Expand my Community achievements bar.
SOLVED
How to detect Approve/Reject Button pressed in the form
Avatar
Former Community Member
Hi, I've created a process and after kick off the process, assigned user can approve/reject the form in workspace. Can I detect which button is pressed in the form and perform different validation before the form is submitted back to server?
For example, the form got field A & field B, if Approve button is pressed, field A will be a manadated field and if Reject button is pressed, field B will be a manadated field. As in my form I only got a submit button and the Approve/Reject button is generated from workspace, so I am not sure how to detect which button is pressed in the form? Thanks.
1 Accepted Solution
Avatar
Correct answer by
Level 10
There's no need to put the Approve/Reject buttons on the form. You just need the process fields.
The following post might be useful: http://forums.adobe.com/message/1356826#1356826.
Jasmin
View solution in original post
Avatar
Hi  hkho,
     I think you may have to change your form design a bit.
     I would suggest add the Approve and Reject buttons to your form rather than route names, so that way you have control over actions.
     You can do required validation on the form on button click event and if validation are successful then submit the form as part of javascript using  AWS_SUBMIT.execEvent("click");
Regards,
Vik
Avatar
Thanks for the reply, so the buttons have to be on the form and I can't put it in the workspace like the Complete button?
Avatar
Correct answer by
Level 10
Jasmin
Avatar
but if that's the case the Approve/Reject will be drop down list instead of button.
Avatar
Level 10
No, The drop down will be hidden and you'll get the buttons in the Workspace chrome.
Jasmin
