1 Reply Latest reply on Feb 16, 2011 6:58 AM by Gregory Lafrance
    Flex 3 WASI Dashboard graph datasource modify - Please help
    jasonxavx123
      I been trying to resolve this for 2 weeks now given that i'm new to Flex. Regarding to the WASI Dashboard, how can i modify the data source for the charts within the POD.xml so that it reference an Array Collection instead of a static xml file.
      I have the first page (login state) which has a combo box. When a user selects a value from the combo box, it will call several PHP services to pull data from a MySql database into several ArrayCollections.  The state then change to the "DashboardComponents" which is the same as the WASI dashboard's Main.mxml which loads the pod under the POD.xml.  How can i change the datasource for the graphs so that is referring to the array collections from the first state(login state)?
      Below are my codes:  Just for testing purpose, i have not added the combo box, however the paramenter for PHP service all suppliermasterService5.getSuppliermasterByID('10029') would eventually hold the value from the selected item in the combo box.
      From Login.mxml
                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)" xmlns:suppliergeneralservice="services.suppliergeneralservice.*" currentState="MainMenu" xmlns:local="*" xmlns:suppliermasterservice5="services.suppliermasterservice5.*" xmlns:view="com.esria.samples.dashboard.view.*">
            <fx:Script>
                  <![CDATA[
                        import mx.collections.ArrayCollection;
                        import mx.controls.Alert;
                        import mx.events.FlexEvent;
                        import mx.rpc.events.ResultEvent;
                        import spark.events.IndexChangeEvent;
                        import spark.events.TextOperationEvent;
                        [Bindable]
                        public var ontime:ArrayCollection = new ArrayCollection;
                        protected function ResponderOntime_resultHandler(event:ResultEvent):void
                              // TODO Auto-generated method stub
                              ontime = event.result as ArrayCollection;
                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                              ResponderOntime.token = suppliermasterService5.getSuppliermasterByID('10029');
                              //currentState = "Dashboard";
            </fx:Script>
            <s:states>
                  <s:State name="MainMenu"/>
                  <s:State name="Dashboard"/>
            </s:states>
            <fx:Declarations>
                  <s:CallResponder id="getSupplierCodeResult"/>
                  <suppliergeneralservice:SuppliergeneralService id="suppliergeneralService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                  <suppliermasterservice5:SuppliermasterService5 id="suppliermasterService5"/>
                  <s:CallResponder id="ResponderOntime" result="ResponderOntime_resultHandler(event)"/>
                  <s:CallResponder id="getSupplierCodeResult2"/>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
            </fx:Declarations>
            <local:DashboardComponent includeIn="Dashboard"/>
            <mx:DataGrid includeIn="MainMenu" x="44" y="42" id="dataGrid" dataProvider="{ontime}" width="187" height="167">
                  <mx:columns>
                        <mx:DataGridColumn headerText="SupplierCode" dataField="SupplierCode"/>
                  </mx:columns>
            </mx:DataGrid>
      </s:Application>
      From DashboardComponents.mxml
      <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml"
                  minWidth="600" minHeight="600"
                  x="0" y="0"
                  width="100%" height="100%"
                  backgroundSize="100%"
                  creationComplete="onApplicationComplete()">
            <mx:Script>
                  <![CDATA[
                        import com.esria.samples.dashboard.events.LayoutChangeEvent;
                        import com.esria.samples.dashboard.managers.PodLayoutManager;
                        import com.esria.samples.dashboard.managers.StateManager;
                        import com.esria.samples.dashboard.view.ChartContent;
                        import com.esria.samples.dashboard.view.FormContent;
                        import com.esria.samples.dashboard.view.ListContent;
                        import com.esria.samples.dashboard.view.PieChartContent;
                        import com.esria.samples.dashboard.view.DragHighlight;
                        import com.esria.samples.dashboard.view.Pod;
                        import com.esria.samples.dashboard.view.PodContentBase;
                        import mx.containers.Canvas;
                        import mx.events.IndexChangedEvent;
                        import mx.events.ItemClickEvent;
                        import mx.rpc.events.FaultEvent;
                        import mx.rpc.http.HTTPService;
                        // Array of PodLayoutManagers
                        private var podLayoutManagers:Array = new Array();
                        // Stores the xml data keyed off of a PodLayoutManager.
                        private var podDataDictionary:Dictionary = new Dictionary();
                        // Stores PodLayoutManagers keyed off of a Pod.
                        // Used for podLayoutManager calls after pods have been created for the first time.
                        // Also, used for look-ups when saving pod content ViewStack changes.
                        private var podHash:Object = new Object();
                        private function onApplicationComplete():void
                              // Load pods.xml, which contains the pod layout.
                              var httpService:HTTPService = new HTTPService();
                              httpService.url = "data/pods.xml";
                              httpService.resultFormat = "e4x";
                              httpService.addEventListener(FaultEvent.FAULT, onFaultHttpService);
                             httpService.addEventListener(ResultEvent.RESULT, onResultHttpService);
                              httpService.send();
                        private function onFaultHttpService(e:FaultEvent):void
                              Alert.show("Unable to load data/pods.xml.");
                        private function onResultHttpService(e:ResultEvent):void
                              var viewXMLList:XMLList = e.result.view;
                              var len:Number = viewXMLList.length();
                              var containerWindowManagerHash:Object = new Object();
                              for (var i:Number = 0; i < len; i++) // Loop through the view nodes.
