4 Replies Latest reply on Jan 20, 2011 6:54 AM by kglad
    Loop Fails to Execute Code But List of Commands Works - Baffled
    Kwangle Level 1
      Hi All,
      I've got 13 movieclips that all run a function (setNames) contained in a child object (namer) it contains. The function displays text in a dynamic text box.
      I've set them up with the instance names mark0 > mark12 so I can target them with a loop and array notation which is something I often use. But the loop sometimes doesn't work, however a list of 13 separate lines of code works fine. Am I overloading Flash with too much code commands at once, and is there a way around this?
      This doesn't work...
      for(i = 0; i<13; i++) {
      //sets names
      this["mark"+i].namer.setNames();
      ...but doing it manually works fine:
      mark0.namer.setNames();
      mark1.namer.setNames();
      mark2.namer.setNames();
      mark3.namer.setNames();
      mark4.namer.setNames();
      mark5.namer.setNames();
      mark6.namer.setNames();
      mark7.namer.setNames();
      mark8.namer.setNames();
      mark9.namer.setNames();
      mark10.namer.setNames();
      mark11.namer.setNames();
      mark12.namer.setNames();
      Strangely, the following code does work:
      for (i=0; i<13; i++) {
      //clears names
      this["mark"+i].namer.phs = 1;
      I have checked the code carefully and tested the code with trace actions but can't see the problem. Any ideas?
