0 Replies Latest reply on Jan 17, 2011 5:11 PM by xyqwerty
    3D Illustrator Import Problem
    xyqwerty
      I am having a problem importing an AI file into flash. The object has a 3D bevel and extrude effect on it and when imported into a Flash library or stage, the object has some whiteline artifacts that are appearing where the top and right side edge of the base vector shape would be.
      When importing to Flash library I do get the following error on the "path" layer of the object:
      "Object is incompatible with Flash. For maximum compatibility, import as bitmap."
      The object does show two layers in AI; the primary layer and a sub named <path>.
      Is there a way to import this type of AI object in Flash without getting these artifacts?
      I have posted a side by side view of the problem at:
      http://www.idg-partners.com/flash_issue.html
      Thanks in advance for any help in this matter.
      I apologize if already discussed and solved elsewhere.
