1 Reply Latest reply on Jan 18, 2011 3:56 AM by Lemtz
    able to add data services into swc?
    Lemtz Level 1
      Hey
      I was wondering is it possible to add the php data servcies that you create with the flash builder 4 wizard into a flex library project ?
      i have couple of projects that use the same services and i would like to gather all the needed data services into one swc and then add that to the projects.
      I tried to just copy already made files intoa swc project but there are some libraries that are missing once services are moved.
      Any suggestions ?
        • 1. Re: able to add data services into swc?
          Lemtz Level 1
          Found a way out.
          it's a bit a hacked way but still, works like a charm.
          Just add fiber.swc,fds.swc and their resourcebundle swc's + serializers.swc also to flex library project.
          Then just add a reference folder to another, flex project , where you have the services and vo's.
          Then you can use the swc where you have the services everywhere.
