4 Replies Latest reply on Jan 18, 2011 8:53 AM by Todd_Kopriva
    Finding a suitable After Effects CS4 rendering setting
    are595
      Hi, I am currently trying to add some text to a video while keeping the video's settings. These are the source video's settings:
      Video
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      Format profile                   : High@L4.1
      Format settings, CABAC           : Yes
      Format settings, ReFrames        : 4 frames
      Codec ID                         : avc1
      Codec ID/Info                    : Advanced Video Coding
      Duration                         : 4mn 15s
      Bit rate mode                    : Variable
      Bit rate                         : 2 022 Kbps
      Maximum bit rate                 : 9 328 Kbps
      Width                            : 1 280 pixels
      Height                           : 720 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 29.970 fps
      Resolution                       : 8 bits
      Colorimetry                      : 4:2:0
      Scan type                        : Progressive
      Bits/(Pixel*Frame)               : 0.073
      Stream size                      : 61.5 MiB (89%)
      Writing library                  : x264 core 112 r1834 a51816a
      Encoding settings                : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.60:0.20 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=1 / scenecut=60 / intra_refresh=0 / rc=crf / mbtree=0 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=30 / qpstep=8 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.50
      Encoded date                     : UTC 2011-01-14 15:37:51
      Tagged date                      : UTC 2011-01-14 15:48:32
      Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
      Transfer characteristics         : BT.709-5, BT.1361
      Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
      Audio
      Format                           : AAC
      Format/Info                      : Advanced Audio Codec
      Format version                   : Version 4
      Format profile                   : LC
      Format settings, SBR             : No
      Codec ID                         : 40
      Duration                         : 4mn 15s
      Bit rate                         : 253 Kbps
      Maximum bit rate                 : 257 Kbps
      Channel(s)                       : 2 channels
      Channel positions                : Front: L R
      Sampling rate                    : 48.0 KHz
      Stream size                      : 7.68 MiB (11%)
      Encoded date                     : UTC 2011-01-14 15:48:32
      I would, in a perfect world, like to render the video with the text with these exact same settings (or without rendering the video but just adding the text). Is there any way I could do this?
        • 1. Re: Finding a suitable After Effects CS4 rendering setting
          No. For all intents and purposes, that is completely mutually exclusive. The footage must be decoded at any cost then the text integrated into the background pixels, resulting in a re-encode. It's simply not possible for technical reasons in any program on this planet. The only way to achieve some sort of pass-through would not to do anything to the footage but cut it, but obviously that is not happening here and also would require a program like Premiere or Vegas to handle it. Based on that, in these programs you could also selectively re-encode only the sections thatr have the text, but never ever any of that in Ae. As a compositing program, it always expands the pixel data fully and after that, everything is a full new encode. so ultimately, how you out put it from there doesn't matter. Naturally, to avoid further recompression once you go back to your edit program, you would use visualyl lossless formats like Quicktime animation or PNG, but that's very much it...
          Mylenium
          • 2. Re: Finding a suitable After Effects CS4 rendering setting
            are595 Level 1
            Alright, so then are there any settings that are similar to the original that i can chose without any major quality degradation? I tried rendering the ~1 minute clip that has the text as lossless and got a 7gb file =/.
            • 3. Re: Finding a suitable After Effects CS4 rendering setting
              What I already wrote - Quicktime with the Animation or PNG CoDecs is what people use all the time. Please read the help on how to adjust output module settings to gain access to other formats.
              Mylenium
              • 4. Re: Finding a suitable After Effects CS4 rendering setting
                Todd_Kopriva Level 8
                Mylenium has given you some good advice and information. This FAQ entry gives some links to additional information explaining the difference between output settngs for intermediate files (usually losslessly encoded) versus files for distribution and playback (usually highly and lossily compressed).