                                    // Create a canvas for each view node.
                                    var canvas:Canvas = new Canvas();
                                    // PodLayoutManager handles resize and should prevent the need for
                                    // scroll bars so turn them off so they aren't visible during resizes.
                                    canvas.horizontalScrollPolicy = "off";
                                    canvas.verticalScrollPolicy = "off";
                                    canvas.label = viewXMLList[i].@label;
                                    canvas.percentWidth = 100;
                                    canvas.percentHeight = 100;
                                    viewStack.addChild(canvas);
                                    // Create a manager for each view.
                                    var manager:PodLayoutManager = new PodLayoutManager();
                                    manager.container = canvas;
                                    manager.id = viewXMLList[i].@id;
                                    manager.addEventListener(LayoutChangeEvent.UPDATE, StateManager.setPodLayout);
                                   // Store the pod xml data. Used when view is first made visible.
                                    podDataDictionary[manager] = viewXMLList[i].pod;
                                    podLayoutManagers.push(manager);
                              var index:Number = StateManager.getViewIndex();
                              // Make sure the index is not out of range.
                              // This can happen if a tab view was saved but then tabs were subsequently removed from the XML.
                              index = Math.min(tabBar.numChildren - 1, index);
                             onItemClickTabBar(new ItemClickEvent(ItemClickEvent.ITEM_CLICK, false, false, null, index));
                              tabBar.selectedIndex = index;
                        private function onItemClickTabBar(e:ItemClickEvent):void
                              var index:Number = e.index;
                              StateManager.setViewIndex(index); // Save the view index.
                              viewStack.selectedIndex = index;
                              // If data exists then add the pods. After the pods have been added the data is cleared.
                              var podLayoutManager:PodLayoutManager = podLayoutManagers[index];
                              if (podDataDictionary[podLayoutManager] != null)
                                    addPods(podLayoutManagers[index]);
                        // Adds the pods to a view.
                        private function addPods(manager:PodLayoutManager):void
                              // Loop through the pod nodes for each view node.
                              var podXMLList:XMLList = podDataDictionary[manager];
                              var podLen:Number = podXMLList.length();
                              var unsavedPodCount:Number = 0;
                              for (var j:Number = 0; j < podLen; j++)
                                    // Figure out which type of pod content to use.
                                    var podContent:PodContentBase = null;
                                    if (podXMLList[j].@type == "chart")
                                          podContent = new ChartContent();
                                    else if (podXMLList[j].@type == "form")
                                          podContent = new FormContent();
                                    else if (podXMLList[j].@type == "list")
                                          podContent = new ListContent();
                                    else if (podXMLList[j].@type == "pieChart")
                                          podContent = new PieChartContent();
                                    if (podContent != null)
                                          var viewId:String = manager.id;
                                          var podId:String = podXMLList[j].@id;
                                          // Get the saved value for the pod content viewStack.
                                          if (StateManager.getPodViewIndex(viewId, podId) != -1)
                                                podXMLList[j].@selectedViewIndex = StateManager.getPodViewIndex(viewId, podId);
                                          podContent.properties = podXMLList[j];
                                          var pod:Pod = new Pod();
                                          pod.id = podId;
                                          pod.title = podXMLList[j].@title;
                                          pod.addChild(podContent);
                                          var index:Number;
                                          if (StateManager.isPodMinimized(viewId, podId))
                                                index = StateManager.getMinimizedPodIndex(viewId, podId);
                                                manager.addMinimizedItemAt(pod, index);
                                          else
                                                index = StateManager.getPodIndex(viewId, podId);
                                                // If the index hasn't been saved move the pod to the last position.
                                                if (index == -1)
                                                      index = podLen + unsavedPodCount;
                                                      unsavedPodCount += 1;
                                                manager.addItemAt(pod, index, StateManager.isPodMaximized(viewId, podId));
                                          pod.addEventListener(IndexChangedEvent.CHANGE, onChangePodView);
                                          podHash[pod] = manager;
                              // Delete the saved data.
                              delete podDataDictionary[manager];
                              // Listen for the last pod to complete so the layout from the ContainerWindowManager is done correctly.
                              pod.addEventListener(FlexEvent.UPDATE_COMPLETE, onCreationCompletePod);
                        // Pod has been created so update the respective PodLayoutManager.
                        private function onCreationCompletePod(e:FlexEvent):void
                              e.currentTarget.removeEventListener(FlexEvent.UPDATE_COMPLETE, onCreationCompletePod);
                              var manager:PodLayoutManager = PodLayoutManager(podHash[e.currentTarget]);
                              manager.removeNullItems();
                              manager.updateLayout(false);
                        // Saves the pod content ViewStack state.
                        private function onChangePodView(e:IndexChangedEvent):void
                              var pod:Pod = Pod(e.currentTarget);
                              var viewId:String = PodLayoutManager(podHash[pod]).id;
                              StateManager.setPodViewIndex(viewId, pod.id, e.newIndex);
            </mx:Script>
            <mx:TabBar
                  id="tabBar"
                  itemClick="onItemClickTabBar(event)"
                  height="35" styleName="TabBar"
                  dataProvider="viewStack" />
            <mx:ViewStack
                  id="viewStack"
                  paddingTop="15"
                  width="100%" height="100%" />
      </mx:VBox>
