2 Replies Latest reply on Feb 15, 2011 3:27 PM by Jhon Carlo
    How to change between two cast member
    Jhon Carlo Level 1
      I need to exchange two cast member, for exemple, the cast member 1 with cast member 2.
      How can I do?
        • 1. Re: How to change between two cast member
          drom_techmarine
          first you need a sprite on the stage then its easy reference the sprite then use lingo to swap the two.
          something like this
          you can put this in almost any type of script
          sprite(1).member = member('"xMemberName")
          you could also use lingo to identify the sprite you want to swap so that in the case you need to move that sprite to a different channel it will not need to be fooled with
          goes something like this
          first you need two scripts now one of the action of swapping the sprite where ever you put it maybe a button. and another one that gets attached to the sprite
          the first is the ID
          global swapSpriteID -- puts this var as a global so the whole movie can know it
          on beginSprite me
               swapSpriteID = sprite(me.spriteNum)
          end
          then in the other script that you use to modify the sprites member needs this
          global swapSpriteID -- recognizing the global var so that this script can access it
          on mouseUp me -- could do this in any way just an example
              sprite(swapSpriteID).member = member("xMemberName")
          end
          hope this was of help
          • 2. Re: How to change between two cast member
            Jhon Carlo Level 1
            Thank you for the help.
            It works fine.
