3 Replies Latest reply on Jan 17, 2011 2:05 PM by snunicycler
    what is wrong with my code?
    snunicycler Level 3
      here is my new code that works for PART of my movie. i have two dynamic text boxes, one named "item" and one named "ssnumber"
      ssnumberNode works fine but itemNode does not. i bolded the parts that i think are relevant to the problems
      on (rollOver) {
          function processXMLData(success)
          if (success)
              var rootNode=this.firstChild.childNodes[0];
              var itemNode=findNode(rootNode, "item");
              var ssnumberNode=findNode(rootNode, "ssnumber");
              content="oops, this is hard";
      function getValue(node)
      if (node && node.firstChild)               >what does this part mean?
            return node.firstChild.nodeValue;
        return "?";
      function findNode(node, nodeName)
          if (node.nodeName==nodeName)
              return node;
          for (var i=0; node.childNodes && i<node.childNodes.length; i++)
              var foundNode=findNode(node.childNodes[i], nodeName);
              if (foundNode!=null)
                  return foundNode;
          return null;
      var xmlData=new XML();
      the part that says " if(node && node.firstChild) return  node.firstChild.nodeValue; return "?" is the thing that is giving me  trouble. the question mark shows up on my dynamic text box called "item"  but the "ssnumber" one works fine. if i delete that part alltogether,  both item and ssnumber return "undefined". what is wrong with my code  that is keeping item from working?
      here is that part of the xml
        • 1. Re: what is wrong with my code?
          What happens when you remove the line...
          return "?";
          • 2. Re: what is wrong with my code?
            snunicycler Level 3
            when i remove that part it returns "null"
            i figured it out though. i hate it when the problem is something totally stupid and  small. like missing a bracket or not closing a tag correctly, in my case  i had a small space in my code that should not have been there. i  figured it out and now it works. the sad part is, i have been staring at  my monitor since 930 this morning trying to figure it out. i have had  my coworkers come in and check it out too. it evaded all of us.  sheesh......
            • 3. Re: what is wrong with my code?
              snunicycler Level 3
              just a side question though (weird how everytime i figure something out, something else doesn't work)...
              i got the info to display when one part is moused over. i want the info for another part to replace that text when the other part is moused over.
              this is how i have it organized. the P01LEM14139 is the part number.  so when i go to the next part i need the dynamic text to skip the first one and display the info for the second one.
                          <item><p>Pedal Strap With Toe Cage and Straps</p></item>
                          <item><p>Arm, Crank, Stainless Steel (Left)</p></item>
                          <item><p>Crank Arm Bolt, Each</p></item>
              i copied and pasted the code from the first button and added this to the code that i had:
              var crankarmNode=this.firstChild.childNodes[1];
              and i changed the rootNode parts to crankarmNode so now it SHOULD (if i understand this all correctly) go to the firstChild.childNodes[1] (which is the part i need the info for) the problem is that it returns "null" for both text boxes.
              am i not allowed to do that? or should i write that part a different way?
