3 Replies Latest reply on Jan 19, 2011 10:03 AM by Gaurav J
    Sending data with URLRequest
    SiHoop Level 1
      I'm having a problem sending multiple variables with a URLRequest when I attempt to send the variables from one file to another.
      The line below tries to send 2 variables: studentID=749 and studentName=sally
      var urlRequest:URLRequest = new URLRequest("http://..../ChartingComponents.html#studentID=749&studentName=sally");
      Inside the receiving file, I have the following code:
                      bm = BrowserManager.getInstance();   //Use  BrowserManager to get the incoming string of variables
                      bm.init("");
                      //Parse a URL that passes string parameters after the "#" sign
                      var o:Object = URLUtil.stringToObject(bm.fragment);
                      userName=o.studentID;
                      studentName=o.studentName;
      I don't have a problem if I try to send only a single variable. If I send 2 variables, only the first variable is recognized and its value is: "749&studentName" instead of "749".
      So my question is, how do I send multiple variables when I use a URLRequest?
      Also, what's the difference between using # and ? in a URLRequest? I know that the ? adds a # sign to the end of my url string.
      Thank you!
