2 Replies Latest reply on Jan 19, 2011 8:49 PM by prethi.flex
    Runtime localization in AIR fails
      Hi All
                i am trying to load system locale in AIR.
      code : initializeHandler(event:FlexEvent)
                var locales:String=Capabilities.languages.toString();
      Set the project properties as [additional complier argument] -locale de_DE -source-path=../locale/{locale} and the system language is en_US.
      If i run this project am getting a blank labels.am getting a blank labels when i set value to resourceManager.localeChain.Its working perfectly in static builds.
      Thanks in advance ..please help me..
        • 1. Re: Runtime localization in AIR fails
          Grace_Wang Level 1
          Hi Preethee,
          I can see some conflicts in your sample code. Could you please try with following one? It works fine for me.
          var locales:Array = Capabilities.languages;
                          for (var i:int = 0; i<locales.length; i ++)
                            var index:int = i;
                            locales[index] = locales[index].replace(/-/g,'_');
                            trace ("locales:" + locales[index]);
                          resourceManager.localeChain = locales;
          AIR Engineering
          Grace Wang
          • 2. Re: Runtime localization in AIR fails
            prethi.flex Level 1
            Thanks Grace Wang,
                Now its working for me.i set -locale de_DE -locale en_US -source-path=../locale/{locale} in properties compiler argument and assign the system locale in localechain.
