7 Replies Latest reply on Jan 19, 2011 1:40 AM by RUSH-ME
    How to get the Label's height (Spark) after setting its fontSize?
    jKnistrum Level 1
      in Flex 4, inside a class which extends Spark.Group I add a Label
      // x axes's label
      xTitle = new Label();
      xTitle.text = this.titleX;
      xTitle.setStyle("fontSize", 72 ) ;
      it works fine, but
      after several attempts with FontMetrics and  label.getExplicitOrMeasuredHeight(), label.getBounds() and so on,  I don't get to know how to retrieve the Label's height, it always return zero.
      Thanks any help,
      jcarlos
        • 1. Re: How to get the Label's height (Spark) after setting its fontSize?
          Wrataxas Level 2
          In one of Flex's skins I saw it use getPreferredBoundsWidth() to determine how wide a Label thought it was, so perhaps getPreferredBoundsHeight() will give you what you need.
          • 2. Re: How to get the Label's height (Spark) after setting its fontSize?
            jKnistrum Level 1
            It shows a number related to Label rotation but it doesn't take the fontSize and Face in account.
            I've made some simple tests
              xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="init();">
              <s:layout>
                <s:VerticalLayout horizontalAlign="center" paddingTop="20" gap="20"/>
              </s:layout>
              <fx:Script>
                <![CDATA[
            private function init():void
            var nt:testClass = new testClass(debug);
            addElement( nt ) ;
            debug.text += "\n\nMain mxml " + nt.label1.getPreferredBoundsHeight(true) + "\n";
              </fx:Script>
            <s:VGroup>
            <s:TextArea id="debug" width="300" height="200">
            </s:TextArea>
            </s:VGroup>
            </s:Application>
            package
            import spark.components.Group;
            import spark.components.Label;
            import spark.components.TextArea;
            public class testClass extends Group
            [Embed(source='../fonts/GOUDOS.ttf',
                    fontName='Goudy',
                    mimeType='application/x-font')]
            private var font1:Class;
            public var label1:Label;
            public function testClass(debug:TextArea)
            super();
            label1 = new Label();
            label1.text = "Meu texto" ;
            label1.x = 0;
            label1.y = 0;
            label1.width = 200;
            label1.setStyle("fontSize", 72 ) ;
            label1.setStyle("fontFamily", "Goudy" ) ;
            label1.rotation = 15;
            addElement(label1);
            debug.text += "\ntestClass\ngetPreferredBoundsHeight() " + label1.getPreferredBoundsHeight();
            debug.text += "\ngetBounds(this) " + label1.getBounds(this);
            debug.text += "\nheight " + label1.height;
            debug.text += "\ngetLayoutBoundsHeight() " + label1.getLayoutBoundsHeight();
            debug.text += "\ngetMaxBoundsHeight() " + label1.getMaxBoundsHeight();
            debug.text += "\ngetExplicitOrMeasuredHeight() " + label1.getExplicitOrMeasuredHeight();
            without success.
            testClass
            getPreferredBoundsHeight() 51.763916015625
            getBounds(this) (x=4745318.4, y=8219136, w=0, h=0)
            height 0
            getLayoutBoundsHeight() 51.763916015625
            getMaxBoundsHeight() 12247.467041015625
            getExplicitOrMeasuredHeight() 0
            Main mxml 51.763916015625
            If the rotation is changed getPreferredBoundsHeight() changes too, but it is not affected by fontSize and fontFamily.
            It seems that Sparks have complicated what I want to measure with the mx.TextField where tField.textWidth  adn tField.textHeight give simply and directly what is needed.
            • 3. Re: How to get the Label's height (Spark) after setting its fontSize?
              RUSH-ME Level 3
              Hi
              check with labelID.measureText(yourText).height.
              Hope this helps
              Rush-me
              • 4. Re: How to get the Label's height (Spark) after setting its fontSize?
                jKnistrum Level 1
                Unfortunately not,
                no matter the fontSize it returns 17
                super();
                label1.text = "My Text" ;
                label1.width = 300;
                label1.setStyle("fontSize", 12 ) ;
                addElement(label1);
                debug.text += "\nlabel1.measureText(label1.text).height " + label1.measureText(label1.text).height;
                jcarlos
                • 5. Re: How to get the Label's height (Spark) after setting its fontSize?
                  Flex harUI Adobe Employee
                  Call validateNow after setStyle
                  • 6. Re: How to get the Label's height (Spark) after setting its fontSize?
                    jKnistrum Level 1
                    Nope.
                    label1.validadeNow() and with this.validateNow()
                    package
                            fontName='Goudy',
                    super();
                    label1.width = 300;
                    label1.validateNow();
                    addElement(label1);
                    • 7. Re: How to get the Label's height (Spark) after setting its fontSize?
                      RUSH-ME Level 3
                      Hi
                      I am not sure why it is not working in your case. below code is working fine as it shows 17 and 83.
                                     creationComplete="application1_creationCompleteHandler(event)">
                          <fx:Script>
                              <![CDATA[
                                  import mx.events.FlexEvent;
                                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                                      var label1:Label = new Label();
                                      label1.width = 300;
                                      this.addElement(label1);
                          </fx:Script>
                          <s:layout>
                              <s:VerticalLayout/>
                          </s:layout>
                          <s:TextArea id="debug"/>
                      </s:Application>
                      Hope this helps
                      Rush-me
