1. Re: Aspect ratio problems in exporting HD movie
JSS1138 Jan 15, 2011 9:51 AM (in response to cooleon)Export out with 1920 x 1080 dimensions and a 1.0 Pixel Aspect Ratio. Using those parameters, it will come out correct.
If it does not appear fine in your player of choice, use a different player. QuickTime certainly isn't the best. Try VLC, KM Player or GOM instead.
2. Re: Aspect ratio problems in exporting HD movie
cooleon Jan 15, 2011 1:08 PM (in response to JSS1138)Thank you so much. Works a treat. That sorts me out for most of what I have to do.
If I can bother you with another question...
I need to eventually put this video into a powerpont presentation created in mac. With a small .mov file that's fine to play on other macs. But I will run into problems when I need that powerpoint presentation to run on a PC. I think I need an MPEG file version to run on a PC.
If that's correct, how do I create a non-jumpy mpeg file that's small enough to go into powerpoint. Can I do that on AME or is it simpler to convert my .mov file in QuickTime to mpeg?
