4 Replies Latest reply on Jan 24, 2011 6:36 AM by ct338
    Full Screen Issues
    ct338
      I've been trying to edit and save a screencast created with Windows Expression Encoder.  When the file is encoded through Expression Encoder, it is a wmv and will play in full screen.  However, when I edit it and try to save it (in any format, mpeg, wmv) it won't open to full screen.  Even when I preview it in Premier Elements in full screen, it's only a fraction of the screen.   It's like there's a large black border around it and it's blurry.  I export it to 1024x768 but it still won't expand to fill the entire screen.  What am I doing wrong??  Does something change when it's imported into Premier Elements?
        • 1. Re: Full Screen Issues
          the_wine_snob Level 9
          Welcome to the forum.
          What are the full specs. of the WMV from Expressions?
          What is the Project Preset that you choose at New Project?
          Those two should match 100%
          What are the settings that you chose when you went to Export/Share?
          All of those things need to be taken into account.
          Good luck, and let us know a bit more,
          • 2. Re: Full Screen Issues
            ct338 Level 1
            Hi Bill,
            I think the problem must be in the project settings when I open a new project because I can play full screen after the Expression video is encoded to WMV.  What should the new project setting be?  I'm only looking to post this video online and be able to watch it on a computer using Windows Media Player not Flash.
            Thanks for your help!
            • 3. Re: Full Screen Issues
              The Project Preset chosen should match the source footage 100%. This is regardless of the intended output. That can then be chosen/adjusted with Export/Share.
              PrE 9 has added a little feature, where the program will help you get the best Preset for the source footage. I'd give you the steps for that, but fear that I'd tell you how to do it in PrPro CS5, and be wrong for PrE 9. Others will be able to give you the exact steps, if you have PrE 9. Otherwise, it's basically get the full specs. of the source files, write them down, and then find a Preset that matches those specs. One can get the specs. in several ways:
              Properties in either Windows Media Player, or from Apple's QuickTime Pro (Ctrl+J there)
              G-Spot
              MediaInfo
              Good luck, and happy editing,
              • 4. Re: Full Screen Issues
                ct338 Level 1
                Thanks, Bill.  This is starting to make more sense but after looking at my source file and the new project presets, I still can't figure out which project preset is the best fit.  I've encoded the source file two different ways.  They're both below.  If you have any clues as to what project preset would work, I would really appreciate it.  Thank you for all of your help!
                Source 1:
                Format :Windows Media
                File size :513 KiB
                Duration :23s 142ms
                Overall bit rate mode :Constant
                Overall bit rate :182 Kbps
                Maximum Overall bit rate :30.2 Mbps
                Encoded date :UTC 2011-01-24 14:30:37.602
                Video
                Format :MTS2
                Codec ID :MTS2
                Duration :23s 133ms
                Bit rate mode :Constant
                Bit rate :30.0 Mbps
                Width :1 024 pixels
                Height :768 pixels
                Display aspect ratio :4:3
                Frame rate :15.000 fps
                Bit depth :8 bits
                Bits/(Pixel*Frame) :2.543
                Stream size :82.7 MiB
                Language :English (US)
                Source 2:
                File size :8.75 MiB
                Duration :1mn 52s
                Overall bit rate :654 Kbps
                Encoded date :UTC 2011-01-19 20:16:17.118
                Video
                Format :MTS2
                Codec ID :MTS2
                Duration :1mn 52s
                Bit rate :30.0 Mbps
                Width :1 024 pixels
                Height :768 pixels
                Bit depth :8 bits
                Stream size :401 MiB
                NumberOfFrames :1681
