {
                          sec = Number(string.substr(0, string.length - 1)) * 3600;
                     }else if(arr.length > 1) {
                          if(arr[2] && String(arr[2]).indexOf(',') != -1) arr[2] = String(arr[2]).replace(/\,/, ".");
                          sec = Number(arr[arr.length - 1]);
                          sec += Number(arr[arr.length - 2]) * 60;
                          if(arr.length == 3) {
                               sec += Number(arr[arr.length - 3]) * 3600;
                     } else {
                          sec = Number(string);
                     return sec;
      SubTitleData.as
           public class SubTitleData {
                public var text : String;
                public var start : Number;
                public var duration : Number;
                public var end : Number;
                public function SubTitleData(inText : String = "",inStart : Number = 0,inDuration : Number = 0,inEnd : Number = 0) {
                     text = inText;
                     start = inStart;
                     duration = inDuration;
                     end = inEnd;
                public function toString() : void {
                     trace("nl.inlet42.data.subtitles.SubTitleData");
      But every time I export my swf I keep getting the following errror message:
      SubtitleParser.as, Line 1    5001: The name of package 'nl.inlet42.data.subtitles' does not reflect the location of this file. Please change the package definition's name inside this file, or move the file. SubtitleParser.as
      Thanks a lot!!!
        • 1. Re: AS3 SRT Subtitle in SWF
          Jankeesvwoezik
          I came across your question by coincidence, i made those classes you mention.
          You made one small mistake, you have to make folder like the package name... (nl/inlet42/data/subtitles)
          If you need any help, drop me a line at jankees [at] base42 [dot] nl
          Good luck!
          • 2. Re: AS3 SRT Subtitle in SWF
            yalp.com.br Level 1
            Thanks for tour attention,
            I was looking at the code and I fixed the path but I'm still getting error messages
            /SubtitleParser.as, Line 8    1046: Type was not found or was not a compile-time constant: SubTitleData.
            /SubtitleParser.as, Line 12    1180: Call to a possibly undefined method SubTitleData.
            line 8        // var translation : SubTitleData;
            line 12     //translation = new SubTitleData();
            anyone has any ideias?
            thanks a lot
