1. Re: AIR project window resizable - can I avoid?
Tanya Heins Jan 19, 2011 9:33 AM (in response to jamco1968)Hi,
Not sure what you mean by users being able to see your pasteboard. (Perhaps post a sample/screenshot of your app)
On the AIR window resizing issue, I expect that you would need to import your project in FlashBuilder to control this. There is an app xml file that controls the following AIR application settings for the initial Window:
If your FB project is called foo a foo-app.xml will also be generated. This is an application configuration file. Edit this file, in particular change:
<!-- Whether the user can resize the window. Optional. Default true. -->
<!-- <resizable></resizable> -->
to:
<resizable>false</resizable>
(Note: This property is commented out and the default value is true.)
Hope this helps.
Tanya
